[petsc-users] Guidance on GAMG preconditioning
Justin Chang jychang48 at gmail.com
Thu Jun 4 16:47:06 CDT 2015
Thank you Matt and Mark for the clarification. Matt, if you recall our
discussion about calculating the arithmetic intensity from the earlier
threads, it seems GAMG now has a myriad of all these additional vector and
matrix operations that were not present in the CG/Jacobi case. Running with
the command line options you and Mark suggested, I now have these
additional operations to deal with:
VecMDot
VecAXPBYCZ
VecMAXPY
VecSetRandom
VecNormalize
MatMultAdd
MatMultTranspose
MatSolve
MatConvert
MatScale
MatResidual
MatCoarsen
MatAXPY
MatMatMult
MatMatMultSym
MatMatMultNum
MatPtAP
MatPtAPSymbolic
PatPtAPNumeric
MatTrnMatMult
MatTrnMatMultSym
MatTrnMatMultNum
MatGetSymTrans
KSPGMRESOrthog
PCGAMGGraph_AGG
PCGAMGCoarse_AGG
PCGAMGProl_AGG
PCGAMGPOpt_AGG
GAMG: createProl and all of its associated events.
GAMG: partLevel
PCSetUpOnBlocks
Attached is the output from -log_summary showing the exact counts for the
case I am running.
I have the following questions:
1) For the Vec operations VecMDot and VecMAXPY, it seems the estimation of
total bytes transferred (TBT) relies on knowing how many vectors there are.
Is there a way to figure this out? Or at least with gamg what would it be,
three vectors?
2) It seems there are a lot of matrix manipulations and multiplications. Is
it safe to say that the size and number of non zeroes is the same? Or will
it change?
3) If I follow the TBT tabulation as in that paper you pointed me to, would
MatMultTranspose follow the same formula if the Jacobian is symmetric?
4) How do I calculate anything that requires the multiplication of at least
two matrices?
5) More importantly, are any of the above calculations necessary? Because
log_summary seems to indicate that MatMult() has the greatest amount of
workload and number of calls. My only hesitation is how much traffic
MatMatMults may take (assuming I go off of the same assumptions as in that
paper).
6) And/or, are there any other functions that I missed that might be
important to calculate as well?
Justin
On Thu, Jun 4, 2015 at 11:33 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Thu, Jun 4, 2015 at 12:29 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Thu, Jun 4, 2015 at 10:31 AM, Justin Chang <jychang48 at gmail.com>
>> wrote:
>>> Yeah I saw his recommendation and am trying it out. But I am not sure
>>> what most of those parameters mean. For instance:
>>> 1) What does -pc_gamg_agg_nsmooths refer to?
>> This is always 1 (its the definition of smoothed aggregation). Mark
>> allows 0 to support unsmoothed aggregation, which may be
>> better for easy problems on extremely large machines.
>>> 2) Does increase in the threshold of -pc_gamg_threshold translate to
>>> making the coarsening faster?
>> Yes, I believe so (easy to check).
> Other way around.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150604/1979063a/attachment-0001.html>
  1 processors:
TSTEP	ANALYSIS TIME	ITER	FLOPS/s
  Linear solve converged due to CONVERGED_RTOL iterations 31
1	2.313901e+00	31	3.629168e+08
  Time summary:
Creating DMPlex: 	0.212745s
Distributing DMPlex: 	0.000274897s
Refining DMPlex: 	1.1645s
Setting up problem: 	0.960611s
Overall analysis time: 	2.39205s
Overall FLOPS/s: 	2.60206e+08
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./main on a arch-linux2-c-opt named compute-0-18.local with 1 processor, by jchang23 Thu Jun  4 16:26:23 2015
Using Petsc Development GIT revision: v3.5.4-3996-gc7ab56a  GIT Date: 2015-06-04 06:26:21 -0500
                         Max       Max/Min        Avg      Total
Time (sec):           4.735e+00      1.00000   4.735e+00
Objects:              5.320e+02      1.00000   5.320e+02
Flops:                8.524e+08      1.00000   8.524e+08  8.524e+08
Flops/sec:            1.800e+08      1.00000   1.800e+08  1.800e+08
MPI Messages:         5.500e+00      1.00000   5.500e+00  5.500e+00
MPI Message Lengths:  2.218e+06      1.00000   4.032e+05  2.218e+06
MPI Reductions:       1.000e+00      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 4.7345e+00 100.0%  8.5241e+08 100.0%  5.500e+00 100.0%  4.032e+05      100.0%  1.000e+00 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
CreateMesh             1 1.0 1.3775e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 29  0  0  0  0  29  0  0  0  0     0
BuildTwoSided          5 1.0 2.0537e-03 1.0 0.00e+00 0.0 5.0e-01 4.0e+00 0.0e+00  0  0  9  0  0   0  0  9  0  0     0
VecView                1 1.0 1.3811e-02 1.0 3.62e+05 1.0 1.0e+00 4.9e+05 0.0e+00  0  0 18 22  0   0  0 18 22  0    26
VecMDot              112 1.0 2.6209e-03 1.0 1.43e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  5464
VecTDot               62 1.0 3.2454e-03 1.0 7.64e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  2354
VecNorm              184 1.0 2.8832e-03 1.0 6.81e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  2362
VecScale             152 1.0 5.1141e-04 1.0 1.43e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2804
VecCopy              171 1.0 1.4133e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               658 1.0 4.2362e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY              106 1.0 2.6708e-03 1.0 8.03e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  3007
VecAYPX             1054 1.0 1.1199e-02 1.0 2.45e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0  2190
VecAXPBYCZ           512 1.0 6.9575e-03 1.0 4.17e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  5  0  0  0   0  5  0  0  0  5987
VecWAXPY               1 1.0 1.0610e-04 1.0 6.16e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   581
VecMAXPY             152 1.0 2.9120e-03 1.0 1.69e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  5813
VecAssemblyBegin       4 1.0 9.5367e-07 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         4 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult     856 1.0 1.0922e-02 1.0 1.39e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  1275
VecSetRandom           4 1.0 6.6662e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         152 1.0 1.7796e-03 1.0 4.30e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  2417
MatMult              915 1.0 3.2228e-01 1.0 5.27e+08 1.0 0.0e+00 0.0e+00 0.0e+00  7 62  0  0  0   7 62  0  0  0  1637
MatMultAdd           128 1.0 2.0048e-02 1.0 2.06e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  1028
MatMultTranspose     128 1.0 2.2771e-02 1.0 2.06e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0   906
MatSolve              64 1.0 9.5367e-05 1.0 1.13e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1188
MatLUFactorSym         1 1.0 3.5048e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 2.0981e-05 1.0 1.76e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   837
MatConvert             4 1.0 1.0548e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale              12 1.0 2.8198e-03 1.0 2.94e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1043
MatResidual          128 1.0 4.4002e-02 1.0 7.35e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  9  0  0  0   1  9  0  0  0  1670
MatAssemblyBegin      33 1.0 5.7220e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        33 1.0 1.8984e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRow         260352 1.0 1.4122e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            1 1.0 5.0068e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 4.1962e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCoarsen             4 1.0 3.9771e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries         1 1.0 1.3030e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY                4 1.0 1.1571e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMult             4 1.0 2.1907e-02 1.0 2.62e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   120
MatMatMultSym          4 1.0 1.5245e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMatMultNum          4 1.0 6.6392e-03 1.0 2.62e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   394
MatPtAP                4 1.0 2.0476e-01 1.0 4.64e+07 1.0 0.0e+00 0.0e+00 0.0e+00  4  5  0  0  0   4  5  0  0  0   227
MatPtAPSymbolic        4 1.0 7.4399e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
MatPtAPNumeric         4 1.0 1.3035e-01 1.0 4.64e+07 1.0 0.0e+00 0.0e+00 0.0e+00  3  5  0  0  0   3  5  0  0  0   356
MatTrnMatMult          1 1.0 3.2565e-01 1.0 2.06e+07 1.0 0.0e+00 0.0e+00 0.0e+00  7  2  0  0  0   7  2  0  0  0    63
MatTrnMatMultSym       1 1.0 1.7446e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
MatTrnMatMultNum       1 1.0 1.5119e-01 1.0 2.06e+07 1.0 0.0e+00 0.0e+00 0.0e+00  3  2  0  0  0   3  2  0  0  0   136
MatGetSymTrans         5 1.0 5.9624e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexInterp           3 1.0 1.8401e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
DMPlexStratify        11 1.0 3.1623e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  7  0  0  0  0   7  0  0  0  0     0
DMPlexPrealloc         1 1.0 5.1204e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 11  0  0  0  0  11  0  0  0  0     0
DMPlexResidualFE       1 1.0 3.5016e-01 1.0 2.09e+07 1.0 0.0e+00 0.0e+00 0.0e+00  7  2  0  0  0   7  2  0  0  0    60
DMPlexJacobianFE       1 1.0 8.6178e-01 1.0 4.22e+07 1.0 0.0e+00 0.0e+00 0.0e+00 18  5  0  0  0  18  5  0  0  0    49
SFSetGraph             6 1.0 1.0118e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin           9 1.0 3.4070e-03 1.0 0.00e+00 0.0 4.5e+00 3.8e+05 0.0e+00  0  0 82 78  0   0  0 82 78  0     0
SFBcastEnd             9 1.0 4.9067e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFReduceBegin          1 1.0 2.2292e-04 1.0 0.00e+00 0.0 1.0e+00 4.9e+05 0.0e+00  0  0 18 22  0   0  0 18 22  0     0
SFReduceEnd            1 1.0 1.5783e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SNESFunctionEval       1 1.0 3.5272e-01 1.0 2.09e+07 1.0 2.0e+00 4.9e+05 0.0e+00  7  2 36 44  0   7  2 36 44  0    59
SNESJacobianEval       1 1.0 8.6338e-01 1.0 4.22e+07 1.0 2.5e+00 3.0e+05 0.0e+00 18  5 45 33  0  18  5 45 33  0    49
KSPGMRESOrthog       112 1.0 5.1789e-03 1.0 2.86e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0  5531
KSPSetUp              15 1.0 3.0289e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               1 1.0 1.0976e+00 1.0 7.77e+08 1.0 0.0e+00 0.0e+00 0.0e+00 23 91  0  0  0  23 91  0  0  0   708
PCGAMGGraph_AGG        4 1.0 7.4403e-02 1.0 2.30e+06 1.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0    31
PCGAMGCoarse_AGG       4 1.0 3.3554e-01 1.0 2.06e+07 1.0 0.0e+00 0.0e+00 0.0e+00  7  2  0  0  0   7  2  0  0  0    61
PCGAMGProl_AGG         4 1.0 7.1132e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGPOpt_AGG         4 1.0 6.7413e-02 1.0 4.42e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   1  5  0  0  0   656
GAMG: createProl       4 1.0 4.8507e-01 1.0 6.71e+07 1.0 0.0e+00 0.0e+00 0.0e+00 10  8  0  0  0  10  8  0  0  0   138
  Graph                8 1.0 7.4155e-02 1.0 2.30e+06 1.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0    31
  MIS/Agg              4 1.0 4.0429e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: col data         4 1.0 1.5974e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: frmProl0         4 1.0 6.3415e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
  SA: smooth           4 1.0 6.7411e-02 1.0 4.42e+07 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   1  5  0  0  0   656
GAMG: partLevel        4 1.0 2.0478e-01 1.0 4.64e+07 1.0 0.0e+00 0.0e+00 0.0e+00  4  5  0  0  0   4  5  0  0  0   227
PCSetUp                2 1.0 6.9165e-01 1.0 1.14e+08 1.0 0.0e+00 0.0e+00 0.0e+00 15 13  0  0  0  15 13  0  0  0   164
PCSetUpOnBlocks       32 1.0 1.4734e-04 1.0 1.76e+04 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   119
PCApply               32 1.0 3.6208e-01 1.0 5.88e+08 1.0 0.0e+00 0.0e+00 0.0e+00  8 69  0  0  0   8 69  0  0  0  1625
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Viewer     4              3         2264     0
              Object     7              7         4032     0
           Container     7              7         3976     0
              Vector   207            207    129392344     0
              Matrix    24             24     43743284     0
      Matrix Coarsen     4              4         2512     0
    Distributed Mesh    28             28       129704     0
    GraphPartitioner    11             11         6644     0
Star Forest Bipartite Graph    60             60        48392     0
     Discrete System    28             28        23744     0
           Index Set    47             47      9592920     0
   IS L to G Mapping     1              1       302332     0
             Section    61             61        40504     0
                SNES     1              1         1332     0
      SNESLineSearch     1              1          864     0
              DMSNES     1              1          664     0
       Krylov Solver    15             15       267352     0
      Preconditioner    15             15        14740     0
        Linear Space     2              2         1280     0
          Dual Space     2              2         1312     0
            FE Space     2              2         1496     0
         PetscRandom     4              4         2496     0
Average time to get PetscTime(): 9.53674e-08
#PETSc Option Table entries:
-al 1
-am 0
-at 0.001
-bcloc 0,1,0,1,0,0,0,1,0,1,1,1,0,0,0,1,0,1,1,1,0,1,0,1,0,1,0,0,0,1,0,1,1,1,0,1,0.45,0.55,0.45,0.55,0.45,0.55
-bcnum 7
-bcval 0,0,0,0,0,0,1
-dim 3
-dm_refine 1
-dt 0.001
-edges 3,3
-floc 0.25,0.75,0.25,0.75,0.25,0.75
-fnum 0
-ftime 0,99
-fval 1
-ksp_atol 1e-8
-ksp_converged_reason
-ksp_max_it 50000
-ksp_rtol 1e-8
-ksp_type cg
-log_summary
-lower 0,0
-mat_petscspace_order 0
-mesh cube_with_hole3_mesh.dat
-mg_levels_ksp_max_it 2
-mg_levels_ksp_type chebyshev
-mg_levels_pc_type jacobi
-mu 1
-nonneg 0
-numsteps 0
-options_left 0
-pc_gamg_agg_nsmooths 1
-pc_gamg_threshold 0.02
-pc_type gamg
-petscpartitioner_type parmetis
-progress 0
-simplex 1
-solution_petscspace_order 1
-tao_fatol 1e-8
-tao_frtol 1e-8
-tao_max_it 50000
-tao_type blmvm
-trans cube_with_hole3_trans.dat
-upper 1,1
-vtuname figure_cube_with_hole_3
-vtuprint 1
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --download-chaco --download-ctetgen --download-fblaslapack --download-hdf5 --download-metis --download-parmetis --download-triangle --with-cc=mpicc --with-cmake=cmake --with-cxx=mpicxx --with-debugging=0 --with-fc=mpif90 --with-mpiexec=mpiexec --with-valgrind=1 CFLAGS= COPTFLAGS=-O3 CXXFLAGS= CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=arch-linux2-c-opt
Libraries compiled on Thu Jun  4 06:27:39 2015 on compute-2-42.local
Machine characteristics: Linux-2.6.32-504.1.3.el6.x86_64-x86_64-with-redhat-6.6-Santiago
Using PETSc directory: /home/jchang23/petsc
Using PETSc arch: arch-linux2-c-opt
Using C compiler: mpicc  -fPIC -O3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O3   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/jchang23/petsc/arch-linux2-c-opt/include -I/home/jchang23/petsc/include -I/home/jchang23/petsc/include -I/home/jchang23/petsc/arch-linux2-c-opt/include -I/share/apps/openmpi-1.8.3/include
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/home/jchang23/petsc/arch-linux2-c-opt/lib -L/home/jchang23/petsc/arch-linux2-c-opt/lib -lpetsc -Wl,-rpath,/home/jchang23/petsc/arch-linux2-c-opt/lib -L/home/jchang23/petsc/arch-linux2-c-opt/lib -lflapack -lfblas -lparmetis -ltriangle -lmetis -lctetgen -lX11 -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lchaco -Wl,-rpath,/share/apps/openmpi-1.8.3/lib -L/share/apps/openmpi-1.8.3/lib -Wl,-rpath,/share/apps/gcc-4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2 -L/share/apps/gcc-4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2 -Wl,-rpath,/share/apps/gcc-4.9.2/lib64 -L/share/apps/gcc-4.9.2/lib64 -Wl,-rpath,/share/apps/gcc-4.9.2/lib -L/share/apps/gcc-4.9.2/lib -lmpi_usempi -lmpi_mpifh -lgfortran -lm -lgfortran -lm -lquadmath -lm -lmpi_cxx -lstdc++ -Wl,-rpath,/share/apps/openmpi-1.8.3/lib -L/share/apps/openmpi-1.8.3/lib -Wl,-rpath,/share/apps/gcc-4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2 -L/share/apps/gcc-4.9.2/lib/gcc/x86_64-unknown-linux-gnu/4.9.2 -Wl,-rpath,/share/apps/gcc-4.9.2/lib64 -L/share/apps/gcc-4.9.2/lib64 -Wl,-rpath,/share/apps/gcc-4.9.2/lib -L/share/apps/gcc-4.9.2/lib -ldl -Wl,-rpath,/share/apps/openmpi-1.8.3/lib -lmpi -lgcc_s -lpthread -ldl
