[petsc-users] [petsc4py] dm/examples/tutorials/ex2 in python
    Francesco Caimmi
    francesco.caimmi at polimi.it
    Wed Jun  3 09:37:04 CDT 2015
Thank you all for your suggestions!
It looks like I will have to re-read the initial parts of the manual to better
understand the assembly operations.
However I am still a bit puzzled by the fact that doing
start, end = global_vec.getOwnershipRange()
with global_vec as v:
        for i in xrange(end-start):
            v[i] = 5.0*rank
viewer = PETSc.Viewer.DRAW(global_vec.comm)
global_vec.view(viewer)
or  doing
for i in xrange(start,end):
        global_vec[i] = 5.0*rank
actually I get the _same_ output, which, btw, is the intended output, as far as I
can tell from the output of ex2.c (after compiling it). This is true regardless of the
number of processors (up to three).
Based on what you said I expected the second piece of code to fail. Have I
misunderstood something?
Francesco Caimmi
Laboratorio di Ingegneria dei Polimeri
http://www.chem.polimi.it/polyenglab/
Politecnico di Milano - Dipartimento di Chimica,
Materiali e Ingegneria Chimica “Giulio Natta”
P.zza Leonardo da Vinci, 32
I-20133 Milano
Tel. +39.02.2399.4711
Fax +39.02.7063.8173
Skype: fmglcaimmi (please arrange meetings by e-mail)
GPG Public Key : http://goo.gl/64dDo
On Tuesday June 2 2015 at 18:49 Jed Brown wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > No, you would need xrange(end-start):
> Specifically, Python made a decision about indexing semantics that,
> while not irrational, really sucks for distributed array computing.  I'm
> not aware of a clean way to give you nice syntax.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150603/e39cfa5a/attachment-0001.html>
