[petsc-users] SuperLU MPI-problem
Mon Jul 20 11:05:01 CDT 2015
On Mon, Jul 20, 2015 at 10:59 AM, Mahir.Ulker-Kaustell at tyrens.se <
Mahir.Ulker-Kaustell at tyrens.se> wrote:
>  Hong:
> Previous experiences with this equation have shown that it is very
> difficult to solve it iteratively. Hence the use of a direct solver.
> The large test problem I am trying to solve has slightly less than 10^6
> degrees of freedom. The matrices are derived from finite elements so they
> are sparse.
Estimated how? It is very difficult to estimate flll-in.
  Matt
>  The machine I am working on has 128GB ram. I have estimated the memory
> needed to less than 20GB, so if the solver needs twice or even three times
> as much, it should still work well. Or have I completely misunderstood
> something here?
> Mahir
> *From:* Hong [mailto:hzhang at mcs.anl.gov]
> *Sent:* den 20 juli 2015 17:39
> *To:* Ülker-Kaustell, Mahir
> *Cc:* petsc-users
> *Subject:* Re: [petsc-users] SuperLU MPI-problem
> Mahir:
> Direct solvers consume large amount of memory. Suggest to try followings:
> 1. A sparse iterative solver if  [-omega^2M + K] is not too
> ill-conditioned. You may test it using the small matrix.
> 2. Incrementally increase your matrix sizes. Try different matrix
> orderings.
> Do you get memory crash in the 1st symbolic factorization?
> In your case, matrix data structure stays same when omega changes, so you
> only need to do one matrix symbolic factorization and reuse it.
> 3. Use a machine that gives larger memory.
> Hong
> Dear Petsc-Users,
> I am trying to use PETSc to solve a set of linear equations arising from
> Naviers equation (elastodynamics) in the frequency domain.
> The frequency dependency of the problem requires that the system
>                              [-omega^2M + K]u = F
> where M and K are constant, square, positive definite matrices (mass and
> stiffness respectively) is solved for each frequency omega of interest.
> K is a complex matrix, including material damping.
> I have written a PETSc program which solves this problem for a small (1000
> degrees of freedom) test problem on one or several processors, but it keeps
> crashing when I try it on my full scale (in the order of 10^6 degrees of
> freedom) problem.
> The program crashes at KSPSetUp() and from what I can see in the error
> messages, it appears as if it consumes too much memory.
> I would guess that similar problems have occurred in this mail-list, so I
> am hoping that someone can push  me in the right direction…
> Mahir
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150720/a669043b/attachment.html>
