[petsc-users] on the performance of MPI PETSc
Jed Brown jed at jedbrown.org
Fri Jun 5 11:45:11 CDT 2015
"Sun, Hui" <hus003 at ucsd.edu> writes:
> If I run ex34 using the command:
> ./ex34 -pc_type none -ksp_type gmres -ksp_monitor_short
> I get the following output:
>   0 KSP Residual norm 0.0289149
>   1 KSP Residual norm < 1.e-11
> Residual norm 9.14804e-15
> Error norm 0.00020064
> Error norm 5.18301e-05
> Error norm 4.90288e-08
> Time cost: 1.60657 4.67008 0.0784049
> From the output, it seems that solving Poisson without a
> preconditioner is actually faster than using multigrid as a
> preconditioner. I think multigrid should do better than that.
Can't beat one iteration with on preconditioner.  The right hand side
(thus solution) is an eigenvector, so GMRES without preconditioning
converges in one iteration always.  The example could not be worse for
testing solvers.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150605/0eb469fa/attachment.pgp>
