[petsc-users] Can't expand MemType 1: jcol 16104
Anthony Haas aph at email.arizona.edu
Mon Jul 6 19:33:49 CDT 2015
I am computing eigenvalues using PETSc/SLEPc and superlu_dist for the LU
decomposition (my problem is a generalized eigenvalue problem). The code
runs fine for a grid with 101x101 but when I increase to 151x151, I get
the following error:
Can't expand MemType 1: jcol 16104   (and then [NID 00037] 2015-07-06
19:19:17 Apid 31025976: OOM killer terminated this process.)
It seems to be a memory problem. I monitor the memory usage as far as I
can and it seems that memory usage is pretty low. The most memory
intensive part of the program is probably the LU decomposition in the
context of the generalized EVP. Is there a way to evaluate how much
memory will be required for that step? I am currently running the debug
version of the code which I would assume would use more memory?
I have attached the output of the job. Note that the program uses twice
PETSc: 1) to solve a linear system for which no problem occurs, and, 2)
to solve the Generalized EVP with SLEPc, where I get the error.
Thanks
Anthony
3D POISEUILLE BASEFLOW COMPUTED ON GRID WITH NX =151 NY =151
Time for build and assembly of baseflow operator =          4.4083 seconds.
Time for Matrix summation =          0.0440 seconds.
.. Starting with 1 OpenMP threads
[0] .. BIG U size 498688
[0] .. BIG V size 131072
  Max row size is 487
  Using buffer_size of 5000000
  Threads per process 1
Time in scattering 0.000000
Time in dgemm 0.000000
Total time spent in schur update is    		: 39.52 seconds,
Total Time in Factorization            		: 76.72 seconds,
Time (other GEMM and Scatter)          		: 76.72 seconds,
Total time spent in schur update when offload    		:  0.00 seconds,
KSP Object: 640 MPI processes
  type: preonly
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-10, absolute=1e-10, divergence=10000
  left preconditioning
  using NONE norm type for convergence test
PC Object: 640 MPI processes
  type: lu
    LU: out-of-place factorization
    tolerance for zero pivot 2.22045e-14
    matrix ordering: natural
    factor fill ratio given 0, needed 0
      Factored matrix follows:
        Mat Object:         640 MPI processes
          type: mpiaij
          rows=22201, cols=22201
          package used to perform factorization: superlu_dist
          total: nonzeros=0, allocated nonzeros=0
          total number of mallocs used during MatSetValues calls =0
            SuperLU_DIST run parameters:
              Process grid nprow 32 x npcol 20
              Equilibrate matrix TRUE
              Matrix input mode 1
              Replace tiny pivots TRUE
              Use iterative refinement FALSE
              Processors in row 32 col partition 20
              Row permutation LargeDiag
              Column permutation METIS_AT_PLUS_A
              Parallel symbolic factorization FALSE
              Repeated factorization SamePattern_SameRowPerm
  linear system matrix = precond matrix:
    type: mpiaij
    total: nonzeros=6.5937e+06, allocated nonzeros=6.5937e+06
      using I-node (on process 0) routines: found 7 nodes, limit used is 5
Summary of Memory Usage in PETSc
[0]Current space PetscMalloc()ed 756192, max space PetscMalloced() 2.00971e+06
[0]Current process memory 7.00047e+07 max process memory 7.00047e+07
[1]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[1]Current process memory 3.44596e+07 max process memory 6.83131e+07
[2]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[2]Current process memory 3.45375e+07 max process memory 6.96975e+07
[3]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[3]Current process memory 3.46358e+07 max process memory 6.96484e+07
[4]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[4]Current process memory 3.52051e+07 max process memory 7.06437e+07
[5]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[5]Current process memory 3.06749e+07 max process memory 6.84564e+07
[6]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[6]Current process memory 3.07077e+07 max process memory 6.87759e+07
[7]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[7]Current process memory 3.06872e+07 max process memory 6.89357e+07
[8]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[8]Current process memory 3.06258e+07 max process memory 6.90422e+07
[9]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[9]Current process memory 3.04415e+07 max process memory 6.91855e+07
[10]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[10]Current process memory 3.05439e+07 max process memory 6.90299e+07
[11]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[11]Current process memory 3.06217e+07 max process memory 6.64822e+07
[12]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94622e+06
[12]Current process memory 3.05766e+07 max process memory 6.49789e+07
[13]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[13]Current process memory 3.05152e+07 max process memory 6.42703e+07
[14]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[14]Current process memory 3.06258e+07 max process memory 6.62979e+07
[15]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[15]Current process memory 3.50904e+07 max process memory 7.16349e+07
[16]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[16]Current process memory 3.44515e+07 max process memory 6.92224e+07
[17]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94595e+06
[17]Current process memory 3.51519e+07 max process memory 7.21961e+07
[18]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[18]Current process memory 3.47341e+07 max process memory 7.04635e+07
[19]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[19]Current process memory 3.42999e+07 max process memory 6.84401e+07
[20]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[20]Current process memory 2.98885e+07 max process memory 6.51715e+07
[21]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[21]Current process memory 2.97779e+07 max process memory 6.45939e+07
[22]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[22]Current process memory 2.98639e+07 max process memory 6.6048e+07
[23]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[23]Current process memory 2.97697e+07 max process memory 6.56671e+07
[24]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[24]Current process memory 2.99131e+07 max process memory 6.64412e+07
[25]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[25]Current process memory 2.9995e+07 max process memory 6.4897e+07
[26]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[26]Current process memory 2.9868e+07 max process memory 6.51428e+07
[27]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[27]Current process memory 2.97288e+07 max process memory 6.49298e+07
[28]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[28]Current process memory 2.98271e+07 max process memory 6.55319e+07
[29]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94619e+06
[29]Current process memory 2.98312e+07 max process memory 6.59128e+07
[30]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[30]Current process memory 2.98967e+07 max process memory 6.56835e+07
[31]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[31]Current process memory 2.97165e+07 max process memory 6.29555e+07
[32]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[32]Current process memory 2.96878e+07 max process memory 6.14072e+07
[33]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[33]Current process memory 2.94461e+07 max process memory 6.07683e+07
[34]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94598e+06
[34]Current process memory 2.94298e+07 max process memory 6.24394e+07
[35]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[35]Current process memory 2.84099e+07 max process memory 6.65846e+07
[36]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[36]Current process memory 2.85532e+07 max process memory 6.43072e+07
[37]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[37]Current process memory 2.83484e+07 max process memory 6.67771e+07
[38]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[38]Current process memory 2.95076e+07 max process memory 6.64658e+07
[39]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[39]Current process memory 2.84344e+07 max process memory 6.35412e+07
[40]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[40]Current process memory 2.95895e+07 max process memory 6.57654e+07
[41]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[41]Current process memory 2.96305e+07 max process memory 6.52001e+07
[42]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[42]Current process memory 3.05725e+07 max process memory 6.75594e+07
[43]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[43]Current process memory 2.96714e+07 max process memory 6.6306e+07
[44]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[44]Current process memory 2.93519e+07 max process memory 6.6818e+07
[45]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[45]Current process memory 2.92372e+07 max process memory 6.51633e+07
[46]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94614e+06
[46]Current process memory 3.0761e+07 max process memory 6.66501e+07
[47]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[47]Current process memory 3.07323e+07 max process memory 6.63552e+07
[48]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[48]Current process memory 3.05439e+07 max process memory 6.69286e+07
[49]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[49]Current process memory 3.03882e+07 max process memory 6.69573e+07
[50]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[50]Current process memory 3.08552e+07 max process memory 6.71785e+07
[51]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94603e+06
[51]Current process memory 3.05807e+07 max process memory 6.43441e+07
[52]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[52]Current process memory 2.97902e+07 max process memory 6.21404e+07
[53]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[53]Current process memory 2.95813e+07 max process memory 6.1186e+07
[54]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[54]Current process memory 2.93396e+07 max process memory 6.33897e+07
[55]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[55]Current process memory 3.05316e+07 max process memory 6.92019e+07
[56]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[56]Current process memory 2.93192e+07 max process memory 6.63634e+07
[57]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[57]Current process memory 2.94175e+07 max process memory 6.88251e+07
[58]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[58]Current process memory 2.99336e+07 max process memory 6.76946e+07
[59]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[59]Current process memory 3.06872e+07 max process memory 6.6646e+07
[60]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[60]Current process memory 6.13786e+07 max process memory 6.13786e+07
[61]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[61]Current process memory 6.05184e+07 max process memory 6.05184e+07
[62]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[62]Current process memory 6.20954e+07 max process memory 6.20954e+07
[63]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94611e+06
[63]Current process memory 6.2718e+07 max process memory 6.2718e+07
[64]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[64]Current process memory 6.47004e+07 max process memory 6.47004e+07
[65]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[65]Current process memory 6.30047e+07 max process memory 6.30047e+07
[66]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[66]Current process memory 6.33201e+07 max process memory 6.33201e+07
[67]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[67]Current process memory 6.34921e+07 max process memory 6.34921e+07
[68]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94606e+06
[68]Current process memory 6.38525e+07 max process memory 6.38525e+07
[69]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[69]Current process memory 6.32996e+07 max process memory 6.32996e+07
[70]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[70]Current process memory 6.29842e+07 max process memory 6.29842e+07
[71]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[71]Current process memory 6.06331e+07 max process memory 6.06331e+07
[72]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[72]Current process memory 6.02644e+07 max process memory 6.02644e+07
[73]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[73]Current process memory 5.83188e+07 max process memory 5.83188e+07
[74]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[74]Current process memory 6.01375e+07 max process memory 6.01375e+07
[75]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[75]Current process memory 2.86515e+07 max process memory 6.44178e+07
[76]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[76]Current process memory 6.4e+07 max process memory 6.4e+07
[77]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[77]Current process memory 2.90857e+07 max process memory 6.49175e+07
[78]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[78]Current process memory 6.39222e+07 max process memory 6.39222e+07
[79]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[79]Current process memory 6.20134e+07 max process memory 6.20134e+07
[80]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94606e+06
[80]Current process memory 6.37747e+07 max process memory 6.37747e+07
[81]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[81]Current process memory 6.31276e+07 max process memory 6.31276e+07
[82]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[82]Current process memory 6.45202e+07 max process memory 6.45202e+07
[83]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[83]Current process memory 6.41802e+07 max process memory 6.41802e+07
[84]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[84]Current process memory 3.0122e+07 max process memory 6.45366e+07
[85]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94611e+06
[85]Current process memory 6.33078e+07 max process memory 6.33078e+07
[86]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[86]Current process memory 6.28982e+07 max process memory 6.28982e+07
[87]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[87]Current process memory 2.87744e+07 max process memory 6.25172e+07
[88]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[88]Current process memory 6.31521e+07 max process memory 6.31521e+07
[89]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[89]Current process memory 6.47987e+07 max process memory 6.47987e+07
[90]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[90]Current process memory 2.92823e+07 max process memory 6.31521e+07
[91]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[91]Current process memory 6.09362e+07 max process memory 6.09362e+07
[92]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[92]Current process memory 5.9646e+07 max process memory 5.9646e+07
[93]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[93]Current process memory 5.96992e+07 max process memory 5.96992e+07
[94]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[94]Current process memory 6.05921e+07 max process memory 6.05921e+07
[95]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[95]Current process memory 2.88973e+07 max process memory 6.51059e+07
[96]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[96]Current process memory 2.84058e+07 max process memory 6.24108e+07
[97]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94603e+06
[97]Current process memory 2.9012e+07 max process memory 6.5409e+07
[98]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[98]Current process memory 2.90652e+07 max process memory 6.38157e+07
[99]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[99]Current process memory 6.25992e+07 max process memory 6.25992e+07
[100]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[100]Current process memory 6.40492e+07 max process memory 6.40492e+07
[101]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[101]Current process memory 6.3914e+07 max process memory 6.3914e+07
[102]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94614e+06
[102]Current process memory 6.53967e+07 max process memory 6.53967e+07
[103]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[103]Current process memory 6.36355e+07 max process memory 6.36355e+07
[104]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[104]Current process memory 6.43195e+07 max process memory 6.43195e+07
[105]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[105]Current process memory 6.29268e+07 max process memory 6.29268e+07
[106]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[106]Current process memory 6.41393e+07 max process memory 6.41393e+07
[107]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[107]Current process memory 6.29064e+07 max process memory 6.29064e+07
[108]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[108]Current process memory 6.31849e+07 max process memory 6.31849e+07
[109]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[109]Current process memory 6.37624e+07 max process memory 6.37624e+07
[110]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[110]Current process memory 6.46431e+07 max process memory 6.46431e+07
[111]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[111]Current process memory 6.11983e+07 max process memory 6.11983e+07
[112]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[112]Current process memory 5.98385e+07 max process memory 5.98385e+07
[113]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[113]Current process memory 5.89701e+07 max process memory 5.89701e+07
[114]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94598e+06
[114]Current process memory 6.18086e+07 max process memory 6.18086e+07
[115]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[115]Current process memory 2.92946e+07 max process memory 6.50281e+07
[116]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[116]Current process memory 6.48561e+07 max process memory 6.48561e+07
[117]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[117]Current process memory 3.03432e+07 max process memory 6.656e+07
[118]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[118]Current process memory 2.95281e+07 max process memory 6.42662e+07
[119]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94619e+06
[119]Current process memory 6.38566e+07 max process memory 6.38566e+07
[120]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[120]Current process memory 2.81272e+07 max process memory 6.19766e+07
[121]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[121]Current process memory 2.83443e+07 max process memory 6.13827e+07
[122]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[122]Current process memory 2.84918e+07 max process memory 6.28818e+07
[123]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[123]Current process memory 2.94175e+07 max process memory 6.35412e+07
[124]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[124]Current process memory 2.94052e+07 max process memory 6.40532e+07
[125]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[125]Current process memory 6.28408e+07 max process memory 6.28408e+07
[126]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[126]Current process memory 6.33528e+07 max process memory 6.33528e+07
[127]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[127]Current process memory 6.32463e+07 max process memory 6.32463e+07
[128]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[128]Current process memory 6.40123e+07 max process memory 6.40123e+07
[129]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[129]Current process memory 6.44628e+07 max process memory 6.44628e+07
[130]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[130]Current process memory 2.98476e+07 max process memory 6.39549e+07
[131]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94595e+06
[131]Current process memory 6.2079e+07 max process memory 6.2079e+07
[132]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[132]Current process memory 6.04119e+07 max process memory 6.04119e+07
[133]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[133]Current process memory 5.98548e+07 max process memory 5.98548e+07
[134]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[134]Current process memory 6.14236e+07 max process memory 6.14236e+07
[135]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[135]Current process memory 2.97533e+07 max process memory 6.58924e+07
[136]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94622e+06
[136]Current process memory 2.9909e+07 max process memory 6.40901e+07
[137]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[137]Current process memory 2.98107e+07 max process memory 6.65027e+07
[138]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[138]Current process memory 2.9868e+07 max process memory 6.50445e+07
[139]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[139]Current process memory 2.96468e+07 max process memory 6.30129e+07
[140]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[140]Current process memory 3.05439e+07 max process memory 6.51305e+07
[141]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[141]Current process memory 3.07405e+07 max process memory 6.49667e+07
[142]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[142]Current process memory 3.05971e+07 max process memory 6.60767e+07
[143]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93346e+06
[143]Current process memory 3.05029e+07 max process memory 6.57695e+07
[144]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94616e+06
[144]Current process memory 3.08511e+07 max process memory 6.67116e+07
[145]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93346e+06
[145]Current process memory 3.06299e+07 max process memory 6.47127e+07
[146]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93346e+06
[146]Current process memory 3.08552e+07 max process memory 6.53435e+07
[147]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93346e+06
[147]Current process memory 3.0634e+07 max process memory 6.52329e+07
[148]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93285e+06
[148]Current process memory 3.05275e+07 max process memory 6.52534e+07
[149]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93269e+06
[149]Current process memory 3.10518e+07 max process memory 6.64166e+07
[150]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[150]Current process memory 3.07855e+07 max process memory 6.58514e+07
[151]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[151]Current process memory 3.08388e+07 max process memory 6.33283e+07
[152]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[152]Current process memory 3.0806e+07 max process memory 6.20503e+07
[153]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[153]Current process memory 3.04906e+07 max process memory 6.10673e+07
[154]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[154]Current process memory 3.08675e+07 max process memory 6.28613e+07
[155]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[155]Current process memory 3.05644e+07 max process memory 6.77356e+07
[156]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[156]Current process memory 3.05684e+07 max process memory 6.58964e+07
[157]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[157]Current process memory 3.06012e+07 max process memory 6.82148e+07
[158]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[158]Current process memory 3.06708e+07 max process memory 6.6818e+07
[159]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[159]Current process memory 3.0507e+07 max process memory 6.4983e+07
[160]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[160]Current process memory 2.97001e+07 max process memory 6.32955e+07
[161]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94622e+06
[161]Current process memory 3.06012e+07 max process memory 6.35863e+07
[162]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[162]Current process memory 2.97247e+07 max process memory 6.40942e+07
[163]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[163]Current process memory 6.51428e+07 max process memory 6.51428e+07
[164]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[164]Current process memory 3.06668e+07 max process memory 6.54868e+07
[165]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[165]Current process memory 6.33733e+07 max process memory 6.33733e+07
[166]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94595e+06
[166]Current process memory 6.47004e+07 max process memory 6.47004e+07
[167]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[167]Current process memory 6.33364e+07 max process memory 6.33364e+07
[168]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[168]Current process memory 6.38321e+07 max process memory 6.38321e+07
[169]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[169]Current process memory 6.41556e+07 max process memory 6.41556e+07
[170]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[170]Current process memory 3.08306e+07 max process memory 6.48479e+07
[171]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[171]Current process memory 6.14523e+07 max process memory 6.14523e+07
[172]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[172]Current process memory 6.00146e+07 max process memory 6.00146e+07
[173]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[173]Current process memory 5.94207e+07 max process memory 5.94207e+07
[174]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[174]Current process memory 6.21363e+07 max process memory 6.21363e+07
[175]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[175]Current process memory 2.91471e+07 max process memory 6.56261e+07
[176]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[176]Current process memory 2.96182e+07 max process memory 6.37215e+07
[177]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[177]Current process memory 2.92987e+07 max process memory 6.58309e+07
[178]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94619e+06
[178]Current process memory 3.0548e+07 max process memory 6.56671e+07
[179]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[179]Current process memory 2.96264e+07 max process memory 6.29514e+07
[180]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[180]Current process memory 2.9995e+07 max process memory 6.43195e+07
[181]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[181]Current process memory 3.00933e+07 max process memory 6.38321e+07
[182]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[182]Current process memory 2.8926e+07 max process memory 6.41597e+07
[183]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94598e+06
[183]Current process memory 2.97902e+07 max process memory 6.46513e+07
[184]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[184]Current process memory 2.8885e+07 max process memory 6.44014e+07
[185]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[185]Current process memory 2.88276e+07 max process memory 6.28654e+07
[186]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[186]Current process memory 2.89178e+07 max process memory 6.35781e+07
[187]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[187]Current process memory 2.98312e+07 max process memory 6.44588e+07
[188]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[188]Current process memory 2.88809e+07 max process memory 6.35453e+07
[189]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[189]Current process memory 2.85573e+07 max process memory 6.42458e+07
[190]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[190]Current process memory 2.87048e+07 max process memory 6.41966e+07
[191]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[191]Current process memory 2.97943e+07 max process memory 6.2378e+07
[192]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[192]Current process memory 2.86147e+07 max process memory 5.95968e+07
[193]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[193]Current process memory 2.80904e+07 max process memory 5.9134e+07
[194]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[194]Current process memory 2.86024e+07 max process memory 6.06536e+07
[195]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94614e+06
[195]Current process memory 2.95731e+07 max process memory 6.65068e+07
[196]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[196]Current process memory 2.84549e+07 max process memory 6.33119e+07
[197]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[197]Current process memory 2.93601e+07 max process memory 6.67402e+07
[198]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[198]Current process memory 2.94011e+07 max process memory 6.54049e+07
[199]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[199]Current process memory 2.84344e+07 max process memory 6.25091e+07
[200]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94603e+06
[200]Current process memory 3.07937e+07 max process memory 6.54705e+07
[201]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[201]Current process memory 2.94707e+07 max process memory 6.39672e+07
[202]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[202]Current process memory 2.96591e+07 max process memory 6.51469e+07
[203]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[203]Current process memory 2.97984e+07 max process memory 6.49544e+07
[204]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[204]Current process memory 3.07159e+07 max process memory 6.6646e+07
[205]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[205]Current process memory 2.9868e+07 max process memory 6.41188e+07
[206]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[206]Current process memory 2.961e+07 max process memory 6.43236e+07
[207]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[207]Current process memory 2.95199e+07 max process memory 6.41679e+07
[208]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[208]Current process memory 3.05357e+07 max process memory 6.52984e+07
[209]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[209]Current process memory 2.96264e+07 max process memory 6.51633e+07
[210]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[210]Current process memory 2.97288e+07 max process memory 6.48847e+07
[211]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[211]Current process memory 2.94257e+07 max process memory 6.21076e+07
[212]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94611e+06
[212]Current process memory 3.0974e+07 max process memory 6.21527e+07
[213]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[213]Current process memory 2.97533e+07 max process memory 6.03709e+07
[214]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[214]Current process memory 3.06668e+07 max process memory 6.2935e+07
[215]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[215]Current process memory 3.07651e+07 max process memory 6.8137e+07
[216]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[216]Current process memory 2.94953e+07 max process memory 6.4684e+07
[217]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94606e+06
[217]Current process memory 3.05152e+07 max process memory 6.81861e+07
[218]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[218]Current process memory 2.97206e+07 max process memory 6.60193e+07
[219]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[219]Current process memory 2.95608e+07 max process memory 6.40328e+07
[220]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[220]Current process memory 6.11942e+07 max process memory 6.11942e+07
[221]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[221]Current process memory 6.17841e+07 max process memory 6.17841e+07
[222]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[222]Current process memory 6.21117e+07 max process memory 6.21117e+07
[223]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[223]Current process memory 2.76521e+07 max process memory 6.14605e+07
[224]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[224]Current process memory 2.93192e+07 max process memory 6.35453e+07
[225]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[225]Current process memory 6.29596e+07 max process memory 6.29596e+07
[226]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[226]Current process memory 6.25705e+07 max process memory 6.25705e+07
[227]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[227]Current process memory 6.26852e+07 max process memory 6.26852e+07
[228]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[228]Current process memory 6.28941e+07 max process memory 6.28941e+07
[229]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94606e+06
[229]Current process memory 6.4553e+07 max process memory 6.4553e+07
[230]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[230]Current process memory 2.88563e+07 max process memory 6.26729e+07
[231]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[231]Current process memory 6.10304e+07 max process memory 6.10304e+07
[232]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[232]Current process memory 5.92609e+07 max process memory 5.92609e+07
[233]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[233]Current process memory 5.87981e+07 max process memory 5.87981e+07
[234]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94611e+06
[234]Current process memory 6.1268e+07 max process memory 6.1268e+07
[235]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[235]Current process memory 2.89587e+07 max process memory 6.50076e+07
[236]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[236]Current process memory 6.27261e+07 max process memory 6.27261e+07
[237]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[237]Current process memory 2.91267e+07 max process memory 6.50732e+07
[238]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[238]Current process memory 3.02162e+07 max process memory 6.47086e+07
[239]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[239]Current process memory 6.19807e+07 max process memory 6.19807e+07
[240]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[240]Current process memory 5.89742e+07 max process memory 5.89742e+07
[241]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[241]Current process memory 5.83352e+07 max process memory 5.83352e+07
[242]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[242]Current process memory 6.09935e+07 max process memory 6.09935e+07
[243]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[243]Current process memory 5.93961e+07 max process memory 5.93961e+07
[244]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[244]Current process memory 6.05184e+07 max process memory 6.05184e+07
[245]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[245]Current process memory 5.89455e+07 max process memory 5.89455e+07
[246]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94603e+06
[246]Current process memory 6.02808e+07 max process memory 6.02808e+07
[247]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[247]Current process memory 5.90193e+07 max process memory 5.90193e+07
[248]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[248]Current process memory 5.94452e+07 max process memory 5.94452e+07
[249]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[249]Current process memory 6.0031e+07 max process memory 6.0031e+07
[250]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[250]Current process memory 5.97361e+07 max process memory 5.97361e+07
[251]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94614e+06
[251]Current process memory 5.82287e+07 max process memory 5.82287e+07
[252]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[252]Current process memory 5.60128e+07 max process memory 5.60128e+07
[253]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[253]Current process memory 5.54598e+07 max process memory 5.54598e+07
[254]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[254]Current process memory 5.69221e+07 max process memory 5.69221e+07
[255]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[255]Current process memory 6.2378e+07 max process memory 6.2378e+07
[256]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[256]Current process memory 5.87366e+07 max process memory 5.87366e+07
[257]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[257]Current process memory 6.07355e+07 max process memory 6.07355e+07
[258]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[258]Current process memory 5.92486e+07 max process memory 5.92486e+07
[259]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[259]Current process memory 5.88718e+07 max process memory 5.88718e+07
[260]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[260]Current process memory 2.96018e+07 max process memory 6.2763e+07
[261]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[261]Current process memory 2.98189e+07 max process memory 6.21527e+07
[262]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[262]Current process memory 2.98107e+07 max process memory 6.37256e+07
[263]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94598e+06
[263]Current process memory 3.06545e+07 max process memory 6.41802e+07
[264]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[264]Current process memory 2.93315e+07 max process memory 6.40246e+07
[265]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[265]Current process memory 2.93437e+07 max process memory 6.21855e+07
[266]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[266]Current process memory 2.93929e+07 max process memory 6.27343e+07
[267]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[267]Current process memory 2.96059e+07 max process memory 6.26115e+07
[268]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94619e+06
[268]Current process memory 3.09084e+07 max process memory 6.40246e+07
[269]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[269]Current process memory 2.93765e+07 max process memory 6.34184e+07
[270]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[270]Current process memory 2.95649e+07 max process memory 6.30497e+07
[271]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[271]Current process memory 2.90488e+07 max process memory 6.03832e+07
[272]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[272]Current process memory 3.05848e+07 max process memory 6.0117e+07
[273]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[273]Current process memory 2.96059e+07 max process memory 5.85441e+07
[274]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[274]Current process memory 2.995e+07 max process memory 6.04815e+07
[275]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[275]Current process memory 2.93274e+07 max process memory 6.53844e+07
[276]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[276]Current process memory 3.03923e+07 max process memory 6.37706e+07
[277]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[277]Current process memory 2.92618e+07 max process memory 6.55032e+07
[278]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[278]Current process memory 2.95322e+07 max process memory 6.40041e+07
[279]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[279]Current process memory 2.90243e+07 max process memory 6.22838e+07
[280]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94595e+06
[280]Current process memory 2.96796e+07 max process memory 6.2718e+07
[281]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[281]Current process memory 2.8418e+07 max process memory 6.07027e+07
[282]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[282]Current process memory 2.84918e+07 max process memory 6.24517e+07
[283]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[283]Current process memory 2.83689e+07 max process memory 6.19684e+07
[284]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[284]Current process memory 2.8418e+07 max process memory 6.28163e+07
[285]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94622e+06
[285]Current process memory 6.2251e+07 max process memory 6.2251e+07
[286]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[286]Current process memory 2.84918e+07 max process memory 6.12557e+07
[287]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[287]Current process memory 2.80289e+07 max process memory 6.11451e+07
[288]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[288]Current process memory 2.88358e+07 max process memory 6.21527e+07
[289]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[289]Current process memory 6.34839e+07 max process memory 6.34839e+07
[290]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[290]Current process memory 2.88563e+07 max process memory 6.21281e+07
[291]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[291]Current process memory 5.98426e+07 max process memory 5.98426e+07
[292]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93346e+06
[292]Current process memory 5.83721e+07 max process memory 5.83721e+07
[293]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94616e+06
[293]Current process memory 5.88882e+07 max process memory 5.88882e+07
[294]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93346e+06
[294]Current process memory 2.83812e+07 max process memory 5.92364e+07
[295]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93346e+06
[295]Current process memory 2.87212e+07 max process memory 6.44219e+07
[296]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93346e+06
[296]Current process memory 2.88604e+07 max process memory 6.23575e+07
[297]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93285e+06
[297]Current process memory 2.88154e+07 max process memory 6.49339e+07
[298]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93269e+06
[298]Current process memory 2.89505e+07 max process memory 6.34348e+07
[299]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[299]Current process memory 2.83689e+07 max process memory 6.144e+07
[300]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[300]Current process memory 2.98435e+07 max process memory 6.69327e+07
[301]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[301]Current process memory 2.97042e+07 max process memory 6.61094e+07
[302]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[302]Current process memory 3.07364e+07 max process memory 6.87391e+07
[303]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[303]Current process memory 2.97738e+07 max process memory 6.74488e+07
[304]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[304]Current process memory 2.92127e+07 max process memory 6.8055e+07
[305]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[305]Current process memory 2.95813e+07 max process memory 6.60439e+07
[306]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[306]Current process memory 3.06258e+07 max process memory 6.7498e+07
[307]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[307]Current process memory 2.99418e+07 max process memory 6.66051e+07
[308]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[308]Current process memory 2.99049e+07 max process memory 6.68385e+07
[309]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[309]Current process memory 2.92372e+07 max process memory 6.71949e+07
[310]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94622e+06
[310]Current process memory 3.0933e+07 max process memory 6.83377e+07
[311]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[311]Current process memory 2.95281e+07 max process memory 6.45693e+07
[312]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[312]Current process memory 2.97329e+07 max process memory 6.26893e+07
[313]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[313]Current process memory 2.96346e+07 max process memory 6.2677e+07
[314]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[314]Current process memory 2.98271e+07 max process memory 6.43441e+07
[315]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94595e+06
[315]Current process memory 3.08511e+07 max process memory 7.08403e+07
[316]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[316]Current process memory 2.97001e+07 max process memory 6.70884e+07
[317]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[317]Current process memory 2.96264e+07 max process memory 6.98163e+07
[318]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[318]Current process memory 2.92987e+07 max process memory 6.86612e+07
[319]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[319]Current process memory 3.06422e+07 max process memory 6.73915e+07
[320]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[320]Current process memory 2.99745e+07 max process memory 6.63675e+07
[321]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[321]Current process memory 2.9569e+07 max process memory 6.54418e+07
[322]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[322]Current process memory 2.91594e+07 max process memory 6.69573e+07
[323]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[323]Current process memory 2.96591e+07 max process memory 6.66952e+07
[324]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[324]Current process memory 2.96468e+07 max process memory 6.75308e+07
[325]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[325]Current process memory 2.93151e+07 max process memory 6.54213e+07
[326]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[326]Current process memory 2.95608e+07 max process memory 6.58227e+07
[327]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94619e+06
[327]Current process memory 2.96428e+07 max process memory 6.58022e+07
[328]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[328]Current process memory 2.96428e+07 max process memory 6.61135e+07
[329]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[329]Current process memory 2.95731e+07 max process memory 6.63552e+07
[330]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[330]Current process memory 2.95567e+07 max process memory 6.64494e+07
[331]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[331]Current process memory 2.95813e+07 max process memory 6.35208e+07
[332]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94598e+06
[332]Current process memory 2.97452e+07 max process memory 6.23206e+07
[333]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[333]Current process memory 2.95158e+07 max process memory 6.16489e+07
[334]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[334]Current process memory 2.96018e+07 max process memory 6.36273e+07
[335]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[335]Current process memory 2.90775e+07 max process memory 6.89357e+07
[336]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[336]Current process memory 2.92332e+07 max process memory 6.66706e+07
[337]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[337]Current process memory 2.93028e+07 max process memory 6.89357e+07
[338]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[338]Current process memory 2.96059e+07 max process memory 6.77069e+07
[339]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[339]Current process memory 2.90857e+07 max process memory 6.56425e+07
[340]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[340]Current process memory 2.85532e+07 max process memory 6.65354e+07
[341]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[341]Current process memory 2.86024e+07 max process memory 6.60398e+07
[342]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[342]Current process memory 2.8459e+07 max process memory 6.76127e+07
[343]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[343]Current process memory 2.85e+07 max process memory 6.7113e+07
[344]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94614e+06
[344]Current process memory 2.90365e+07 max process memory 6.80305e+07
[345]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[345]Current process memory 2.90652e+07 max process memory 6.60849e+07
[346]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[346]Current process memory 2.88727e+07 max process memory 6.63101e+07
[347]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[347]Current process memory 2.85164e+07 max process memory 6.61176e+07
[348]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[348]Current process memory 2.86024e+07 max process memory 6.66296e+07
[349]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94603e+06
[349]Current process memory 2.84385e+07 max process memory 6.70106e+07
[350]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[350]Current process memory 2.84262e+07 max process memory 6.71334e+07
[351]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[351]Current process memory 2.8799e+07 max process memory 6.40942e+07
[352]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[352]Current process memory 2.85041e+07 max process memory 6.2378e+07
[353]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[353]Current process memory 2.82952e+07 max process memory 6.20954e+07
[354]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[354]Current process memory 2.8586e+07 max process memory 6.37133e+07
[355]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[355]Current process memory 2.85819e+07 max process memory 6.92306e+07
[356]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[356]Current process memory 2.85614e+07 max process memory 6.67771e+07
[357]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[357]Current process memory 3.37142e+07 max process memory 6.94927e+07
[358]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[358]Current process memory 2.80699e+07 max process memory 6.79363e+07
[359]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[359]Current process memory 2.83402e+07 max process memory 6.59661e+07
[360]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[360]Current process memory 2.96387e+07 max process memory 6.68099e+07
[361]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94611e+06
[361]Current process memory 2.94175e+07 max process memory 6.65805e+07
[362]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[362]Current process memory 2.93929e+07 max process memory 6.79485e+07
[363]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[363]Current process memory 2.92454e+07 max process memory 6.74775e+07
[364]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[364]Current process memory 2.97001e+07 max process memory 6.8223e+07
[365]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[365]Current process memory 2.96305e+07 max process memory 6.61627e+07
[366]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94606e+06
[366]Current process memory 2.92413e+07 max process memory 6.64248e+07
[367]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[367]Current process memory 2.96346e+07 max process memory 6.63347e+07
[368]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[368]Current process memory 2.99377e+07 max process memory 6.72031e+07
[369]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[369]Current process memory 2.9311e+07 max process memory 6.7244e+07
[370]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[370]Current process memory 2.93806e+07 max process memory 6.74324e+07
[371]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[371]Current process memory 2.9438e+07 max process memory 6.44301e+07
[372]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[372]Current process memory 2.9655e+07 max process memory 6.26074e+07
[373]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[373]Current process memory 3.00032e+07 max process memory 6.27507e+07
[374]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[374]Current process memory 2.97411e+07 max process memory 6.43645e+07
[375]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[375]Current process memory 2.97533e+07 max process memory 6.98081e+07
[376]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[376]Current process memory 2.97861e+07 max process memory 6.74365e+07
[377]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[377]Current process memory 2.93888e+07 max process memory 6.98737e+07
[378]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94606e+06
[378]Current process memory 2.96673e+07 max process memory 6.85343e+07
[379]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[379]Current process memory 2.92209e+07 max process memory 6.6773e+07
[380]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[380]Current process memory 3.36077e+07 max process memory 6.97426e+07
[381]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[381]Current process memory 3.34193e+07 max process memory 6.90708e+07
[382]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[382]Current process memory 3.35708e+07 max process memory 7.04635e+07
[383]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94611e+06
[383]Current process memory 3.35462e+07 max process memory 7.01686e+07
[384]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[384]Current process memory 3.50208e+07 max process memory 7.22657e+07
[385]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[385]Current process memory 3.46972e+07 max process memory 7.00006e+07
[386]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[386]Current process memory 3.44842e+07 max process memory 6.99843e+07
[387]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[387]Current process memory 3.46317e+07 max process memory 7.03529e+07
[388]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[388]Current process memory 3.49716e+07 max process memory 7.09304e+07
[389]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[389]Current process memory 3.48938e+07 max process memory 7.10697e+07
[390]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[390]Current process memory 3.4857e+07 max process memory 7.11025e+07
[391]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[391]Current process memory 3.43327e+07 max process memory 6.80468e+07
[392]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[392]Current process memory 3.45088e+07 max process memory 6.64986e+07
[393]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[393]Current process memory 3.42508e+07 max process memory 6.61217e+07
[394]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[394]Current process memory 3.46235e+07 max process memory 6.82025e+07
[395]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94603e+06
[395]Current process memory 3.55328e+07 max process memory 7.39656e+07
[396]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[396]Current process memory 3.48488e+07 max process memory 7.15284e+07
[397]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[397]Current process memory 3.47136e+07 max process memory 7.40884e+07
[398]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[398]Current process memory 3.46153e+07 max process memory 7.26016e+07
[399]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[399]Current process memory 3.42262e+07 max process memory 7.04266e+07
[400]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94614e+06
[400]Current process memory 3.47464e+07 max process memory 7.16063e+07
[401]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[401]Current process memory 3.49798e+07 max process memory 7.1168e+07
[402]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[402]Current process memory 3.52133e+07 max process memory 7.26794e+07
[403]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[403]Current process memory 3.49839e+07 max process memory 7.21265e+07
[404]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[404]Current process memory 3.51805e+07 max process memory 7.33471e+07
[405]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[405]Current process memory 3.50659e+07 max process memory 7.12253e+07
[406]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[406]Current process memory 3.50781e+07 max process memory 7.1426e+07
[407]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[407]Current process memory 3.47341e+07 max process memory 7.14875e+07
[408]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[408]Current process memory 3.52338e+07 max process memory 7.22493e+07
[409]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[409]Current process memory 3.51724e+07 max process memory 7.21961e+07
[410]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[410]Current process memory 3.54796e+07 max process memory 7.24869e+07
[411]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[411]Current process memory 3.46522e+07 max process memory 6.93617e+07
[412]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94598e+06
[412]Current process memory 3.45088e+07 max process memory 6.76004e+07
[413]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[413]Current process memory 3.47382e+07 max process memory 6.74365e+07
[414]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[414]Current process memory 3.50044e+07 max process memory 6.92183e+07
[415]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[415]Current process memory 3.56352e+07 max process memory 7.48175e+07
[416]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[416]Current process memory 3.39313e+07 max process memory 7.16022e+07
[417]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94619e+06
[417]Current process memory 3.41484e+07 max process memory 7.40065e+07
[418]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[418]Current process memory 3.40337e+07 max process memory 7.26221e+07
[419]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[419]Current process memory 3.37961e+07 max process memory 7.04717e+07
[420]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[420]Current process memory 3.49266e+07 max process memory 7.07953e+07
[421]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[421]Current process memory 3.53239e+07 max process memory 7.07748e+07
[422]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[422]Current process memory 3.56557e+07 max process memory 7.20937e+07
[423]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[423]Current process memory 3.5455e+07 max process memory 7.16104e+07
[424]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[424]Current process memory 3.54386e+07 max process memory 7.24337e+07
[425]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94589e+06
[425]Current process memory 3.54427e+07 max process memory 7.10656e+07
[426]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[426]Current process memory 3.54181e+07 max process memory 7.10164e+07
[427]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[427]Current process memory 3.54796e+07 max process memory 7.14138e+07
[428]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[428]Current process memory 3.54099e+07 max process memory 7.13441e+07
[429]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94595e+06
[429]Current process memory 3.54017e+07 max process memory 7.1766e+07
[430]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[430]Current process memory 3.56147e+07 max process memory 7.16923e+07
[431]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[431]Current process memory 3.50986e+07 max process memory 6.90422e+07
[432]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93496e+06
[432]Current process memory 3.45498e+07 max process memory 6.70065e+07
[433]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93435e+06
[433]Current process memory 3.4558e+07 max process memory 6.67238e+07
[434]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94622e+06
[434]Current process memory 3.53812e+07 max process memory 6.88742e+07
[435]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[435]Current process memory 3.60038e+07 max process memory 7.45841e+07
[436]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[436]Current process memory 3.51109e+07 max process memory 7.18356e+07
[437]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[437]Current process memory 3.53485e+07 max process memory 7.45144e+07
[438]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.94594e+06
[438]Current process memory 3.53649e+07 max process memory 7.30112e+07
[439]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[439]Current process memory 3.52338e+07 max process memory 7.10287e+07
[440]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.93326e+06
[440]Current process memory 3.40951e+07 max process memory 7.14711e+07
[441]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[441]Current process memory 3.39026e+07 max process memory 7.08608e+07
[442]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90696e+06
[442]Current process memory 3.41443e+07 max process memory 7.23395e+07
[443]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[443]Current process memory 3.42344e+07 max process memory 7.18766e+07
[444]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[444]Current process memory 3.42958e+07 max process memory 7.25852e+07
[445]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[445]Current process memory 3.39845e+07 max process memory 7.09673e+07
[446]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[446]Current process memory 3.38207e+07 max process memory 7.1209e+07
[447]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90699e+06
[447]Current process memory 3.40787e+07 max process memory 7.14424e+07
[448]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[448]Current process memory 3.46972e+07 max process memory 7.20527e+07
[449]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[449]Current process memory 3.45252e+07 max process memory 7.23395e+07
[450]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[450]Current process memory 3.46972e+07 max process memory 7.25033e+07
[451]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.9068e+06
[451]Current process memory 3.44351e+07 max process memory 6.96689e+07
[452]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[452]Current process memory 3.3751e+07 max process memory 6.76536e+07
[453]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[453]Current process memory 3.36732e+07 max process memory 6.75308e+07
[454]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[454]Current process memory 3.40664e+07 max process memory 6.94395e+07
[455]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90683e+06
[455]Current process memory 3.5201e+07 max process memory 7.52968e+07
[456]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[456]Current process memory 3.43859e+07 max process memory 7.25852e+07
[457]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[457]Current process memory 3.47136e+07 max process memory 7.53664e+07
[458]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[458]Current process memory 3.43368e+07 max process memory 7.37075e+07
[459]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[459]Current process memory 3.45088e+07 max process memory 7.17046e+07
[460]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90718e+06
[460]Current process memory 3.45948e+07 max process memory 6.91036e+07
[461]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[461]Current process memory 3.44433e+07 max process memory 6.85015e+07
[462]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[462]Current process memory 3.47095e+07 max process memory 7.00744e+07
[463]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[463]Current process memory 3.45129e+07 max process memory 6.96074e+07
[464]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90715e+06
[464]Current process memory 3.49307e+07 max process memory 7.04225e+07
[465]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[465]Current process memory 3.46276e+07 max process memory 6.85916e+07
[466]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[466]Current process memory 3.45702e+07 max process memory 6.8907e+07
[467]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[467]Current process memory 3.45661e+07 max process memory 6.92142e+07
[468]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[468]Current process memory 2.97329e+07 max process memory 6.92142e+07
[469]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90686e+06
[469]Current process memory 3.47996e+07 max process memory 6.95706e+07
[470]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[470]Current process memory 3.51314e+07 max process memory 6.98163e+07
[471]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[471]Current process memory 3.43286e+07 max process memory 6.65969e+07
[472]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[472]Current process memory 2.95158e+07 max process memory 6.49134e+07
[473]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.9068e+06
[473]Current process memory 3.41115e+07 max process memory 6.4684e+07
[474]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[474]Current process memory 3.43613e+07 max process memory 6.6519e+07
[475]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[475]Current process memory 3.473e+07 max process memory 7.19053e+07
[476]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[476]Current process memory 3.4431e+07 max process memory 6.95132e+07
[477]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90694e+06
[477]Current process memory 3.48242e+07 max process memory 7.22862e+07
[478]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[478]Current process memory 3.45211e+07 max process memory 7.0828e+07
[479]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[479]Current process memory 3.42712e+07 max process memory 6.88538e+07
[480]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[480]Current process memory 3.42057e+07 max process memory 6.84196e+07
[481]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[481]Current process memory 3.41279e+07 max process memory 6.76454e+07
[482]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90706e+06
[482]Current process memory 3.44965e+07 max process memory 6.93084e+07
[483]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[483]Current process memory 3.42548e+07 max process memory 6.88046e+07
[484]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[484]Current process memory 3.44023e+07 max process memory 6.96361e+07
[485]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[485]Current process memory 2.96387e+07 max process memory 6.77888e+07
[486]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.9068e+06
[486]Current process memory 2.95035e+07 max process memory 6.8055e+07
[487]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[487]Current process memory 3.42958e+07 max process memory 6.83991e+07
[488]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[488]Current process memory 2.94912e+07 max process memory 6.82967e+07
[489]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[489]Current process memory 2.95526e+07 max process memory 6.87759e+07
[490]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89357e+06
[490]Current process memory 3.43409e+07 max process memory 6.83459e+07
[491]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89357e+06
[491]Current process memory 2.95731e+07 max process memory 6.57818e+07
[492]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[492]Current process memory 2.95567e+07 max process memory 6.43359e+07
[493]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[493]Current process memory 2.9356e+07 max process memory 6.38075e+07
[494]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[494]Current process memory 2.94666e+07 max process memory 6.5536e+07
[495]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90698e+06
[495]Current process memory 3.43613e+07 max process memory 7.10574e+07
[496]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[496]Current process memory 3.39599e+07 max process memory 6.89193e+07
[497]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[497]Current process memory 3.45088e+07 max process memory 7.14465e+07
[498]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89424e+06
[498]Current process memory 3.42057e+07 max process memory 6.98941e+07
[499]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.9075e+06
[499]Current process memory 3.3878e+07 max process memory 6.79076e+07
[500]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[500]Current process memory 3.3452e+07 max process memory 6.73219e+07
[501]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[501]Current process memory 3.32145e+07 max process memory 6.66665e+07
[502]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[502]Current process memory 2.86761e+07 max process memory 6.79854e+07
[503]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[503]Current process memory 2.87334e+07 max process memory 6.76536e+07
[504]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90712e+06
[504]Current process memory 2.87293e+07 max process memory 6.82066e+07
[505]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[505]Current process memory 2.89382e+07 max process memory 6.67566e+07
[506]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[506]Current process memory 2.86679e+07 max process memory 6.68549e+07
[507]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[507]Current process memory 2.89505e+07 max process memory 6.72563e+07
[508]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90698e+06
[508]Current process memory 2.8373e+07 max process memory 6.7158e+07
[509]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[509]Current process memory 2.89137e+07 max process memory 6.78502e+07
[510]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[510]Current process memory 2.87334e+07 max process memory 6.74734e+07
[511]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[511]Current process memory 2.86392e+07 max process memory 6.45939e+07
[512]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90704e+06
[512]Current process memory 2.83075e+07 max process memory 6.30006e+07
[513]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[513]Current process memory 2.82337e+07 max process memory 6.20175e+07
[514]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[514]Current process memory 2.84713e+07 max process memory 6.43113e+07
[515]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[515]Current process memory 3.31899e+07 max process memory 6.96443e+07
[516]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[516]Current process memory 3.26615e+07 max process memory 6.73505e+07
[517]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90733e+06
[517]Current process memory 3.29032e+07 max process memory 7.0185e+07
[518]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[518]Current process memory 3.32022e+07 max process memory 6.85302e+07
[519]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[519]Current process memory 3.26902e+07 max process memory 6.6388e+07
[520]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[520]Current process memory 2.95322e+07 max process memory 6.73956e+07
[521]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90736e+06
[521]Current process memory 2.9524e+07 max process memory 6.69409e+07
[522]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[522]Current process memory 2.96919e+07 max process memory 6.84933e+07
[523]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89592e+06
[523]Current process memory 2.95895e+07 max process memory 6.80387e+07
[524]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89592e+06
[524]Current process memory 2.96428e+07 max process memory 6.87432e+07
[525]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[525]Current process memory 2.94789e+07 max process memory 6.69942e+07
[526]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90701e+06
[526]Current process memory 2.91389e+07 max process memory 6.73997e+07
[527]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[527]Current process memory 2.96305e+07 max process memory 6.75512e+07
[528]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[528]Current process memory 2.96714e+07 max process memory 6.78093e+07
[529]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[529]Current process memory 2.95567e+07 max process memory 6.81492e+07
[530]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90698e+06
[530]Current process memory 2.92291e+07 max process memory 6.80059e+07
[531]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[531]Current process memory 2.97533e+07 max process memory 6.52698e+07
[532]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[532]Current process memory 2.91553e+07 max process memory 6.3746e+07
[533]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[533]Current process memory 2.97533e+07 max process memory 6.31931e+07
[534]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90717e+06
[534]Current process memory 2.96305e+07 max process memory 6.50609e+07
[535]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[535]Current process memory 3.4263e+07 max process memory 7.03693e+07
[536]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[536]Current process memory 2.94134e+07 max process memory 6.78298e+07
[537]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[537]Current process memory 3.39026e+07 max process memory 7.07174e+07
[538]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[538]Current process memory 3.37428e+07 max process memory 6.92511e+07
[539]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.9072e+06
[539]Current process memory 2.96264e+07 max process memory 6.74939e+07
[540]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[540]Current process memory 3.25878e+07 max process memory 6.64494e+07
[541]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[541]Current process memory 3.23052e+07 max process memory 6.57818e+07
[542]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[542]Current process memory 3.25059e+07 max process memory 6.72154e+07
[543]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90698e+06
[543]Current process memory 2.78651e+07 max process memory 6.67771e+07
[544]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[544]Current process memory 3.40951e+07 max process memory 6.8907e+07
[545]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[545]Current process memory 2.89915e+07 max process memory 6.67976e+07
[546]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[546]Current process memory 2.89669e+07 max process memory 6.73423e+07
[547]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90696e+06
[547]Current process memory 2.92946e+07 max process memory 6.75963e+07
[548]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[548]Current process memory 2.90202e+07 max process memory 6.77151e+07
[549]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[549]Current process memory 2.91512e+07 max process memory 6.81042e+07
[550]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[550]Current process memory 2.93929e+07 max process memory 6.81492e+07
[551]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[551]Current process memory 2.93396e+07 max process memory 6.52247e+07
[552]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90739e+06
[552]Current process memory 2.91512e+07 max process memory 6.35617e+07
[553]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[553]Current process memory 2.91267e+07 max process memory 6.28613e+07
[554]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[554]Current process memory 2.89997e+07 max process memory 6.47782e+07
[555]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[555]Current process memory 3.4046e+07 max process memory 7.03611e+07
[556]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90755e+06
[556]Current process memory 3.32063e+07 max process memory 6.77765e+07
[557]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89539e+06
[557]Current process memory 3.34807e+07 max process memory 7.05946e+07
[558]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[558]Current process memory 3.34479e+07 max process memory 6.92593e+07
[559]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[559]Current process memory 3.30916e+07 max process memory 6.72522e+07
[560]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[560]Current process memory 3.34561e+07 max process memory 6.87555e+07
[561]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90707e+06
[561]Current process memory 3.38166e+07 max process memory 6.82557e+07
[562]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[562]Current process memory 3.4132e+07 max process memory 6.9759e+07
[563]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[563]Current process memory 3.39231e+07 max process memory 6.93985e+07
[564]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[564]Current process memory 3.39067e+07 max process memory 7.00088e+07
[565]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90698e+06
[565]Current process memory 2.93315e+07 max process memory 6.82762e+07
[566]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[566]Current process memory 3.38657e+07 max process memory 6.84646e+07
[567]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[567]Current process memory 3.39476e+07 max process memory 6.88374e+07
[568]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[568]Current process memory 3.40091e+07 max process memory 6.92552e+07
[569]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90707e+06
[569]Current process memory 3.42385e+07 max process memory 6.94272e+07
[570]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[570]Current process memory 3.4431e+07 max process memory 6.93207e+07
[571]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[571]Current process memory 2.8926e+07 max process memory 6.62651e+07
[572]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[572]Current process memory 2.89587e+07 max process memory 6.477e+07
[573]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[573]Current process memory 2.90447e+07 max process memory 6.38198e+07
[574]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90728e+06
[574]Current process memory 2.8545e+07 max process memory 6.5921e+07
[575]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[575]Current process memory 3.40582e+07 max process memory 7.12786e+07
[576]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[576]Current process memory 3.29523e+07 max process memory 6.8436e+07
[577]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[577]Current process memory 3.29196e+07 max process memory 7.09714e+07
[578]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90739e+06
[578]Current process memory 3.24731e+07 max process memory 6.9206e+07
[579]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[579]Current process memory 3.23215e+07 max process memory 6.74324e+07
[580]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[580]Current process memory 3.33537e+07 max process memory 6.81615e+07
[581]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89592e+06
[581]Current process memory 3.35258e+07 max process memory 6.78584e+07
[582]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89539e+06
[582]Current process memory 3.39845e+07 max process memory 6.90463e+07
[583]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90696e+06
[583]Current process memory 2.96305e+07 max process memory 6.88456e+07
[584]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[584]Current process memory 3.38944e+07 max process memory 6.9333e+07
[585]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[585]Current process memory 2.97124e+07 max process memory 6.79281e+07
[586]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[586]Current process memory 2.91717e+07 max process memory 6.79076e+07
[587]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90698e+06
[587]Current process memory 2.92332e+07 max process memory 6.81288e+07
[588]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[588]Current process memory 2.94175e+07 max process memory 6.83581e+07
[589]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[589]Current process memory 2.9524e+07 max process memory 6.89971e+07
[590]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89405e+06
[590]Current process memory 2.93601e+07 max process memory 6.88374e+07
[591]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90702e+06
[591]Current process memory 2.95281e+07 max process memory 6.58555e+07
[592]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[592]Current process memory 2.9143e+07 max process memory 6.42171e+07
[593]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[593]Current process memory 2.93601e+07 max process memory 6.3873e+07
[594]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[594]Current process memory 2.95485e+07 max process memory 6.57613e+07
[595]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[595]Current process memory 3.42876e+07 max process memory 7.10615e+07
[596]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90699e+06
[596]Current process memory 3.35503e+07 max process memory 6.85711e+07
[597]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[597]Current process memory 3.39558e+07 max process memory 7.15694e+07
[598]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[598]Current process memory 3.35831e+07 max process memory 6.98696e+07
[599]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[599]Current process memory 3.32718e+07 max process memory 6.78912e+07
[600]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.9068e+06
[600]Current process memory 3.31162e+07 max process memory 6.83377e+07
[601]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[601]Current process memory 3.2768e+07 max process memory 6.75635e+07
[602]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[602]Current process memory 3.33906e+07 max process memory 6.92224e+07
[603]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[603]Current process memory 3.3493e+07 max process memory 6.88169e+07
[604]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90683e+06
[604]Current process memory 3.35299e+07 max process memory 6.95501e+07
[605]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[605]Current process memory 2.82788e+07 max process memory 6.75144e+07
[606]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[606]Current process memory 3.30506e+07 max process memory 6.79526e+07
[607]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[607]Current process memory 3.32227e+07 max process memory 6.81247e+07
[608]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[608]Current process memory 2.91758e+07 max process memory 6.93002e+07
[609]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90718e+06
[609]Current process memory 3.37306e+07 max process memory 6.91569e+07
[610]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[610]Current process memory 3.3833e+07 max process memory 6.91855e+07
[611]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[611]Current process memory 2.893e+07 max process memory 6.6261e+07
[612]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[612]Current process memory 2.83894e+07 max process memory 6.42867e+07
[613]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90715e+06
[613]Current process memory 2.86433e+07 max process memory 6.35576e+07
[614]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.8952e+06
[614]Current process memory 2.84262e+07 max process memory 6.61094e+07
[615]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89571e+06
[615]Current process memory 3.42344e+07 max process memory 7.14179e+07
[616]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[616]Current process memory 3.37101e+07 max process memory 6.91118e+07
[617]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[617]Current process memory 3.4005e+07 max process memory 7.19913e+07
[618]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90686e+06
[618]Current process memory 3.36609e+07 max process memory 7.03324e+07
[619]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[619]Current process memory 3.34889e+07 max process memory 6.85425e+07
[620]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[620]Current process memory 3.33906e+07 max process memory 6.76291e+07
[621]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[621]Current process memory 3.33128e+07 max process memory 6.70802e+07
[622]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.9068e+06
[622]Current process memory 3.36773e+07 max process memory 6.87432e+07
[623]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[623]Current process memory 2.95936e+07 max process memory 6.84564e+07
[624]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[624]Current process memory 2.91758e+07 max process memory 6.91651e+07
[625]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[625]Current process memory 2.90693e+07 max process memory 6.72481e+07
[626]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90694e+06
[626]Current process memory 2.94789e+07 max process memory 6.75062e+07
[627]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[627]Current process memory 2.97288e+07 max process memory 6.78871e+07
[628]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[628]Current process memory 2.961e+07 max process memory 6.79076e+07
[629]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89555e+06
[629]Current process memory 2.93847e+07 max process memory 6.81861e+07
[630]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89507e+06
[630]Current process memory 2.91799e+07 max process memory 6.79813e+07
[631]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.90706e+06
[631]Current process memory 2.96878e+07 max process memory 6.53804e+07
[632]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[632]Current process memory 2.95117e+07 max process memory 6.38771e+07
[633]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[633]Current process memory 2.95977e+07 max process memory 6.33242e+07
[634]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[634]Current process memory 2.94339e+07 max process memory 6.51919e+07
[635]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.9068e+06
[635]Current process memory 3.42139e+07 max process memory 7.08116e+07
[636]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[636]Current process memory 2.96182e+07 max process memory 6.82189e+07
[637]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[637]Current process memory 3.38289e+07 max process memory 7.08772e+07
[638]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89392e+06
[638]Current process memory 3.36159e+07 max process memory 6.93576e+07
[639]Current space PetscMalloc()ed 400976, max space PetscMalloced() 1.89357e+06
[639]Current process memory 3.32227e+07 max process memory 6.72686e+07
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
BiGlobal_Spectral_Petsc.x on a linux-gnu-debug-mumps-superludist-complex named nid00020 with 640 processors, by anthony Mon Jul  6 19:17:34 2015
Using Petsc Release Version 3.6.0, Jun, 09, 2015
                         Max       Max/Min        Avg      Total
Time (sec):           9.893e+01      1.00002   9.893e+01
Objects:              4.600e+01      1.00000   4.600e+01
Flops:                0.000e+00      0.00000   0.000e+00  0.000e+00
Flops/sec:            0.000e+00      0.00000   0.000e+00  0.000e+00
Memory:               2.010e+06      1.06134              1.232e+09
MPI Messages:         2.468e+03      2.10221   1.194e+03  7.643e+05
MPI Message Lengths:  2.667e+06     55.30826   4.467e+01  3.415e+07
MPI Reductions:       1.060e+02      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 9.8928e+01 100.0%  0.0000e+00   0.0%  7.643e+05 100.0%  4.467e+01      100.0%  1.050e+02  99.1%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
      #                          WARNING!!!                    #
      #   The code for various complex numbers numerical       #
      #   kernels uses C++, which generally is not well        #
      #   optimized.  For performance that is about 4-5 times  #
      #   faster, specify --with-fortran-kernels=1             #
      #   when running ./configure.py.                         #
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecCopy                2 1.0 5.1975e-05 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet                 8 1.0 2.1489e-03 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyBegin       3 1.0 1.8239e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  6   0  0  0  0  6     0
VecAssemblyEnd         3 1.0 9.0837e-05 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin        2 1.0 4.7238e-0358.1 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  1  2   0  0  0  1  2     0
MatSolve               2 1.0 6.2515e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatLUFactorSym         1 1.0 5.8460e-03 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum         1 1.0 9.0827e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 92  0  0  0  0  92  0  0  0  0     0
MatAssemblyBegin       3 1.0 8.5411e-03 7.3 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  6   0  0  0  0  6     0
MatAssemblyEnd         3 1.0 4.6783e+00 1.0 0.00e+00 0.0 7.6e+05 3.7e+01 4.2e+01  5  0100 84 40   5  0100 84 40     0
MatGetRow             70 1.0 6.0654e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            1 1.0 2.2888e-05 4.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 5.9700e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatView                2 1.0 9.6297e-04 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  2   0  0  0  0  2     0
MatAXPY                1 1.0 4.5847e-02 1.0 0.00e+00 0.0 3.8e+05 3.7e+01 2.2e+01  0  0 50 42 21   0  0 50 42 21     0
KSPSetUp               1 1.0 1.6928e-05 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               2 1.0 9.1463e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+01 92  0  0  0 17  92  0  0  0 17     0
PCSetUp                1 1.0 9.0836e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.1e+01 92  0  0  0 10  92  0  0  0 10     0
PCApply                2 1.0 6.2523e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector    12             10       541888     0
      Vector Scatter     5              5         4488     0
              Matrix    12             12       709200     0
           Index Set    14             14        53412     0
       Krylov Solver     1              1         1136     0
      Preconditioner     1              1          984     0
              Viewer     1              0            0     0
Average time to get PetscTime(): 1.90735e-07
Average time for MPI_Barrier(): 3.11852e-05
Average time for zero size MPI_Send(): 1.06096e-06
#PETSc Option Table entries:
-eps_view
-ksp_type preonly
-log_summary
-malloc_log
-memory_info
-pc_factor_mat_solver_package superlu_dist
-pc_type lu
-st_ksp_type preonly
-st_pc_factor_mat_solver_package superlu_dist
-st_pc_type lu
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 16 sizeof(PetscInt) 4
Configure options: PETSC_ARCH=linux-gnu-debug-mumps-superludist-complex CC=cc CXX=CC FC=ftn --useThreads=1 --with-x=0 --with-clib-autodetect=0 --with-cxxlib-autodetect=0 --with-fortranlib-autodetect=0 --with-scalar-type=complex --download-fblaslapack --download-scalapack --download-metis --download-parmetis --download-mumps --download-superlu_dist
Libraries compiled on Wed Jul  1 16:28:12 2015 on garnet06
Machine characteristics: Linux-2.6.32.59-0.7-default-x86_64-with-SuSE-11-x86_64
Using PETSc directory: /lustre/home1/u/anthony/petsc-3.6.0
Using PETSc arch: linux-gnu-debug-mumps-superludist-complex
Using C compiler: cc  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -O0  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: ftn  -fPIC -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/lustre/home1/u/anthony/petsc-3.6.0/linux-gnu-debug-mumps-superludist-complex/include -I/lustre/home1/u/anthony/petsc-3.6.0/include -I/lustre/home1/u/anthony/petsc-3.6.0/include -I/lustre/home1/u/anthony/petsc-3.6.0/linux-gnu-debug-mumps-superludist-complex/include
Using C linker: cc
Using Fortran linker: ftn
Using libraries: -Wl,-rpath,/lustre/home1/u/anthony/petsc-3.6.0/linux-gnu-debug-mumps-superludist-complex/lib -L/lustre/home1/u/anthony/petsc-3.6.0/linux-gnu-debug-mumps-superludist-complex/lib -lpetsc -Wl,-rpath,/lustre/home1/u/anthony/petsc-3.6.0/linux-gnu-debug-mumps-superludist-complex/lib -L/lustre/home1/u/anthony/petsc-3.6.0/linux-gnu-debug-mumps-superludist-complex/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lsuperlu_dist_4.0 -lflapack -lfblas -lparmetis -lmetis -ldl
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
Option left: name:-eps_view (no value)
Option left: name:-st_ksp_type value: preonly
Option left: name:-st_pc_factor_mat_solver_package value: superlu_dist
Option left: name:-st_pc_type value: lu
[0] Maximum memory PetscMalloc()ed 2009712 maximum size of entire process 70217728
[0] Memory usage sorted by function
[0] 2 3216 ClassPerfLogCreate()
[0] 2 9616 EventPerfLogCreate()
[0] 1 19200 EventPerfLogEnsureSize()
[0] 2 1616 EventRegLogCreate()
[0] 1 3200 EventRegLogRegister()
[0] 14 10528 ISCreate()
[0] 9 144 ISCreate_General()
[0] 5 80 ISCreate_Stride()
[0] 6 42688 ISGeneralSetIndices_General()
[0] 3 42368 ISGetIndices_Stride()
[0] 6 416 ISSetPermutation()
[0] 1 16 KSPConvergedDefaultCreate()
[0] 1 1136 KSPCreate()
[0] 2 288 MatAXPY_MPIAIJ()
[0] 12 27648 MatCreate()
[0] 4 768 MatCreate_MPIAIJ()
[0] 8 3200 MatCreate_SeqAIJ()
[0] 1 416 MatGetFactor_aij_superlu_dist()
[0] 2 288 MatGetOrdering()
[0] 1 32 MatGetOrdering_Natural()
[0] 4 5984 MatGetRow_MPIAIJ()
[0] 3 320 MatInodeAdjustForInodes_SeqAIJ_Inode()
[0] 6 864 MatMarkDiagonal_SeqAIJ()
[0] 8 256 MatRegisterBaseName()
[0] 3 432 MatSeqAIJCheckInode()
[0] 36 634224 MatSeqAIJSetPreallocation_SeqAIJ()
[0] 3 42384 MatSetUpMultiply_MPIAIJ()
[0] 23 1008 MatSolverPackageRegister()
[0] 8 30720 MatStashCreate_Private()
[0] 18 30816 MatStashScatterBegin_Private()
[0] 1 144 Mat_CreateColInode()
[0] 1 816 PCCreate()
[0] 1 176 PCCreate_LU()
[0] 2 1616 PetscClassRegLogCreate()
[0] 2 32 PetscCommDuplicate()
[0] 374 11968 PetscFunctionListAdd_Private()
[0] 12 57168 PetscGatherMessageLengths()
[0] 12 30720 PetscGatherNumberOfMessages()
[0] 2 528 PetscIntStackCreate()
[0] 50 3200 PetscLayoutCreate()
[0] 43 44208 PetscLayoutSetUp()
[0] 4 64 PetscLogView_Default()
[0] 4 20480 PetscMaxSum()
[0] 14 1120 PetscObjectComposedDataIncreaseReal()
[0] 5 128 PetscOptionsGetEList()
[0] 3 48 PetscPostIrecvInt()
[0] 3 48 PetscPostIrecvScalar()
[0] 1 32 PetscPushSignalHandler()
[0] 2 10048 PetscSegBufferCreate()
[0] 2 1328 PetscStageLogCreate()
[0] 676 16032 PetscStrallocpy()
[0] 639 5234688 PetscSynchronizedFlush()
[0] 30 281568 PetscTableAddExpand()
[0] 9 1824 PetscTableCreate()
[0] 1 16 PetscViewerASCIIOpen()
[0] 1 688 PetscViewerCreate()
[0] 1 80 PetscViewerCreate_ASCII()
[0] 1 2576 VecAssemblyBegin_MPI()
[0] 12 18048 VecCreate()
[0] 9 2256 VecCreate_MPI_Private()
[0] 6 1235056 VecCreate_Seq()
[0] 6 192 VecCreate_Seq_Private()
[0] 11 13616 VecScatterCreate()
[0] 6 4800 VecScatterCreateCommon_PtoS()
[0] 75 671072 VecScatterCreate_PtoS()
[0] 12 30720 VecStashCreate_Private()
[0] 8 30720 VecStashScatterBegin_Private()
Time for baseflow computation =         94.0019 seconds.
On Processor (entering module)  0    memory:    0.68481024000E+08
On Processor (after matcreate)  0    memory:    0.68489216000E+08
Time Partial Parallel Build A #1 =                 1.128 seconds.
Time Partial Parallel Build A #2 =                 0.048 seconds.
On Processor (A just before assembly)  0    memory:    0.68517888000E+08
Time to assemble A =                 0.116 seconds.
On Processor (A build and assembled)  0    memory:    0.68521984000E+08
On Processor (B build and assembled)  0    memory:    0.68521984000E+08
Time to build and assemble B =                 0.004 seconds.
 norm A:   1297526.6999112994
 norm B:   258.07557032776270
On Processor (begin slepc)  0    memory:    0.68911104000E+08
On Processor (slepc after EPSSetType)  0    memory:    0.69107712000E+08
On Processor (before EPSGetST)  0    memory:    0.69111808000E+08
On Processor (after EPSSetFromOptions)  0    memory:    0.69369856000E+08
Can't expand MemType 1: jcol 16104
[NID 00037] 2015-07-06 19:19:14 Apid 31025976: initiated application termination
[NID 00037] 2015-07-06 19:19:17 Apid 31025976: OOM killer terminated this process.
Application 31025976 exit signals: Killed
Application 31025976 resources: utime ~20s, stime ~25s, Rss ~3920, inblocks ~714100, outblocks ~2221320
