[petsc-users] access suitesparse from petsc
Barry Smith
bsmith at mcs.anl.gov
Tue Feb 24 13:32:52 CST 2015
For UMFPack you can control a great deal of the solver behavior:
MATSOLVERUMFPACK = "umfpack" - A matrix type providing direct solvers (LU) for sequential matrices
via the external package UMFPACK.
./configure --download-suitesparse to install PETSc to use UMFPACK
Consult UMFPACK documentation for more information about the Control parameters
which correspond to the options database keys below.
Options Database Keys:
+ -mat_umfpack_ordering - CHOLMOD, AMD, GIVEN, METIS, BEST, NONE
. -mat_umfpack_prl - UMFPACK print level: Control[UMFPACK_PRL]
. -mat_umfpack_strategy <AUTO> - (choose one of) AUTO UNSYMMETRIC SYMMETRIC 2BY2
. -mat_umfpack_dense_col <alpha_c> - UMFPACK dense column threshold: Control[UMFPACK_DENSE_COL]
. -mat_umfpack_dense_row <0.2> - Control[UMFPACK_DENSE_ROW]
. -mat_umfpack_amd_dense <10> - Control[UMFPACK_AMD_DENSE]
. -mat_umfpack_block_size <bs> - UMFPACK block size for BLAS-Level 3 calls: Control[UMFPACK_BLOCK_SIZE]
. -mat_umfpack_2by2_tolerance <0.01> - Control[UMFPACK_2BY2_TOLERANCE]
. -mat_umfpack_fixq <0> - Control[UMFPACK_FIXQ]
. -mat_umfpack_aggressive <1> - Control[UMFPACK_AGGRESSIVE]
. -mat_umfpack_pivot_tolerance <delta> - UMFPACK partial pivot tolerance: Control[UMFPACK_PIVOT_TOLERANCE]
. -mat_umfpack_sym_pivot_tolerance <0.001> - Control[UMFPACK_SYM_PIVOT_TOLERANCE]
. -mat_umfpack_scale <NONE> - (choose one of) NONE SUM MAX
. -mat_umfpack_alloc_init <delta> - UMFPACK factorized matrix allocation modifier: Control[UMFPACK_ALLOC_INIT]
. -mat_umfpack_droptol <0> - Control[UMFPACK_DROPTOL]
- -mat_umfpack_irstep <maxit> - UMFPACK maximum number of iterative refinement steps: Control[UMFPACK_IRSTEP]
For Cholmod we don't seem to have currently the ability. If there are some you would like added you can try yourself or let us know what you need.
Barry
> On Feb 24, 2015, at 11:43 AM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
>> On Feb 24, 2015, at 11:40 AM, Jed Brown <jed at jedbrown.org> wrote:
>> Manav Bhatia <bhatiamanav at gmail.com> writes:
>>> Greetings!
>>> What are the command line options to access suitesparse from petsc? I was not able to find any specification in the manual.
>> Presumably you mean Umfpack or Cholmod.
>> -pc_type lu -pc_factor_mat_solver_package umfpack
>> -pc_type cholesky -pc_factor_mat_solver_package cholmod
> Aha!
> I was thinking that there would be something that would read like suitesparse. Thanks for the info.
> Also, the suitesparse website talks of different orderings available (AMD, CAMD, COLAMD, and CCOLAMD). Are any of these accessible by command line options as well?
> Thanks,
> Manav
