[petsc-users] Lumped matrix
Jed Brown jed at jedbrown.org
Tue Jan 6 12:46:04 CST 2015
Eric Chamberland <Eric.Chamberland at giref.ulaval.ca> writes:
> Hi,
> We are asking ourselves what would be the most efficient way to
> create/do assembly/solve a problem involving a lumped matrix in PETSC?
Lumping frequently comes from reduced quadrature, so you could simply
use the reduced quadrature.  Lumping in a solver often comes from
computing row sums instead of the diagonal for Jacobi
smoothers/preconditioners.  In that case, just -pc_jacobi_type rowsum.
> #1- To create the matrix: Use an standard AIJ with 1 nnz per line
> (didn't find any lumped or diagonal type)?
Right, or assemble the normal matrix and use Jacobi as above.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150106/76871a5b/attachment.pgp>
