[petsc-users] KSP changes for successive solver
Michele Rosso mrosso at uci.edu
Sat Jul 18 21:53:13 CDT 2015
Barry,
I tried the master branch of PETSc as you suggested and unfortunately
the problem with KSP being set to GMRES on the coarse level when using
"-mg_coarse_ksp_type preonly"  is still there. I attached the output
from ksp view and the options stack.
Am I missing something?
Michele
On Thu, 2015-07-16 at 17:30 -0500, Barry Smith wrote:
>    Michel,
>     This is a very annoying feature that has been fixed in master http://www.mcs.anl.gov/petsc/developers/index.html  I would like to have changed it in maint but Jed would have a shit-fit :-) since it changes behavior.
>   Barry
> > On Jul 16, 2015, at 4:53 PM, Michele Rosso <mrosso at uci.edu> wrote:
> > Hi,
> > I am performing a series of solves inside a loop. The matrix for each solve changes but not enough to justify a rebuilt of the PC at each solve.
> > Therefore I am using  KSPSetReusePreconditioner to avoid rebuilding unless necessary. The solver is CG + MG with a custom  PC at the coarse level.
> > If KSP is not updated each time, everything works as it is supposed to.
> > When instead I allow the default PETSc  behavior, i.e. updating PC every time the matrix changes, the coarse level KSP , initially set to PREONLY, is changed into GMRES
> > after the first solve. I am not sure where the problem lies (my PC or PETSc), so I would like to have your opinion on this.
> > I attached the ksp_view for the 2 successive solve and the options stack.
> > Thanks for your help,
> > Michel
> > <ksp_view.txt><petsc_options.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150718/43610a8b/attachment.html>
KSP Object: 8 MPI processes
  type: cg
  maximum iterations=10000
  tolerances:  relative=1e-07, absolute=1e-50, divergence=10000
  left preconditioning
  using nonzero initial guess
  using UNPRECONDITIONED norm type for convergence test
PC Object: 8 MPI processes
  type: mg
    MG: type is MULTIPLICATIVE, levels=3 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_coarse_)     8 MPI processes
      type: gmres
        GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
        GMRES: happy breakdown tolerance 1e-30
      maximum iterations=1, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      using NONE norm type for convergence test
    PC Object:    (mg_coarse_)     8 MPI processes
      type: gamg
        MG: type is MULTIPLICATIVE, levels=2 cycles=v
          GAMG specific options
            Threshold for dropping small values from graph 0
            AGG specific options
              Symmetric graph false
        KSP Object:        (mg_coarse_mg_coarse_)         8 MPI processes
          type: gmres
        PC Object:        (mg_coarse_mg_coarse_)         8 MPI processes
          type: bjacobi
            block Jacobi: number of blocks = 8
            Local solve is same for all blocks, in the following KSP and PC objects:
          KSP Object:          (mg_coarse_mg_coarse_sub_)           1 MPI processes
            type: preonly
          PC Object:          (mg_coarse_mg_coarse_sub_)           1 MPI processes
            type: lu
              LU: out-of-place factorization
              tolerance for zero pivot 2.22045e-14
              using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
              matrix ordering: nd
              factor fill ratio given 5, needed 1.07143
                Factored matrix follows:
                  Mat Object:                   1 MPI processes
                    type: seqaij
                    rows=10, cols=10
                    package used to perform factorization: petsc
                    total: nonzeros=90, allocated nonzeros=90
                    total number of mallocs used during MatSetValues calls =0
                      using I-node routines: found 5 nodes, limit used is 5
            linear system matrix = precond matrix:
              type: seqaij
              rows=10, cols=10
              total: nonzeros=84, allocated nonzeros=84
                not using I-node routines
          Mat Object:           8 MPI processes
            type: mpiaij
            rows=10, cols=10
              not using I-node (on process 0) routines
      Down solver (pre-smoother) on level 1 -------------------------------
        KSP Object:        (mg_coarse_mg_levels_1_)         8 MPI processes
          type: chebyshev
            Chebyshev: eigenvalue estimates:  min = 0.152971, max = 1.68268
            Chebyshev: eigenvalues estimated using gmres with translations  [0 0.1; 0 1.1]
            KSP Object:            (mg_coarse_mg_levels_1_esteig_)             8 MPI processes
              type: gmres
          maximum iterations=2
        PC Object:        (mg_coarse_mg_levels_1_)         8 MPI processes
          type: sor
            SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
            type: mpiaij
            rows=64, cols=64
            total: nonzeros=352, allocated nonzeros=352
      Up solver (post-smoother) same as down solver (pre-smoother)
        type: mpiaij
        rows=64, cols=64
    KSP Object:    (mg_levels_1_)     8 MPI processes
      type: richardson
        Richardson: damping factor=1
    PC Object:    (mg_levels_1_)     8 MPI processes
      type: sor
        type: mpiaij
        rows=512, cols=512
        total: nonzeros=3200, allocated nonzeros=3200
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (mg_levels_2_)     8 MPI processes
      type: richardson
    PC Object:    (mg_levels_2_)     8 MPI processes
      type: sor
        type: mpiaij
        rows=4096, cols=4096
        total: nonzeros=27136, allocated nonzeros=27136
    type: mpiaij
-ksp_type        cg
-ksp_norm_type   unpreconditioned
-ksp_rtol        1e-7
-options_left
-ksp_initial_guess_nonzero  yes
-pc_type mg
-pc_mg_galerkin
-pc_mg_levels 3
-mg_levels_ksp_type richardson
#-mg_levels_ksp_max_it 1
-mg_coarse_pc_type gamg
#-mg_coarse_mg_coarse_ksp_type preonly
#-mg_coarse_mg_coarse_ksp_type chebyshev
#-mg_coarse_mg_coarse_pc_type lu
-ksp_view
