[petsc-users] Problem with ksp view
    Michele Rosso
    mrosso at uci.edu
    Fri Jul 10 13:14:19 CDT 2015
I am having a problem with KSPview. If I use the command line option,
the output of KSPView is complete. If instead I call KSPView after
KSPsolve and I have the ksp infos printed on  file, the output misses
some
parts (see attached files).
What can I do to fix this?
Michele
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150710/23548389/attachment.html>
      KSP Object:      (mg_coarse_dmdarepart_)       4 MPI processes
        type: richardson
          Richardson: damping factor=1
        maximum iterations=10000, initial guess is zero
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
        left preconditioning
        has attached null space
        using PRECONDITIONED norm type for convergence test
      PC Object:      (mg_coarse_dmdarepart_)       4 MPI processes
        type: mg
          MG: type is MULTIPLICATIVE, levels=2 cycles=v
            Cycles per PCApply=1
            Using Galerkin computed coarse grid matrices
        Coarse grid solver -- level -------------------------------
          KSP Object:          (mg_coarse_dmdarepart_mg_coarse_)           4 MPI processes
            type: preonly
            maximum iterations=1, initial guess is zero
       linear system matrix = precond matrix:
      Mat Object:       8 MPI processes
        type: mpiaij
        rows=64, cols=64
        total: nonzeros=352, allocated nonzeros=352
        total number of mallocs used during MatSetValues calls =0
          not using I-node (on process 0) routines
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (mg_levels_1_)     8 MPI processes
      type: richardson
      using nonzero initial guess
      using NONE norm type for convergence test
    PC Object:    (mg_levels_1_)     8 MPI processes
      type: sor
        SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
        type: mpiaij
        rows=512, cols=512
        total: nonzeros=3200, allocated nonzeros=3200
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (mg_levels_2_)     8 MPI processes
      type: richardson
    PC Object:    (mg_levels_2_)     8 MPI processes
      type: sor
        type: mpiaij
        rows=4096, cols=4096
        total: nonzeros=27136, allocated nonzeros=27136
    type: mpiaij
            Mat Object:             4 MPI processes
              type: mpiaij
              rows=64, cols=64
          type: mpiaij
          rows=64, cols=64
KSP Object: 8 MPI processes
  type: cg
  tolerances:  relative=1e-09, absolute=1e-50, divergence=10000
  using UNPRECONDITIONED norm type for convergence test
PC Object: 8 MPI processes
  type: mg
    MG: type is MULTIPLICATIVE, levels=3 cycles=v
    KSP Object:    (mg_coarse_)     8 MPI processes
      type: preonly
    PC Object:    (mg_coarse_)     8 MPI processes
      type: dmdarepart
        DMDARepart: parent comm size reduction factor = 2
        DMDARepart: subcomm_size = 4
        type: richardson
        type: mg
            type: preonly
          PC Object:          (mg_coarse_dmdarepart_mg_coarse_)           4 MPI processes
            type: lu
              LU: out-of-place factorization
              tolerance for zero pivot 2.22045e-14
              matrix ordering: natural
              factor fill ratio given 0, needed 0
                Factored matrix follows:
                    type: mpiaij
                    rows=8, cols=8
                    package used to perform factorization: superlu_dist
                    total: nonzeros=0, allocated nonzeros=0
                      SuperLU_DIST run parameters:
                        Process grid nprow 2 x npcol 2
                        Equilibrate matrix TRUE
                        Matrix input mode 1
                        Replace tiny pivots TRUE
                        Use iterative refinement FALSE
                        Processors in row 2 col partition 2
                        Row permutation LargeDiag
                        Column permutation METIS_AT_PLUS_A
                        Parallel symbolic factorization FALSE
                        Repeated factorization SamePattern_SameRowPerm
              type: mpiaij
              rows=8, cols=8
              total: nonzeros=32, allocated nonzeros=32
                using I-node (on process 0) routines: found 1 nodes, limit used is 5
          KSP Object:          (mg_coarse_dmdarepart_mg_levels_1_)           4 MPI processes
            type: richardson
            maximum iterations=2
          PC Object:          (mg_coarse_dmdarepart_mg_levels_1_)           4 MPI processes
            type: sor
              type: mpiaij
              rows=64, cols=64
          type: mpiaij
          rows=64, cols=64
        type: mpiaij
        rows=64, cols=64
      type: richardson
      type: sor
        type: mpiaij
        rows=512, cols=512
      type: richardson
      type: sor
        type: mpiaij
    type: mpiaij
  type: cg
  type: mg
      type: preonly
      type: dmdarepart
        type: richardson
        type: mg
            type: preonly
            type: lu
                    type: mpiaij
                    rows=8, cols=8
                        Matrix input mode 1
              type: mpiaij
              rows=8, cols=8
            type: richardson
            type: sor
              type: mpiaij
              rows=64, cols=64
          type: mpiaij
          rows=64, cols=64
        type: mpiaij
        rows=64, cols=64
      type: richardson
      type: sor
        type: mpiaij
        rows=512, cols=512
      type: richardson
      type: sor
        type: mpiaij
    type: mpiaij
