[petsc-users] PETSc 3.5.2 on Mac OS X Yosemite, configuring gives C preprocessor error
Satish Balay
balay at mcs.anl.gov
Sun Jan 18 15:03:38 CST 2015
Checking for program /usr/local/bin/gcc...found
Executing: gcc -c -o /var/folders/_v/0817pkss07z1y_v4bzw9ssy80000gn/T/petsc-y_tzNl/config.setCompilers/conftest.o -I/var/folders/_v/0817pkss07z1y_v4bzw9ssy80000gn/T/petsc-y_tzNl/config.setCompilers /var/folders/_v/0817pkss07z1y_v4bzw9ssy80000gn/T/petsc-y_tzNl/config.setCompilers/conftest.c
Possible ERROR while running compiler:
stderr:
gcc: warning: couldn’t understand kern.osversion ‘14.0.0
You have broken gcc in your PATH. [it broke due to Yosemite
upgrade]. Is this homewrew or something else? You should delete your
/usr/local and reinstall whatever you need in there.
However wrt PETSc - you can use:
./configure --with-cc=/usr/bin/clang --with-cxx=/usr/bin/clang++ --with-fc=0 --download-mpich --with-debugging=0
However if you need gfortran - you would have to do the 'reinstall
/usr/local' stuff for that.
Satish
On Sun, 18 Jan 2015, Justin Dong wrote:
> Sorry, configure.log is attached below.
> On Sun, Jan 18, 2015 at 3:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > We need configure.log
> > You do not need --download-blaslapack Apple always has them
> > Suggest just running without passing the compiler names also.
> > Barry
> > > On Jan 18, 2015, at 2:45 PM, Justin Dong <jdong217 at gmail.com> wrote:
> > > Hi all,
> > > I just updated to OS X Yosemite. I have the latest XCode and also
> > reinstalled command line developer tools.
> > > When I try to install PETSc, I get the following error:
> > > ./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> > --download-fblaslapack --download-mpich --with-debugging=0
> > > Configuring PETSc to compile on your system
> > > TESTING: checkCPreprocessor from
> > config.setCompilers(config/BuildSystem/config/setCompilers.py:568)
> > > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
> > for details):
> > > Cannot find a C preprocessor
> > > Can someone explain to me what's going on here?
> > > Thanks,
> > > Justin
