[petsc-users] [petsc4py] dm/examples/tutorials/ex2 in python
    Francesco Caimmi
    francesco.caimmi at polimi.it
    Tue Jun  2 09:30:35 CDT 2015
On Tuesday 02 June 2015 07:43:21 Matthew Knepley wrote:
> On Tue, Jun 2, 2015 at 4:52 AM, Francesco Caimmi <francesco.caimmi at gmail.com
> > wrote:
> > with global_vec as v:
> >         for i in xrange(start,end):
> >             v[i] = 5.0*rank
> The 'with' construction just uses
>   VecGetArray()
> which return the raw C pointer. This is indexed from 0 always, so you want
>   v[i-start] = 5.0*rank
> If you want to index using [start, end), you need something like
>   DMDAVecGetArray()
>   Thanks,
>      Matt
Matt,
thank you very much for your answer. Unfortunately I wasn't able to find
documentation for the 'with' construction.
As far as I understand using DMDAVecGetArray would give me an object with
shape (M,N) in this case, not a vector with shape M*N as global_vec, so I
would have to resort to something different than VecGetOwnershipRange to get
the indexes.
I would prefer to avoid it because I don't feel it would be very clear.
Ithink I will go with the "v[i-start]" thing .
Anyway, would it be ok to do as follows?
        global_vec[i] = 5.0*rank
global_vec.assemblyBegin()
global_vec.assemblyEnd()
I ask because, while the program works, I cannot see assembly operation in the
C code for ex2, so I am trying to figure out why.
Is there some (python related ) reason that would make such an approach
unwise?
Francesco Caimmi
