[petsc-users] WHY "C++ error! MPI_Finalize() could not be located!"? Thanks.
Jerry
orzgodlo at gmail.com
Sat Jan 17 13:18:44 CST 2015
Hi, Matthew.
Please find attached the configure log. Thanks.
-Jerry
2015-01-17 4:52 GMT-08:00 Matthew Knepley <knepley at gmail.com>:
> Send the whole configure.log
> Thanks,
> Matt
> On Sat, Jan 17, 2015 at 4:07 AM, Jerry <orzgodlo at gmail.com> wrote:
>> Hi, all.
>> I am trying to configure&compile petsc. However, during configuring, I
>> got the following error (C++ error! MPI_Finalize() could not be located!).
>> I am also copying the last few lines in configure.log.
>> But I am sure mpi.h is under the folder I specified
>> (--with-mpi-include=/usr/include/mpi )
>> Any idea about the problem? Thanks.
>> $$ ./configure --prefix=~/local --with-cc=gcc --with-cxx=g++
>> --with-fc=gfortran --with-mpi-include=/usr/include/mpi
>> --with-mpi-lib=/usr/lib/libmpi.so
>> Configuring PETSc to compile on your
>> system
>> TESTING: CxxMPICheck from
>> config.packages.MPI(config/BuildSystem/config/packages*******************************************************************************
>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
>> details):
>> =========== Last few lines from configure.log ================
>> File "./config/configure.py", line 272, in petsc_configure
>> framework.configure(out = sys.stdout)
>> File
>> "/home/delia/workspace/programs/petsc/config/BuildSystem/config/framework.py",
>> line 941, in configure
>> child.configure()
>> File
>> "/home/delia/workspace/programs/petsc/config/BuildSystem/config/package.py",
>> line 606, in configure
>> self.executeTest(self.configureLibrary)
>> File
>> "/home/delia/workspace/programs/petsc/config/BuildSystem/config/base.py",
>> line 126, in executeTest
>> ret = test(*args,**kargs)
>> File
>> "/home/delia/workspace/programs/petsc/config/BuildSystem/config/packages/MPI.py",
>> line 660, in CxxMPICheck
>> raise RuntimeError('C++ error! MPI_Finalize() could not be located!')
>> Finishing Configure Run at Sat Jan 17 01:34:31 2015
>> Jerry
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150117/d7a70260/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150117/d7a70260/attachment-0001.bin>
