[petsc-users] Weird behavior for log_summary
Michele Rosso mrosso at uci.edu
Fri Jun 5 21:22:59 CDT 2015
I am checking the performances of my code via -log_summary, but the
output is incomplete (please see attached) file.
I configured petsc with the following options:
if __name__ == '__main__':
  import sys
  import os
  sys.path.insert(0, os.path.abspath('config'))
  import configure
  configure_options = [
    '--with-batch=1 ',
    '--known-mpi-shared=0 ',
    '--known-mpi-shared-libraries=0',
    '--known-memcmp-ok ',
    '--with-blas-lapack-lib=-L/opt/acml/5.3.1/gfortran64/lib  -lacml',
    '--COPTFLAGS=-march=bdver1 -fopenmp -O3 -ffast-math -fPIC ',
    '--FOPTFLAGS=-march=bdver1 -fopenmp -O3 -ffast-math -fPIC ',
    '--CXXOPTFLAGS=-march=bdver1 -fopenmp -O3 -ffast-math -fPIC ',
    '--with-x=0 ',
    '--with-debugging=0',
    '--with-clib-autodetect=0 ',
    '--with-cxxlib-autodetect=0 ',
    '--with-fortranlib-autodetect=0 ',
    '--with-shared-libraries=0 ',
    '--with-mpi-compilers=1 ',
    '--with-cc=cc ',
    '--with-cxx=CC ',
    '--with-fc=ftn ',
#    '--with-64-bit-indices',
    '--download-hypre=1',
    '--download-blacs=1 ',
    '--download-scalapack=1 ',
    '--download-superlu_dist=1 ',
    '--download-metis=1 ',
    '--download-parmetis=1 ',
  configure.petsc_configure(configure_options)
Any idea about this issue?
Michele
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150605/a58db747/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150605/a58db747/attachment.obj>
