[petsc-users] SLEPc example failed ...
Xujun Zhao xzhao99 at gmail.com
Fri Jul 31 17:29:58 CDT 2015
Hi all,
I run the EPS example ex9, and it failed. Can anyone help me figure out the
problem? Thanks. The following are the output error msg:
mcswl156:eps_tutorials xzhao$ ./ex9 -n 10
Brusselator wave model, n=10
---> my test: VecCreateMPIWithArray is done.
---> my test: Shell Matrix is created.
---> my test: EPS is set.
---> my test: Start to solve the EPS ...
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
run
[0]PETSC ERROR: to get more information on the crash.
*[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
[0]PETSC ERROR: ./ex9 on a arch-darwin-c-opt named mcswl156.mcs.anl.gov by
xzhao Fri Jul 31 17:26:52 2015
[0]PETSC ERROR: Configure options --with-cc=gcc-4.9 --with-cxx=g++-4.9
--with-fc=gfortran-4.9 --with-cxx-dialect=C++11 --download-mpich
--download-fblaslapack --download-scalapack --download-mumps
–download-superlu_dist --download-hypre --download-ml --download-parmetis
--download-metis --download-triangle --download-chaco --download-elemental
--with-debugging=0
[0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[unset]: aborting job:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150731/4e11d15c/attachment.html>
