[petsc-users] Trouble finding PETSc with cmake
Alice Raeli
alice.raeli at math.u-bordeaux1.fr
Fri Feb 27 10:57:07 CST 2015
Hi all,
i’m trying to build my project using cmake.
PETSc is already installed and its tests runned but when I try cmake .. for my project it appears that it doesn’t find PETSc. The error message is:
cmake module path /Users/Alice/Documents/Work/Programmazione/TEST_AUTOMATIZZAZIONE/ParallelOrder/Penalizzazione/cmake-modules
dir /usr/local/petsc arch arch-darwin-c-debug
CMake Warning (dev) at cmake-modules/FindPackageMultipass.cmake:48 (if):
Policy CMP0054 is not set: Only interpret if() arguments as variables or
keywords when unquoted. Run "cmake --help-policy CMP0054" for policy
details. Use the cmake_policy command to set the policy and suppress this
warning.
Quoted variables like "/usr/local/petsc" will no longer be dereferenced
when the policy is set to NEW. Since the policy is not set the OLD
behavior will be used.
Call Stack (most recent call first):
cmake-modules/FindPETSc.cmake:108 (find_package_multipass)
test/CMakeLists.txt:8 (FIND_PACKAGE)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Error at /usr/local/homebrew/Cellar/cmake/3.1.3/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:138 (message):
PETSc could not be found. Be sure to set PETSC_DIR and PETSC_ARCH.
(missing: PETSC_EXECUTABLE_RUNS)
/usr/local/homebrew/Cellar/cmake/3.1.3/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:374 (_FPHSA_FAILURE_MESSAGE)
cmake-modules/FindPETSc.cmake:323 (find_package_handle_standard_args)
______________
PETSC_DIR and PETSC_ARCH are:
/usr/local/petsc/
arch-darwin-c-debug
but also following the given instruction it seems not reading the correct path.
I work on OS X Yosemite 10.10.2
cmake version 3.1.3
CmakeLists.txt […]
SET(CMAKE_C_COMPILER mpicc)
SET(CMAKE_CXX_COMPILER mpicxx)
SET (CMAKE_C_FLAGS_INIT "-Wall -std=c99")
SET (CMAKE_C_FLAGS_DEBUG_INIT "-g")
SET (CMAKE_C_FLAGS_MINSIZEREL_INIT "-Os -DNDEBUG")
SET (CMAKE_C_FLAGS_RELEASE_INIT "-O4 -DNDEBUG")
SET (CMAKE_C_FLAGS_RELWITHDEBINFO_INIT "-O2 -g")
SET (CMAKE_CXX_FLAGS_INIT "-Wall")
SET (CMAKE_CXX_FLAGS_DEBUG_INIT "-g")
SET (CMAKE_CXX_FLAGS_MINSIZEREL_INIT "-Os -DNDEBUG")
SET (CMAKE_CXX_FLAGS_RELEASE_INIT "-O4 -DNDEBUG")
SET (CMAKE_CXX_FLAGS_RELWITHDEBINFO_INIT "-O2 -g")
Have you got a solution?
Alice
Alice Raeli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150227/3ca83739/attachment.html>
