[petsc-users] Petsc with Elemental installation in Cray
venkatesh g venkateshgk.j at gmail.com
Sat Jul 25 06:48:02 CDT 2015
Thank you. I managed to install it.
On Mon, Jul 13, 2015 at 11:00 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    You gnu compiler is ancient and supports little of C++11. Likely there
> is a more recent one on the system (like 4.8) that you can switch to by
> using the right module.
>   Barry
> > On Jul 13, 2015, at 10:35 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
> > sorry, I have attached the configure.log
> > Venkatesh
> > On Mon, Jul 13, 2015 at 5:24 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Mon, Jul 13, 2015 at 1:30 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
> > Hi, when I use --with-cxx-dialect=C++11, I get the error
> > Could not determine compiler flag for with-cxx-dialect=C++11, use
> CXXFLAGS
> > Always always always send configure.log or we have no idea what happened.
> >    Matt
> > Kindly let me know the syntax or how to enable this.
> > w.r.t --with-mpi-dir on Crays, I will keep it in mind and will not pass
> them as you have told Barry, they locate it automatically.
> > Thank you
> > Venkatesh
> > On Sun, Jul 12, 2015 at 5:31 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Sun, Jul 12, 2015 at 6:52 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
> > Hi all,
> > I am trying to install elemental with Petsc.
> > I configure using:
> > ./configure --with-cc=gcc --with-cxx=g++
> PETSC_ARCH=linux-intel_elemental
> -with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/
> --with-mpi-dir=/opt/cray/mpt/7.0.5/gni/mpich2-intel/140
> --with-scalar-type=complex --with-fortran-kernels=1
> -known-mpi-shared-libraries=0 --with-large-file-io=1
> --with-64-bit-indices=0 --with-batch FC=ifort
> --with-valgrind-dir=/mnt/lustre/esd2/esdveng/valgrind
> --download-elemental=/home/proj/14/esdveng/apps/Elemental-0.84-p5.tgz
> --download-cmake=/home/proj/14/esdveng/apps/cmake-2.8.12.2.tar.gz
> > I get this error:
> > Cannot use elemental without enabling C++11, see --with-cxx-dialect=C++11
> > Pls let me know what flag must I use and its syntax.
> > Did you try using --with-cxx-dialect=C++11 on configure?
> >   Thanks,
> >     Matt
> > Venkatesh
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150725/6556f5bf/attachment.html>
