[petsc-users] Petsc with Elemental installation in Cray
venkatesh g venkateshgk.j at gmail.com
Mon Jul 13 10:35:06 CDT 2015
sorry, I have attached the configure.log
Venkatesh
On Mon, Jul 13, 2015 at 5:24 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Jul 13, 2015 at 1:30 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
>> Hi, when I use --with-cxx-dialect=C++11, I get the error
>> Could not determine compiler flag for with-cxx-dialect=C++11, use CXXFLAGS
> Always always always send configure.log or we have no idea what happened.
>    Matt
>> Kindly let me know the syntax or how to enable this.
>> w.r.t --with-mpi-dir on Crays, I will keep it in mind and will not pass
>> them as you have told Barry, they locate it automatically.
>> Thank you
>> Venkatesh
>> On Sun, Jul 12, 2015 at 5:31 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sun, Jul 12, 2015 at 6:52 AM, venkatesh g <venkateshgk.j at gmail.com>
>>> wrote:
>>>> Hi all,
>>>> I am trying to install elemental with Petsc.
>>>> I configure using:
>>>> ./configure --with-cc=gcc --with-cxx=g++
>>>> PETSC_ARCH=linux-intel_elemental
>>>> -with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/
>>>> --with-mpi-dir=/opt/cray/mpt/7.0.5/gni/mpich2-intel/140
>>>> --with-scalar-type=complex --with-fortran-kernels=1
>>>> -known-mpi-shared-libraries=0 --with-large-file-io=1
>>>> --with-64-bit-indices=0 --with-batch FC=ifort
>>>> --with-valgrind-dir=/mnt/lustre/esd2/esdveng/valgrind
>>>> --download-elemental=/home/proj/14/esdveng/apps/Elemental-0.84-p5.tgz
>>>> --download-cmake=/home/proj/14/esdveng/apps/cmake-2.8.12.2.tar.gz
>>>> I get this error:
>>>> Cannot use elemental without enabling C++11, see
>>>> Pls let me know what flag must I use and its syntax.
>>> Did you try using --with-cxx-dialect=C++11 on configure?
>>>   Thanks,
>>>     Matt
>>>> Venkatesh
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150713/11e04bd1/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150713/11e04bd1/attachment-0001.obj>
