[petsc-users] SuperLU MPI-problem
Mahir.Ulker-Kaustell at tyrens.se Mahir.Ulker-Kaustell at tyrens.se
Mon Jul 20 10:44:01 CDT 2015
Ah, of course. Here it is:
Malloc fails for Lnzval_bc_ptr[*][] at line 626 in file zdistribute.c
col block 797 col block 1518 Malloc fails for Lnzval_bc_ptr[*][] at line 626 in file zdistribute.c
col block 6369 -------------------------------------------------------
Primary job  terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] SuperLU_DIST:pzgssvx_ABglobal line 405 /packages/petsc-3.6.0/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[0]PETSC ERROR: [0] MatLUFactorNumeric_SuperLU_DIST line 282 /packages/petsc-3.6.0/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[0]PETSC ERROR: [0] MatLUFactorNumeric line 2937 /packages/petsc-3.6.0/src/mat/interface/matrix.c
[0]PETSC ERROR: [0] PCSetUp_LU line 99 /packages/petsc-3.6.0/src/ksp/pc/impls/factor/lu/lu.c
[0]PETSC ERROR: [0] PCSetUp line 944 /packages/petsc-3.6.0/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: [0] KSPSetUp line 247 /packages/petsc-3.6.0/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: User provided function() line 0 in  unknown file (null)
mpiexec detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
 Process name: [[40547,1],3]
  Exit code:    255
Mahir
Mahir Ülker-Kaustell, Kompetenssamordnare, Brokonstruktör, Tekn. Dr, Tyréns AB
010 452 30 82, Mahir.Ulker-Kaustell at tyrens.se
From: Matthew Knepley [mailto:knepley at gmail.com]
Sent: den 20 juli 2015 17:35
To: Ülker-Kaustell, Mahir
Cc: petsc-users
Subject: Re: [petsc-users] SuperLU MPI-problem
We cannot say anything without the full error message.
  Matt
On Mon, Jul 20, 2015 at 9:38 AM, Mahir.Ulker-Kaustell at tyrens.se<mailto:Mahir.Ulker-Kaustell at tyrens.se> <Mahir.Ulker-Kaustell at tyrens.se<mailto:Mahir.Ulker-Kaustell at tyrens.se>> wrote:
Dear Petsc-Users,
I am trying to use PETSc to solve a set of linear equations arising from Naviers equation (elastodynamics) in the frequency domain.
The frequency dependency of the problem requires that the system
                             [-omega^2M + K]u = F
where M and K are constant, square, positive definite matrices (mass and stiffness respectively) is solved for each frequency omega of interest.
K is a complex matrix, including material damping.
I have written a PETSc program which solves this problem for a small (1000 degrees of freedom) test problem on one or several processors, but it keeps crashing when I try it on my full scale (in the order of 10^6 degrees of freedom) problem.
The program crashes at KSPSetUp() and from what I can see in the error messages, it appears as if it consumes too much memory.
I would guess that similar problems have occurred in this mail-list, so I am hoping that someone can push  me in the right direction…
Mahir
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150720/e187d6e4/attachment.html>
