[petsc-users] DMNetworkGetEdgeRange() in parallel
    Miguel Angel Salazar de Troya
    salazardetroya at gmail.com
    Mon Feb 23 13:40:35 CST 2015
Wouldn't including the edge variables in the global vector make the code
slower? I'm using the global vector in a TS, using one of the explicit RK
schemes. The edge variables would not be updated in the RHSFunction
evaluation. I only change the edge variables in the TSUpdate. If the global
vector had the edge variables, it would be a much larger vector, and all
the vector operations performed by the TS would be slower. Although the
vector F returned by the RHSFunction would be zero in the edge variable
components. I guess that being the vector sparse that would not be a
problem.
I think I'm more interested in the PetscSection approach because it might
require less modifications in my code. However, I don't know how I could do
this. Maybe something like this?
PetscSectionCreate(PETSC_COMM_WORLD, &s);
PetscSectionSetNumFields(s, 1);
PetscSectionSetFieldComponents(s, 0, 1);
// Now to set the chart, I pick the edge range
DMNetworkGetEdgeRange(dm, & eStart, & eEnd
PetscSectionSetChart(s, eStart, eEnd);
for(PetscInt e = eStart; c < eEnd; ++e) {
     PetscSectionSetDof(s, e, 1);
     PetscSectionSetFieldDof(s, e, 1, 1);
PetscSectionSetUp(s);
Now in the manual I see this:
DMSetDefaultSection(dm, s);
DMGetLocalVector(dm, &localVec);
DMGetGlobalVector(dm, &globalVec);
Setting up the default section in the DM would interfere with the section
already set up with the variables in the vertices?
Thanks a lot for your responses.
On Mon, Feb 23, 2015 at 11:37 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Feb 23, 2015 at 9:27 AM, Miguel Angel Salazar de Troya <
> salazardetroya at gmail.com> wrote:
>> I'm iterating through local edges given in DMNetworkGetEdgeRange(). For
>> each edge, I extract or modify its corresponding value in a global petsc
>> vector. Therefore that vector must have as many components as edges there
>> are in the network. To extract the value in the vector, I use VecGetArray()
>> and a variable counter that is incremented in each iteration. The array
>> that I obtain in VecGetArray() has to be the same size than the edge
>> range. That variable counter starts as 0, so if the array that I obtained
>> in VecGetArray() is x_array, x_array[0] must be the component in the
>> global vector that corresponds with the start edge given in
>> I need that global petsc vector because I will use it in other
>> operations, it's not just data. Sorry for the confusion. Thanks in advance.
> This sounds like an assembly operation. The usual paradigm is to compute
> in the local space, and then communicate to get to the global space. So you
> would make a PetscSection that had 1 (or some) unknowns on each cell (edge)
> and then you can use DMCreateGlobal/LocalVector() and DMLocalToGlobal() to
> do this.
> Does that make sense?
>   Thanks,
>      Matt
>> Miguel
>> On Mon, Feb 23, 2015 at 9:09 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Feb 23, 2015 at 8:42 AM, Miguel Angel Salazar de Troya <
>>>> Thanks, that will help me. Now what I would like to have is the
>>>> following: if I have two processors and ten edges, the partitioning results
>>>> in the first processor having the edges 0-4 and the second processor, the
>>>> edges 5-9. I also have a global vector with as many components as edges,
>>>> 10. How can I partition it so the first processor also has the 0-4
>>>> components and the second, the 5-9 components of the vector?
>>> I think it would help to know what you want to accomplish. This is how
>>> you are proposing to do it.'
>>> If you just want to put data on edges, DMNetwork has a facility for that
>>> already.
>>>   Thanks,
>>>      Matt
>>>> Miguel
>>>> On Feb 23, 2015 8:08 AM, "Abhyankar, Shrirang G." <abhyshr at mcs.anl.gov>
>>>> wrote:
>>>>>  Miguel,
>>>>>    One possible way is to store the global numbering of any
>>>>> edge/vertex in the "component" attached to it. Once the mesh gets
>>>>> partitioned, the components are also distributed so you can easily retrieve
>>>>> the global number of any edge/vertex by accessing its component. This is
>>>>> what is done in the DMNetwork example pf.c although the global numbering is
>>>>> not used for anything.
>>>>>  Shri
>>>>>  From: Matthew Knepley <knepley at gmail.com>
>>>>> Date: Mon, 23 Feb 2015 07:54:34 -0600
>>>>> To: Miguel Angel Salazar de Troya <salazardetroya at gmail.com>
>>>>> Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
>>>>> Subject: Re: [petsc-users] DMNetworkGetEdgeRange() in parallel
>>>>>   On Sun, Feb 22, 2015 at 3:59 PM, Miguel Angel Salazar de Troya <
>>>>>> Thanks. Once I obtain that Index Set with the routine DMPlexCreateCellNumbering()
>>>>>> (I assume that the edges in DMNetwork correspond to cells in DMPlex) can I
>>>>>> use it to partition a vector with as many components as edges I have in my
>>>>>> network?
>>>>>  I do not completely understand the question.
>>>>>  If you want a partition of the edges, you can use
>>>>> DMPlexCreatePartition() and its friend DMPlexDistribute(). What
>>>>> are you trying to do?
>>>>>     Matt
>>>>>>  Thanks
>>>>>> Miguel
>>>>>> On Sun, Feb 22, 2015 at 12:15 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>>  On Sun, Feb 22, 2015 at 11:01 AM, Miguel Angel Salazar de Troya <
>>>>>>>> Hi
>>>>>>>>  I noticed that the routine DMNetworkGetEdgeRange() returns the
>>>>>>>> local indices for the edge range. Is there any way to obtain the global
>>>>>>>> indices? So if my network has 10 edges, the processor 1 has the 0-4 edges
>>>>>>>> and the processor 2, the 5-9 edges, how can I obtain this information?
>>>>>>>  One of the points of DMPlex is we do not require a global
>>>>>>> numbering. Everything is numbered
>>>>>>> locally, and the PetscSF maps local numbers to local numbers in
>>>>>>> order to determine ownership.
>>>>>>>  If you want to create a global numbering for some reason, you can
>>>>>>> using DMPlexCreatePointNumbering().
>>>>>>> There are also cell and vertex versions that we use for output, so
>>>>>>> you could do it just for edges as well.
>>>>>>>    Thanks,
>>>>>>>       Matt
>>>>>>>>  Thanks
>>>>>>>>  Miguel
>>>>>>>>  *Miguel Angel Salazar de Troya*
>>>>>>>> Graduate Research Assistant
>>>>>>>> Department of Mechanical Science and Engineering
>>>>>>>> University of Illinois at Urbana-Champaign
>>>>>>>> (217) 550-2360
>>>>>>>> salaza11 at illinois.edu
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> (217) 550-2360
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> (217) 550-2360
> experiments lead.
> -- Norbert Wiener
(217) 550-2360
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150223/db154c3f/attachment.html>
