[petsc-users] Modified Taylor-Hood elements with piece-wise constant pressure for Stokes equation
    Lawrence Mitchell
    lawrence.mitchell at imperial.ac.uk
    Tue Jun  2 11:51:10 CDT 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 02/06/15 17:20, Jed Brown wrote:
> Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> writes:
>>> So the mass matrix for CG1+DG0 is singular?
>> I believe so, yes.
> Fabulous.  Now let's take a one element domain.  What is the norm
> of the vector
> u=((1,1,1),(-1))
> in the "basis" {CG1, DG0}?  Note that this represents the
> continuous function u(x,y)=0.
> I assume FEniCS is not using QR to solve the under-determined
> system, so are they silently pinning (e.g., remove the DG0 part
> from one element in the domain)?  If they are just "solving" the
> under-determined systems by hoping that the solver doesn't notice
> that the system is singular, rather than rigorously finding a
> minimum norm solution (expensive), then the discrete solution can
> vary an arbitrary amount by the choice of algebraic solver.
Maybe Justin can chime in here, I don't know, I just happened to know
how the fenics implementation produces the "basis", so proffered that.
> Why does it appear that none of the papers talk about these
> issues?
Pass.
Lawrence
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJVbd76AAoJECOc1kQ8PEYvaUUH/AoKpZCNISMHrpGWNbZ67aCd
7mBJyPk7z0S7BLDeSm8i1iF+LitnzaxFNZEaGmSDWjlr1Z9tG2vjRk1R0Aj2cte+
Pb1Ki8pwdU+N1bJgV5GCW+lyaXI3QQQs2K3vsUA530ohwpPUNRqHaW4BB+IIR0hs
d/vzIPEn4K9tF5JpFGMKZhJ8zuayI0NdGQ6dVqRTCxGGhTCNuOKgB9xonecHUxFg
ZosuoQAVOzgbIJunJutekydvrKKpSf0I6z6cTjp713lR5cVnrGyN6J5evI9Jt7x1
Sdtczorz+EcbQ5lycBMxEGmWKIHCOM5kBG+IxjN+pQg6R/+TDbsIQL9Lyj0BU6I=
=irr/
-----END PGP SIGNATURE-----
