[petsc-users] Least Square solver LSQR
Natacha BEREUX natacha.bereux at gmail.com
Tue Jan 6 03:57:48 CST 2015
Dear  PETSc users,
I am trying to solve an over determined linear system of equations Ax =b
with the least square solver LSQR.
The matrix A is rectangular : it has m rows and n columns with m>n.
I set the preconditioner to "PCNONE"  (following for instance post
https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2012-May/013591.html)
Matrix A has the form :
A(1:n,1:n)        = Identity(n)
A(n+1:m, 1:n) = 0.
I define a vector u of size n and set u(1:n) to 1.0
The right hand side b= Au.
The (fortran) test program is attached (it's
petsc-3.5.2/src/ksp/ksp/examples/tutorials/ex1f.F slightly modified)
The size of matrix A is defined at runtime
The solver ends OK with m=10, n=2 but goes wrong  with  m=10, n=3 (KSP
Converged reason = -5)
The output is shown below:
First run with n=2 columns
./ex1f -ksp_type lsqr -vec_type seq -ksp_monitor -m 10 -n 2
  0 KSP Residual norm 1.414213562373e+00
  1 KSP Residual norm 3.790370795009e-16
KSP Object: 1 MPI processes
  type: lsqr
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-07, absolute=1e-50, divergence=10000
  left preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: none
  linear system matrix = precond matrix:
  Mat Object:   1 MPI processes
    type: seqaij
    rows=10, cols=2
    total: nonzeros=2, allocated nonzeros=50
    total number of mallocs used during MatSetValues calls =0
      using I-node routines: found 4 nodes, limit used is 5
 KSP Converged Reason  2
Norm of error < 1.e-12,Iterations =     1
Second run, with n=3
./ex1f -ksp_type lsqr -vec_type seq -ksp_monitor -m 10 -n 3
 0 KSP Residual norm 1.732050807569e+00
  type: lsqr
  type: none
    type: seqaij
    rows=10, cols=3
    total: nonzeros=3, allocated nonzeros=50
      using I-node routines: found 5 nodes, limit used is 5
 KSP Converged Reason -5
Norm of error =  0.1732E+01,  Iterations =     0
I am using version 3.5.2 of PETSc library
I am probably doing something wrong, but I don't understand what the
problem is.
Does anyone have an idea of what is going on ?
Best regards
Natacha
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150106/c241d5e7/attachment.html>
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150106/c241d5e7/attachment.bin>
