[petsc-users] DMComposite and Matrix construction
Gautam Bisht
gbisht at lbl.gov
Fri Jul 31 13:56:15 CDT 2015
On Fri, Jul 31, 2015 at 11:33 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Jul 31, 2015, at 11:34 AM, Gautam Bisht <gbisht at lbl.gov> wrote:
> > I have a followup question on this topic regarding memory usage.
> > For the Jacobian matrix in src/snes/examples/tutorials/ex28.c of
> problem_type 2, MAT_NEW_NONZERO_LOCATION_ERR and
> MAT_NEW_NONZERO_ALLOCATION_ERR are set PETSC_FALSE. If the problem_type 2
> is solved multiple times (see the git difference below), would the memory
> usage keep on increasing? Or, since the non-zero pattern isn't changing
> over time, there would only be an increase in memory on the first SNESSolve?
> Only the first time through. In fact after your first matrix assembly
> you could turn those flags back on to generate errors if you start adding
> new locations the second time (just as a double check that there is not
> some mistake in your code the generates matrix entries).
Thanks. That works perfectly.
-Gautam.
> Barry
> > >git diff ex28.c
> > diff --git a/src/snes/examples/tutorials/ex28.c
> b/src/snes/examples/tutorials/ex28.c
> > index 98dd6b9..40f94d1 100644
> > --- a/src/snes/examples/tutorials/ex28.c
> > +++ b/src/snes/examples/tutorials/ex28.c
> > @@ -342,6 +342,7 @@ int main(int argc, char *argv[])
> > Mat B;
> > IS *isg;
> > PetscBool view_draw,pass_dm;
> > + PetscInt iter;
> > PetscInitialize(&argc,&argv,0,help);
> > ierr =
> DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,-10,1,1,NULL,&dau);CHKERRQ(ierr);
> > @@ -434,7 +435,10 @@ int main(int argc, char *argv[])
> > * of splits, but it requires using a DM (perhaps your own
> implementation). */
> > ierr = SNESSetDM(snes,pack);CHKERRQ(ierr);
> > + for (iter=1; iter<10000; iter++) {
> > ierr = SNESSolve(snes,NULL,X);CHKERRQ(ierr);
> > + ierr = FormInitial_Coupled(user,X);CHKERRQ(ierr);
> > break;
> > if (view_draw) {ierr =
> VecView(X,PETSC_VIEWER_DRAW_WORLD);CHKERRQ(ierr);}
> > -Gautam.
> > On Wed, Jul 29, 2015 at 11:25 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > On Jul 29, 2015, at 12:58 PM, Gideon Simpson <gideon.simpson at gmail.com>
> wrote:
> > > That fixed it, thanks. Given that I the nonzero pattern will not
> change throughout the solve, would it still be unreasonable to use this for
> larger problems?
> > Eventually it will kill you in the first time you assemble the matrix.
> > Barry
> > > -gideon
> > >> On Jul 29, 2015, at 1:52 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >> To start, immediately after you have created the matrix do what it
> says call
> > >>> MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE)
> > >> this will allow you to build your matrix and work fine for modest
> size problems. For larger problems (only when you have your code running
> and solving the problem you want) you need to add in more preallocation
> information. But to do it now would be premature optimization.
> > >> Barry
> > >>> On Jul 29, 2015, at 11:51 AM, Gideon Simpson <
> gideon.simpson at gmail.com> wrote:
> > >>> That’s generating malloc errors:
> > >>> [0]PETSC ERROR: --------------------- Error Message
> > >>> [0]PETSC ERROR: Argument out of range
> > >>> [0]PETSC ERROR: New nonzero at (10,0) caused a malloc
> > >>> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to
> turn off this check
> > >>> I suspect this is because DMCreateMatrix is picking a sparsity
> pattern which is not consistent with what I need.
> > >>> -gideon
> > >>>> On Jul 28, 2015, at 10:10 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > >>>> DMCreateMatrix() ?
> > >>>>> On Jul 28, 2015, at 9:02 PM, Gideon Simpson <
> > >>>>> I’m working with a DMComposite where I have a DMRedundant with 2
> parameters, and then a standard DMDACreate with some number of entires that
> I would like to have distributed. For concreteness, suppose it is
> > >>>>> DMCompositeCreate(PETSC_COMM_WORLD, &packer);
> > >>>>> DMRedundantCreate(PETSC_COMM_WORLD, 0, 2, &p_dm);
> > >>>>> DMCompositeAddDM(packer,p_dm);
> > >>>>> DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE, nx, 1, 1,
> NULL,&u_dm);
> > >>>>> DMCompositeAddDM(packer,u_dm);
> > >>>>> DMCreateGlobalVector(packer,&U);
> > >>>>> Now, I would like to construct a matrix for this problem that can
> be used for computing Jacobians in a nonlinear solve. Is there a way to
> get the matrix size to layout in a “useful” way, in the sense that the
> first process, which owns the two degrees of freedom of p_dm and the first
> N0 number of the rows of u_dm, controls the corresponding N0+2 rows of the
> matrix, and analgously for the second process has the next N1 rows of the
> u_dm vector, and has the next N1 rows of the matrix?
> > >>>>> -gideon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150731/9815c42b/attachment.html>
