[petsc-users] DM and HDF5 Viewer
Matthew Knepley
knepley at gmail.com
Thu Jul 16 13:35:23 CDT 2015
On Thu, Jul 16, 2015 at 1:31 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Jul 16, 2015, at 11:14 AM, Jed Brown <jed at jedbrown.org> wrote:
> > Gianluca Meneghello <gianmail at gmail.com> writes:
> >> Hi again,
> >> I am now trying to write a vector to an HDF5, this time using a DM
> >> structure to impose the vector layout.
> >> Creating the vector with (as in src/dm/examples/tutorials/ex10.c)
> >> DMCreateGlobalVector(da2D,&gauss);
> >> every works fine, i.e. the hdf5 file has the correct layout given by the
> >> dimension of the DM. On the other side, if I use:
> >> VecCreate(PETSC_COMM_WORLD,&gauss);
> >> VecSetSizes(gauss,PETSC_DECIDE,Nx*Ny);
> >> VecSetDM(gauss,da2D);
> > VecSetDM only associates a DM with the Vec. It does not interpose
> > itself into VecView.
> > Should we change this so that creating a Vec of the correct size/block
> > size/layout and associating a DM is equivalent? Perhaps, but it's more
> > nuanced than it might seem.
> Yikes. VecSetDM() seems a very dangerous and odd thing. Should it exist?
> If it exists it seems it should be exactly equivalent to creating the
> vector from the DM.
I tend to disagree. It is used to set a member variable which is not
exposed:
find src -name "*.c" | xargs grep VecSetDM
src/dm/impls/composite/pack.c: ierr = VecSetDM(*gvec, dm);CHKERRQ(ierr);
src/dm/impls/composite/pack.c: ierr = VecSetDM(*lvec, dm);CHKERRQ(ierr);
src/dm/impls/da/dadist.c: ierr = VecSetDM(*g, da);CHKERRQ(ierr);
src/dm/impls/da/dalocal.c: ierr = VecSetDM(*g, da);CHKERRQ(ierr);
src/dm/impls/network/networkcreate.c: ierr =
VecSetDM(*vec,dm);CHKERRQ(ierr);
src/dm/impls/redundant/dmredundant.c: ierr =
VecSetDM(*gvec,dm);CHKERRQ(ierr);
VecSetDM(*lvec,dm);CHKERRQ(ierr);
src/dm/impls/shell/dmshell.c: ierr = VecSetDM(*gvec,dm);CHKERRQ(ierr);
src/dm/impls/sliced/sliced.c: ierr = VecSetDM(*gvec,dm);CHKERRQ(ierr);
src/dm/interface/dmi.c: ierr = VecSetDM(*vec, dm);CHKERRQ(ierr);
src/dm/interface/ftn-auto/dmf.c:*__ierr = VecSetDM(
I don't like putting in a bunch of side-effects. Those come from actually
being created from a DM, which is correct.
Matt
> > Why don't you want to just call DMCreateGlobalVector()?
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150716/1cdd9bf7/attachment-0001.html>
