[petsc-users] SuperLU MPI-problem
Hong
hzhang at mcs.anl.gov
Wed Jul 22 14:34:29 CDT 2015
In Petsc/superlu_dist interface, we set default
options.ParSymbFact = NO;
When user raises the flag "-mat_superlu_dist_parsymbfact",
we set
options.ParSymbFact = YES;
options.ColPerm = PARMETIS; /* in v2.2, PARMETIS is forced for
ParSymbFact regardless of user ordering setting */
We do not change anything else.
Hong
On Wed, Jul 22, 2015 at 2:19 PM, Xiaoye S. Li <xsli at lbl.gov> wrote:
> I am trying to understand your problem. You said you are solving Naviers
> equation (elastodynamics) in the frequency domain, using finite element
> discretization. I wonder why you have about 1000 nonzeros per row.
> Usually in many PDE discretized matrices, the number of nonzeros per row is
> in the tens (even for 3D problems), not in the thousands. So, your matrix
> is quite a bit denser than many sparse matrices we deal with.
> The number of nonzeros in the L and U factors is much more than that in
> original matrix A -- typically we see 10-20x fill ratio for 2D, or can be
> as bad as 50-100x fill ratio for 3D. But since your matrix starts much
> denser (i.e., the underlying graph has many connections), it may not lend
> to any good ordering strategy to preserve sparsity of L and U; that is, the
> L and U fill ratio may be large.
> I don't understand why you get the following error when you use
> ‘-mat_superlu_dist_parsymbfact’.
> Invalid ISPEC at line 484 in file get_perm_c.c
> Perhaps Hong Zhang knows; she built the SuperLU_DIST interface for PETSc.
> Hong -- in order to use parallel symbolic factorization, is it sufficient
> to specify only
> ? (the default is to use sequential symbolic factorization.)
> Sherry
> On Wed, Jul 22, 2015 at 9:11 AM, Mahir.Ulker-Kaustell at tyrens.se <
> Mahir.Ulker-Kaustell at tyrens.se> wrote:
>> Thank you for your reply.
>> As you have probably figured out already, I am not a computational
>> scientist. I am a researcher in civil engineering (railways for high-speed
>> traffic), trying to produce some, from my perspective, fairly large
>> parametric studies based on finite element discretizations.
>> I am working in a Windows-environment and have installed PETSc through
>> Cygwin.
>> Apparently, there is no support for Valgrind in this OS.
>> If I have understood you correct, the memory issues are related to
>> superLU and given my background, there is not much I can do. Is this
>> correct?
>> Best regards,
>> Mahir
>> ______________________________________________
>> Mahir Ülker-Kaustell, Kompetenssamordnare, Brokonstruktör, Tekn. Dr,
>> Tyréns AB
>> 010 452 30 82, Mahir.Ulker-Kaustell at tyrens.se
>> -----Original Message-----
>> From: Barry Smith [mailto:bsmith at mcs.anl.gov]
>> Sent: den 22 juli 2015 02:57
>> To: Ülker-Kaustell, Mahir
>> Cc: Xiaoye S. Li; petsc-users
>> Subject: Re: [petsc-users] SuperLU MPI-problem
>> Run the program under valgrind
>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind . When I
>> use the option -mat_superlu_dist_parsymbfact I get many scary memory
>> problems some involving for example ddist_psymbtonum
>> (pdsymbfact_distdata.c:1332)
>> Note that I consider it unacceptable for running programs to EVER use
>> uninitialized values; until these are all cleaned up I won't trust any runs
>> like this.
>> Barry
>> ==42050== Conditional jump or move depends on uninitialised value(s)
>> ==42050== at 0x10274C436: MPI_Allgatherv (allgatherv.c:1053)
>> ==42050== by 0x101557F60: get_perm_c_parmetis
>> (get_perm_c_parmetis.c:285)
>> ==42050== by 0x101501192: pdgssvx (pdgssvx.c:934)
>> ==42050== by 0x1009CFE7A: MatLUFactorNumeric_SuperLU_DIST
>> (superlu_dist.c:414)
>> ==42050== by 0x10046CC5C: MatLUFactorNumeric (matrix.c:2946)
>> ==42050== by 0x100F09F2C: PCSetUp_LU (lu.c:152)
>> ==42050== by 0x100FF9036: PCSetUp (precon.c:982)
>> ==42050== by 0x1010F54EB: KSPSetUp (itfunc.c:332)
>> ==42050== by 0x1010F7985: KSPSolve (itfunc.c:546)
>> ==42050== by 0x10125541E: SNESSolve_NEWTONLS (ls.c:233)
>> ==42050== by 0x1011C49B7: SNESSolve (snes.c:3906)
>> ==42050== by 0x100001B3C: main (in ./ex19)
>> ==42050== Uninitialised value was created by a stack allocation
>> ==42050== at 0x10155751B: get_perm_c_parmetis
>> (get_perm_c_parmetis.c:96)
>> ==42050==
>> ==42050== at 0x102851C61: MPIR_Allgatherv_intra (allgatherv.c:651)
>> ==42050== by 0x102853EC7: MPIR_Allgatherv (allgatherv.c:903)
>> ==42050== by 0x102853F84: MPIR_Allgatherv_impl (allgatherv.c:944)
>> ==42050== by 0x10274CA41: MPI_Allgatherv (allgatherv.c:1107)
>> ==42050==
>> ==42049== Syscall param writev(vector[...]) points to uninitialised
>> byte(s)
>> ==42049== at 0x102DA1C3A: writev (in
>> /usr/lib/system/libsystem_kernel.dylib)
>> ==42049== by 0x10296A0DC: MPL_large_writev (mplsock.c:32)
>> ==42049== by 0x10295F6AD: MPIDU_Sock_writev (sock_immed.i:610)
>> ==42049== by 0x102943FCA: MPIDI_CH3_iSendv (ch3_isendv.c:84)
>> ==42049== by 0x102934361: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
>> ==42049== by 0x102939531: MPID_Isend (mpid_isend.c:138)
>> ==42049== by 0x10277656E: MPI_Isend (isend.c:125)
>> ==42049== by 0x102088B66: libparmetis__gkMPI_Isend (gkmpi.c:63)
>> ==42049== by 0x10208140F: libparmetis__CommInterfaceData (comm.c:298)
>> ==42049== by 0x1020A8758: libparmetis__CompactGraph (ometis.c:553)
>> ==42049== by 0x1020A77BB: libparmetis__MultilevelOrder (ometis.c:225)
>> ==42049== by 0x1020A7493: ParMETIS_V32_NodeND (ometis.c:151)
>> ==42049== by 0x1020A6AFB: ParMETIS_V3_NodeND (ometis.c:34)
>> ==42049== by 0x101557CFC: get_perm_c_parmetis
>> (get_perm_c_parmetis.c:241)
>> ==42049== by 0x101501192: pdgssvx (pdgssvx.c:934)
>> ==42049== by 0x1009CFE7A: MatLUFactorNumeric_SuperLU_DIST
>> ==42049== by 0x10046CC5C: MatLUFactorNumeric (matrix.c:2946)
>> ==42049== by 0x100F09F2C: PCSetUp_LU (lu.c:152)
>> ==42049== by 0x100FF9036: PCSetUp (precon.c:982)
>> ==42048== Syscall param writev(vector[...]) points to uninitialised
>> byte(s)
>> ==42049== by 0x1010F54EB: KSPSetUp (itfunc.c:332)
>> ==42049== Address 0x105edff70 is 1,424 bytes inside a block of size
>> 752,720 alloc'd
>> ==42049== at 0x1000183B1: malloc (vg_replace_malloc.c:303)
>> ==42049== by 0x1020EB90C: gk_malloc (memory.c:147)
>> ==42049== by 0x1020EAA28: gk_mcoreCreate (mcore.c:28)
>> ==42048== at 0x102DA1C3A: writev (in
>> ==42048== by 0x10296A0DC: MPL_large_writev (mplsock.c:32)
>> ==42049== by 0x1020BA5CF: libparmetis__AllocateWSpace (wspace.c:23)
>> ==42049== by 0x1020A6E84: ParMETIS_V32_NodeND (ometis.c:98)
>> ==42048== by 0x10295F6AD: MPIDU_Sock_writev (sock_immed.i:610)
>> ==42048== by 0x102943FCA: MPIDI_CH3_iSendv (ch3_isendv.c:84)
>> ==42048== by 0x102934361: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
>> ==42048== by 0x102939531: MPID_Isend (mpid_isend.c:138)
>> ==42048== by 0x10277656E: MPI_Isend (isend.c:125)
>> ==42048== by 0x102088B66: libparmetis__gkMPI_Isend (gkmpi.c:63)
>> ==42048== by 0x10208140F: libparmetis__CommInterfaceData (comm.c:298)
>> ==42049== by 0x1010F7985: KSPSolve (itfunc.c:546)
>> ==42049== by 0x10125541E: SNESSolve_NEWTONLS (ls.c:233)
>> ==42048== by 0x1020A8758: libparmetis__CompactGraph (ometis.c:553)
>> ==42048== by 0x1020A77BB: libparmetis__MultilevelOrder (ometis.c:225)
>> ==42048== by 0x1020A7493: ParMETIS_V32_NodeND (ometis.c:151)
>> ==42049== by 0x1011C49B7: SNESSolve (snes.c:3906)
>> ==42049== by 0x100001B3C: main (in ./ex19)
>> ==42049== Uninitialised value was created by a heap allocation
>> ==42048== by 0x1020A6AFB: ParMETIS_V3_NodeND (ometis.c:34)
>> ==42048== by 0x101557CFC: get_perm_c_parmetis
>> ==42048== by 0x101501192: pdgssvx (pdgssvx.c:934)
>> ==42048== by 0x1009CFE7A: MatLUFactorNumeric_SuperLU_DIST
>> ==42049== by 0x10211C50B: libmetis__imalloc (gklib.c:24)
>> ==42049== by 0x1020A8566: libparmetis__CompactGraph (ometis.c:519)
>> ==42048== by 0x10046CC5C: MatLUFactorNumeric (matrix.c:2946)
>> ==42048== by 0x100F09F2C: PCSetUp_LU (lu.c:152)
>> ==42048== by 0x100FF9036: PCSetUp (precon.c:982)
>> ==42048== by 0x1010F54EB: KSPSetUp (itfunc.c:332)
>> ==42048== Address 0x10597a860 is 1,408 bytes inside a block of size
>> 752,720 alloc'd
>> ==42049==
>> ==42048== at 0x1000183B1: malloc (vg_replace_malloc.c:303)
>> ==42048== by 0x1020EB90C: gk_malloc (memory.c:147)
>> ==42048== by 0x1020EAA28: gk_mcoreCreate (mcore.c:28)
>> ==42048== by 0x1020BA5CF: libparmetis__AllocateWSpace (wspace.c:23)
>> ==42048== by 0x1020A6E84: ParMETIS_V32_NodeND (ometis.c:98)
>> ==42048== by 0x1010F7985: KSPSolve (itfunc.c:546)
>> ==42048== by 0x10125541E: SNESSolve_NEWTONLS (ls.c:233)
>> ==42048== by 0x1011C49B7: SNESSolve (snes.c:3906)
>> ==42048== by 0x100001B3C: main (in ./ex19)
>> ==42048== Uninitialised value was created by a heap allocation
>> ==42048== by 0x10211C50B: libmetis__imalloc (gklib.c:24)
>> ==42048== by 0x1020A8566: libparmetis__CompactGraph (ometis.c:519)
>> ==42048==
>> ==42048== Syscall param write(buf) points to uninitialised byte(s)
>> ==42048== at 0x102DA1C22: write (in
>> ==42048== by 0x10295F5BD: MPIDU_Sock_write (sock_immed.i:525)
>> ==42048== by 0x102944839: MPIDI_CH3_iStartMsg (ch3_istartmsg.c:86)
>> ==42048== by 0x102933B80: MPIDI_CH3_EagerContigShortSend
>> (ch3u_eager.c:257)
>> ==42048== by 0x10293ADBA: MPID_Send (mpid_send.c:130)
>> ==42048== by 0x10277A1FA: MPI_Send (send.c:127)
>> ==42048== by 0x10155802F: get_perm_c_parmetis
>> (get_perm_c_parmetis.c:299)
>> ==42048== Address 0x104810704 is on thread 1's stack
>> ==42048== in frame #3, created by MPIDI_CH3_EagerContigShortSend
>> (ch3u_eager.c:218)
>> ==42048== by 0x10153B704: superlu_malloc_dist (memory.c:108)
>> ==42048== by 0x101557AB9: get_perm_c_parmetis
>> (get_perm_c_parmetis.c:185)
>> ==42048==
>> ==42050== at 0x102744CB8: MPI_Alltoallv (alltoallv.c:480)
>> ==42050== by 0x101510B3E: dist_symbLU (pdsymbfact_distdata.c:539)
>> ==42050== by 0x10150A5C6: ddist_psymbtonum (pdsymbfact_distdata.c:1275)
>> ==42050== by 0x1015018C2: pdgssvx (pdgssvx.c:1057)
>> ==42050== at 0x10150E4C4: dist_symbLU (pdsymbfact_distdata.c:96)
>> ==42050==
>> ==42050== at 0x102744E43: MPI_Alltoallv (alltoallv.c:490)
>> ==42050==
>> ==42050== at 0x102744EBF: MPI_Alltoallv (alltoallv.c:497)
>> ==42050==
>> ==42050== at 0x1027450B1: MPI_Alltoallv (alltoallv.c:512)
>> ==42050==
>> ==42050== at 0x10283FB06: MPIR_Alltoallv_intra (alltoallv.c:92)
>> ==42050== by 0x1028407B6: MPIR_Alltoallv (alltoallv.c:343)
>> ==42050== by 0x102840884: MPIR_Alltoallv_impl (alltoallv.c:380)
>> ==42050== by 0x10274541B: MPI_Alltoallv (alltoallv.c:531)
>> ==42050==
>> ==42050== Syscall param writev(vector[...]) points to uninitialised
>> byte(s)
>> ==42050== at 0x102DA1C3A: writev (in
>> ==42050== by 0x10296A0DC: MPL_large_writev (mplsock.c:32)
>> ==42050== by 0x10295F6AD: MPIDU_Sock_writev (sock_immed.i:610)
>> ==42050== by 0x102943FCA: MPIDI_CH3_iSendv (ch3_isendv.c:84)
>> ==42050== by 0x102934361: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
>> ==42050== by 0x102939531: MPID_Isend (mpid_isend.c:138)
>> ==42050== by 0x10277656E: MPI_Isend (isend.c:125)
>> ==42050== by 0x101524C41: pdgstrf2_trsm (pdgstrf2.c:201)
>> ==42050== by 0x10151ECBF: pdgstrf (pdgstrf.c:1082)
>> ==42050== by 0x1015019A5: pdgssvx (pdgssvx.c:1069)
>> ==42050== Address 0x1060144d0 is 1,168 bytes inside a block of size
>> 131,072 alloc'd
>> ==42050== at 0x1000183B1: malloc (vg_replace_malloc.c:303)
>> ==42050== by 0x10153B704: superlu_malloc_dist (memory.c:108)
>> ==42050== by 0x1014FD7AD: doubleMalloc_dist (dmemory.c:145)
>> ==42050== by 0x10151DA7D: pdgstrf (pdgstrf.c:735)
>> ==42050== Uninitialised value was created by a heap allocation
>> ==42050==
>> ==42048== Conditional jump or move depends on uninitialised value(s)
>> ==42048== at 0x10151F141: pdgstrf (pdgstrf.c:1139)
>> ==42048== by 0x1015019A5: pdgssvx (pdgssvx.c:1069)
>> ==42048== by 0x10150ABE2: ddist_psymbtonum (pdsymbfact_distdata.c:1332)
>> ==42048== by 0x1015018C2: pdgssvx (pdgssvx.c:1057)
>> ==42048==
>> ==42049== Conditional jump or move depends on uninitialised value(s)
>> ==42049== at 0x10151F141: pdgstrf (pdgstrf.c:1139)
>> ==42049== by 0x1015019A5: pdgssvx (pdgssvx.c:1069)
>> ==42049== by 0x10153B704: superlu_malloc_dist (memory.c:108)
>> ==42049== by 0x10150ABE2: ddist_psymbtonum (pdsymbfact_distdata.c:1332)
>> ==42049== by 0x1015018C2: pdgssvx (pdgssvx.c:1057)
>> ==42049==
>> ==42048== at 0x101520054: pdgstrf (pdgstrf.c:1429)
>> ==42049== at 0x101520054: pdgstrf (pdgstrf.c:1429)
>> ==42048==
>> ==42049==
>> ==42050== at 0x10151FDE6: pdgstrf (pdgstrf.c:1382)
>> ==42050== by 0x10150B241: ddist_psymbtonum (pdsymbfact_distdata.c:1389)
>> ==42050==
>> > On Jul 20, 2015, at 12:03 PM, Mahir.Ulker-Kaustell at tyrens.se wrote:
>> > Ok. So I have been creating the full factorization on each process.
>> That gives me some hope!
>> > I followed your suggestion and tried to use the runtime option
>> > However, now the program crashes with:
>> > And so on…
>> > From the SuperLU manual; I should give the option either YES or NO,
>> however -mat_superlu_dist_parsymbfact YES makes the program crash in the
>> same way as above.
>> > Also I can’t find any reference to -mat_superlu_dist_parsymbfact in the
>> PETSc documentation
>> > Mahir
>> Tyréns AB
>> > From: Xiaoye S. Li [mailto:xsli at lbl.gov]
>> > Sent: den 20 juli 2015 18:12
>> > Cc: Hong; petsc-users
>> > The default SuperLU_DIST setting is to serial symbolic factorization.
>> Therefore, what matters is how much memory do you have per MPI task?
>> > The code failed to malloc memory during redistribution of matrix A to
>> {L\U} data struction (using result of serial symbolic factorization.)
>> > You can use parallel symbolic factorization, by runtime option:
>> '-mat_superlu_dist_parsymbfact'
>> > Sherry Li
>> > On Mon, Jul 20, 2015 at 8:59 AM, Mahir.Ulker-Kaustell at tyrens.se <
>> > Hong:
>> > Previous experiences with this equation have shown that it is very
>> difficult to solve it iteratively. Hence the use of a direct solver.
>> > The large test problem I am trying to solve has slightly less than 10^6
>> degrees of freedom. The matrices are derived from finite elements so they
>> are sparse.
>> > The machine I am working on has 128GB ram. I have estimated the memory
>> needed to less than 20GB, so if the solver needs twice or even three times
>> as much, it should still work well. Or have I completely misunderstood
>> something here?
>> > Mahir
>> > From: Hong [mailto:hzhang at mcs.anl.gov]
>> > Sent: den 20 juli 2015 17:39
>> > Cc: petsc-users
>> > Mahir:
>> > Direct solvers consume large amount of memory. Suggest to try
>> followings:
>> > 1. A sparse iterative solver if [-omega^2M + K] is not too
>> ill-conditioned. You may test it using the small matrix.
>> > 2. Incrementally increase your matrix sizes. Try different matrix
>> orderings.
>> > Do you get memory crash in the 1st symbolic factorization?
>> > In your case, matrix data structure stays same when omega changes, so
>> you only need to do one matrix symbolic factorization and reuse it.
>> > 3. Use a machine that gives larger memory.
>> > Hong
>> > Dear Petsc-Users,
>> > I am trying to use PETSc to solve a set of linear equations arising
>> from Naviers equation (elastodynamics) in the frequency domain.
>> > The frequency dependency of the problem requires that the system
>> > [-omega^2M + K]u = F
>> > where M and K are constant, square, positive definite matrices (mass
>> and stiffness respectively) is solved for each frequency omega of interest.
>> > K is a complex matrix, including material damping.
>> > I have written a PETSc program which solves this problem for a small
>> (1000 degrees of freedom) test problem on one or several processors, but it
>> keeps crashing when I try it on my full scale (in the order of 10^6 degrees
>> of freedom) problem.
>> > The program crashes at KSPSetUp() and from what I can see in the error
>> messages, it appears as if it consumes too much memory.
>> > I would guess that similar problems have occurred in this mail-list, so
>> I am hoping that someone can push me in the right direction…
>> > Mahir
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150722/56294d7b/attachment-0001.html>
