[petsc-users] KSP changes for successive solver
Michele Rosso mrosso at uci.edu
Thu Jul 16 19:18:57 CDT 2015
Barry,
thank you very much for the detailed answer.  I tried what you suggested
and it works.
So far I tried on a small system but the final goal is to use it for
very large runs.  How does  PCGAMG compares to PCMG  as far as
performances and scalability are concerned?
Also, could you help me to tune the GAMG part ( my current setup is in
the attached ksp_view.txt file )?
I also tried to use superlu_dist for the LU decomposition on
mg_coarse_mg_sub_
-mg_coarse_mg_coarse_sub_pc_type lu
-mg_coarse_mg_coarse_sub_pc_factor_mat_solver_package superlu_dist
but I got an error:
****** Error in MC64A/AD. INFO(1) = -2
symbfact() error returns 0
Thank you,
Michele
On Thu, 2015-07-16 at 18:07 -0500, Barry Smith wrote:
> > On Jul 16, 2015, at 5:42 PM, Michele Rosso <mrosso at uci.edu> wrote:
> > Barry,
> > thanks for your reply. So if I want it fixed, I will have to use the master branch, correct?
>   Yes, or edit mg.c and remove the offending lines of code (easy enough).
> > On a side note, what I am trying to achieve is to be able to use how many levels of MG I want, despite the limitation imposed by the local number of grid nodes.
>    I assume you are talking about with DMDA? There is no generic limitation for PETSc's multigrid, it is only with the way the DMDA code figures out the interpolation that causes a restriction.
> > So far I am using a borrowed code that implements a PC that creates a sub communicator and perform MG on it.
> > While reading the documentation I found out that PCMGSetLevels takes in an optional array of communicators. How does this work?
>    It doesn't work. It was an idea that never got pursued.
> > Can I can simply define my matrix and rhs on the fine grid as I would do normally ( I do not use kspsetoperators and kspsetrhs ) and KSP would take care of it by using the correct communicator for each level?
>    No.
>    You can use the PCMG geometric multigrid with DMDA for as many levels as it works and then use PCGAMG as the coarse grid solver. PCGAMG automatically uses fewer processes for the coarse level matrices and vectors. You could do this all from the command line without writing code.
>    For example if your code uses a DMDA and calls KSPSetDM() use for example -da_refine 3 -pc_type mg -pc_mg_galerkin -mg_coarse_pc_type gamg  -ksp_view
>   Barry
> > Thanks,
> > Michele
> > On Thu, 2015-07-16 at 17:30 -0500, Barry Smith wrote:
> >>    Michel,
> >>     This is a very annoying feature that has been fixed in master
> >> http://www.mcs.anl.gov/petsc/developers/index.html
> >>   I would like to have changed it in maint but Jed would have a shit-fit :-) since it changes behavior.
> >>   Barry
> >> > On Jul 16, 2015, at 4:53 PM, Michele Rosso <mrosso at uci.edu> wrote:
> >> > Hi,
> >> > I am performing a series of solves inside a loop. The matrix for each solve changes but not enough to justify a rebuilt of the PC at each solve.
> >> > Therefore I am using  KSPSetReusePreconditioner to avoid rebuilding unless necessary. The solver is CG + MG with a custom  PC at the coarse level.
> >> > If KSP is not updated each time, everything works as it is supposed to.
> >> > When instead I allow the default PETSc  behavior, i.e. updating PC every time the matrix changes, the coarse level KSP , initially set to PREONLY, is changed into GMRES
> >> > after the first solve. I am not sure where the problem lies (my PC or PETSc), so I would like to have your opinion on this.
> >> > I attached the ksp_view for the 2 successive solve and the options stack.
> >> > Thanks for your help,
> >> > Michel
> >> > <ksp_view.txt><petsc_options.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150716/4353f29d/attachment-0001.html>
Linear solve converged due to CONVERGED_RTOL iterations 13
KSP Object: 8 MPI processes
  type: cg
  maximum iterations=10000
  tolerances:  relative=1e-07, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using nonzero initial guess
  using UNPRECONDITIONED norm type for convergence test
PC Object: 8 MPI processes
  type: mg
    MG: type is MULTIPLICATIVE, levels=3 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (mg_coarse_)     8 MPI processes
      type: preonly
      maximum iterations=1, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      using NONE norm type for convergence test
    PC Object:    (mg_coarse_)     8 MPI processes
      type: gamg
        MG: type is MULTIPLICATIVE, levels=2 cycles=v
        KSP Object:        (mg_coarse_mg_coarse_)         8 MPI processes
          type: preonly
        PC Object:        (mg_coarse_mg_coarse_)         8 MPI processes
          type: bjacobi
            block Jacobi: number of blocks = 8
            Local solve is same for all blocks, in the following KSP and PC objects:
          KSP Object:          (mg_coarse_mg_coarse_sub_)           1 MPI processes
            type: preonly
          PC Object:          (mg_coarse_mg_coarse_sub_)           1 MPI processes
            type: lu
              LU: out-of-place factorization
              tolerance for zero pivot 2.22045e-14
              using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
              matrix ordering: nd
              factor fill ratio given 5, needed 2.9459
                Factored matrix follows:
                  Mat Object:                   1 MPI processes
                    type: seqaij
                    rows=119, cols=119
                    package used to perform factorization: petsc
                    total: nonzeros=7079, allocated nonzeros=7079
                    total number of mallocs used during MatSetValues calls =0
                      not using I-node routines
            linear system matrix = precond matrix:
              type: seqaij
              rows=119, cols=119
              total: nonzeros=2403, allocated nonzeros=2403
          Mat Object:           8 MPI processes
            type: mpiaij
            rows=119, cols=119
              not using I-node (on process 0) routines
      Down solver (pre-smoother) on level 1 -------------------------------
        KSP Object:        (mg_coarse_mg_levels_1_)         8 MPI processes
          type: richardson
            Richardson: damping factor=1
          maximum iterations=2
        PC Object:        (mg_coarse_mg_levels_1_)         8 MPI processes
          type: sor
            SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
            type: mpiaij
            rows=1024, cols=1024
            total: nonzeros=6528, allocated nonzeros=6528
      Up solver (post-smoother) same as down solver (pre-smoother)
        type: mpiaij
    KSP Object:    (mg_levels_1_)     8 MPI processes
      type: richardson
    PC Object:    (mg_levels_1_)     8 MPI processes
      type: sor
        type: mpiaij
        rows=8192, cols=8192
        total: nonzeros=54784, allocated nonzeros=54784
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (mg_levels_2_)     8 MPI processes
      type: richardson
    PC Object:    (mg_levels_2_)     8 MPI processes
      type: sor
        type: mpiaij
        rows=65536, cols=65536
        total: nonzeros=448512, allocated nonzeros=448512
    type: mpiaij
Linear solve converged due to CONVERGED_RTOL iterations 7
  type: cg
  type: mg
      type: preonly
      type: gamg
          type: preonly
          type: bjacobi
            type: preonly
            type: lu
              matrix ordering: nd
                    type: seqaij
                    rows=119, cols=119
              type: seqaij
              rows=119, cols=119
            type: mpiaij
            rows=119, cols=119
          type: richardson
          type: sor
            type: mpiaij
        type: mpiaij
      type: richardson
      type: sor
        type: mpiaij
      type: richardson
      type: sor
        type: mpiaij
    type: mpiaij
#PETSc Option Table entries:
-ksp_converged_reason
-ksp_initial_guess_nonzero yes
-ksp_norm_type unpreconditioned
-ksp_rtol 1e-7
-ksp_type cg
-ksp_view
-max_tsteps 1
-mg_coarse_ksp_type preonly
-mg_coarse_mg_levels_ksp_type richardson
-mg_levels_ksp_type richardson
-nout 1
-options_left
-pc_mg_galerkin
-pc_mg_levels 3
-pc_type mg
#End of PETSc Option Table entries
There are 2 unused database options. They are:
Option left: name:-max_tsteps value: 1
Option left: name:-nout value: 1
