[petsc-users] customized MatMult
Mon Jan 19 10:38:34 CST 2015
> On Jan 19, 2015, at 10:09 AM, Marco Cisternino <marco.cisternino at optimad.it> wrote:
> Thank you Matthew,
> If I have understood:
> - I have to pass to myMatMult global vecs. And Vec created with VecGhostCreate are global, right?
> - In myMatMult I use VecGetArray, I store my result in the associated c-array, I call VecRestoreArray and the global vec is done! Right?
> - If I re-use VecGetArray/VecRestore array, ghosted locations in the c-array are updated, right?
   VecGet/RestoreArray() does not trigger updating ghost points. You need to use VecGhostUpdateBegin/End() see the manual page to update the ghost points.
  barry
> I'm sorry about confusion and thanks, again.
> Marco
> Marco Cisternino, PhD
> Software Developer
> OPTIMAD Engineering s.r.l.
> Via Giacinto Collegno 18
> 10143 Torino - Italy
> www.optimad.it
> +39 011 19719782
> Da: "Matthew Knepley" <knepley at gmail.com>
> A: "Marco Cisternino" <marco.cisternino at optimad.it>
> Cc: petsc-users at mcs.anl.gov
> Inviato: Lunedì, 19 gennaio 2015 16:40:28
> Oggetto: Re: [petsc-users] customized MatMult
> On Mon, Jan 19, 2015 at 9:28 AM, Marco Cisternino <marco.cisternino at optimad.it> wrote:
> Good morning,
> I'm writing my MatMult function, but I don't know how to treat the ghost elements of the result vec. Let's say myMatMult(A,x,y).
> First question is: if I use my MatMult in a KSP to solve a linear system, do I have to update ghost elements in the result vec of MatMult?? Consider that any time the code enters myMatMult the vec x is copied in my container and the ghost of my container are updated. I made computation for matrix-vector and I copied the results in vec y, without considering ghost elements of y.
> Second question: if I have to, how?
> Let's say I state:
> ierr = myMatMult(A,x,y);
> and x has been built out of myMatMult with VecGhostCreate.
> How do I update ghost elements of y in myMatMult? VecGhostUpdateBegin/VecGhostUpdateEnd in myMatMult?
> Any hints would be appreciated.
> There is some confusion here about the spaces that Vecs represent. Vecs in the solver are globally
> assembled vectors, which come from the "global" space. Vecs used in calculated integrals, differences,
> etc. for assembly often have ghost entries. We will say that these come from the "local" space.
> MatMult takes in a global Vec x and returns a global Vec y.
>   Hopefully that is clear,
>      Matt
> Thanks for you advices in advance.
> Bests,
> Marco
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
