[petsc-users] Guidance on GAMG preconditioning
Thu Jun 4 11:29:35 CDT 2015
On Thu, Jun 4, 2015 at 10:31 AM, Justin Chang <jychang48 at gmail.com> wrote:
> Yeah I saw his recommendation and am trying it out. But I am not sure what
> most of those parameters mean. For instance:
> 1) What does -pc_gamg_agg_nsmooths refer to?
This is always 1 (its the definition of smoothed aggregation). Mark allows
0 to support unsmoothed aggregation, which may be
better for easy problems on extremely large machines.
> 2) Does increase in the threshold of -pc_gamg_threshold translate to
> making the coarsening faster?
Yes, I believe so (easy to check).
> 3) What does -mg_levels_ksp_max_it refer to?
This sets the maximum number of iterations for the smoother on each level.
     Matt
I am not too worried about "bad" solutions from anisotropy (because it is
> driven by the velocity field, not the actual material property or mesh
> orientations) and we have a work-around for it (via optimization). I am
> more concerned about the time to solution especially for bigger problems.
> Thanks,
> Justin
> On Thu, Jun 4, 2015 at 9:04 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jun 4, 2015 at 8:12 AM, Justin Chang <jychang48 at gmail.com> wrote:
>>> Hello everyone,
>>> Apologies if this sounds like a newbie question, but I am attempting to
>>> play around with the gamg preconditioner for my anisotropic diffusion
>>> problem, but I have no idea how to "fine tune" the parameters such that I
>>> get better performance. I understand that this depends on both the material
>>> properties and the type of mesh used, but I guess for starters, here is
>>> what I am doing and some stuff I have noticed:
>>> - I am solving a unit cube with a small hole in the middle. The outside
>>> BC conditions are 0 and the inside is unity. I have a tensorial dispersion
>>> diffusivity (with constant velocity). I have 6 different sized grids to
>>> solve this problem on. The problem sizes range from 36K dofs to 1M dofs. I
>>> was able to solve all of them using the CG and Jacobi solver and
>>> preconditioner combination.
>>> - When I try to solve them using CG and GAMG (I did not set any other
>>> command line options) I seem to get slower wall clock times but with much
>>> fewer KSP iterations. I also notice that the FLOPS/s metric is much smaller.
>>> - For certain meshes, my CG/GAMG solver fails to converge after 2
>>> iterations due to DIVERGED_INDEFINITE_PC. This does not happen when I solve
>>> this on one processor or with the CG/Jacobi solver.
>>> From what I have read online and through these petsc-mailing lists, it
>>> sounds to me the gamg preconditioner will give better performance for nice
>>> elliptic problems like the one I am solving. When I saw the SNES ex12 test
>>> case 39 from builder.py, it only had -pc_type gamg. I am guessing that I
>>> need to set additional command line options? If so, where should I start?
>> Mark recommends starting with
>> -ksp_type cg
>> -pc_type gamg
>> -pc_gamg_agg_nsmooths 1
>> -pc_gamg_threshold 0.02  #  [0 - 0.1]
>> #-mg_levels_ksp_type richardson
>> -mg_levels_ksp_type chebyshev
>> -mg_levels_pc_type sor
>> #-mg_levels_pc_type jacobi
>> -mg_levels_ksp_max_it 2   # [1-8]
>> and messing with the # stuff.
>> 1) GAMG should definitely be more scalable than CG/ILU. You should be
>> able to see this by plotting the time/iterates as a function of problem
>> size. GAMG
>>     should have a constant number of iterates, whereas CG should grow.
>> GAMG will have higher overheads, so for smaller problem sizes CG can be
>> better.
>> 2)  The DIVERGED_INDEFINITE_PC can happen if the GAMG is non-symmetric
>> due to different number of iterates or the subsolver choice. Try out
>>      richardson instead of chebyshev.
>> 3) If your coefficient is highly anisotropic, GAMG may need help making
>> good coarse basis vectors. Mark has some experimental stuff for this.
>> Adjusting the
>>     thresholding parameter determines how fast you coarsen (you can see
>> the coarse problem sizes in -ksp_view). If its too fast, convergence
>> deteriorates,
>>     too slow and the coarse problems are expensive.
>>     Mark, how do you turn on heavy-edge matching?
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Justin
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150604/6d9c2bf0/attachment-0001.html>
