[petsc-users] Removing rigid body motion using Null Space
Jed Brown
jed at jedbrown.org
Tue Jul 28 14:38:31 CDT 2015
Hom Nath Gharti <hng.email at gmail.com> writes:
> Dear all,
> After searching old mailing lists, it appears that the rigid body
> motion
"rigid body motion" refers to rotations and translations, which appear
in vector-valued problems like elasticity or fluids.
> can be removed using Null Space features in PETSc. Unfortunately, I
> could not successfully implement this to a simple elastostatic
> problem.
What is vector-valued in your electrostatic problem?
> I have an unconstrained sphere and I need to compute displacement
> field due to a point load on the surface.
> I tried:
> call MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_TRUE,0,0,nullspace,ierr)
> call MatSetNullSpace(Kmat,nullspace,ierr)
> call MatNullSpaceRemove(nullspace,bvec,PETSC_NULL_OBJECT,ierr)
> call MatNullSpaceDestroy(nullspace,ierr)
> But the solution did not converge! Any help/hint would be greatly appreciated.
Check that this really is the null space of the operator. You can use
-ksp_test_null_space, for example.
Check that the preconditioner is stable. Use a simple preconditioner on
a tiny problem to start with.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150728/cf6cd5ca/attachment.pgp>
