[petsc-users] Tao iterations
Jed Brown
jed at jedbrown.org
Mon Jun 8 10:55:40 CDT 2015
Justin Chang <jychang48 at gmail.com> writes:
> Jed,
> Thank you for your response. I agree completely with all that you said. I
> just wonder what would happen if I attempted to use the TAO routines after
> forming the Jacobian J and residual r arising from the advection diffusion
> equation.
> In my current (linear) diffusion framework, i have the following objective
> function and gradient vector:
> f = \frac{1}{2} x \cdot J*x + x\cdot[r - J*x^(0)]
If J is non-symmetric, then you're no longer looking for a minimum of
this functional. Let's take a prototypical example in 2 variables
J = [0 1; -1 0]
Now the J-"inner product"
conj(x) \cdot J x = 0
for all real-valued x. (I'll assume you're working over the reals.)
Similarly, the J-"inner product" with
J = [1 1; -1 1]
is identical to that with J = eye(2), but obviously you want the
anti-symmetric part to affect your solution.
In short, none of this makes mathematical sense in the way you intend if
J is nonsymmetric.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150608/3136ce11/attachment.pgp>
