[petsc-users] Hypre 2.10 lapack undefined symbols (OS-X)
Denis Davydov
davydden at gmail.com
Sun Jul 12 04:26:22 CDT 2015
Hi Matthew,
> On 12 Jul 2015, at 10:54, Matthew Knepley <knepley at gmail.com> wrote:
> I have Lapack-related undefined symbols errors when trying to run tests on Hypre, configured and compiled by PETSc
> (./configure --download-superlu_dist --download-metis --download-parmetis --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --with-debugging=0 --download-hypre).
> Any ideas what’s happening?
> We need configure.log. This certainly sounds like a problem from mixing builds. Had you had unsuccessfu
please, find it attached.
> builds in this directory before? I would recommend wiping out the $PETSC_ARCH directory completely in
no.
> these cases.
wiped, reconfigured, but the problem is still there.
p.s. I submitted a pull request for homebrew-science (os-x): https://github.com/Homebrew/homebrew-science/pull/2511
and Hypre 2.10 compiles and runs 'make check' and 'make test' fine.
The configure line is different from the one PETSc uses (blas and lapack libs are specified here):
./configure
--prefix=/usr/local/Cellar/hypre/2.10.0b
--with-blas=yes
--with-blas-libs=blas cblas
--with-blas-lib-dirs=/usr/lib
--with-lapack=yes
--with-lapack-libs=lapack clapack f77lapack
--with-lapack-lib-dirs=/usr/lib
--without-superlu
--without-fei
--without-mli
--with-MPI
--with-MPI-include=/usr/local/include
--with-MPI-lib-dirs=/usr/local/lib
--with-MPI-libs=mpi
Denis.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150712/b88cac89/attachment-0002.html>
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150712/b88cac89/attachment-0001.zip>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150712/b88cac89/attachment-0003.html>
