[petsc-users] Petsc with Elemental installation in Cray
venkatesh g venkateshgk.j at gmail.com
Mon Jul 13 01:30:41 CDT 2015
Hi, when I use --with-cxx-dialect=C++11, I get the error
Could not determine compiler flag for with-cxx-dialect=C++11, use CXXFLAGS
Kindly let me know the syntax or how to enable this.
w.r.t --with-mpi-dir on Crays, I will keep it in mind and will not pass
them as you have told Barry, they locate it automatically.
Thank you
Venkatesh
On Sun, Jul 12, 2015 at 5:31 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Jul 12, 2015 at 6:52 AM, venkatesh g <venkateshgk.j at gmail.com>
> wrote:
>> Hi all,
>> I am trying to install elemental with Petsc.
>> I configure using:
>> ./configure --with-cc=gcc --with-cxx=g++ PETSC_ARCH=linux-intel_elemental
>> -with-blas-lapack-dir=/opt/intel/composer_xe_2015.1.133/mkl/lib/intel64/
>> --with-mpi-dir=/opt/cray/mpt/7.0.5/gni/mpich2-intel/140
>> --with-scalar-type=complex --with-fortran-kernels=1
>> -known-mpi-shared-libraries=0 --with-large-file-io=1
>> --with-64-bit-indices=0 --with-batch FC=ifort
>> --with-valgrind-dir=/mnt/lustre/esd2/esdveng/valgrind
>> --download-elemental=/home/proj/14/esdveng/apps/Elemental-0.84-p5.tgz
>> --download-cmake=/home/proj/14/esdveng/apps/cmake-2.8.12.2.tar.gz
>> I get this error:
>> Cannot use elemental without enabling C++11, see --with-cxx-dialect=C++11
>> Pls let me know what flag must I use and its syntax.
> Did you try using --with-cxx-dialect=C++11 on configure?
>   Thanks,
>     Matt
>> Venkatesh
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150713/16f6a243/attachment.html>
