[petsc-users] Petsc without debugging enabled
Michele Rosso mrosso at uci.edu
Wed Jun 3 13:30:55 CDT 2015
I am performing some timing runs with PETSc. I think I correctly
compiled it with no debug mode, yet -log_summary gives me a warning:
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
Here are my configure options ( from -log_summary ):
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --known-level1-dcache-size=16384
--known-level1-dcache-linesize=64 --known-level1-dcache-assoc=4
--known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8
--known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8
--known-sizeof-long-long=8 --known-sizeof-float=4
--known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8
--known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4
--known-mpi-long-double=1 --known-mpi-int64_t=1
--known-mpi-c-double-complex=1 --known-sdot-returns-double=0
--known-snrm2-returns-double=0 --with-batch="1 " --known-mpi-shared="0 "
--known-mpi-shared-libraries=0 --known-memcmp-ok
--with-blas-lapack-lib="-L/opt/acml/5.3.1/gfortran64/lib  -lacml"
--COPTFLAGS="-march=bdver1 -fopenmp -O3 -ffast-math -fPIC "
--FOPTFLAGS="-march=bdver1 -fopenmp -O3 -ffast-math -fPIC "
--CXXOPTFLAGS="-march=bdver1 -fopenmp -O3 -ffast-math -fPIC "
--with-x="0 " --with-debugging=0 --with-clib-autodetect="0 "
--with-cxxlib-autodetect="0 " --with-fortranlib-autodetect="0 "
--with-shared-libraries="0 " --with-mpi-compilers="1 " --with-cc="cc "
--with-cxx="CC " --with-fc="ftn " --download-hypre=1 --download-blacs="1
" --download-scalapack="1 " --download-superlu_dist="1 "
--download-metis="1 " --download-parmetis="1 " PETSC_ARCH=gnu-opt-32idx
Libraries compiled on Wed Jun  3 12:14:19 2015 on h2ologin2
Machine characteristics:
Linux-3.0.101-0.46-default-x86_64-with-SuSE-11-x86_64
Using PETSc directory: /mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4
Using PETSc arch: gnu-opt-32idx
Using C compiler: cc  -march=bdver1 -fopenmp -O3 -ffast-math -fPIC
${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: ftn  -march=bdver1 -fopenmp -O3 -ffast-math
-fPIC   ${FOPTFLAGS} ${FFLAGS}
Using include paths:
-I/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4/gnu-opt-32idx/include
-I/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4/include
Using C linker: cc
Using Fortran linker: ftn
Using libraries:
-Wl,-rpath,/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4/gnu-opt-32idx/lib
-L/mnt/a/u/sciteam/mrosso/LIBS/petsc-3.5.4/gnu-opt-32idx/lib -lpetsc
-lsuperlu_dist_3.3 -lHYPRE -L/opt/acml/5.3.1/gfortran64/lib -lacml
-lparmetis -lmetis -lpthread -lssl -lcrypto -ldl
What am I doing wrong?
Michele
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150603/e3fb47be/attachment.html>
