[petsc-users] SuperLU MPI-problem
Mark Adams
mfadams at lbl.gov
Mon Jul 27 13:29:46 CDT 2015
On Sun, Jul 26, 2015 at 8:48 AM, Mahir.Ulker-Kaustell at tyrens.se <
Mahir.Ulker-Kaustell at tyrens.se> wrote:
> Thank you very much for the input. I will test this approach. I have
> some reading (about the numerical techniques that you have implemented) to
> do as well, so it might take some time for me, but I’ll be back…
> What does NV abbreviate?
Naviers ... typing too fast
> Mahir
> *From:* Mark Adams [mailto:mfadams at lbl.gov]
> *Sent:* den 26 juli 2015 15:41
> *To:* Jed Brown
> *Cc:* Ülker-Kaustell, Mahir; Matthew Knepley; petsc-users
> *Subject:* Re: [petsc-users] SuperLU MPI-problem
> Coming in late to this thread but you are doing frequency domain NV.
> Start by getting your time domain (definite, no omega shift) solves
> working. This can be a challenge for NV. There are techiques for this but
> we do not have them. Start with plane aggregation (-pc_gamg_nsmooths 0),
> this should be able to work OK, then try smoothing, this will probably not
> work.
> Now add the shift. If you are shifting to high frequency then there is no
> hope w/o very special methods so use a direct solver.
> Mark
> On Wed, Jul 22, 2015 at 5:29 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Mahir.Ulker-Kaustell at tyrens.se" <Mahir.Ulker-Kaustell at tyrens.se> writes:
> > I am solving Ax = b with a sparse, indefinite, symmetric, complex
> > matrix, can anything be said about the chances of success in using an
> > iterative method?
> Not without more information/experimentation. You should check the
> literature for your problem domain to see what people claim is
> successful or does not work.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150727/083716d0/attachment.html>
