[petsc-users] MatEqual and explicit zero behaviour
Jørgen Kvalsvik
jorgekva at stud.ntnu.no
Wed Jan 21 06:25:17 CST 2015
I was unable to find this in the PETSc docs nor any relevant example
through search engines.
I have two matrices, A and B.
A:
PetscScalar values[] = {
10.0, 0, 0, 0, 0, 5.72,
0.2, 0, 0, 0, 0, 0,
0, 0, 4.2, 0, 0, 0,
0, 0, 0, 3.4, 0, 0,
0, 0, 3.14, 0, 0, 0,
0, 0, 0, 0, 0, 0 };
And an array [0..6] passed to both row and columns in my MatSetValues call.
err = MatSetValues( A,
6, indices,
6, indices,
values, INSERT_VALUES );
B is constructed from CSR:
PetscInt csr_rows[] = { 0, 2, 3, 4, 5, 6, 6 };
PetscInt csr_cols[] = { 0, 5, 0, 2, 3, 2 };
PetscScalar csr_vals[] = { 10.0, 5.72, 0.2, 4.2, 3.4, 3.14 };
for( int i = 0; i < rows - 1; ++i ) {
PetscInt row_entries = csr_rows[ i + 1 ] - csr_rows[ i ];
PetscInt row_index[] = { i };
PetscInt offset = csr_rows[ i ];
1, row_index,
row_entries, csr_cols + offset,
csr_vals + offset, INSERT_VALUES );
Printing them with PetscView gives:
A:
Matrix Object: 1 MPI processes
type: seqaij
row 0: (0, 10) (1, 0) (2, 0) (3, 0) (4, 0) (5, 5.72)
row 1: (0, 0.2) (1, 0) (2, 0) (3, 0) (4, 0) (5, 0)
row 2: (0, 0) (1, 0) (2, 4.2) (3, 0) (4, 0) (5, 0)
row 3: (0, 0) (1, 0) (2, 0) (3, 3.4) (4, 0) (5, 0)
row 4: (0, 0) (1, 0) (2, 3.14) (3, 0) (4, 0) (5, 0)
row 5: (0, 0) (1, 0) (2, 0) (3, 0) (4, 0) (5, 0)
B:
type: seqaij
row 0: (0, 10) (5, 5.72)
row 1: (0, 0.2)
row 2: (2, 4.2)
row 3: (3, 3.4)
row 4: (2, 3.14)
row 5:
Which, as far as I can tell, are identical matrices.
But here's the problem. When I compare them with MatEqual it gives me
false, which I did not expect. Is there some undocumented behaviour
regarding explicit and implicit zeroes, and is this intentional? Is it
not possible to compare matrices with different structures?
Thanks
