[petsc-users] Vector form of TS solvers
Chris Bradley c.bradley at auckland.ac.nz
Wed Jul 8 18:25:02 CDT 2015
Dear PETSc,
I was wondering if you had any advice for using PETSc TS solvers to
solve a vector of ODEs. PETSc TS solvers solve DAEs of the form
f(t,u,u^dot,a) = g(u,t) = 0 (for my case)
where f is a user provided function, u is a vector of state variables,
u^dot a vector of the derivatives of state variables and a is a vector
of parameters (passed through the context).
I need to solve a large number of these DAEs (one for every node in a
bigger finite element problem). Is there a vector form of the TS solvers
that can solve
F(t,U,U^dot) = G(U,t) = 0
where F is now a vector, U is a matrix of state variables and U^dot is a
matrix of the derivatives of U. Each row of the system corresponds to
the standard PETSc TS problem above and is independent of every other row.
If I understand the TS manual correctly then if I wanted to do this in
PETSc I would have to create a TS object and state and derivative
vectors objects for each row? All these PETSc objects for each row would
seem like a big overhead if there was a very large number of rows
(potentially tens of millions for my problem).
Thanks for your help
Chris
Chris Bradley
Auckland Bioengineering Institute,
University of Auckland,
Private Bag 92019,
New Zealand.
Tel: +64 9 373 7599 xtn 89924
Fax: +64 9 367 7157
