[petsc-users] Is PetscViewerBinary special?
Barry Smith
bsmith at mcs.anl.gov
Fri Jan 30 07:56:12 CST 2015
Dave,
I did the mpiio hack originally and yes it is very ad hoc and could do with a good reorganization. I am fine with accepting a branch that treats the MPIIO one as a completely different class; the only reason not to do this is if both classes have essentially the same code but no reuse between them.
Barry
> On Jan 30, 2015, at 7:51 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
> Thanks Matt.
> Given the PETSc way of doing things, I believe the following should be possible:
> [1] attach an option prefix to a viewer
> [2] skip the header on some binary viewers
> [3] use mpiio for some binary viewers, but not all of them.
> However, it doesn't appear to be completely simple to allow this behaviour.
> For instance, replacing
> ierr = PetscOptionsGetBool(NULL,"-viewer_binary_mpiio",&useMPIIO,NULL);CHKERRQ(ierr);
> with
> ierr = PetscOptionsGetBool(((PetscObject)viewer)->prefix,"-viewer_binary_mpiio",&useMPIIO,NULL);CHKERRQ(ierr);
> won't work as an option prefix will never have been set.
> If I was to add a PetscViewerSetFromOptions_Binary(), I would have to ensure that PetscViewerSetFromOptions() was called before PetscViewerFileSetName() was called as the latter this triggers a swap of the functions used to open binary file, e.g. from PetscViewerFileSetName_Binary() to PetscViewerFileSetName_MPIIO()
> Would it be simpler and cleaner to have MPIIO be defined as an independent implementation which was a sub-class of the binary class?
> Then we could use command line flags to switch between implementations at runtime
> -xxx_viewer_type binary
> versus
> -xxx_viewer_type mpiio
> rather than having to use
> -xxx_viewer_type binary -viewer_binary_mpiio
> which has obvious short comings like forcing all binary viewers, independent of the prefix to use mpiio. It would also allow the PetscViewer object to be used in a manner which follows the standard PETSc pattern of: XXCreate(), XXSetOptionsPrefix(), XXSetType(), XXSetFromOptions().
> Then we could do this
> PetscViewerCreate()
> PetscViewerSetOptionsPrefix()
> PetscViewerSetType()
> PetscViewerFileSetMode()
> PetscViewerBinarySetSkipHeader()
> and it wouldn't matter which order SetName(), BinarySkipHeader() etc were called.
> What do people think?
> Cheers
> Dave
> On 30 January 2015 at 13:56, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 30, 2015 at 2:06 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
> Hello,
> I've noticed the create function PetscViewerCreate_Binary() doesn't appear to be using the options prefix attached to the PetscViewer.
> Specifically, I see on line 1276 of
> petsc-3.5.2/src/sys/classes/viewer/impls/binary/binv.c
> the following
> Is this an oversight or something intentional?
> This is an oversight.
> Matt
> Are PetscViewers in general behaving such that they cannot be configured independently of each other if
> PetscViewerSetOptionsPrefix() and PetscViewerSetFromOptions() are called?
> Cheers
> Dave
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
