[petsc-users] petsc-3.5.3.tar.gz now available
Sat Jan 31 09:50:54 CST 2015
Dear PETSc users,
The patch release petsc-3.5.3 is now available for download.
http://www.mcs.anl.gov/petsc/download/index.html
Some of the changes include:
 * BJacobi: optimize KSP/PCSetReusePreconditioner() for bjacobi with
   one block per process
 * DM: update validity checks in DMLocalToGlobalBegin_DA
 * lsqr:  bugfix when beta==0.0
 * fortran: enable interface for MatMAIJGetAIJ(), VecSetOptionsPrefix()
 * pastix: update to bugfix version 5.2.2.12
 * build: update suitesparse build with correct value for 'long long' indices.
 * TS: TSAdapt fixes and update error checks in TS
 * IS: fix memory leak in ISConcatenate
 * Vec: VecSetValues, VecSetValuesLocal and VecGetValues - do not
   check for validity of array pointers - when no-of-entries=0
 * build: fix --download-openmpi to workarround -Wall failure
 * Mat:  bugfix for MatConvertToTriples_seqaij_seqsbaij()
 * PCMG: allow user to provide either interpolation or restriction
   operator with Galerkin coarse grid operators
 * Mat: fix memory allocation error where space is allocated in
   MatMult_SeqBAIJ with a space shorter than that needed in
   MatSOR_SeqBAIJ
 * KSP: allow Schur complement to be non-square
 * Vec: VecLoad_HDF5_DA() do not ignore group information
 * Mat: fix MatAXPY() for SUBSET_NONZERO_PATTERN case for sbaij matrix
 * Mat: Allow setting the matrix block size with MatSetBlockSize() before calling MatLoad()
 * configure: add option to disable prefetch check: [--with-prefetch=0]
 * configure: fix for Apple's blas in single precision (sdot and snrm2
   return double precision number instead of float)
 * KSP: fixes for zero rank eigen calc.
 * Mat: fix memory leak of MatAXPY in the case of SUBSET_NONZERO_PATTERN
 * Mat: Added MatForward/BackwardSolve for SeqBAIJ block size 1-3 natural ordering
 * Tao: reassemble hessian after bqpip sets diagonal
 * Vec: fix VecMedian() restore parameter
 * PCASM remove "error check" for non-overlapping subdomains that
   prevents valid subdomains being provided by users
 * Mat: fix for MatMatMut_MPIAIJ_MPIAIJ, MatMatMult_xxx_nonscalable()
   when np=1 by pass parts of the code that for np>1
 * fix: The PETSc macros MPI_Scatter() and friends could call
   MPI_Type_size() on MPI_DATATYPE_NULL which triggers an error with
   some MPI implementations
 * Vec: Fixes bug in VecMTDot_Seq/MPI where it did not work correctly
   for more than four vectors
 * Tao: bug fixes, check for repeated model in POUNDERS
 * Vec: fix VecRestoreSubVector for non-contiguous SubVector.
Satish
