[petsc-users] Petsc without debugging enabled
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Jun  3 14:23:57 CDT 2015
   Hmm, look in  $PETSC_ARCH/include/petscconf.h and look for
#ifndef PETSC_USE_DEBUG
#define PETSC_USE_DEBUG 1
#endif
is it there? This is what triggers the printing of that message with -log_summary and PETSC_USE_DEBUG is defined in config/PETSc/options/LibraryOptions.py based on
self.debugging.debugging:  which is set in config/BuildSystem/config/compilerFlags.py  so I am totally lost how it could be printing that message with that choice of configure options. Did you run make all after you ran the ./configure ?
   Barry
> On Jun 3, 2015, at 2:05 PM, Michele Rosso <mrosso at uci.edu> wrote:
> Hi Barry,
> I think I did (see below in bold red):
> Configure options: --known-level1-dcache-size=16384 --known-level1-dcache-linesize=64 --known-level1-dcache-assoc=4 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1 --known-mpi-c-double-complex=1 --known-sdot-returns-double=0 --known-snrm2-returns-double=0 --with-batch="1 " --known-mpi-shared="0 " --known-mpi-shared-libraries=0 --known-memcmp-ok  --with-blas-lapack-lib="-L/opt/acml/5.3.1/gfortran64/lib  -lacml" --COPTFLAGS="-march=bdver1 -fopenmp -O3 -ffast-math -fPIC " --FOPTFLAGS="-march=bdver1 -fopenmp -O3 -ffast-math -fPIC " --CXXOPTFLAGS="-march=bdver1 -fopenmp -O3 -ffast-math -fPIC " --with-x="0 " --with-debugging=0 --with-clib-autodetect="0 " --with-cxxlib-autodetect="0 " --with-fortranlib-autodetect="0 " --with-shared-libraries="0 " --with-mpi-compilers="1 " --with-cc="cc " --with-cxx="CC " --with-fc="ftn " --download-hypre=1 --download-blacs="1 " --download-scalapack="1 " --download-superlu_dist="1 " --download-metis="1 " --download-parmetis="1 " PETSC_ARCH=gnu-opt-32idx
> On Wed, 2015-06-03 at 13:50 -0500, Barry Smith wrote:
>>    Though you turned on various compiler optimizations you did not turn off the "extra" PETSc error checking that is enabled by default.  For optimized runs you should also use the argument --with-debugging=0
>>   Barry
>> > On Jun 3, 2015, at 1:30 PM, Michele Rosso <mrosso at uci.edu> wrote:
>> > Hi,
>> > I am performing some timing runs with PETSc. I think I correctly compiled it with no debug mode, yet -log_summary gives me a warning:
>> >       #                          WARNING!!!                    #
>> >       #   This code was compiled with a debugging option,      #
>> >       #   To get timing results run ./configure                #
>> >       #   using --with-debugging=no, the performance will      #
>> >       #   be generally two or three times faster.              #
>> > Here are my configure options ( from -log_summary ):
>> > Compiled without FORTRAN kernels
>> > Compiled with full precision matrices (default)
>> > sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>> > Libraries compiled on Wed Jun  3 12:14:19 2015 on h2ologin2
>> > Machine characteristics: Linux-3.0.101-0.46-default-x86_64-with-SuSE-11-x86_64
>> > Using PETSc directory: /mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4
>> > Using PETSc arch: gnu-opt-32idx
>> > Using C compiler: cc  -march=bdver1 -fopenmp -O3 -ffast-math -fPIC  ${COPTFLAGS} ${CFLAGS}
>> > Using Fortran compiler: ftn  -march=bdver1 -fopenmp -O3 -ffast-math -fPIC   ${FOPTFLAGS} ${FFLAGS}
>> > Using include paths: -I/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4/gnu-opt-32idx/include -I/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4/include -I/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4/include -I/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4/gnu-opt-32idx/include
>> > Using C linker: cc
>> > Using Fortran linker: ftn
>> > Using libraries: -Wl,-rpath,/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4/gnu-opt-32idx/lib -L/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4/gnu-opt-32idx/lib -lpetsc -Wl,-rpath,/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4/gnu-opt-32idx/lib -L/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4/gnu-opt-32idx/lib -lsuperlu_dist_3.3 -lHYPRE -L/opt/acml/5.3.1/gfortran64/lib -lacml -lparmetis -lmetis -lpthread -lssl -lcrypto -ldl
>> > What am I doing wrong?
>> > Thanks,
>> > Michele
