[petsc-users] Can't expand MemType 1: jcol 16104
Thu Jul 30 20:05:37 CDT 2015
https://bitbucket.org/petsc/petsc/commits/1216793c5e02eeb91a6711f4ee34b47012a7925a
All it does it update --download-superlu_dist to use the v4.1 tarball by default.
i.e what you currently have with --download-superlu_dist=superlu_dist_4.1.tar.gz is the same thing.
Satish
On Thu, 30 Jul 2015, Anthony Haas wrote:
> Hi Hong, Satish,
> I have been using petsc-3.6.1 with superlu_dist 4.1
> (--download-superlu_dist=superlu_dist_4.1.tar.gz) for a few days now. It seems
> to be working fine. However, reading Satish email below, I wonder if there is
> some kind of patch I need to apply for PETSc?
> Thanks
> Anthony
> On 07/30/2015 01:51 PM, Satish Balay wrote:
> > I've updated petsc to use v4.1. The changes are in branch
> > 'balay/update-superlu_dist-4.1' - and merged to 'next' for now.
> > Satish
> > On Wed, 29 Jul 2015, Xiaoye S. Li wrote:
> > > Thanks for quick update.  In the new tarball, I have already removed the
> > > junk files, as pointed out by Satish.
> > > Sherry
> > > On Wed, Jul 29, 2015 at 8:36 AM, Hong <hzhang at mcs.anl.gov> wrote:
> > > > Sherry,
> > > > With your bugfix, superlu_dist-4.1 works now:
> > > > petsc/src/ksp/ksp/examples/tutorials (master)
> > > > $ mpiexec -n 4 ./ex10 -f0 Amat_binary.m -rhs 0 -pc_type lu
> > > > -pc_factor_mat_solver_package superlu_dist -mat_superlu_dist_parsymbfact
> > > > Number of iterations =   1
> > > > Residual norm 2.11605e-11
> > > > Once you address Satish's request, we'll update petsc interface to this
> > > > version of superlu_dist.
> > > > Anthony:
> > > > Please download the latest superlu_dist-v4.1,
> > > > then configure petsc with
> > > > '--download-superlu_dist=superlu_dist_4.1.tar.gz'
> > > > Hong
> > > > On Tue, Jul 28, 2015 at 11:11 AM, Satish Balay <balay at mcs.anl.gov>
> > > > wrote:
> > > > > Sherry,
> > > > > One minor issue with the tarball. I see the following new files in the
> > > > > v4.1 tarball
> > > > > [when comparing it with v4.0]. Some of these files are perhaps junk
> > > > > files
> > > > > - and can
> > > > > be removed from the tarball?
> > > > >     EXAMPLE/dscatter.c.bak
> > > > >     EXAMPLE/g10.cua
> > > > >     EXAMPLE/g4.cua
> > > > >     EXAMPLE/g4.postorder.eps
> > > > >     EXAMPLE/g4.rua
> > > > >     EXAMPLE/g4_postorder.jpg
> > > > >     EXAMPLE/hostname
> > > > >     EXAMPLE/pdgssvx.c
> > > > >     EXAMPLE/pdgstrf2.c
> > > > >     EXAMPLE/pwd
> > > > >     EXAMPLE/pzgstrf2.c
> > > > >     EXAMPLE/pzgstrf_v3.3.c
> > > > >     EXAMPLE/pzutil.c
> > > > >     EXAMPLE/test.bat
> > > > >     EXAMPLE/test.cpu.bat
> > > > >     EXAMPLE/test.err
> > > > >     EXAMPLE/test.err.1
> > > > >     EXAMPLE/zlook_ahead_update.c
> > > > >     FORTRAN/make.out
> > > > >     FORTRAN/zcreate_dist_matrix.c
> > > > >     MAKE_INC/make.xc30
> > > > >     SRC/int_t
> > > > >     SRC/lnbrow
> > > > >     SRC/make.out
> > > > >     SRC/rnbrow
> > > > >     SRC/temp
> > > > >     SRC/temp1
> > > > > Thanks,
> > > > > Satish
> > > > > On Tue, 28 Jul 2015, Xiaoye S. Li wrote:
> > > > > > I am checking v4.1 now. I'll let you know when I fixed the problem.
> > > > > > Sherry
> > > > > > On Tue, Jul 28, 2015 at 8:27 AM, Hong <hzhang at mcs.anl.gov> wrote:
> > > > > > > Sherry,
> > > > > > > I tested with superlu_dist v4.1. The extra printings are gone, but
> > > > > hang
> > > > > > > remains.
> > > > > > > It hangs at
> > > > > > > #5  0x00007fde5af1c818 in PMPI_Wait (request=0xb6e4e0,
> > > > > > > status=0x7fff9cd83d60)
> > > > > > >      at src/mpi/pt2pt/wait.c:168
> > > > > > > #6  0x00007fde602dd635 in pzgstrf (options=0x9202f0, m=4900,
> > > > > > > n=4900,
> > > > > > >      anorm=13.738475134194639, LUstruct=0x9203c8, grid=0x9202c8,
> > > > > > >      stat=0x7fff9cd84880, info=0x7fff9cd848bc) at pzgstrf.c:1308
> > > > > > >                  if (recv_req[0] != MPI_REQUEST_NULL) {
> > > > > > >   -->                   MPI_Wait (&recv_req[0], &status);
> > > > > > > We will update petsc interface to superlu_dist v4.1.
> > > > > > > Hong
> > > > > > > On Mon, Jul 27, 2015 at 11:33 PM, Xiaoye S. Li <xsli at lbl.gov>
> > > > > > > wrote:
> > > > > > > > ​Hong,
> > > > > > > > Thanks for trying out.
> > > > > > > > The extra printings are not properly guarded by the print level.
> > > > > > > > I
> > > > > will
> > > > > > > > fix that.   I will look into the hang problem soon.
> > > > > > > > Sherry
> > > > > > > > On Mon, Jul 27, 2015 at 7:50 PM, Hong <hzhang at mcs.anl.gov>
> > > > > > > > wrote:
> > > > > > > > > Sherry,
> > > > > > > > > I can repeat hang using
> > > > > > > > > petsc/src/ksp/ksp/examples/tutorials/ex10.c:
> > > > > > > > > mpiexec -n 4 ./ex10 -f0 /homes/hzhang/tmp/Amat_binary.m -rhs 0
> > > > > -pc_type
> > > > > > > > > lu -pc_factor_mat_solver_package superlu_dist
> > > > > > > > > .. Starting with 1 OpenMP threads
> > > > > > > > > [0] .. BIG U size 1342464
> > > > > > > > > [0] .. BIG V size 131072
> > > > > > > > >    Max row size is 1311
> > > > > > > > >    Using buffer_size of 5000000
> > > > > > > > >    Threads per process 1
> > > > > > > > > using a debugger (with petsc option '-start_in_debugger'), I
> > > > > > > > > find
> > > > > that
> > > > > > > > > hang occurs at
> > > > > > > > > #0  0x00007f117d870998 in __GI___poll (fds=0x20da750, nfds=4,
> > > > > > > > >      timeout=<optimized out>, timeout at entry=-1)
> > > > > > > > >      at ../sysdeps/unix/sysv/linux/poll.c:83
> > > > > > > > > #1  0x00007f117de9f7de in MPIDU_Sock_wait (sock_set=0x20da550,
> > > > > > > > >      millisecond_timeout=millisecond_timeout at entry=-1,
> > > > > > > > >      eventp=eventp at entry=0x7fff654930b0)
> > > > > > > > >      at src/mpid/common/sock/poll/sock_wait.i:123
> > > > > > > > > #2  0x00007f117de898b8 in MPIDI_CH3i_Progress_wait (
> > > > > > > > >      progress_state=0x7fff65493120)
> > > > > > > > >      at src/mpid/ch3/channels/sock/src/ch3_progress.c:218
> > > > > > > > > #3  MPIDI_CH3I_Progress (blocking=blocking at entry=1,
> > > > > > > > >      state=state at entry=0x7fff65493120)
> > > > > > > > >      at src/mpid/ch3/channels/sock/src/ch3_progress.c:921
> > > > > > > > > #4  0x00007f117de1a559 in MPIR_Wait_impl
> > > > > > > > > (request=request at entry
> > > > > > > > > =0x262df90,
> > > > > > > > >      status=status at entry=0x7fff65493390) at
> > > > > > > > > src/mpi/pt2pt/wait.c:67
> > > > > > > > > #5  0x00007f117de1a818 in PMPI_Wait (request=0x262df90,
> > > > > > > > > status=0x7fff65493390)
> > > > > > > > > #6  0x00007f11831da557 in pzgstrf (options=0x23dfda0, m=4900,
> > > > > n=4900,
> > > > > > > > >      anorm=13.738475134194639, LUstruct=0x23dfe78,
> > > > > > > > > grid=0x23dfd78,
> > > > > > > > >      stat=0x7fff65493ea0, info=0x7fff65493edc) at
> > > > > > > > > pzgstrf.c:1308
> > > > > > > > > #7  0x00007f11831bf3bd in pzgssvx (options=0x23dfda0,
> > > > > > > > > A=0x23dfe30,
> > > > > > > > >      ScalePermstruct=0x23dfe50, B=0x0, ldb=1225, nrhs=0,
> > > > > grid=0x23dfd78,
> > > > > > > > >      LUstruct=0x23dfe78, SOLVEstruct=0x23dfe98, berr=0x0,
> > > > > > > > > ---Type <return> to continue, or q <return> to quit---
> > > > > > > > >      info=0x7fff65493edc) at pzgssvx.c:1063
> > > > > > > > > #8  0x00007f11825c2340 in MatLUFactorNumeric_SuperLU_DIST
> > > > > (F=0x23a0110,
> > > > > > > > >      A=0x21bb7e0, info=0x2355068)
> > > > > > > > >      at
> > > > > /sandbox/hzhang/petsc/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:411
> > > > > > > > > #9  0x00007f1181c6c567 in MatLUFactorNumeric (fact=0x23a0110,
> > > > > > > > > mat=0x21bb7e0,
> > > > > > > > >      info=0x2355068) at
> > > > > > > > > /sandbox/hzhang/petsc/src/mat/interface/matrix.c:2946
> > > > > > > > > #10 0x00007f1182a56489 in PCSetUp_LU (pc=0x2353a10)
> > > > > > > > >      at
> > > > > > > > > /sandbox/hzhang/petsc/src/ksp/pc/impls/factor/lu/lu.c:152
> > > > > > > > > #11 0x00007f1182b16f24 in PCSetUp (pc=0x2353a10)
> > > > > > > > >      at
> > > > > > > > > /sandbox/hzhang/petsc/src/ksp/pc/interface/precon.c:983
> > > > > > > > > #12 0x00007f1182be61b5 in KSPSetUp (ksp=0x232c2a0)
> > > > > > > > >      at
> > > > > > > > > /sandbox/hzhang/petsc/src/ksp/ksp/interface/itfunc.c:332
> > > > > > > > > #13 0x0000000000405a31 in main (argc=11, args=0x7fff65499578)
> > > > > > > > >      at
> > > > > /sandbox/hzhang/petsc/src/ksp/ksp/examples/tutorials/ex10.c:312
> > > > > > > > > You may take a look at it. Sequential symbolic factorization
> > > > > > > > > works
> > > > > fine.
> > > > > > > > > Why superlu_dist (v4.0) in complex precision displays
> > > > > > > > > I realize that I use superlu_dist v4.0. Would v4.1 works? I'll
> > > > > > > > > give
> > > > > it a
> > > > > > > > > try tomorrow.
> > > > > > > > > Hong
> > > > > > > > > On Mon, Jul 27, 2015 at 1:25 PM, Anthony Paul Haas <
> > > > > > > > > aph at email.arizona.edu> wrote:
> > > > > > > > > > Hi Hong,
> > > > > > > > > > No that is not the correct matrix. Note that I forgot to
> > > > > > > > > > mention
> > > > > that
> > > > > > > > > > it is a complex matrix. I tried loading the matrix I sent
> > > > > > > > > > you this
> > > > > morning
> > > > > > > > > > with:
> > > > > > > > > > !...Load a Matrix in Binary Format
> > > > > > > > > >        call
> > > > > PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Amat_binary.m",FILE_MODE_READ,viewer,ierr)
> > > > > > > > > >        call MatCreate(PETSC_COMM_WORLD,DLOAD,ierr)
> > > > > > > > > >        call MatSetType(DLOAD,MATAIJ,ierr)
> > > > > > > > > >        call MatLoad(DLOAD,viewer,ierr)
> > > > > > > > > >        call PetscViewerDestroy(viewer,ierr)
> > > > > > > > > >        call MatView(DLOAD,PETSC_VIEWER_STDOUT_WORLD,ierr)
> > > > > > > > > > The first 37 rows should look like this:
> > > > > > > > > > Mat Object: 2 MPI processes
> > > > > > > > > >    type: mpiaij
> > > > > > > > > > row 0: (0, 1)
> > > > > > > > > > row 1: (1, 1)
> > > > > > > > > > row 2: (2, 1)
> > > > > > > > > > row 3: (3, 1)
> > > > > > > > > > row 4: (4, 1)
> > > > > > > > > > row 5: (5, 1)
> > > > > > > > > > row 6: (6, 1)
> > > > > > > > > > row 7: (7, 1)
> > > > > > > > > > row 8: (8, 1)
> > > > > > > > > > row 9: (9, 1)
> > > > > > > > > > row 10: (10, 1)
> > > > > > > > > > row 11: (11, 1)
> > > > > > > > > > row 12: (12, 1)
> > > > > > > > > > row 13: (13, 1)
> > > > > > > > > > row 14: (14, 1)
> > > > > > > > > > row 15: (15, 1)
> > > > > > > > > > row 16: (16, 1)
> > > > > > > > > > row 17: (17, 1)
> > > > > > > > > > row 18: (18, 1)
> > > > > > > > > > row 19: (19, 1)
> > > > > > > > > > row 20: (20, 1)
> > > > > > > > > > row 21: (21, 1)
> > > > > > > > > > row 22: (22, 1)
> > > > > > > > > > row 23: (23, 1)
> > > > > > > > > > row 24: (24, 1)
> > > > > > > > > > row 25: (25, 1)
> > > > > > > > > > row 26: (26, 1)
> > > > > > > > > > row 27: (27, 1)
> > > > > > > > > > row 28: (28, 1)
> > > > > > > > > > row 29: (29, 1)
> > > > > > > > > > row 30: (30, 1)
> > > > > > > > > > row 31: (31, 1)
> > > > > > > > > > row 32: (32, 1)
> > > > > > > > > > row 33: (33, 1)
> > > > > > > > > > row 34: (34, 1)
> > > > > > > > > > row 35: (35, 1)
> > > > > > > > > > row 36: (1, -41.2444)  (35, -41.2444)  (36, 118.049 -
> > > > > > > > > > 0.999271 i)
> > > > > (37,
> > > > > > > > > > -21.447)  (38, 5.18873)  (39, -2.34856)  (40, 1.3607)  (41,
> > > > > -0.898206)
> > > > > > > > > > (42, 0.642715)  (43, -0.48593)  (44, 0.382471)  (45,
> > > > > > > > > > -0.310476)
> > > > > (46,
> > > > > > > > > > 0.258302)  (47, -0.219268)  (48, 0.189304)  (49, -0.165815)
> > > > > > > > > > (50,
> > > > > > > > > > 0.147076)  (51, -0.131907)  (52, 0.119478)  (53, -0.109189)
> > > > > > > > > > (54,
> > > > > 0.1006)
> > > > > > > > > > (55, -0.0933795)  (56, 0.0872779)  (57, -0.0821019)  (58,
> > > > > 0.0777011)  (59,
> > > > > > > > > > -0.0739575)  (60, 0.0707775)  (61, -0.0680868)  (62,
> > > > > > > > > > 0.0658258)
> > > > > (63,
> > > > > > > > > > -0.0639473)  (64, 0.0624137)  (65, -0.0611954)  (66,
> > > > > > > > > > 0.0602698)
> > > > > (67,
> > > > > > > > > > -0.0596202)  (68, 0.0592349)  (69, -0.0295536)  (71,
> > > > > > > > > > -21.447)
> > > > > (106,
> > > > > > > > > > 5.18873)  (141, -2.34856)  (176, 1.3607)  (211, -0.898206)
> > > > > > > > > > (246,
> > > > > > > > > > 0.642715)  (281, -0.48593)  (316, 0.382471)  (351,
> > > > > > > > > > -0.310476)
> > > > > (386,
> > > > > > > > > > 0.258302)  (421, -0.219268)  (456, 0.189304)  (491,
> > > > > > > > > > -0.165815)
> > > > > (526,
> > > > > > > > > > 0.147076)  (561, -0.131907)  (596, 0.119478)  (631,
> > > > > > > > > > -0.109189)
> > > > > (666,
> > > > > > > > > > 0.1006)  (701, -0.0933795)  (736, 0.0872779)  (771,
> > > > > > > > > > -0.0821019)
> > > > > (806,
> > > > > > > > > > 0.0777011)  (841, -0.0739575)  (876, 0.0707775)  (911,
> > > > > -0.0680868)  (946,
> > > > > > > > > > 0.0658258)  (981, -0.0639473)  (1016, 0.0624137)  (1051,
> > > > > -0.0611954)
> > > > > > > > > > (1086, 0.0602698)  (1121, -0.0596202)  (1156, 0.0592349)
> > > > > > > > > > (1191,
> > > > > > > > > > -0.0295536)  (1261, 0)  (3676, 117.211)  (3711, -58.4801)
> > > > > > > > > > (3746,
> > > > > > > > > > -78.3633)  (3781, 29.4911)  (3816, -15.8073)  (3851,
> > > > > > > > > > 9.94324)
> > > > > (3886,
> > > > > > > > > > -6.87205)  (3921, 5.05774)  (3956, -3.89521)  (3991,
> > > > > > > > > > 3.10522)
> > > > > (4026,
> > > > > > > > > > -2.54388)  (4061, 2.13082)  (4096, -1.8182)  (4131, 1.57606)
> > > > > (4166,
> > > > > > > > > > -1.38491)  (4201, 1.23155)  (4236, -1.10685)  (4271,
> > > > > > > > > > 1.00428)
> > > > > (4306,
> > > > > > > > > > -0.919116)  (4341, 0.847829)  (4376, -0.787776)  (4411,
> > > > > > > > > > 0.736933)
> > > > > (4446,
> > > > > > > > > > -0.693735)  (4481, 0.656958)  (4516, -0.625638)  (4551,
> > > > > > > > > > 0.599007)
> > > > > (4586,
> > > > > > > > > > -0.576454)  (4621, 0.557491)  (4656, -0.541726)  (4691,
> > > > > > > > > > 0.528849)
> > > > > (4726,
> > > > > > > > > > -0.518617)  (4761, 0.51084)  (4796, -0.50538)  (4831,
> > > > > > > > > > 0.502142)
> > > > > (4866,
> > > > > > > > > > -0.250534)
> > > > > > > > > > Thanks,
> > > > > > > > > > Anthony
> > > > > > > > > > On Fri, Jul 24, 2015 at 7:56 PM, Hong <hzhang at mcs.anl.gov>
> > > > > > > > > > wrote:
> > > > > > > > > > > Anthony:
> > > > > > > > > > > I test your Amat_binary.m
> > > > > > > > > > > using petsc/src/ksp/ksp/examples/tutorials/ex10.c.
> > > > > > > > > > > Your matrix has many zero rows:
> > > > > > > > > > > ./ex10 -f0 ~/tmp/Amat_binary.m -rhs 0 -mat_view |more
> > > > > > > > > > > Mat Object: 1 MPI processes
> > > > > > > > > > >    type: seqaij
> > > > > > > > > > > row 0: (0, 1)
> > > > > > > > > > > row 1: (1, 0)
> > > > > > > > > > > row 2: (2, 1)
> > > > > > > > > > > row 3: (3, 0)
> > > > > > > > > > > row 4: (4, 1)
> > > > > > > > > > > row 5: (5, 0)
> > > > > > > > > > > row 6: (6, 1)
> > > > > > > > > > > row 7: (7, 0)
> > > > > > > > > > > row 8: (8, 1)
> > > > > > > > > > > row 9: (9, 0)
> > > > > > > > > > > row 36: (1, 1)  (35, 0)  (36, 1)  (37, 0)  (38, 1)  (39,
> > > > > > > > > > > 0)  (40,
> > > > > 1)
> > > > > > > > > > >   (41, 0)  (42, 1)  (43, 0)  (44, 1)  (45,
> > > > > > > > > > > 0)  (46, 1)  (47, 0)  (48, 1)  (49, 0)  (50, 1)  (51, 0)
> > > > > > > > > > > (52, 1)
> > > > > > > > > > >   (53, 0)  (54, 1)  (55, 0)  (56, 1)  (57, 0)
> > > > > > > > > > >   (58, 1)  (59, 0)  (60, 1)  ...
> > > > > > > > > > > Do you send us correct matrix?
> > > > > > > > > > > > I ran my code through valgrind and gdb as suggested by
> > > > > > > > > > > > Barry. I
> > > > > am
> > > > > > > > > > > > now coming back to some problem I have had while running
> > > > > > > > > > > > with
> > > > > parallel
> > > > > > > > > > > > symbolic factorization. I am attaching a test matrix
> > > > > > > > > > > > (petsc
> > > > > binary format)
> > > > > > > > > > > > that I LU decompose and then use to solve a linear
> > > > > > > > > > > > system (see
> > > > > code below).
> > > > > > > > > > > > I can run on 2 processors with parsymbfact or with 4
> > > > > > > > > > > > processors
> > > > > without
> > > > > > > > > > > > parsymbfact. However, if I run on 4 procs with
> > > > > > > > > > > > parsymbfact, the
> > > > > code is
> > > > > > > > > > > > just hanging. Below is the simplified test case that I
> > > > > > > > > > > > have used
> > > > > to test.
> > > > > > > > > > > > The matrix A and B are built somewhere else in my
> > > > > > > > > > > > program. The
> > > > > matrix I am
> > > > > > > > > > > > attaching is A-sigma*B (see below).
> > > > > > > > > > > > One thing is that I don't know for sparse matrices what
> > > > > > > > > > > > is the
> > > > > > > > > > > > optimum number of processors to use for a LU
> > > > > > > > > > > > decomposition? Does
> > > > > it depend
> > > > > > > > > > > > on the total number of nonzero? Do you have an easy way
> > > > > > > > > > > > to
> > > > > compute it?
> > > > > > > > > > > You have to experiment your matrix on a target machine to
> > > > > > > > > > > find
> > > > > out.
> > > > > > > > > > > Hong
> > > > > > > > > > > >       Subroutine HowBigLUCanBe(rank)
> > > > > > > > > > > >        IMPLICIT NONE
> > > > > > > > > > > >        integer(i4b),intent(in) :: rank
> > > > > > > > > > > >        integer(i4b)            :: i,ct
> > > > > > > > > > > >        real(dp)                :: begin,endd
> > > > > > > > > > > >        complex(dpc)            :: sigma
> > > > > > > > > > > >        PetscErrorCode ierr
> > > > > > > > > > > >        if (rank==0) call cpu_time(begin)
> > > > > > > > > > > >        if (rank==0) then
> > > > > > > > > > > >           write(*,*)
> > > > > > > > > > > >           write(*,*)'Testing How Big LU Can Be...'
> > > > > > > > > > > >           write(*,*)'============================'
> > > > > > > > > > > >           write(*,*)
> > > > > > > > > > > >        endif
> > > > > > > > > > > >        sigma = (1.0d0,0.0d0)
> > > > > > > > > > > >        call
> > > > > > > > > > > > MatAXPY(A,-sigma,B,DIFFERENT_NONZERO_PATTERN,ierr) !
> > > > > on
> > > > > > > > > > > > exit A = A-sigma*B
> > > > > > > > > > > > !.....Write Matrix to ASCII and Binary Format
> > > > > > > > > > > >        !call
> > > > > > > > > > > > PetscViewerASCIIOpen(PETSC_COMM_WORLD,"Amat.m",viewer,ierr)
> > > > > > > > > > > >        !call MatView(DXX,viewer,ierr)
> > > > > > > > > > > >        !call PetscViewerDestroy(viewer,ierr)
> > > > > > > > > > > >        call
> > > > > PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Amat_binary.m",FILE_MODE_WRITE,viewer,ierr)
> > > > > > > > > > > >        call MatView(A,viewer,ierr)
> > > > > > > > > > > > !.....Create Linear Solver Context
> > > > > > > > > > > >        call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
> > > > > > > > > > > > !.....Set operators. Here the matrix that defines the
> > > > > > > > > > > > linear
> > > > > system
> > > > > > > > > > > > also serves as the preconditioning matrix.
> > > > > > > > > > > >        !call
> > > > > KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
> > > > > > > > > > > > !aha commented and replaced by next line
> > > > > > > > > > > >        call KSPSetOperators(ksp,A,A,ierr) ! remember:
> > > > > > > > > > > > here A =
> > > > > > > > > > > > A-sigma*B
> > > > > > > > > > > > !.....Set Relative and Absolute Tolerances and Uses
> > > > > > > > > > > > Default for
> > > > > > > > > > > > Divergence Tol
> > > > > > > > > > > >        tol = 1.e-10
> > > > > > > > > > > >        call
> > > > > KSPSetTolerances(ksp,tol,tol,PETSC_DEFAULT_REAL,PETSC_DEFAULT_INTEGER,ierr)
> > > > > > > > > > > > !.....Set the Direct (LU) Solver
> > > > > > > > > > > >        call KSPSetType(ksp,KSPPREONLY,ierr)
> > > > > > > > > > > >        call KSPGetPC(ksp,pc,ierr)
> > > > > > > > > > > >        call PCSetType(pc,PCLU,ierr)
> > > > > > > > > > > >        call
> > > > > PCFactorSetMatSolverPackage(pc,MATSOLVERSUPERLU_DIST,ierr)
> > > > > > > > > > > > ! MATSOLVERSUPERLU_DIST MATSOLVERMUMPS
> > > > > > > > > > > > !.....Create Right-Hand-Side Vector
> > > > > > > > > > > >        call MatCreateVecs(A,frhs,PETSC_NULL_OBJECT,ierr)
> > > > > > > > > > > >        call MatCreateVecs(A,sol,PETSC_NULL_OBJECT,ierr)
> > > > > > > > > > > >        allocate(xwork1(IendA-IstartA))
> > > > > > > > > > > >        allocate(loc(IendA-IstartA))
> > > > > > > > > > > >        ct=0
> > > > > > > > > > > >        do i=IstartA,IendA-1
> > > > > > > > > > > >           ct=ct+1
> > > > > > > > > > > >           loc(ct)=i
> > > > > > > > > > > >           xwork1(ct)=(1.0d0,0.0d0)
> > > > > > > > > > > >        enddo
> > > > > > > > > > > >        call
> > > > > > > > > > > > VecSetValues(frhs,IendA-IstartA,loc,xwork1,INSERT_VALUES,ierr)
> > > > > > > > > > > >        call VecZeroEntries(sol,ierr)
> > > > > > > > > > > >        deallocate(xwork1,loc)
> > > > > > > > > > > > !.....Assemble Vectors
> > > > > > > > > > > >        call VecAssemblyBegin(frhs,ierr)
> > > > > > > > > > > >        call VecAssemblyEnd(frhs,ierr)
> > > > > > > > > > > > !.....Solve the Linear System
> > > > > > > > > > > >        call KSPSolve(ksp,frhs,sol,ierr)
> > > > > > > > > > > >        !call VecView(sol,PETSC_VIEWER_STDOUT_WORLD,ierr)
> > > > > > > > > > > >        if (rank==0) then
> > > > > > > > > > > >           call cpu_time(endd)
> > > > > > > > > > > >           write(*,*)
> > > > > > > > > > > >           print '("Total time for HowBigLUCanBe =
> > > > > > > > > > > > ",f21.3,"
> > > > > > > > > > > > seconds.")',endd-begin
> > > > > > > > > > > >        endif
> > > > > > > > > > > >        call SlepcFinalize(ierr)
> > > > > > > > > > > >        STOP
> > > > > > > > > > > >      end Subroutine HowBigLUCanBe
> > > > > > > > > > > > On 07/08/2015 11:23 AM, Xiaoye S. Li wrote:
> > > > > > > > > > > >   Indeed, the parallel symbolic factorization routine
> > > > > > > > > > > > needs power
> > > > > of
> > > > > > > > > > > > 2 processes, however, you can use however many processes
> > > > > > > > > > > > you
> > > > > need;
> > > > > > > > > > > > internally, we redistribute matrix to nearest power of 2
> > > > > processes, do
> > > > > > > > > > > > symbolic, then redistribute back to all the processes to
> > > > > > > > > > > > do
> > > > > factorization,
> > > > > > > > > > > > triangular solve etc.  So, there is no  restriction from
> > > > > > > > > > > > the
> > > > > users
> > > > > > > > > > > > viewpoint.
> > > > > > > > > > > >   It's difficult to tell what the problem is.  Do you
> > > > > > > > > > > > think you
> > > > > can
> > > > > > > > > > > > print your matrix, then, I can do some debugging by
> > > > > > > > > > > > running
> > > > > superlu_dist
> > > > > > > > > > > > standalone?
> > > > > > > > > > > >   Sherry
> > > > > > > > > > > > On Wed, Jul 8, 2015 at 10:34 AM, Anthony Paul Haas <
> > > > > > > > > > > > >    Hi,
> > > > > > > > > > > > >   I have used the switch -mat_superlu_dist_parsymbfact
> > > > > > > > > > > > > in my pbs
> > > > > > > > > > > > > script. However, although my program worked fine with
> > > > > sequential symbolic
> > > > > > > > > > > > > factorization, I get one of the following 2 behaviors
> > > > > > > > > > > > > when I
> > > > > run with
> > > > > > > > > > > > > parallel symbolic factorization (depending on the
> > > > > > > > > > > > > number of
> > > > > processors that
> > > > > > > > > > > > > I use):
> > > > > > > > > > > > >   1) the program just hangs (it seems stuck in some
> > > > > > > > > > > > > subroutine
> > > > > > > > > > > > > see test.out-hangs)
> > > > > > > > > > > > >   2) I get a floating point exception ==> see
> > > > > > > > > > > > > test.out-floating-point-exception
> > > > > > > > > > > > >   Note that as suggested in the Superlu manual, I use
> > > > > > > > > > > > > a power of
> > > > > 2
> > > > > > > > > > > > > number of procs. Are there any tunable parameters for
> > > > > > > > > > > > > the
> > > > > parallel symbolic
> > > > > > > > > > > > > factorization? Note that when I build my sparse
> > > > > > > > > > > > > matrix, most
> > > > > elements I add
> > > > > > > > > > > > > are nonzero of course but to simplify the programming,
> > > > > > > > > > > > > I also
> > > > > add a few
> > > > > > > > > > > > > zero elements in the sparse matrix. I was thinking
> > > > > > > > > > > > > that maybe
> > > > > if the
> > > > > > > > > > > > > parallel symbolic factorization proceed by block,
> > > > > > > > > > > > > there could
> > > > > be some
> > > > > > > > > > > > > blocks where the pivot would be zero, hence creating
> > > > > > > > > > > > > the FPE??
> > > > > > > > > > > > >   Thanks,
> > > > > > > > > > > > >   Anthony
> > > > > > > > > > > > > On Wed, Jul 8, 2015 at 6:46 AM, Xiaoye S. Li
> > > > > > > > > > > > > <xsli at lbl.gov>
> > > > > wrote:
> > > > > > > > > > > > > >   Did you find out how to change option to use
> > > > > > > > > > > > > > parallel symbolic
> > > > > > > > > > > > > > factorization?  Perhaps PETSc team can help.
> > > > > > > > > > > > > >   Sherry
> > > > > > > > > > > > > > On Tue, Jul 7, 2015 at 3:58 PM, Xiaoye S. Li
> > > > > > > > > > > > > > <xsli at lbl.gov>
> > > > > wrote:
> > > > > > > > > > > > > > >   Is there an inquiry function that tells you all
> > > > > > > > > > > > > > > the available
> > > > > > > > > > > > > > > options?
> > > > > > > > > > > > > > >   Sherry
> > > > > > > > > > > > > > > On Tue, Jul 7, 2015 at 3:25 PM, Anthony Paul Haas
> > > > > > > > > > > > > > > >     Hi Sherry,
> > > > > > > > > > > > > > > >   Thanks for your message. I have used
> > > > > > > > > > > > > > > > superlu_dist default
> > > > > > > > > > > > > > > > options. I did not realize that I was doing
> > > > > > > > > > > > > > > > serial symbolic
> > > > > factorization.
> > > > > > > > > > > > > > > > That is probably the cause of my problem.
> > > > > > > > > > > > > > > >   Each node on Garnet has 60GB usable memory and
> > > > > > > > > > > > > > > > I can run
> > > > > with
> > > > > > > > > > > > > > > > 1,2,4,8,16 or 32 core per node.
> > > > > > > > > > > > > > > >   So I should use:
> > > > > > > > > > > > > > > > -mat_superlu_dist_r 20
> > > > > > > > > > > > > > > > -mat_superlu_dist_c 32
> > > > > > > > > > > > > > > >   How do you specify the parallel symbolic
> > > > > > > > > > > > > > > > factorization
> > > > > option?
> > > > > > > > > > > > > > > > is it -mat_superlu_dist_matinput 1
> > > > > > > > > > > > > > > >   Thanks,
> > > > > > > > > > > > > > > >   Anthony
> > > > > > > > > > > > > > > > On Tue, Jul 7, 2015 at 3:08 PM, Xiaoye S. Li
> > > > > > > > > > > > > > > > <xsli at lbl.gov>
> > > > > > > > > > > > > > > > wrote:
> > > > > > > > > > > > > > > > >   For superlu_dist failure, this occurs during
> > > > > > > > > > > > > > > > > symbolic
> > > > > > > > > > > > > > > > > factorization.  Since you are using serial
> > > > > > > > > > > > > > > > > symbolic
> > > > > factorization, it
> > > > > > > > > > > > > > > > > requires the entire graph of A to be available
> > > > > > > > > > > > > > > > > in the
> > > > > memory of one MPI
> > > > > > > > > > > > > > > > > task. How much memory do you have for each MPI
> > > > > > > > > > > > > > > > > task?
> > > > > > > > > > > > > > > > >   It won't help even if you use more
> > > > > > > > > > > > > > > > > processes.  You should
> > > > > try
> > > > > > > > > > > > > > > > > to use parallel symbolic factorization option.
> > > > > > > > > > > > > > > > >   Another point.  You set up process grid as:
> > > > > > > > > > > > > > > > >         Process grid nprow 32 x npcol 20
> > > > > > > > > > > > > > > > >   For better performance, you show swap the
> > > > > > > > > > > > > > > > > grid dimension.
> > > > > That
> > > > > > > > > > > > > > > > > is, it's better to use 20 x 32, never gives
> > > > > > > > > > > > > > > > > nprow larger
> > > > > than npcol.
> > > > > > > > > > > > > > > > >   Sherry
> > > > > > > > > > > > > > > > > On Tue, Jul 7, 2015 at 1:27 PM, Barry Smith <
> > > > > bsmith at mcs.anl.gov>
> > > > > > > > > > > > > > > > > wrote:
> > > > > > > > > > > > > > > > > >     I would suggest running a sequence of
> > > > > > > > > > > > > > > > > > problems, 101 by
> > > > > 101
> > > > > > > > > > > > > > > > > > 111 by 111 etc and get the memory usage in
> > > > > > > > > > > > > > > > > > each case (when
> > > > > you run out of
> > > > > > > > > > > > > > > > > > memory you can get NO useful information out
> > > > > > > > > > > > > > > > > > about memory
> > > > > needs). You can
> > > > > > > > > > > > > > > > > > then plot memory usage as a function of
> > > > > > > > > > > > > > > > > > problem size to
> > > > > get a handle on how
> > > > > > > > > > > > > > > > > > much memory it is using.  You can also run
> > > > > > > > > > > > > > > > > > on more and
> > > > > more processes
> > > > > > > > > > > > > > > > > > (which have a total of more memory) to see
> > > > > > > > > > > > > > > > > > how large a
> > > > > problem you may be
> > > > > > > > > > > > > > > > > > able to reach.
> > > > > > > > > > > > > > > > > >     MUMPS also has an "out of core" version
> > > > > > > > > > > > > > > > > > (which we have
> > > > > never
> > > > > > > > > > > > > > > > > > used) that could in theory anyways let you
> > > > > > > > > > > > > > > > > > get to large
> > > > > problems if you
> > > > > > > > > > > > > > > > > > have lots of disk space, but you are on your
> > > > > > > > > > > > > > > > > > own figuring
> > > > > out how to use it.
> > > > > > > > > > > > > > > > > >    Barry
> > > > > > > > > > > > > > > > > > > On Jul 7, 2015, at 2:37 PM, Anthony Paul
> > > > > > > > > > > > > > > > > > > Haas <
> > > > > > > > > > > > > > > > > > > Hi Jose,
> > > > > > > > > > > > > > > > > > > In my code, I use once PETSc to solve a
> > > > > > > > > > > > > > > > > > > linear system to
> > > > > get
> > > > > > > > > > > > > > > > > > the baseflow (without using SLEPc) and then
> > > > > > > > > > > > > > > > > > I use SLEPc to
> > > > > do the stability
> > > > > > > > > > > > > > > > > > analysis of that baseflow. This is why,
> > > > > > > > > > > > > > > > > > there are some
> > > > > SLEPc options that
> > > > > > > > > > > > > > > > > > are not used in
> > > > > > > > > > > > > > > > > > test.out-superlu_dist-151x151 (when I am
> > > > > solving for the
> > > > > > > > > > > > > > > > > > baseflow with PETSc only). I have attached a
> > > > > > > > > > > > > > > > > > 101x101 case
> > > > > for which I get
> > > > > > > > > > > > > > > > > > the eigenvalues. That case works fine.
> > > > > > > > > > > > > > > > > > However If i
> > > > > increase to 151x151, I
> > > > > > > > > > > > > > > > > > get the error that you can see in
> > > > > test.out-superlu_dist-151x151 (similar
> > > > > > > > > > > > > > > > > > error with mumps: see test.out-mumps-151x151
> > > > > > > > > > > > > > > > > > line 2918 ).
> > > > > If you look a the
> > > > > > > > > > > > > > > > > > very end of the files
> > > > > > > > > > > > > > > > > > test.out-superlu_dist-151x151 and
> > > > > > > > > > > > > > > > > > test.out-mumps-151x151, you will see that
> > > > > > > > > > > > > > > > > > the last info
> > > > > message printed is:
> > > > > > > > > > > > > > > > > > > On Processor (after EPSSetFromOptions)  0
> > > > > > > > > > > > > > > > > > > memory:
> > > > > > > > > > > > > > > > > > 0.65073152000E+08          =====>  (see line
> > > > > > > > > > > > > > > > > > 807 of
> > > > > module_petsc.F90)
> > > > > > > > > > > > > > > > > > > This means that the memory error probably
> > > > > > > > > > > > > > > > > > > occurs in the
> > > > > call
> > > > > > > > > > > > > > > > > > to EPSSolve (see module_petsc.F90 line 810).
> > > > > > > > > > > > > > > > > > I would like
> > > > > to evaluate how
> > > > > > > > > > > > > > > > > > much memory is required by the most memory
> > > > > > > > > > > > > > > > > > intensive
> > > > > operation within
> > > > > > > > > > > > > > > > > > EPSSolve. Since I am solving a generalized
> > > > > > > > > > > > > > > > > > EVP, I would
> > > > > imagine that it
> > > > > > > > > > > > > > > > > > would be the LU decomposition. But is there
> > > > > > > > > > > > > > > > > > an accurate
> > > > > way of doing it?
> > > > > > > > > > > > > > > > > > > Before starting with iterative solvers, I
> > > > > > > > > > > > > > > > > > > would like to
> > > > > > > > > > > > > > > > > > exploit as much as I can direct solvers. I
> > > > > > > > > > > > > > > > > > tried GMRES
> > > > > with default
> > > > > > > > > > > > > > > > > > preconditioner at some point but I had
> > > > > > > > > > > > > > > > > > convergence
> > > > > problem. What
> > > > > > > > > > > > > > > > > > solver/preconditioner would you recommend
> > > > > > > > > > > > > > > > > > for a
> > > > > generalized non-Hermitian
> > > > > > > > > > > > > > > > > > (EPS_GNHEP) EVP?
> > > > > > > > > > > > > > > > > > > Thanks,
> > > > > > > > > > > > > > > > > > > Anthony
> > > > > > > > > > > > > > > > > > > On Tue, Jul 7, 2015 at 12:17 AM, Jose E.
> > > > > > > > > > > > > > > > > > > Roman <
> > > > > > > > > > > > > > > > > > jroman at dsic.upv.es> wrote:
> > > > > > > > > > > > > > > > > > > El 07/07/2015, a las 02:33, Anthony Haas
> > > > > > > > > > > > > > > > > > > escribió:
> > > > > > > > > > > > > > > > > > > > Hi,
> > > > > > > > > > > > > > > > > > > > I am computing eigenvalues using
> > > > > > > > > > > > > > > > > > > > PETSc/SLEPc and
> > > > > > > > > > > > > > > > > > superlu_dist for the LU decomposition (my
> > > > > > > > > > > > > > > > > > problem is a
> > > > > generalized
> > > > > > > > > > > > > > > > > > eigenvalue problem). The code runs fine for
> > > > > > > > > > > > > > > > > > a grid with
> > > > > 101x101 but when I
> > > > > > > > > > > > > > > > > > increase to 151x151, I get the following
> > > > > > > > > > > > > > > > > > error:
> > > > > > > > > > > > > > > > > > > > (and then [NID
> > > > > 00037]
> > > > > > > > > > > > > > > > > > 2015-07-06 19:19:17 Apid 31025976: OOM
> > > > > > > > > > > > > > > > > > killer terminated
> > > > > this process.)
> > > > > > > > > > > > > > > > > > > > It seems to be a memory problem. I
> > > > > > > > > > > > > > > > > > > > monitor the memory
> > > > > usage
> > > > > > > > > > > > > > > > > > as far as I can and it seems that memory
> > > > > > > > > > > > > > > > > > usage is pretty
> > > > > low. The most
> > > > > > > > > > > > > > > > > > memory intensive part of the program is
> > > > > > > > > > > > > > > > > > probably the LU
> > > > > decomposition in
> > > > > > > > > > > > > > > > > > the context of the generalized EVP. Is there
> > > > > > > > > > > > > > > > > > a way to
> > > > > evaluate how much
> > > > > > > > > > > > > > > > > > memory will be required for that step? I am
> > > > > > > > > > > > > > > > > > currently
> > > > > running the debug
> > > > > > > > > > > > > > > > > > version of the code which I would assume
> > > > > > > > > > > > > > > > > > would use more
> > > > > memory?
> > > > > > > > > > > > > > > > > > > > I have attached the output of the job.
> > > > > > > > > > > > > > > > > > > > Note that the
> > > > > > > > > > > > > > > > > > program uses twice PETSc: 1) to solve a
> > > > > > > > > > > > > > > > > > linear system for
> > > > > which no problem
> > > > > > > > > > > > > > > > > > occurs, and, 2) to solve the Generalized EVP
> > > > > > > > > > > > > > > > > > with SLEPc,
> > > > > where I get the
> > > > > > > > > > > > > > > > > > error.
> > > > > > > > > > > > > > > > > > > > Thanks
> > > > > > > > > > > > > > > > > > > > Anthony
> > > > > > > > > > > > > > > > > > > > <test.out-superlu_dist-151x151>
> > > > > > > > > > > > > > > > > > > In the output you are attaching there are
> > > > > > > > > > > > > > > > > > > no SLEPc
> > > > > objects in
> > > > > > > > > > > > > > > > > > the report and SLEPc options are not used.
> > > > > > > > > > > > > > > > > > It seems that
> > > > > SLEPc calls are
> > > > > > > > > > > > > > > > > > skipped?
> > > > > > > > > > > > > > > > > > > Do you get the same error with MUMPS? Have
> > > > > > > > > > > > > > > > > > > you tried to
> > > > > solve
> > > > > > > > > > > > > > > > > > linear systems with a preconditioned
> > > > > > > > > > > > > > > > > > iterative solver?
> > > > > > > > > > > > > > > > > > > Jose
> > > > > <module_petsc.F90><test.out-mumps-151x151><test.out_superlu_dist-101x101><test.out-superlu_dist-151x151>
