[petsc-users] Weird behavior for log_summary
Michele Rosso
mrosso at uci.edu
Wed Jul 1 16:52:21 CDT 2015
Hi Barry,
I accidentally found out what triggers the problem with log_summary.
If I specify log_summary from command line, it works as expected. If
instead I open and load an options file with -log_summary in it,
the output is incomplete.
I am actually concerned about using options files now because this weird
behavior could affect the correct loading of other options as well.
Michele
On Fri, 2015-06-05 at 21:34 -0500, Barry Smith wrote:
> [NID 04001] 2015-06-04 19:07:24 Apid 25022256: initiated application termination
> Application 25022256 exit signals: Killed
> Application 25022256 resources: utime ~271s, stime ~15107s, Rss ~188536, inblocks ~5078831, outblocks ~12517984
> Usually this kind of message indicates that either the OS or the batch system killed the process for some reason: often because it ran out of time or maybe memory.
> Can you run in batch with a request for more time? Do smaller jobs run through ok?
> If utime means user time and stime means system time then this is very bad, the system time is HUGE relative to the user time.
> Barry
> > On Jun 5, 2015, at 9:22 PM, Michele Rosso <mrosso at uci.edu> wrote:
> > Hi,
> > I am checking the performances of my code via -log_summary, but the output is incomplete (please see attached) file.
> > I configured petsc with the following options:
> > if __name__ == '__main__':
> > import sys
> > import os
> > sys.path.insert(0, os.path.abspath('config'))
> > import configure
> > configure_options = [
> > '--with-batch=1 ',
> > '--known-mpi-shared=0 ',
> > '--known-mpi-shared-libraries=0',
> > '--known-memcmp-ok ',
> > '--with-blas-lapack-lib=-L/opt/acml/5.3.1/gfortran64/lib -lacml',
> > '--COPTFLAGS=-march=bdver1 -fopenmp -O3 -ffast-math -fPIC ',
> > '--FOPTFLAGS=-march=bdver1 -fopenmp -O3 -ffast-math -fPIC ',
> > '--CXXOPTFLAGS=-march=bdver1 -fopenmp -O3 -ffast-math -fPIC ',
> > '--with-x=0 ',
> > '--with-debugging=0',
> > '--with-clib-autodetect=0 ',
> > '--with-cxxlib-autodetect=0 ',
> > '--with-fortranlib-autodetect=0 ',
> > '--with-shared-libraries=0 ',
> > '--with-mpi-compilers=1 ',
> > '--with-cc=cc ',
> > '--with-cxx=CC ',
> > '--with-fc=ftn ',
> > # '--with-64-bit-indices',
> > '--download-hypre=1',
> > '--download-blacs=1 ',
> > '--download-scalapack=1 ',
> > '--download-superlu_dist=1 ',
> > '--download-metis=1 ',
> > '--download-parmetis=1 ',
> > configure.petsc_configure(configure_options)
> > Any idea about this issue?
> > Thanks,
> > Michele
> > <log_summary>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150701/67aa09dc/attachment.html>
