[petsc-users] Weird behavior for log_summary
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Jun  8 12:48:47 CDT 2015
> On Jun 8, 2015, at 12:16 PM, Michele Rosso <mrosso at uci.edu> wrote:
> Hi Barry,
> I run a small test case like you suggested: this results in no error, but the problem with log_summary still persists.
> Please find attached the output of log_summary.
   I cannot explain why nothing gets listed in the log summary. It appears to have used the command line options and hence a Krylov solver. I am dumbfounded why no events are listed in the log_summary.
   Barry
> Thanks,
> Michele
> On Fri, 2015-06-05 at 21:34 -0500, Barry Smith wrote:
>> [NID 04001] 2015-06-04 19:07:24 Apid 25022256: initiated application termination
>> Application 25022256 exit signals: Killed
>> Application 25022256 resources: utime ~271s, stime ~15107s, Rss ~188536, inblocks ~5078831, outblocks ~12517984
>>    Usually this kind of message indicates that either the OS or the batch system killed the process for some reason: often because it ran out of time or maybe memory.
>>    Can you run in batch with a request for more time? Do smaller jobs run through ok?
>>    If utime means user time and stime means system time then this is very bad, the system time is HUGE relative to the user time.
>>   Barry
>> > On Jun 5, 2015, at 9:22 PM, Michele Rosso <mrosso at uci.edu> wrote:
>> > Hi,
>> > I am checking the performances of my code via -log_summary, but the output is incomplete (please see attached) file.
>> > I configured petsc with the following options:
>> > if __name__ == '__main__':
>> >   import sys
>> >   import os
>> >   sys.path.insert(0, os.path.abspath('config'))
>> >   import configure
>> >   configure_options = [
>> >     '--with-batch=1 ',
>> >     '--known-mpi-shared=0 ',
>> >     '--known-mpi-shared-libraries=0',
>> >     '--known-memcmp-ok ',
>> >     '--with-blas-lapack-lib=-L/opt/acml/5.3.1/gfortran64/lib  -lacml',
>> >     '--COPTFLAGS=-march=bdver1 -fopenmp -O3 -ffast-math -fPIC ',
>> >     '--FOPTFLAGS=-march=bdver1 -fopenmp -O3 -ffast-math -fPIC ',
>> >     '--CXXOPTFLAGS=-march=bdver1 -fopenmp -O3 -ffast-math -fPIC ',
>> >     '--with-x=0 ',
>> >     '--with-debugging=0',
>> >     '--with-clib-autodetect=0 ',
>> >     '--with-cxxlib-autodetect=0 ',
>> >     '--with-fortranlib-autodetect=0 ',
>> >     '--with-shared-libraries=0 ',
>> >     '--with-mpi-compilers=1 ',
>> >     '--with-cc=cc ',
>> >     '--with-cxx=CC ',
>> >     '--with-fc=ftn ',
>> > #    '--with-64-bit-indices',
>> >     '--download-hypre=1',
>> >     '--download-blacs=1 ',
>> >     '--download-scalapack=1 ',
>> >     '--download-superlu_dist=1 ',
>> >     '--download-metis=1 ',
>> >     '--download-parmetis=1 ',
>> >   configure.petsc_configure(configure_options)
>> > Any idea about this issue?
>> > Thanks,
>> > Michele
>> > <log_summary>
> <outfile.txt>
