[petsc-users] Fwd: same petsc problem
Mark Adams mfadams at lbl.gov
Mon Jul 13 13:54:25 CDT 2015
Greg, I am forwarding this to the PETSc mailing list.
Please send the entire output from this run.  As I recall you were getting
a message that all values were not the same on all processors in GMRES.  I
have seen this when I get NaNs in the system.
While you are doing this you should use a simple solver like change:
-pressure_pc_type gamg
to
-pressure_pc_type jacobi
And add:
*-*pressure_*ksp_monitor_true_residual*
---------- Forwarded message ----------
Date: Mon, Jul 13, 2015 at 2:08 PM
Subject: same petsc problem
To: Mark Adams <mfadams at lbl.gov>
Cc: David Trebotich <treb at hpcrd.lbl.gov>
Hi Mark.  I'm still stuck on the same petsc problem.   Would you please try
the attached minimal example and advise me?
I'm running this without MPI:
make DIM=2 DEBUG=TRUE MPI=FALSE USE_PETSC=TRUE test
There is no input file.
Thank you,
Greg
Greg Miller
Department of Chemical Engineering and Materials Science
University of California, Davis
One Shields Avenue
Davis, CA 95616
grgmiller at ucdavis.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150713/9ddeca45/attachment-0001.html>
makefiles+=test
ebase = test
CHOMBO_HOME = ../Chombo/lib
LibNames := EBAMRTimeDependent EBAMRElliptic  EBAMRTools Workshop EBTools AMRTimeDependent AMRElliptic AMRTools BoxTools
base_dir = .
src_dirs =
#$(CHOMBO_HOME)/../releasedExamples/EBAMRINS/srcLib
include $(CHOMBO_HOME)/mk/Make.example
# valgrind --leak-check=full
# mpiexec -n 4 valgrind -v --leak-check=full --track-origins=yes --log-file=valgrind.foo
#-help
#-proj_mac_pc_mg_type full
#-proj_mac_pc_mg_cycle_type w
#-proj_mac_pc_type hypre
-proj_mac_pc_type gamg
-proj_mac_pc_gamg_sym_graph true
-proj_mac_pc_gamg_square_graph true
-proj_mac_pc_gamg_type agg
-proj_mac_pc_gamg_repartition false
-proj_mac_pc_gamg_process_eq_limit 100
-proj_mac_pc_gamg_coarse_eq_limit 1000
-proj_mac_pc_gamg_agg_nsmooths 1
-proj_mac_pc_gamg_threshold -.01
#-proj_mac_pc_gamg_verbose 2
#-proj_mac_pc_mg_log
#-proj_mac_pc_gamg_use_agg_gasm true
#-gamg_est_ksp_view
#-gamg_est_ksp_max_it 10
#-gamg_est_ksp_type gmres
#-gamg_est_ksp_gmres_restart 50
-proj_mac_pc_hypre_type boomeramg
-proj_mac_pc_hypre_boomeramg_no_CF
-proj_mac_pc_hypre_boomeramg_agg_nl 1
-proj_mac_pc_hypre_boomeramg_coarsen_type HMIS
-proj_mac_pc_hypre_boomeramg_interp_type ext+i
#-proj_mac_pc_hypre_boomeramg_P_max 4
#-proj_mac_pc_hypre_boomeramg_agg_num_paths 2
#-proj_mac_pc_hypre_boomeramg_print_statistics
#-proj_mac_pc_hypre_boomeramg_relax_type_coarse symmetric-SOR/Jacobi
#-proj_mac_pc_hypre_boomeramg_grid_sweeps_coarse 4
-proj_mac_pc_ml_Threshold 0.01
-proj_mac_pc_ml_EnergyMinimization 2
-proj_mac_pc_ml_PrintLevel 1
-proj_mac_ksp_type gmres
#-proj_mac_ksp_gmres_restart 50
-proj_mac_ksp_max_it 50
#-proj_mac_mg_levels_ksp_type chebyshev
-proj_mac_mg_levels_ksp_type richardson
#-proj_mac_mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.1,0,1.1
-proj_mac_mg_levels_pc_type sor
-proj_mac_ksp_rtol 1.e-6
-proj_mac_ksp_atol 1.e-30
-proj_mac_mg_levels_ksp_max_it 2
#-mat_ascii_output_large
-options_left
#-mat_view_matlab
#-log_summary
#-info
-visc_ksp_rtol 1.e-6
-visc_pc_type jacobi
-visc_pc_hypre_type boomeramg
-visc_pc_hypre_boomeramg_no CF
-visc_pc_hypre_boomeramg_agg_nl 1
-visc_pc_hypre_boomeramg_coarsen_type HMIS
-visc_pc_hypre_boomeramg_interp_type ext+i
-visc_ksp_type gmres
-visc_ksp_max_it 50
-diff_ksp_rtol 1.e-6
-diff_pc_type jacobi
-diff_ksp_max_it 50
#-ksp_view
#-visc_ksp_view
#-diff_ksp_view
#-proj_mac_ksp_view
#-proj_mac_ksp_monitor
#-proj_mac_ksp_monitor_max
#-visc_ksp_monitor_max
#-proj_mac_ksp_converged_reason
#-visc_ksp_converged_reason
#-diff_ksp_converged_reason
-proj_mac_ksp_norm_type unpreconditioned
-diff_ksp_norm_type unpreconditioned
-visc_ksp_norm_type unpreconditioned
#-proj_mac_ksp_converged_use_initial_residual_norm
-pressure_pc_gamg_sym_graph true
-pressure_pc_gamg_square_graph true
-pressure_pc_gamg_type agg
-pressure_pc_gamg_repartition false
-pressure_pc_gamg_process_eq_limit 100
-pressure_pc_gamg_coarse_eq_limit 1000
-pressure_pc_gamg_agg_nsmooths 1
-pressure_pc_gamg_threshold -.01
-pressure_ksp_type gmres
-pressure_ksp_gmres_restart 50
-pressure_ksp_max_it 50
-pressure_ksp_rtol 1.e-12
-pressure_ksp_atol 1.e-30
-pressure_ksp_norm_type unpreconditioned
-pressure_mg_levels_pc_type sor
-pressure_mg_levels_ksp_max_it 4
-pressure_ksp_converged_reason
-pressure_ksp_monitor
-pressure_backup_pc_type gamg
-pressure_backup_pc_gamg_sym_graph true
-pressure_backup_pc_gamg_square_graph true
-pressure_backup_pc_gamg_type agg
-pressure_backup_pc_gamg_repartition false
-pressure_backup_pc_gamg_process_eq_limit 100
-pressure_backup_pc_gamg_coarse_eq_limit 1000
-pressure_backup_pc_gamg_agg_nsmooths 1
-pressure_backup_pc_gamg_threshold 0.05
-pressure_backup_ksp_type gmres
-pressure_backup_ksp_gmres_restart 50
-pressure_backup_ksp_max_it 200
-pressure_backup_ksp_rtol 1.e-12
-pressure_backup_ksp_atol 1.e-30
-pressure_backup_ksp_norm_type unpreconditioned
-pressure_backup_mg_levels_pc_type sor
-pressure_backup_mg_levels_ksp_max_it 4
-pressure_backup_ksp_converged_reason
-pressure_backup_ksp_monitor
-viscous_pc_type gamg
-viscous_pc_gamg_sym_graph true
-viscous_pc_gamg_square_graph true
-viscous_pc_gamg_type agg
-viscous_pc_gamg_repartition false
-viscous_pc_gamg_process_eq_limit 100
-viscous_pc_gamg_coarse_eq_limit 1000
-viscous_pc_gamg_agg_nsmooths 1
-viscous_pc_gamg_threshold 0.05
-viscous_ksp_type gmres
-viscous_ksp_gmres_restart 50
-viscous_ksp_max_it 50
-viscous_ksp_rtol 1.e-12
-viscous_ksp_atol 1.e-30
-viscous_ksp_norm_type unpreconditioned
-viscous_mg_levels_pc_type sor
-viscous_mg_levels_ksp_max_it 4
-viscous_ksp_converged_reason
-viscous_ksp_monitor
-viscous_backup_pc_type sor
#-viscous_backup_pc_gamg_verbose 2
#-viscous_backup_mg_levels_ksp_type chebyshev
#-viscous_backup_pc_type gamg
#-viscous_backup_pc_gamg_sym_graph true
#-viscous_backup_pc_gamg_square_graph true
#-viscous_backup_pc_gamg_type agg
#-viscous_backup_pc_gamg_repartition false
#-viscous_backup_pc_gamg_process_eq_limit 100
#-viscous_backup_pc_gamg_coarse_eq_limit 1000
#-viscous_backup_pc_gamg_agg_nsmooths 1
#-viscous_backup_pc_gamg_threshold 0.05
-viscous_backup_ksp_view
-viscous_backup_ksp_type gmres
-viscous_backup_ksp_gmres_restart 100
-viscous_backup_ksp_max_it 1000
-viscous_backup_ksp_rtol 1.e-12
-viscous_backup_ksp_atol 1.e-30
#-viscous_backup_ksp_norm_type unpreconditioned
#-viscous_backup_mg_levels_pc_type sor
#-viscous_backup_mg_levels_ksp_max_it 4
-viscous_backup_ksp_converged_reason
-viscous_backup_ksp_monitor
-log_summary
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150713/9ddeca45/attachment-0001.cpp>
