[petsc-users] Solving multiple linear systems with similar matrix sequentially
Mon Feb 23 07:43:31 CST 2015
> On Feb 23, 2015, at 5:18 AM, domenico lahaye <domenico_lahaye at yahoo.com> wrote:
> Hi,
>   Contingency analysis of power systems requires to solve a sequence
> a (non-)linear systems in which the Jacobian/matrix changes by a
> rank-2/rank-1 update.
>    Does the PETSc interface to GAMG allow to freeze the AMG hierarchy
> for a given matrix (base case) and to reuse this hierarchy in solving a list of
> slightly perturbed linear problems (list of contingencies)?
  You can do two things.
   Freeze the current preconditioner and solve a sequence of (new with slightly different numerical values) linear systems using that same precondition. Use KSPSetReusePreconditioner() in PETSc 3.5.x to freeze/unfreeze the preconditioner
   Freeze the hierarchy and coarse grid interpolations of GAMG but compute the new coarse grid operators RAP for each new linear system (this is a much cheaper operation). Use PCGAMGSetReuseInterpolation() to freeze/unfreeze the hierarchy.
   Barry
>   Thanks, Domenico.
