[petsc-users] Guidance on GAMG preconditioning
    Justin Chang
    jychang48 at gmail.com
    Sun Jun  7 21:18:57 CDT 2015
Sorry forgot one more comment.
So basically I am comparing a "good" TAO solver (though this can be
debated) with a "so-so" KSP solver in CG/Jacobi. If this "good" TAO solver
cannot beat the performance of the "so-so" KSP, is there really any need to
include the performance of the "good"KSP if my objective is focused on TAO
and my methodology?
On Sunday, June 7, 2015, Justin Chang <jychang48 at gmail.com> wrote:
> Matt (Knepley),
> I see what you're saying and it makes perfect sense. The point of my work
> isn't necessarily to compare CG/Jacobi with GAMG. Rather I am trying to
> compare both the numerical solution and the computational performance of my
> "correction" methodology (through optimization) with just solving the FEM
> problem normally. Of course this methodology is going to be more expensive
> but I think it would be nice to have some "benchmark" to compare against. I
> have examples that show where the parallel efficiency of TAO
> overtakes CG/Jacobi, and I also have the AI that shows how TAO is higher
> than CG/Jacobi and that both are invariant with respect to problem size.
> I ran some (smaller) experiments with GAMG and have noticed problems in
> which GAMG wall-clock time is less than CG/Jacobi (though not by much).
> However the problem is that it seems I cannot compute the arithmetic
> intensity for GAMG.
> The way I see it I have these three options:
> 1) Stick with what I have and acknowledge that GAMG can be better for
> larger problems. Since I have compared TAO with CG/Jacobi, somebody else
> can compare GAMG with CG/Jacobi.
> 2) Do strong scaling studies with GAMG and TAO and forget about the AI
> stuff. If I do this, then IMHO the paper will lose much of its flavor.
> 3) Use a different performance model that can be used to measure GAMG. I
> can only imagine that the complexity in applying any other model would
> proliferate for GAMG
> 4) Simply report FLOPS/s and the associated wall-clock times with respect
> to each solver. Yes this is easily gamed but I would think that this can at
> least tell you something (I.e., if this metric drops for a given problem
> size, it can be an indicator that the program is losing some efficiency)
> Thoughts?
> Justin
> On Saturday, June 6, 2015, Matthew Knepley <knepley at gmail.com
> <javascript:_e(%7B%7D,'cvml','knepley at gmail.com');>> wrote:
>> On Sat, Jun 6, 2015 at 4:29 AM, Justin Chang <jychang48 at gmail.com> wrote:
>>> Matt and Mark thank you guys for your responses.
>>> The reason I brought up GAMG was because it seems to me that this is the
>>> preconditioner to use for elliptic problems. However, I am using CG/Jacobi
>>> for my larger problems and the solver converges (with -ksp_atol and
>>> -ksp_rtol set to 1e-8). Using GAMG I get rough the same wall-clock time,
>>> but significantly fewer solver iterations.
>>> As I also kind of mentioned in another mail, the ultimate purpose is to
>>> compare how this "correction" methodology using the TAO solver (with
>>> bounded constraints) performs compared to the original methodology using
>>> the KSP solver (without constraints). I have the A for BLMVM and CG/Jacobi
>>> and they are roughly 0.3 and 0.2 respectively (do these sound about
>>> right?). Although the AI is higher for TAO , the ratio of actual FLOPS/s
>>> over the AI*STREAMS BW is smaller, though I am not sure what conclusions to
>>> make of that. This was also partly why I wanted to see what kind of metrics
>>> another KSP solver/preconditioner produces.
>>> Point being, if I were to draw such comparisons between TAO and KSP,
>>> would I get crucified if people find out I am using CG/Jacobi and not GAMG?
>> Here is what someone like me reviewing your paper would say first. I can
>> believe that a well-conditioned problem would
>> converge using CG/Jacobi. However, if the highest order derivative looks
>> like the Laplacian, then the condition number of
>> the equations will be O(h^2), and even with CG it will be O(h), so the
>> number of iterations should increase as the square root
>> of the problem size (in 2D), where GAMG should be constant. Thus at some
>> size GAMG will be more efficient. I would want
>> to see where the crossover is for your problem. If you do not get the
>> O(h) dependence, I would think that there is a problem
>> in the formulation.
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Justin
>>> On Fri, Jun 5, 2015 at 2:02 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> The overwhleming cost of AMG is the Galerkin triple-product RAP.
>>>> That is overstating it a bit.  It can be if you have a hard 3D operator
>>>> and coarsening slowly is best.
>>>> Rule of thumb is you spend 50% time is the solver and 50% in the setup,
>>>> which is often mostly RAP (in 3D, 2D is much faster).  That way you are
>>>> within 2x of optimal and it often works out that way anyway.
>>>> Mark
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150607/3c428d02/attachment.html>
