[petsc-users] petsc4py installation error with PETSc v 3.6.1
Justin Chang jychang48 at gmail.com
Sat Jul 25 15:23:32 CDT 2015
I am working on 5 different machines and didn't keep good track of which
machines had which petsc versions. The machine in question did not have the
latest petsc 3.6.1 which was causing the problems. Rebuilding from
petsc-dev did the trick, thanks for the help guys.
Justin
PS - Every time I do a git pull of the latest petsc4py, i always have to
apply Satish's patch in order to avoid the issue originally posted. Is
there a way to update petsc4py master such that it conforms to the
latest PetscSectionCreateGlobalSection()
format?
On Sat, Jul 25, 2015 at 4:44 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 25 July 2015 at 00:12, Justin Chang <jychang48 at gmail.com> wrote:
> > ImportError:
> /usr/local/lib/python2.7/dist-packages/petsc4py/lib/arch-linux2-c-opt/PETSc.so:
> > undefined symbol: DMShellSetCreateSubDM
> > make: *** [unit_sequential] Error 1
> You need to git pull in branch master of petsc-dev and rebuild.
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Numerical Porous Media Center (NumPor)
> King Abdullah University of Science and Technology (KAUST)
> http://numpor.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 4332
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150725/5ce981d8/attachment.html>
