[petsc-users] Crash when trying to use FD Jacobian
    Harshad Sahasrabudhe
    hsahasra at purdue.edu
    Fri Jun  5 12:32:23 CDT 2015
I'm solving a non-linear equation using NEWTONLS. The SNES is called from a
wrapper in the LibMesh library. I'm trying to use the default FD Jacobian
by not setting any Mat or callback function for the Jacobian.
When doing this I get the following error. I'm not able to figure out why I
get this error. Can I get some pointers to what I might be doing wrong?
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state!
[0]PETSC ERROR: Not for unassembled matrix!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./nemo on a linux named conte-fe02.rcac.purdue.edu by
hsahasra Fri Jun  5 13:25:27 2015
[0]PETSC ERROR: Libraries linked from
/home/hsahasra/NEMO5/libs/petsc/build-real/linux/lib
[0]PETSC ERROR: Configure run at Fri Mar 20 15:18:25 2015
[0]PETSC ERROR: Configure options --with-x=0 --download-hdf5=1
--with-scalar-type=real --with-single-library=0 --with-shared-libraries=0
--with-clanguage=C++ --with-fortran=1 --with-cc=mpiicc --with-fc=mpiifort
--with-cxx=mpiicpc COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3
--download-metis=1 --download-parmetis=1
--with-valgrind-dir=/apps/rhel6/valgrind/3.8.1/ --download-mumps=1
--with-fortran-kernels=0
--with-blas-lapack-dir=/apps/rhel6/intel/composer_xe_2013.3.163/mkl
--download-superlu_dist=1
--with-blacs-lib=/apps/rhel6/intel/composer_xe_2013.3.163/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.so
--with-blacs-include=/apps/rhel6/intel/composer_xe_2013.3.163/mkl/include
--with-scalapack-lib="-L/apps/rhel6/intel/composer_xe_2013.3.163/mkl/lib/intel64
-lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64" i
--with-scalapack-include=/apps/rhel6/intel/composer_xe_2013.3.163/mkl/include
--with-pic=1 --with-debugging=1
[0]PETSC ERROR:
[0]PETSC ERROR: MatGetColoring() line 481 in
/home/hsahasra/NEMO5/libs/petsc/build-real/src/mat/color/color.c
[0]PETSC ERROR: SNESComputeJacobianDefaultColor() line 64 in
/home/hsahasra/NEMO5/libs/petsc/build-real/src/snes/interface/snesj2.c
[0]PETSC ERROR: SNESComputeJacobian() line 2152 in
/home/hsahasra/NEMO5/libs/petsc/build-real/src/snes/interface/snes.c
[0]PETSC ERROR: SNESSolve_NEWTONLS() line 218 in
/home/hsahasra/NEMO5/libs/petsc/build-real/src/snes/impls/ls/ls.c
[0]PETSC ERROR: SNESSolve() line 3636 in
[0]PETSC ERROR: solve() line 538 in
"unknowndirectory/"src/solvers/petsc_nonlinear_solver.C
application called MPI_Abort(comm=0x84000000, 73) - process 0
Harshad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150605/b0ea1472/attachment.html>
