[petsc-users] Refinement, interpolation, and auxiliary data
Wed Jan 21 06:49:42 CST 2015
On Tue, Jan 20, 2015 at 5:06 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Matt,
> 1) I am not sure if I fully understand the difference between those two
> types of refinement you just described. If I understand this correctly, in
> the first method, Triangle and TetGen will refine the mesh based on the
> refinement limit (largest allowable cell size) but doesn't necessarily
> have  to uniformly refine the mesh, meaning the box/cube mesh could end up
> looking very distorted and unstructured with various element sizes. And in
> the second method, it ensures that all elements/cells are refined the same
> number of times no matter how what method was used to create the DMPlex
> mesh. Or am I missing something?
Yes, that is right.
> 2) Okay that makes sense.
> 3) Generally speaking the data would be cell-wise, but hypothetically what
> if I had to work with data that's defined at the cell vertices? Data like
> the Marmousi set (btw the link I proved was sort of broken, here is another
> link
> <http://www.reproducibility.org/RSF/book/data/marmousi/paper_html/node2.html>
> to it) is pointwise, but i am sure it could be preprocessed and
> interpolated to cell-centered data. When I see your run examples in
> builder.py for SNES ex12, you have the flag "-mat_petscspace_order 1" even
> when -petscspace_order is 2. So I guess my question is does the order of
> the material/auxiliary FE necessarily have to match that of the trial
> function FE?
No, its does not. As you noted, there are tests for ex12 that have
different orders for the coefficient and the solution.
This month is completely busy for me, but I think I will have time to meet
in Feb.
     Matt
> Thanks,
> Justin
> On Tue, Jan 20, 2015 at 5:45 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Tue, Jan 20, 2015 at 3:06 AM, Justin Chang <jychang48 at gmail.com>
>> wrote:
>>> Hi all,
>>> I have a few simple questions regarding DMPlex mesh refinement,
>>> interpolation, and auxiliary data:
>>> 1) What exactly does DMPlexSetRefinementUniform do? Is it relevant only
>>> for the DMPlexCreateBoxMesh() function?
>> Plex supports two types of refinement now. First, you can call a mesh
>> generator for refinement, like Triangle or TetGen. Second,
>> you can uniformly refine cells, although I have only coded this for
>> simplices and tensor products. The uniform refinement works
>> on any mesh, not just the builtin ones.
>>> 2) When I interpolate a given DMPlex mesh, what becomes of the
>>> "boundary" edge/face labels and/or IDs? That is, say if I had a 2D simplex
>>> element on the boundary domain and two of its vertices are assigned
>>> different marker ID's and/or labels, what will become of those intermediate
>>> mesh point(s) become?
>> I do not mark them. That is up to the application, since there is no way
>> to do it generically. What I do in my simple code is to use
>> MarkBoundaryFaces() and LabelComplete(). For complex things, I use the
>> ExodusII format for marking faces.
>>> 3) If I have highly heterogeneous diffusivity or permeability (e.g.,
>>> random permeability or a marmousi
>>> <http://www.caam.rice.edu/~benamou/OLD/marmousi.html>data set) that
>>> need to be read in as auxiliary coefficients, would I need to manually
>>> interpolate the data for the intermediate mesh points before I project the
>>> field into the FE space, or does PETSc have an ability somewhere to
>>> automatically interpolate these values for you?
>> You have to explain more about what this data means. Is it cell-wise
>> data? If so, why do you need to interpolate?
>> Shouldn't it just be in P0? If not, you can project the P0 data into any
>> other space using either ProjectFunction()
>> or a slightly modified version of DMPlexComputeInterpolatorFEM().
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Justin
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150121/e1f9f35d/attachment.html>
