[petsc-users] petsc hangs
Fri Jul 24 12:03:55 CDT 2015
On Fri, Jul 24, 2015 at 11:58 AM, Aaron Kitzmiller <
akitzmiller at g.harvard.edu> wrote:
> I'm using 1.8.3 which is Sept 2014.  I'll try some others.
> Do you happen to know what the bug is (or a good Google term for finding
> it)?
It was fixed in 1.8.4
https://github.com/open-mpi/ompi-release/commit/6dcd42be28ac1a8dac887bf5e6c9ffb9b99f9511
  Matt
> ajk
> Aaron Kitzmiller
> Informatics and Scientific Applications
> aaron_kitzmiller at harvard.edu
> On Jul 24, 2015, at 12:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jul 24, 2015 at 11:36 AM, Aaron Kitzmiller <
>> futex is a Linux system call used for locking shared resources.
>> It could be indicative of an MPI problem.  I wouldn't be surprised.  If
>> anyone has any idea how to get around it that would be great.  We have
>> dozens of applications on our compute cluster that use MPI, this version
>> being our default.  I'm wondering if there is something specific to the mix
>> of MPI flavor / compiler, etc. that could be going on here.
> Yes, this is a bug in OpenMPI that has been open for years.
> Can you please switch to MPICH and try another test? I thought the newest
> version of OpenMPI had fixed this, but maybe you are using an older release.
>   Thanks,
>     Matt
>> This is the gdb stack trace:
>> #0  0x00000039c6a0e264 in __lll_lock_wait () from /lib64/libpthread.so.0
>> #1  0x00000039c6a09508 in _L_lock_854 () from /lib64/libpthread.so.0
>> #2  0x00000039c6a093d7 in pthread_mutex_lock ()
>> #3  0x00002aaaaf13ddd4 in opal_mutex_lock (attr_hash=0x2aaaaf651c70,
>> key=128, attribute=0x7fffffffc200, flag=0xffffffffffffffff)
>>     at ../opal/threads/mutex_unix.h:104
>> #4  ompi_attr_get_c (attr_hash=0x2aaaaf651c70,
>>     at attribute/attribute.c:758
>> #5  0x00002aaaaf17080e in PMPI_Attr_get (comm=0x2aaaaf651c70, keyval=128,
>> attribute_val=0x7fffffffc200, flag=0xffffffffffffffff)
>>     at pattr_get.c:61
>> #6  0x00002aaaaacad0b3 in Petsc_DelComm_Outer (comm=0x2aaaaf6d4140,
>> keyval=13, attr_val=0x7af160, extra_state=0x0)
>>     at /n/home08/lchristakis/petsc/petsc-3.5.4/src/sys/objects/pinit.c:409
>> #7  0x00002aaaaf13f1a4 in ompi_attr_delete_impl
>> (type=2942639216, object=0x80, attr_hash=0x7fffffffc200, key=-1,
>> predefined=112 'p')
>>     at attribute/attribute.c:970
>> #8  0x00002aaaaf13ee02 in ompi_attr_delete (type=2942639216, object=0x80,
>> attr_hash=0x7fffffffc200, key=-1, predefined=112 'p')
>>     at attribute/attribute.c:1019
>> #9  0x00002aaaaf170710 in PMPI_Attr_delete
>> (comm=0x2aaaaf651c70, keyval=128) at pattr_delete.c:59
>> #10 0x00002aaaaac61848 in PetscCommDestroy (comm=0x888cf0)
>> at /n/home08/lchristakis/petsc/petsc-3.5.4/src/sys/objects/tagm.c:256
>> #11 0x00002aaaaac6a273 in PetscHeaderDestroy_Private (h=0x888ce0)
>>     at
>> /n/home08/lchristakis/petsc/petsc-3.5.4/src/sys/objects/inherit.c:121
>> #12 0x00002aaaaaf51512 in VecDestroy (v=0x7fffffffcbd0)
>>     at
>> /n/home08/lchristakis/petsc/petsc-3.5.4/src/vec/vec/interface/vector.c:434
>> #13 0x00002aaaab9c5c7f in DMSetUp_DA_2D (da=0x87b1b0)
>> at /n/home08/lchristakis/petsc/petsc-3.5.4/src/dm/impls/da/da2.c:776
>> #14 0x00002aaaaba73bfd in DMSetUp_DA (da=0x87b1b0)
>> at /n/home08/lchristakis/petsc/petsc-3.5.4/src/dm/impls/da/dareg.c:25
>> #15 0x00002aaaab93399a in DMSetUp (dm=0x87b1b0)
>> at /n/home08/lchristakis/petsc/petsc-3.5.4/src/dm/interface/dm.c:560
>> #16 0x00002aaaab9c6941 in DMDACreate2d
>> (comm=0x2aaaaf6d45c0, bx=DM_BOUNDARY_NONE, by=DM_BOUNDARY_NONE,
>>     stencil_type=DMDA_STENCIL_STAR, M=-4, N=-4, m=-1, n=-1, dof=1, s=1,
>> lx=0x0, ly=0x0, da=0x7fffffffd668)
>>     at /n/home08/lchristakis/petsc/petsc-3.5.4/src/dm/impls/da/da2.c:862
>> #17 0x00000000004023d0 in main (argc=1, argv=0x7fffffffd8c8)
>>     at
>> /n/home08/lchristakis/petsc/petsc-3.5.4/src/snes/examples/tutorials/ex5.c:116
>> Aaron Kitzmiller
>> On Jul 24, 2015, at 12:18 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jul 24, 2015 at 11:17 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Jul 24, 2015 at 11:09 AM, Aaron Kitzmiller <
>>>> Doesn't run.  Hangs just like the tests do.
>>>> I doubt it's helpful, but when I run it under strace, it hangs on a
>>>> "futex".  The last thing vaguely informative was an attempt to read the
>>>> non-existent .petscrc.
>>> Run in the debugger and get a stack trace.
>> Also futex does not appear in the PETSc source:
>>    knepley/feature-snes-deflation *+$|MERGING:/PETSc3/petsc/petsc-dev$
>> find src -name "*.c" | xargs grep futex
>> You have an MPI problem.
>>    Matt
>>>   Matt
>>>> ajk
>>>> Aaron Kitzmiller
>>>> On Jul 24, 2015, at 11:21 AM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>   ./ex5 -snes_monitor
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150724/6392f555/attachment.html>
