[petsc-users] about MATSOR
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Feb 25 13:48:39 CST 2015
   Let me try to understand what you wish to do. You have a sequential matrix A and a  matrix B and you wish to compute the (dense) matrix C where each column of C is obtained by running three iterations of SOR (using the matrix A) with the corresponding column of B as the right hand side for the SOR; using an initial guess of zero to start the SOR?
   If this is the case then create a seq dense matrix C of the same size as B (it will automatically be initialized with zeros).  Say B has n rows
   VecCreateSeq(PETSC_COMM_SELF,n,&b);
   VecCreateSeqWithArray(PETSC_COMM_SELF,1,n,NULL,&x);
   PetscScalar *xx,*carray;
   MatCreateSeqDense(PETSC_COMM_SELF,n,n,NULL,&C);
   MatDenseGetArray(C,&carray);
   loop over columns
      ierr = MatGetColumnVector(B,b,col);CHKERRQ(ierr);
      ierr = VecPlaceArray(x,carray + n*col);    /* this makes the vec x point to the correct column of entries in the matrix C.
> err = MatSOR(A, b, 1, (SOR_FORWARD_SWEEP|SOR_ZERO_INITIAL_GUESS), 0, 3, 0, x);CHKERRQ(ierr);
   Barry
Note you could also do this in parallel but it is kind of bogus be the SOR is run independently on each process so I don't recommend it as useful.
> On Feb 25, 2015, at 12:14 PM, Sun, Hui <hus003 at ucsd.edu> wrote:
> I want to do 3 steps of gauss seidel from a Mat A to another Mat B. Is there a way to do this?
> I mean, what I can think of is to get the column vectors of B by
> ierr = MatGetColumnVector(B,v,col);CHKERRQ(ierr);
> and apply Gauss seidel from A to v:
> ierr = MatSOR(A, v, 1, (SOR_FORWARD_SWEEP|SOR_ZERO_INITIAL_GUESS), 0, 3, 0, x);CHKERRQ(ierr);
> But then I have to form another matrix C whose columns are composed by v, and I'm not sure how to do that.
> Best,
> Hui
