[petsc-users] Efficient Use of GAMG for Poisson Equation with Full Neumann Boundary Conditions
Fabian Gabel
gabel.fabian at gmail.com
Fri Feb 20 03:35:09 CST 2015
Barry,
> First, is your pressure problem changing dramatically at each new solver? That is, for example, is the mesh moving or are there very different numerical values in the matrix? Is the nonzero structure of the pressure matrix changing?
No moving grids, the non-zero structure is maintained throughout the
entire solution process. I am not sure about the "very different
numerical values". I determined the minimal matrix coefficient to be
approx -5e-7 and the maximal matrix coefficient to be 3e-6 (but once I
use block structured grids with locally refined blocks the range will
become wider), but there are some lines containing only a 1 on the
diagonal. This comes from the variable indexing I use, which includes
boundary values. If this should present a problem, I think I could scale
the corresponding rows with a factor depending on the maximal/minimal
element of the matrix.
> Currently the entire GAMG process is done for each new solve, if you use the flag
> -pressure_pc_gamg_reuse_interpolation true
> it will create the interpolation needed for GAMG once and reuse it for all the solves. Please try that and see what happens.
I attached the output for the additional solver option
(-reuse_interpolation). Since there appear to be some inconsistencies
with the previous output file for the GAMG solve I provided, I'll attach
the results for the solution process without the flag for reusing the
interpolation once again. So far wall clock time has been reduced by
almost 50%.
Fabian
> Then I will have many more suggestions.
> Barry
> > On Feb 17, 2015, at 9:14 AM, Fabian Gabel <gabel.fabian at gmail.com> wrote:
> > Dear PETSc team,
> > I am trying to optimize the solver parameters for the linear system I
> > get, when I discretize the pressure correction equation Poisson equation
> > with Neumann boundary conditions) in a SIMPLE-type algorithm using a
> > finite volume method.
> > The resulting system is symmetric and positive semi-definite. A basis to
> > the associated nullspace has been provided to the KSP object.
> > Using a CG solver with ICC preconditioning the solver needs a lot of
> > inner iterations to converge (-ksp_monitor -ksp_view output attached for
> > a case with approx. 2e6 unknowns; the lines beginning with 000XXXX show
> > the relative residual regarding the initial residual in the outer
> > iteration no. 1 for the variables u,v,w,p). Furthermore I don't quite
> > understand, why the solver reports
> > Linear solve did not converge due to DIVERGED_INDEFINITE_PC
> > at the later stages of my Picard iteration process (iteration 0001519).
> > I then tried out CG+GAMG preconditioning with success regarding the
> > number of inner iterations, but without advantages regarding wall time
> > (output attached). Also the DIVERGED_INDEFINITE_PC reason shows up
> > repeatedly after iteration 0001487. I used the following options
> > -pressure_mg_coarse_sub_pc_type svd
> > -pressure_mg_levels_ksp_rtol 1e-4
> > -pressure_mg_levels_ksp_type richardson
> > -pressure_mg_levels_pc_type sor
> > -pressure_pc_gamg_agg_nsmooths 1
> > -pressure_pc_type gamg
> > I would like to get an opinion on how the solver performance could be
> > increased further. -log_summary shows that my code spends 80% of the
> > time solving the linear systems for the pressure correction (STAGE 2:
> > PRESSCORR). Furthermore, do you know what could be causing the
> > DIVERGED_INDEFINITE_PC converged reason?
> > Regards,
> > Fabian Gabel
> > <gamg.128.out.531314><icc.128.out.429762>
Sender: LSF System <lsfadmin at hpb0075>
Subject: Job 544044: <mg_test> in cluster <lichtenberg> Done
Job <mg_test> was submitted from host <hla0003> by user <gu08vomo> in cluster <lichtenberg>.
Job was executed on host(s) <hpb0075>, in queue <test_mpi2>, as user <gu08vomo> in cluster <lichtenberg>.
</home/gu08vomo> was used as the home directory.
</work/scratch/gu08vomo/thesis/singleblock/128_1_1_seg_selfcontained> was used as the working directory.
Started at Thu Feb 19 20:41:19 2015
Results reported at Fri Feb 20 03:10:18 2015
Your job looked like:
# LSBATCH: User input
#! /bin/sh
#BSUB -J mg_test
#BSUB -o /home/gu08vomo/thesis/mgtest/selfcontained.gamg.128.out.%J
#BSUB -n 1
#BSUB -W 14:00
#BSUB -x
#BSUB -q test_mpi2
#BSUB -a openmpi
module load openmpi/intel/1.8.2
#export PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr
export PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr-ext
export MYWORKDIR=/work/scratch/gu08vomo/thesis/singleblock/128_1_1_seg_selfcontained/
export OUTPUTDIR=/home/gu08vomo/thesis/coupling
export PETSC_OPS="-options_file ops.gamg"
cat ops.gamg
echo "PETSC_DIR="$PETSC_DIR
echo "MYWORKDIR="$MYWORKDIR
cd $MYWORKDIR
mpirun -n 1 ./caffa3d.MB.lnx ${PETSC_OPS}
Successfully completed.
Resource usage summary:
CPU time : 23345.93 sec.
Max Memory : 2114 MB
Average Memory : 2091.60 MB
Total Requested Memory : -
Delta Memory : -
(Delta: the difference between total requested memory and actual max usage.)
Max Swap : 2872 MB
Max Processes : 6
Max Threads : 11
The output (if any) follows:
Modules: loading openmpi/intel/1.8.2
-momentum_ksp_type gmres
-log_summary
-options_left
-pressure_ksp_converged_reason
ENTER PROBLEM NAME (SIX CHARACTERS):
NAME OF PROBLEM SOLVED control
CONTROL SETTINGS
LREAD,LWRITE,LPOST,LTEST,LOUTS,LOUTE,LTIME,LGRAD
F F F F F F F F
IMON, JMON, KMON, MMON, RMON, IPR, JPR, KPR, MPR,NPCOR,NIGRAD
8 9 8 1 0 2 2 3 1 1 1
SORMAX, SLARGE, ALFA
0.1000E-07 0.1000E+31 0.9200E+00
(URF(I),I=1,5)
0.9000E+00 0.9000E+00 0.9000E+00 0.1000E+00 0.1000E+01
(SOR(I),I=1,5)
0.1000E+00 0.1000E+00 0.1000E+00 0.1000E+00 0.1000E+00
(GDS(I),I=1,5) - BLENDING (CDS-UDS)
0.1000E+01 0.1000E+01 0.1000E+01 0.1000E+01 0.1000E+01
LSG
100000
START SIMPLE RELAXATIONS
Linear solve converged due to CONVERGED_RTOL iterations 2
KSP Object:(pressure_) 1 MPI processes
type: cg
maximum iterations=10000, initial guess is zero
tolerances: relative=0.1, absolute=1e-50, divergence=10000
left preconditioning
has attached null space
using PRECONDITIONED norm type for convergence test
PC Object:(pressure_) 1 MPI processes
type: gamg
MG: type is MULTIPLICATIVE, levels=4 cycles=v
Cycles per PCApply=1
Using Galerkin computed coarse grid matrices
Coarse grid solver -- level -------------------------------
KSP Object: (pressure_mg_coarse_) 1 MPI processes
type: preonly
maximum iterations=1, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
using NONE norm type for convergence test
PC Object: (pressure_mg_coarse_) 1 MPI processes
type: bjacobi
block Jacobi: number of blocks = 1
Local solve is same for all blocks, in the following KSP and PC objects:
KSP Object: (pressure_mg_coarse_sub_) 1 MPI processes
type: preonly
PC Object: (pressure_mg_coarse_sub_) 1 MPI processes
type: svd
linear system matrix = precond matrix:
Mat Object: 1 MPI processes
type: seqaij
rows=26, cols=26
total: nonzeros=536, allocated nonzeros=536
total number of mallocs used during MatSetValues calls =0
not using I-node routines
type: seqaij
rows=26, cols=26
Down solver (pre-smoother) on level 1 -------------------------------
KSP Object: (pressure_mg_levels_1_) 1 MPI processes
type: richardson
Richardson: damping factor=1
maximum iterations=2
tolerances: relative=0.0001, absolute=1e-50, divergence=10000
using nonzero initial guess
PC Object: (pressure_mg_levels_1_) 1 MPI processes
type: sor
SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
type: seqaij
rows=2781, cols=2781
total: nonzeros=156609, allocated nonzeros=156609
Up solver (post-smoother) same as down solver (pre-smoother)
Down solver (pre-smoother) on level 2 -------------------------------
KSP Object: (pressure_mg_levels_2_) 1 MPI processes
type: richardson
PC Object: (pressure_mg_levels_2_) 1 MPI processes
type: sor
type: seqaij
rows=188698, cols=188698
total: nonzeros=6.12809e+06, allocated nonzeros=6.12809e+06
Down solver (pre-smoother) on level 3 -------------------------------
KSP Object: (pressure_mg_levels_3_) 1 MPI processes
type: richardson
PC Object: (pressure_mg_levels_3_) 1 MPI processes
type: sor
type: seqaij
rows=2197000, cols=2197000
total: nonzeros=1.46816e+07, allocated nonzeros=1.46816e+07
type: seqaij
0000001 0.1000E+01 0.1000E+01 0.1000E+01 0.1000E+01 0.0000E+00
0000002 0.7654E+00 0.7194E+00 0.7661E+00 0.7330E+00 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 3
0000003 0.4442E+00 0.3597E+00 0.4375E+00 0.2886E+00 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 5
0000004 0.1641E+00 0.1296E+00 0.1648E+00 0.4463E-01 0.0000E+00
0000005 0.5112E-01 0.3598E-01 0.5166E-01 0.3104E-01 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 6
0000006 0.1957E-01 0.7820E-02 0.1983E-01 0.1447E-01 0.0000E+00
0000007 0.1497E-01 0.7200E-02 0.1495E-01 0.8590E-02 0.0000E+00
0000008 0.1272E-01 0.5662E-02 0.1269E-01 0.8206E-02 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 7
0000009 0.1135E-01 0.4639E-02 0.1135E-01 0.5068E-02 0.0000E+00
0000010 0.1033E-01 0.4072E-02 0.1035E-01 0.5708E-02 0.0000E+00
0000011 0.9421E-02 0.3706E-02 0.9432E-02 0.3233E-02 0.0000E+00
0000012 0.8734E-02 0.3483E-02 0.8746E-02 0.3921E-02 0.0000E+00
0000013 0.8122E-02 0.3221E-02 0.8130E-02 0.2095E-02 0.0000E+00
0000014 0.7652E-02 0.3058E-02 0.7662E-02 0.3045E-02 0.0000E+00
0000015 0.7237E-02 0.2890E-02 0.7245E-02 0.1618E-02 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 8
0000016 0.6956E-02 0.2818E-02 0.6965E-02 0.1471E-02 0.0000E+00
0000017 0.6339E-02 0.2521E-02 0.6346E-02 0.1578E-02 0.0000E+00
0000018 0.6017E-02 0.2392E-02 0.6023E-02 0.1044E-02 0.0000E+00
0000019 0.5734E-02 0.2283E-02 0.5740E-02 0.1212E-02 0.0000E+00
0000020 0.5476E-02 0.2180E-02 0.5481E-02 0.7940E-03 0.0000E+00
0000021 0.5248E-02 0.2095E-02 0.5254E-02 0.1054E-02 0.0000E+00
0000022 0.5044E-02 0.2020E-02 0.5050E-02 0.8217E-03 0.0000E+00
0000023 0.4875E-02 0.1970E-02 0.4881E-02 0.1209E-02 0.0000E+00
0000024 0.4745E-02 0.1949E-02 0.4751E-02 0.1315E-02 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 9
0000025 0.4687E-02 0.1991E-02 0.4694E-02 0.4871E-03 0.0000E+00
0000026 0.4312E-02 0.1718E-02 0.4317E-02 0.4958E-03 0.0000E+00
0000027 0.4170E-02 0.1661E-02 0.4174E-02 0.4818E-03 0.0000E+00
0000028 0.4040E-02 0.1617E-02 0.4045E-02 0.5838E-03 0.0000E+00
0000029 0.3930E-02 0.1591E-02 0.3935E-02 0.7477E-03 0.0000E+00
0000030 0.3852E-02 0.1602E-02 0.3858E-02 0.1019E-02 0.0000E+00
0000031 0.3836E-02 0.1682E-02 0.3842E-02 0.1235E-02 0.0000E+00
0000032 0.3904E-02 0.1425E-02 0.3914E-02 0.4310E-03 0.0000E+00
0000033 0.3462E-02 0.1459E-02 0.3465E-02 0.4804E-03 0.0000E+00
0000034 0.3375E-02 0.1481E-02 0.3378E-02 0.4951E-03 0.0000E+00
0000035 0.3307E-02 0.1300E-02 0.3311E-02 0.5204E-03 0.0000E+00
0000036 0.3259E-02 0.1284E-02 0.3263E-02 0.7728E-03 0.0000E+00
0000037 0.3254E-02 0.1329E-02 0.3259E-02 0.1037E-02 0.0000E+00
0000038 0.3346E-02 0.1486E-02 0.3353E-02 0.3282E-03 0.0000E+00
0000039 0.2956E-02 0.1177E-02 0.2960E-02 0.2359E-03 0.0000E+00
0000040 0.2892E-02 0.1160E-02 0.2896E-02 0.4576E-03 0.0000E+00
0000041 0.2838E-02 0.1160E-02 0.2841E-02 0.5030E-03 0.0000E+00
0000042 0.2811E-02 0.1200E-02 0.2815E-02 0.7012E-03 0.0000E+00
0000043 0.2820E-02 0.1068E-02 0.2824E-02 0.8205E-03 0.0000E+00
0000044 0.2892E-02 0.1123E-02 0.2897E-02 0.4962E-03 0.0000E+00
0000045 0.2573E-02 0.1220E-02 0.2576E-02 0.2104E-03 0.0000E+00
0000046 0.2534E-02 0.9942E-03 0.2537E-02 0.4036E-03 0.0000E+00
0000047 0.2498E-02 0.9794E-03 0.2501E-02 0.4000E-03 0.0000E+00
0000048 0.2489E-02 0.9990E-03 0.2492E-02 0.7027E-03 0.0000E+00
0000049 0.2529E-02 0.1090E-02 0.2532E-02 0.8338E-03 0.0000E+00
0000050 0.2644E-02 0.9371E-03 0.2648E-02 0.3577E-03 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 10
0000051 0.2274E-02 0.1012E-02 0.2276E-02 0.1423E-03 0.0000E+00
0000052 0.2239E-02 0.8736E-03 0.2242E-02 0.3321E-03 0.0000E+00
0000053 0.2206E-02 0.8618E-03 0.2209E-02 0.3065E-03 0.0000E+00
0000054 0.2193E-02 0.8675E-03 0.2196E-02 0.5479E-03 0.0000E+00
0000055 0.2211E-02 0.9236E-03 0.2213E-02 0.6273E-03 0.0000E+00
0000056 0.2286E-02 0.8231E-03 0.2289E-02 0.2699E-03 0.0000E+00
0000057 0.2029E-02 0.8714E-03 0.2032E-02 0.1083E-03 0.0000E+00
0000058 0.1999E-02 0.7774E-03 0.2002E-02 0.2617E-03 0.0000E+00
0000059 0.1970E-02 0.7665E-03 0.1973E-02 0.2341E-03 0.0000E+00
0000060 0.1954E-02 0.7659E-03 0.1957E-02 0.4193E-03 0.0000E+00
0000061 0.1959E-02 0.7992E-03 0.1961E-02 0.5482E-03 0.0000E+00
0000062 0.2019E-02 0.8872E-03 0.2021E-02 0.1874E-03 0.0000E+00
0000063 0.1828E-02 0.7171E-03 0.1830E-02 0.1414E-03 0.0000E+00
0000064 0.1802E-02 0.7103E-03 0.1804E-02 0.2711E-03 0.0000E+00
0000065 0.1780E-02 0.7150E-03 0.1782E-02 0.2977E-03 0.0000E+00
0000066 0.1775E-02 0.7407E-03 0.1777E-02 0.4188E-03 0.0000E+00
0000067 0.1793E-02 0.6706E-03 0.1794E-02 0.4859E-03 0.0000E+00
0000068 0.1853E-02 0.7134E-03 0.1854E-02 0.1724E-03 0.0000E+00
0000069 0.1658E-02 0.6460E-03 0.1660E-02 0.1030E-03 0.0000E+00
0000070 0.1634E-02 0.6452E-03 0.1636E-02 0.2447E-03 0.0000E+00
0000071 0.1615E-02 0.6498E-03 0.1617E-02 0.2467E-03 0.0000E+00
0000072 0.1610E-02 0.6750E-03 0.1612E-02 0.3604E-03 0.0000E+00
0000073 0.1623E-02 0.6071E-03 0.1624E-02 0.4072E-03 0.0000E+00
0000074 0.1670E-02 0.6422E-03 0.1672E-02 0.2927E-03 0.0000E+00
0000075 0.1511E-02 0.6956E-03 0.1513E-02 0.1032E-03 0.0000E+00
0000076 0.1498E-02 0.5768E-03 0.1500E-02 0.2234E-03 0.0000E+00
0000077 0.1486E-02 0.5720E-03 0.1488E-02 0.2207E-03 0.0000E+00
0000078 0.1490E-02 0.5875E-03 0.1492E-02 0.4043E-03 0.0000E+00
0000079 0.1524E-02 0.6456E-03 0.1525E-02 0.4684E-03 0.0000E+00
0000080 0.1606E-02 0.5600E-03 0.1607E-02 0.2275E-03 0.0000E+00
0000081 0.1386E-02 0.6101E-03 0.1387E-02 0.8311E-04 0.0000E+00
0000082 0.1372E-02 0.5256E-03 0.1374E-02 0.1982E-03 0.0000E+00
0000083 0.1360E-02 0.5216E-03 0.1362E-02 0.1917E-03 0.0000E+00
0000084 0.1360E-02 0.5293E-03 0.1362E-02 0.3408E-03 0.0000E+00
0000085 0.1382E-02 0.5710E-03 0.1383E-02 0.3904E-03 0.0000E+00
0000086 0.1443E-02 0.5078E-03 0.1443E-02 0.1817E-03 0.0000E+00
0000087 0.1275E-02 0.5449E-03 0.1276E-02 0.6985E-04 0.0000E+00
0000088 0.1262E-02 0.4818E-03 0.1264E-02 0.1668E-03 0.0000E+00
0000089 0.1250E-02 0.4775E-03 0.1252E-02 0.1587E-03 0.0000E+00
0000090 0.1247E-02 0.4809E-03 0.1248E-02 0.2788E-03 0.0000E+00
0000091 0.1259E-02 0.5097E-03 0.1261E-02 0.3156E-03 0.0000E+00
0000092 0.1303E-02 0.4637E-03 0.1303E-02 0.1476E-03 0.0000E+00
0000093 0.1176E-02 0.4901E-03 0.1178E-02 0.1786E-03 0.0000E+00
0000094 0.1165E-02 0.5038E-03 0.1166E-02 0.1799E-03 0.0000E+00
0000095 0.1161E-02 0.4410E-03 0.1162E-02 0.1606E-03 0.0000E+00
0000096 0.1165E-02 0.4456E-03 0.1166E-02 0.2954E-03 0.0000E+00
0000097 0.1190E-02 0.4843E-03 0.1191E-02 0.3493E-03 0.0000E+00
0000098 0.1251E-02 0.4346E-03 0.1251E-02 0.1745E-03 0.0000E+00
0000099 0.1089E-02 0.4733E-03 0.1091E-02 0.6287E-04 0.0000E+00
0000100 0.1081E-02 0.4100E-03 0.1082E-02 0.1508E-03 0.0000E+00
0000101 0.1072E-02 0.4073E-03 0.1074E-02 0.1477E-03 0.0000E+00
0000102 0.1073E-02 0.4132E-03 0.1075E-02 0.2604E-03 0.0000E+00
0000103 0.1091E-02 0.4455E-03 0.1092E-02 0.2983E-03 0.0000E+00
0000104 0.1139E-02 0.3984E-03 0.1139E-02 0.1423E-03 0.0000E+00
0000105 0.1011E-02 0.4275E-03 0.1012E-02 0.5486E-04 0.0000E+00
0000106 0.1002E-02 0.3791E-03 0.1003E-02 0.1289E-03 0.0000E+00
0000107 0.9939E-03 0.3763E-03 0.9951E-03 0.1251E-03 0.0000E+00
0000108 0.9925E-03 0.3793E-03 0.9936E-03 0.2172E-03 0.0000E+00
0000109 0.1003E-02 0.4023E-03 0.1004E-02 0.2469E-03 0.0000E+00
0000110 0.1039E-02 0.3670E-03 0.1039E-02 0.1175E-03 0.0000E+00
0000111 0.9400E-03 0.3884E-03 0.9411E-03 0.4702E-04 0.0000E+00
0000112 0.9314E-03 0.3515E-03 0.9326E-03 0.1080E-03 0.0000E+00
0000113 0.9232E-03 0.3486E-03 0.9243E-03 0.1045E-03 0.0000E+00
0000114 0.9200E-03 0.3496E-03 0.9211E-03 0.1799E-03 0.0000E+00
0000115 0.9259E-03 0.3656E-03 0.9268E-03 0.2472E-03 0.0000E+00
0000116 0.9561E-03 0.4049E-03 0.9566E-03 0.3358E-03 0.0000E+00
0000117 0.1017E-02 0.3465E-03 0.1017E-02 0.1589E-03 0.0000E+00
0000118 0.8667E-03 0.3811E-03 0.8678E-03 0.7975E-04 0.0000E+00
0000119 0.8612E-03 0.3240E-03 0.8623E-03 0.1111E-03 0.0000E+00
0000120 0.8578E-03 0.3235E-03 0.8588E-03 0.1533E-03 0.0000E+00
0000121 0.8630E-03 0.3341E-03 0.8638E-03 0.2287E-03 0.0000E+00
0000122 0.8873E-03 0.3706E-03 0.8878E-03 0.2975E-03 0.0000E+00
0000123 0.9398E-03 0.3204E-03 0.9399E-03 0.1344E-03 0.0000E+00
0000124 0.8088E-03 0.3522E-03 0.8098E-03 0.5957E-04 0.0000E+00
0000125 0.8036E-03 0.3015E-03 0.8046E-03 0.1102E-03 0.0000E+00
0000126 0.7996E-03 0.3006E-03 0.8005E-03 0.1291E-03 0.0000E+00
0000127 0.8031E-03 0.3073E-03 0.8039E-03 0.2047E-03 0.0000E+00
0000128 0.8216E-03 0.3367E-03 0.8222E-03 0.2506E-03 0.0000E+00
0000129 0.8655E-03 0.2962E-03 0.8657E-03 0.1150E-03 0.0000E+00
0000130 0.7558E-03 0.3227E-03 0.7567E-03 0.4880E-04 0.0000E+00
0000131 0.7506E-03 0.2811E-03 0.7514E-03 0.1009E-03 0.0000E+00
0000132 0.7460E-03 0.2798E-03 0.7468E-03 0.1086E-03 0.0000E+00
0000133 0.7475E-03 0.2838E-03 0.7482E-03 0.1776E-03 0.0000E+00
0000134 0.7604E-03 0.3062E-03 0.7610E-03 0.2101E-03 0.0000E+00
0000135 0.7945E-03 0.2747E-03 0.7948E-03 0.9760E-04 0.0000E+00
0000136 0.7071E-03 0.2953E-03 0.7078E-03 0.4072E-04 0.0000E+00
0000137 0.7017E-03 0.2624E-03 0.7025E-03 0.8785E-04 0.0000E+00
0000138 0.6968E-03 0.2608E-03 0.6976E-03 0.9057E-04 0.0000E+00
0000139 0.6966E-03 0.2631E-03 0.6973E-03 0.1507E-03 0.0000E+00
0000140 0.7050E-03 0.2795E-03 0.7056E-03 0.1748E-03 0.0000E+00
0000141 0.7305E-03 0.2554E-03 0.7309E-03 0.8246E-04 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 11
0000142 0.6621E-03 0.2708E-03 0.6628E-03 0.3419E-04 0.0000E+00
0000143 0.6568E-03 0.2453E-03 0.6575E-03 0.7491E-04 0.0000E+00
0000144 0.6517E-03 0.2436E-03 0.6524E-03 0.7552E-04 0.0000E+00
0000145 0.6502E-03 0.2447E-03 0.6508E-03 0.1269E-03 0.0000E+00
0000146 0.6552E-03 0.2565E-03 0.6558E-03 0.1776E-03 0.0000E+00
0000147 0.6775E-03 0.2847E-03 0.6779E-03 0.2377E-03 0.0000E+00
0000148 0.7225E-03 0.2438E-03 0.7225E-03 0.1154E-03 0.0000E+00
0000149 0.6148E-03 0.2689E-03 0.6154E-03 0.5615E-04 0.0000E+00
0000150 0.6115E-03 0.2280E-03 0.6122E-03 0.7955E-04 0.0000E+00
0000151 0.6098E-03 0.2280E-03 0.6104E-03 0.1097E-03 0.0000E+00
0000152 0.6143E-03 0.2361E-03 0.6148E-03 0.1648E-03 0.0000E+00
0000153 0.6327E-03 0.2630E-03 0.6330E-03 0.2129E-03 0.0000E+00
0000154 0.6718E-03 0.2269E-03 0.6718E-03 0.9835E-04 0.0000E+00
0000155 0.5767E-03 0.2504E-03 0.5773E-03 0.4277E-04 0.0000E+00
0000156 0.5736E-03 0.2135E-03 0.5741E-03 0.7934E-04 0.0000E+00
0000157 0.5713E-03 0.2131E-03 0.5718E-03 0.9365E-04 0.0000E+00
0000158 0.5745E-03 0.2184E-03 0.5750E-03 0.1485E-03 0.0000E+00
0000159 0.5889E-03 0.2405E-03 0.5892E-03 0.1814E-03 0.0000E+00
0000160 0.6221E-03 0.2109E-03 0.6221E-03 0.8473E-04 0.0000E+00
0000161 0.5414E-03 0.2309E-03 0.5418E-03 0.3557E-04 0.0000E+00
0000162 0.5381E-03 0.2001E-03 0.5386E-03 0.7318E-04 0.0000E+00
0000163 0.5353E-03 0.1994E-03 0.5358E-03 0.7973E-04 0.0000E+00
0000164 0.5370E-03 0.2028E-03 0.5375E-03 0.1300E-03 0.0000E+00
0000165 0.5474E-03 0.2199E-03 0.5477E-03 0.1538E-03 0.0000E+00
0000166 0.5737E-03 0.1966E-03 0.5738E-03 0.7252E-04 0.0000E+00
0000167 0.5084E-03 0.2123E-03 0.5089E-03 0.3004E-04 0.0000E+00
0000168 0.5050E-03 0.1878E-03 0.5054E-03 0.6436E-04 0.0000E+00
0000169 0.5019E-03 0.1868E-03 0.5023E-03 0.6726E-04 0.0000E+00
0000170 0.5024E-03 0.1889E-03 0.5027E-03 0.1115E-03 0.0000E+00
0000171 0.5095E-03 0.2018E-03 0.5098E-03 0.1295E-03 0.0000E+00
0000172 0.5296E-03 0.1836E-03 0.5298E-03 0.6188E-04 0.0000E+00
0000173 0.4777E-03 0.1957E-03 0.4781E-03 0.2550E-04 0.0000E+00
0000174 0.4742E-03 0.1763E-03 0.4746E-03 0.5548E-04 0.0000E+00
0000175 0.4710E-03 0.1752E-03 0.4713E-03 0.5675E-04 0.0000E+00
0000176 0.4704E-03 0.1764E-03 0.4708E-03 0.9496E-04 0.0000E+00
0000177 0.4750E-03 0.1859E-03 0.4753E-03 0.1337E-03 0.0000E+00
0000178 0.4930E-03 0.2079E-03 0.4932E-03 0.4391E-04 0.0000E+00
0000179 0.4493E-03 0.1693E-03 0.4496E-03 0.3741E-04 0.0000E+00
0000180 0.4458E-03 0.1689E-03 0.4462E-03 0.6681E-04 0.0000E+00
0000181 0.4435E-03 0.1715E-03 0.4438E-03 0.7805E-04 0.0000E+00
0000182 0.4455E-03 0.1794E-03 0.4458E-03 0.1020E-03 0.0000E+00
0000183 0.4540E-03 0.1630E-03 0.4543E-03 0.1249E-03 0.0000E+00
0000184 0.4746E-03 0.1776E-03 0.4748E-03 0.4554E-04 0.0000E+00
0000185 0.4227E-03 0.1588E-03 0.4230E-03 0.2914E-04 0.0000E+00
0000186 0.4191E-03 0.1599E-03 0.4194E-03 0.6642E-04 0.0000E+00
0000187 0.4168E-03 0.1626E-03 0.4171E-03 0.7010E-04 0.0000E+00
0000188 0.4185E-03 0.1712E-03 0.4188E-03 0.9635E-04 0.0000E+00
0000189 0.4261E-03 0.1531E-03 0.4263E-03 0.1137E-03 0.0000E+00
0000190 0.4445E-03 0.1665E-03 0.4446E-03 0.4378E-04 0.0000E+00
0000191 0.3977E-03 0.1492E-03 0.3979E-03 0.2408E-04 0.0000E+00
0000192 0.3943E-03 0.1503E-03 0.3945E-03 0.6230E-04 0.0000E+00
0000193 0.3920E-03 0.1525E-03 0.3923E-03 0.6226E-04 0.0000E+00
0000194 0.3933E-03 0.1603E-03 0.3935E-03 0.8894E-04 0.0000E+00
0000195 0.3998E-03 0.1438E-03 0.3999E-03 0.1031E-03 0.0000E+00
0000196 0.4158E-03 0.1557E-03 0.4159E-03 0.4061E-04 0.0000E+00
0000197 0.3742E-03 0.1403E-03 0.3744E-03 0.2071E-04 0.0000E+00
0000198 0.3710E-03 0.1412E-03 0.3712E-03 0.5712E-04 0.0000E+00
0000199 0.3688E-03 0.1431E-03 0.3690E-03 0.5552E-04 0.0000E+00
0000200 0.3696E-03 0.1502E-03 0.3698E-03 0.8150E-04 0.0000E+00
0000201 0.3751E-03 0.1352E-03 0.3752E-03 0.9356E-04 0.0000E+00
0000202 0.3890E-03 0.1456E-03 0.3891E-03 0.3714E-04 0.0000E+00
0000203 0.3522E-03 0.1320E-03 0.3524E-03 0.1826E-04 0.0000E+00
0000204 0.3492E-03 0.1327E-03 0.3493E-03 0.5202E-04 0.0000E+00
0000205 0.3470E-03 0.1344E-03 0.3471E-03 0.4991E-04 0.0000E+00
0000206 0.3475E-03 0.1406E-03 0.3477E-03 0.7452E-04 0.0000E+00
0000207 0.3521E-03 0.1272E-03 0.3522E-03 0.8514E-04 0.0000E+00
0000208 0.3642E-03 0.1363E-03 0.3642E-03 0.3380E-04 0.0000E+00
0000209 0.3316E-03 0.1242E-03 0.3317E-03 0.1633E-04 0.0000E+00
0000210 0.3287E-03 0.1248E-03 0.3288E-03 0.4733E-04 0.0000E+00
0000211 0.3265E-03 0.1262E-03 0.3267E-03 0.4520E-04 0.0000E+00
0000212 0.3269E-03 0.1318E-03 0.3270E-03 0.6826E-04 0.0000E+00
0000213 0.3307E-03 0.1197E-03 0.3308E-03 0.7786E-04 0.0000E+00
0000214 0.3413E-03 0.1278E-03 0.3413E-03 0.1209E-03 0.0000E+00
0000215 0.3624E-03 0.1207E-03 0.3624E-03 0.4753E-04 0.0000E+00
0000216 0.3094E-03 0.1352E-03 0.3095E-03 0.2928E-04 0.0000E+00
0000217 0.3079E-03 0.1144E-03 0.3081E-03 0.4019E-04 0.0000E+00
0000218 0.3072E-03 0.1143E-03 0.3073E-03 0.5720E-04 0.0000E+00
0000219 0.3095E-03 0.1178E-03 0.3096E-03 0.8150E-04 0.0000E+00
0000220 0.3186E-03 0.1312E-03 0.3187E-03 0.1088E-03 0.0000E+00
0000221 0.3382E-03 0.1136E-03 0.3381E-03 0.4429E-04 0.0000E+00
0000222 0.2914E-03 0.1261E-03 0.2915E-03 0.2233E-04 0.0000E+00
0000223 0.2899E-03 0.1077E-03 0.2900E-03 0.4024E-04 0.0000E+00
0000224 0.2889E-03 0.1076E-03 0.2890E-03 0.4806E-04 0.0000E+00
0000225 0.2907E-03 0.1102E-03 0.2907E-03 0.7508E-04 0.0000E+00
0000226 0.2981E-03 0.1214E-03 0.2981E-03 0.9334E-04 0.0000E+00
0000227 0.3151E-03 0.1066E-03 0.3151E-03 0.4049E-04 0.0000E+00
0000228 0.2744E-03 0.1172E-03 0.2745E-03 0.1845E-04 0.0000E+00
0000229 0.2729E-03 0.1015E-03 0.2730E-03 0.3757E-04 0.0000E+00
0000230 0.2717E-03 0.1012E-03 0.2718E-03 0.4122E-04 0.0000E+00
0000231 0.2729E-03 0.1031E-03 0.2729E-03 0.6738E-04 0.0000E+00
0000232 0.2786E-03 0.1123E-03 0.2786E-03 0.8076E-04 0.0000E+00
0000233 0.2928E-03 0.1000E-03 0.2927E-03 0.3621E-04 0.0000E+00
0000234 0.2585E-03 0.1088E-03 0.2586E-03 0.1567E-04 0.0000E+00
0000235 0.2570E-03 0.9566E-04 0.2570E-03 0.3375E-04 0.0000E+00
0000236 0.2556E-03 0.9529E-04 0.2557E-03 0.3549E-04 0.0000E+00
0000237 0.2562E-03 0.9664E-04 0.2563E-03 0.5946E-04 0.0000E+00
0000238 0.2606E-03 0.1040E-03 0.2606E-03 0.6992E-04 0.0000E+00
0000239 0.2722E-03 0.9395E-04 0.2722E-03 0.3214E-04 0.0000E+00
0000240 0.2436E-03 0.1011E-03 0.2436E-03 0.1355E-04 0.0000E+00
0000241 0.2420E-03 0.9017E-04 0.2420E-03 0.2990E-04 0.0000E+00
0000242 0.2405E-03 0.8973E-04 0.2406E-03 0.3082E-04 0.0000E+00
0000243 0.2407E-03 0.9069E-04 0.2408E-03 0.5231E-04 0.0000E+00
0000244 0.2440E-03 0.9658E-04 0.2440E-03 0.6096E-04 0.0000E+00
0000245 0.2534E-03 0.8830E-04 0.2534E-03 0.2845E-04 0.0000E+00
0000246 0.2295E-03 0.9407E-04 0.2295E-03 0.1181E-04 0.0000E+00
0000247 0.2279E-03 0.8500E-04 0.2279E-03 0.2636E-04 0.0000E+00
0000248 0.2264E-03 0.8453E-04 0.2265E-03 0.2693E-04 0.0000E+00
0000249 0.2263E-03 0.8519E-04 0.2263E-03 0.4602E-04 0.0000E+00
0000250 0.2287E-03 0.8995E-04 0.2287E-03 0.6504E-04 0.0000E+00
0000251 0.2379E-03 0.1012E-03 0.2379E-03 0.2121E-04 0.0000E+00
0000252 0.2164E-03 0.8187E-04 0.2164E-03 0.1794E-04 0.0000E+00
0000253 0.2148E-03 0.8184E-04 0.2149E-03 0.3297E-04 0.0000E+00
0000254 0.2139E-03 0.8340E-04 0.2139E-03 0.3899E-04 0.0000E+00
0000255 0.2152E-03 0.8784E-04 0.2153E-03 0.5173E-04 0.0000E+00
0000256 0.2201E-03 0.7910E-04 0.2202E-03 0.6376E-04 0.0000E+00
0000257 0.2314E-03 0.8696E-04 0.2314E-03 0.2269E-04 0.0000E+00
0000258 0.2040E-03 0.7713E-04 0.2040E-03 0.1473E-04 0.0000E+00
0000259 0.2024E-03 0.7794E-04 0.2025E-03 0.3393E-04 0.0000E+00
0000260 0.2016E-03 0.7966E-04 0.2016E-03 0.3651E-04 0.0000E+00
0000261 0.2030E-03 0.8472E-04 0.2030E-03 0.5052E-04 0.0000E+00
0000262 0.2078E-03 0.7458E-04 0.2078E-03 0.6018E-04 0.0000E+00
0000263 0.2186E-03 0.8236E-04 0.2186E-03 0.2258E-04 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 12
0000264 0.1924E-03 0.7272E-04 0.1924E-03 0.1272E-04 0.0000E+00
0000265 0.1909E-03 0.7356E-04 0.1909E-03 0.3295E-04 0.0000E+00
0000266 0.1900E-03 0.7515E-04 0.1901E-03 0.3372E-04 0.0000E+00
0000267 0.1914E-03 0.8008E-04 0.1914E-03 0.4828E-04 0.0000E+00
0000268 0.1960E-03 0.7030E-04 0.1959E-03 0.5657E-04 0.0000E+00
0000269 0.2061E-03 0.7768E-04 0.2061E-03 0.2168E-04 0.0000E+00
0000270 0.1813E-03 0.6858E-04 0.1813E-03 0.1138E-04 0.0000E+00
0000271 0.1799E-03 0.6940E-04 0.1799E-03 0.3127E-04 0.0000E+00
0000272 0.1792E-03 0.7089E-04 0.1792E-03 0.3119E-04 0.0000E+00
0000273 0.1804E-03 0.7561E-04 0.1804E-03 0.4570E-04 0.0000E+00
0000274 0.1847E-03 0.6630E-04 0.1847E-03 0.5304E-04 0.0000E+00
0000275 0.1942E-03 0.7325E-04 0.1942E-03 0.2051E-04 0.0000E+00
0000276 0.1710E-03 0.6469E-04 0.1710E-03 0.1040E-04 0.0000E+00
0000277 0.1697E-03 0.6547E-04 0.1697E-03 0.2944E-04 0.0000E+00
0000278 0.1689E-03 0.6687E-04 0.1689E-03 0.2900E-04 0.0000E+00
0000279 0.1701E-03 0.7134E-04 0.1701E-03 0.4312E-04 0.0000E+00
0000280 0.1741E-03 0.6254E-04 0.1741E-03 0.4978E-04 0.0000E+00
0000281 0.1830E-03 0.6904E-04 0.1829E-03 0.1928E-04 0.0000E+00
0000282 0.1612E-03 0.6103E-04 0.1612E-03 0.9613E-05 0.0000E+00
0000283 0.1600E-03 0.6176E-04 0.1600E-03 0.2765E-04 0.0000E+00
0000284 0.1593E-03 0.6308E-04 0.1593E-03 0.2709E-04 0.0000E+00
0000285 0.1604E-03 0.6731E-04 0.1604E-03 0.4065E-04 0.0000E+00
0000286 0.1641E-03 0.5899E-04 0.1641E-03 0.4681E-04 0.0000E+00
0000287 0.1724E-03 0.6510E-04 0.1724E-03 0.1810E-04 0.0000E+00
0000288 0.1520E-03 0.5759E-04 0.1520E-03 0.8957E-05 0.0000E+00
0000289 0.1509E-03 0.5827E-04 0.1508E-03 0.2597E-04 0.0000E+00
0000290 0.1502E-03 0.5952E-04 0.1502E-03 0.2541E-04 0.0000E+00
0000291 0.1512E-03 0.6352E-04 0.1512E-03 0.3837E-04 0.0000E+00
0000292 0.1547E-03 0.5566E-04 0.1547E-03 0.4413E-04 0.0000E+00
0000293 0.1626E-03 0.6140E-04 0.1625E-03 0.1701E-04 0.0000E+00
0000294 0.1434E-03 0.5434E-04 0.1434E-03 0.8393E-05 0.0000E+00
0000295 0.1423E-03 0.5498E-04 0.1423E-03 0.2445E-04 0.0000E+00
0000296 0.1416E-03 0.5618E-04 0.1416E-03 0.2393E-04 0.0000E+00
0000297 0.1426E-03 0.5998E-04 0.1426E-03 0.3628E-04 0.0000E+00
0000298 0.1459E-03 0.5252E-04 0.1459E-03 0.4171E-04 0.0000E+00
0000299 0.1534E-03 0.5795E-04 0.1533E-03 0.1601E-04 0.0000E+00
0000300 0.1352E-03 0.5128E-04 0.1352E-03 0.7901E-05 0.0000E+00
0000301 0.1342E-03 0.5189E-04 0.1342E-03 0.2307E-04 0.0000E+00
0000302 0.1336E-03 0.5304E-04 0.1336E-03 0.2260E-04 0.0000E+00
0000303 0.1346E-03 0.5666E-04 0.1345E-03 0.3436E-04 0.0000E+00
0000304 0.1377E-03 0.4956E-04 0.1377E-03 0.3952E-04 0.0000E+00
0000305 0.1447E-03 0.5472E-04 0.1447E-03 0.1511E-04 0.0000E+00
0000306 0.1275E-03 0.4840E-04 0.1275E-03 0.7463E-05 0.0000E+00
0000307 0.1266E-03 0.4898E-04 0.1265E-03 0.2181E-04 0.0000E+00
0000308 0.1260E-03 0.5008E-04 0.1260E-03 0.2141E-04 0.0000E+00
0000309 0.1270E-03 0.5355E-04 0.1269E-03 0.3261E-04 0.0000E+00
0000310 0.1300E-03 0.4678E-04 0.1299E-03 0.3751E-04 0.0000E+00
0000311 0.1367E-03 0.5169E-04 0.1367E-03 0.1429E-04 0.0000E+00
0000312 0.1203E-03 0.4568E-04 0.1203E-03 0.7068E-05 0.0000E+00
0000313 0.1194E-03 0.4624E-04 0.1194E-03 0.2067E-04 0.0000E+00
0000314 0.1189E-03 0.4731E-04 0.1189E-03 0.2032E-04 0.0000E+00
0000315 0.1198E-03 0.5063E-04 0.1198E-03 0.3100E-04 0.0000E+00
0000316 0.1227E-03 0.4415E-04 0.1227E-03 0.3566E-04 0.0000E+00
0000317 0.1291E-03 0.4885E-04 0.1291E-03 0.1354E-04 0.0000E+00
0000318 0.1135E-03 0.4311E-04 0.1135E-03 0.6707E-05 0.0000E+00
0000319 0.1126E-03 0.4366E-04 0.1126E-03 0.1962E-04 0.0000E+00
0000320 0.1122E-03 0.4469E-04 0.1122E-03 0.1931E-04 0.0000E+00
0000321 0.1131E-03 0.4788E-04 0.1130E-03 0.2950E-04 0.0000E+00
0000322 0.1159E-03 0.4167E-04 0.1158E-03 0.3395E-04 0.0000E+00
0000323 0.1220E-03 0.4618E-04 0.1220E-03 0.1285E-04 0.0000E+00
0000324 0.1071E-03 0.4069E-04 0.1070E-03 0.6374E-05 0.0000E+00
0000325 0.1063E-03 0.4123E-04 0.1062E-03 0.1865E-04 0.0000E+00
0000326 0.1058E-03 0.4223E-04 0.1058E-03 0.1838E-04 0.0000E+00
0000327 0.1067E-03 0.4530E-04 0.1067E-03 0.2811E-04 0.0000E+00
0000328 0.1094E-03 0.3934E-04 0.1094E-03 0.3234E-04 0.0000E+00
0000329 0.1154E-03 0.4367E-04 0.1154E-03 0.1221E-04 0.0000E+00
0000330 0.1010E-03 0.3841E-04 0.1010E-03 0.6063E-05 0.0000E+00
0000331 0.1003E-03 0.3893E-04 0.1002E-03 0.1775E-04 0.0000E+00
0000332 0.9987E-04 0.3990E-04 0.9986E-04 0.1751E-04 0.0000E+00
0000333 0.1007E-03 0.4286E-04 0.1007E-03 0.2680E-04 0.0000E+00
0000334 0.1034E-03 0.3714E-04 0.1034E-03 0.3083E-04 0.0000E+00
0000335 0.1091E-03 0.4131E-04 0.1091E-03 0.1161E-04 0.0000E+00
0000336 0.9530E-04 0.3626E-04 0.9529E-04 0.5772E-05 0.0000E+00
0000337 0.9460E-04 0.3677E-04 0.9459E-04 0.1690E-04 0.0000E+00
0000338 0.9425E-04 0.3771E-04 0.9424E-04 0.1669E-04 0.0000E+00
0000339 0.9511E-04 0.4056E-04 0.9511E-04 0.2556E-04 0.0000E+00
0000340 0.9766E-04 0.3506E-04 0.9765E-04 0.2939E-04 0.0000E+00
0000341 0.1032E-03 0.3907E-04 0.1032E-03 0.1105E-04 0.0000E+00
0000342 0.8993E-04 0.3423E-04 0.8992E-04 0.5496E-05 0.0000E+00
0000343 0.8927E-04 0.3473E-04 0.8926E-04 0.1610E-04 0.0000E+00
0000344 0.8896E-04 0.3564E-04 0.8895E-04 0.1591E-04 0.0000E+00
0000345 0.8981E-04 0.3838E-04 0.8980E-04 0.2438E-04 0.0000E+00
0000346 0.9228E-04 0.3309E-04 0.9227E-04 0.2803E-04 0.0000E+00
0000347 0.9759E-04 0.3696E-04 0.9758E-04 0.1052E-04 0.0000E+00
0000348 0.8486E-04 0.3231E-04 0.8485E-04 0.5234E-05 0.0000E+00
0000349 0.8425E-04 0.3280E-04 0.8424E-04 0.1534E-04 0.0000E+00
0000350 0.8397E-04 0.3368E-04 0.8396E-04 0.1516E-04 0.0000E+00
0000351 0.8480E-04 0.3633E-04 0.8480E-04 0.2326E-04 0.0000E+00
0000352 0.8720E-04 0.3124E-04 0.8719E-04 0.2673E-04 0.0000E+00
0000353 0.9232E-04 0.3497E-04 0.9231E-04 0.1002E-04 0.0000E+00
0000354 0.8009E-04 0.3050E-04 0.8008E-04 0.4984E-05 0.0000E+00
0000355 0.7951E-04 0.3097E-04 0.7951E-04 0.1462E-04 0.0000E+00
0000356 0.7926E-04 0.3184E-04 0.7925E-04 0.1445E-04 0.0000E+00
0000357 0.8008E-04 0.3438E-04 0.8008E-04 0.2218E-04 0.0000E+00
0000358 0.8240E-04 0.2950E-04 0.8240E-04 0.2548E-04 0.0000E+00
0000359 0.8733E-04 0.3308E-04 0.8732E-04 0.9537E-05 0.0000E+00
0000360 0.7559E-04 0.2879E-04 0.7558E-04 0.4745E-05 0.0000E+00
0000361 0.7505E-04 0.2925E-04 0.7505E-04 0.1393E-04 0.0000E+00
0000362 0.7482E-04 0.3009E-04 0.7482E-04 0.1377E-04 0.0000E+00
0000363 0.7563E-04 0.3254E-04 0.7563E-04 0.2115E-04 0.0000E+00
0000364 0.7788E-04 0.2785E-04 0.7787E-04 0.2428E-04 0.0000E+00
0000365 0.8261E-04 0.3130E-04 0.8261E-04 0.9079E-05 0.0000E+00
0000366 0.7135E-04 0.2718E-04 0.7134E-04 0.4516E-05 0.0000E+00
0000367 0.7084E-04 0.2763E-04 0.7084E-04 0.1326E-04 0.0000E+00
0000368 0.7064E-04 0.2844E-04 0.7064E-04 0.1311E-04 0.0000E+00
0000369 0.7143E-04 0.3079E-04 0.7143E-04 0.2016E-04 0.0000E+00
0000370 0.7360E-04 0.2629E-04 0.7360E-04 0.2313E-04 0.0000E+00
0000371 0.7815E-04 0.2961E-04 0.7815E-04 0.8641E-05 0.0000E+00
0000372 0.6735E-04 0.2566E-04 0.6735E-04 0.4297E-05 0.0000E+00
0000373 0.6688E-04 0.2609E-04 0.6688E-04 0.1263E-04 0.0000E+00
0000374 0.6669E-04 0.2687E-04 0.6669E-04 0.1249E-04 0.0000E+00
0000375 0.6747E-04 0.2913E-04 0.6747E-04 0.1920E-04 0.0000E+00
0000376 0.6957E-04 0.2482E-04 0.6957E-04 0.2202E-04 0.0000E+00
0000377 0.7393E-04 0.2800E-04 0.7393E-04 0.8221E-05 0.0000E+00
0000378 0.6358E-04 0.2422E-04 0.6358E-04 0.4087E-05 0.0000E+00
0000379 0.6314E-04 0.2464E-04 0.6314E-04 0.1202E-04 0.0000E+00
0000380 0.6297E-04 0.2539E-04 0.6298E-04 0.1188E-04 0.0000E+00
0000381 0.6373E-04 0.2756E-04 0.6373E-04 0.1829E-04 0.0000E+00
0000382 0.6575E-04 0.2343E-04 0.6575E-04 0.2095E-04 0.0000E+00
0000383 0.6994E-04 0.2649E-04 0.6994E-04 0.7819E-05 0.0000E+00
0000384 0.6003E-04 0.2286E-04 0.6003E-04 0.3885E-05 0.0000E+00
0000385 0.5961E-04 0.2327E-04 0.5962E-04 0.1144E-04 0.0000E+00
0000386 0.5946E-04 0.2400E-04 0.5947E-04 0.1130E-04 0.0000E+00
0000387 0.6020E-04 0.2607E-04 0.6021E-04 0.1740E-04 0.0000E+00
0000388 0.6215E-04 0.2212E-04 0.6215E-04 0.1993E-04 0.0000E+00
0000389 0.6615E-04 0.2505E-04 0.6616E-04 0.7433E-05 0.0000E+00
0000390 0.5668E-04 0.2158E-04 0.5668E-04 0.3692E-05 0.0000E+00
0000391 0.5629E-04 0.2197E-04 0.5629E-04 0.1088E-04 0.0000E+00
0000392 0.5616E-04 0.2267E-04 0.5616E-04 0.1075E-04 0.0000E+00
0000393 0.5687E-04 0.2466E-04 0.5688E-04 0.1655E-04 0.0000E+00
0000394 0.5874E-04 0.2088E-04 0.5875E-04 0.1895E-04 0.0000E+00
0000395 0.6257E-04 0.2369E-04 0.6258E-04 0.7064E-05 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 13
0000396 0.5352E-04 0.2037E-04 0.5352E-04 0.3507E-05 0.0000E+00
0000397 0.5315E-04 0.2075E-04 0.5316E-04 0.1034E-04 0.0000E+00
0000398 0.5304E-04 0.2142E-04 0.5304E-04 0.1021E-04 0.0000E+00
0000399 0.5373E-04 0.2332E-04 0.5374E-04 0.1574E-04 0.0000E+00
0000400 0.5552E-04 0.1971E-04 0.5553E-04 0.1801E-04 0.0000E+00
0000401 0.5918E-04 0.2240E-04 0.5919E-04 0.6710E-05 0.0000E+00
0000402 0.5054E-04 0.1923E-04 0.5055E-04 0.3329E-05 0.0000E+00
0000403 0.5020E-04 0.1959E-04 0.5021E-04 0.9820E-05 0.0000E+00
0000404 0.5009E-04 0.2024E-04 0.5010E-04 0.9698E-05 0.0000E+00
0000405 0.5076E-04 0.2205E-04 0.5077E-04 0.1496E-04 0.0000E+00
0000406 0.5248E-04 0.1860E-04 0.5249E-04 0.1710E-04 0.0000E+00
0000407 0.5598E-04 0.2117E-04 0.5598E-04 0.6371E-05 0.0000E+00
0000408 0.4773E-04 0.1815E-04 0.4774E-04 0.3160E-05 0.0000E+00
0000409 0.4741E-04 0.1850E-04 0.4742E-04 0.9325E-05 0.0000E+00
0000410 0.4732E-04 0.1912E-04 0.4733E-04 0.9208E-05 0.0000E+00
0000411 0.4796E-04 0.2085E-04 0.4797E-04 0.1420E-04 0.0000E+00
0000412 0.4960E-04 0.1756E-04 0.4962E-04 0.1624E-04 0.0000E+00
0000413 0.5294E-04 0.2001E-04 0.5295E-04 0.6046E-05 0.0000E+00
0000414 0.4508E-04 0.1713E-04 0.4509E-04 0.2998E-05 0.0000E+00
0000415 0.4478E-04 0.1747E-04 0.4480E-04 0.8852E-05 0.0000E+00
0000416 0.4470E-04 0.1806E-04 0.4471E-04 0.8738E-05 0.0000E+00
0000417 0.4532E-04 0.1971E-04 0.4533E-04 0.1349E-04 0.0000E+00
0000418 0.4689E-04 0.1657E-04 0.4690E-04 0.1541E-04 0.0000E+00
0000419 0.5007E-04 0.1892E-04 0.5008E-04 0.5736E-05 0.0000E+00
0000420 0.4258E-04 0.1617E-04 0.4260E-04 0.2843E-05 0.0000E+00
0000421 0.4230E-04 0.1649E-04 0.4232E-04 0.8399E-05 0.0000E+00
0000422 0.4223E-04 0.1705E-04 0.4224E-04 0.8289E-05 0.0000E+00
0000423 0.4282E-04 0.1863E-04 0.4284E-04 0.1280E-04 0.0000E+00
0000424 0.4432E-04 0.1564E-04 0.4434E-04 0.1462E-04 0.0000E+00
0000425 0.4735E-04 0.1788E-04 0.4736E-04 0.5441E-05 0.0000E+00
0000426 0.4023E-04 0.1526E-04 0.4024E-04 0.2695E-05 0.0000E+00
0000427 0.3996E-04 0.1557E-04 0.3998E-04 0.7967E-05 0.0000E+00
0000428 0.3989E-04 0.1611E-04 0.3991E-04 0.7861E-05 0.0000E+00
0000429 0.4047E-04 0.1761E-04 0.4048E-04 0.1214E-04 0.0000E+00
0000430 0.4190E-04 0.1477E-04 0.4191E-04 0.1386E-04 0.0000E+00
0000431 0.4478E-04 0.1690E-04 0.4479E-04 0.5158E-05 0.0000E+00
0000432 0.3801E-04 0.1440E-04 0.3802E-04 0.2555E-05 0.0000E+00
0000433 0.3776E-04 0.1470E-04 0.3778E-04 0.7554E-05 0.0000E+00
0000434 0.3770E-04 0.1521E-04 0.3771E-04 0.7452E-05 0.0000E+00
0000435 0.3824E-04 0.1664E-04 0.3826E-04 0.1152E-04 0.0000E+00
0000436 0.3961E-04 0.1394E-04 0.3963E-04 0.1314E-04 0.0000E+00
0000437 0.4235E-04 0.1597E-04 0.4236E-04 0.4890E-05 0.0000E+00
0000438 0.3591E-04 0.1359E-04 0.3593E-04 0.2421E-05 0.0000E+00
0000439 0.3568E-04 0.1387E-04 0.3570E-04 0.7161E-05 0.0000E+00
0000440 0.3562E-04 0.1436E-04 0.3564E-04 0.7063E-05 0.0000E+00
0000441 0.3615E-04 0.1572E-04 0.3617E-04 0.1092E-04 0.0000E+00
0000442 0.3745E-04 0.1315E-04 0.3746E-04 0.1246E-04 0.0000E+00
0000443 0.4005E-04 0.1508E-04 0.4007E-04 0.4634E-05 0.0000E+00
0000444 0.3394E-04 0.1283E-04 0.3396E-04 0.2293E-05 0.0000E+00
0000445 0.3372E-04 0.1310E-04 0.3374E-04 0.6786E-05 0.0000E+00
0000446 0.3367E-04 0.1356E-04 0.3369E-04 0.6693E-05 0.0000E+00
0000447 0.3417E-04 0.1486E-04 0.3419E-04 0.1035E-04 0.0000E+00
0000448 0.3540E-04 0.1241E-04 0.3542E-04 0.1181E-04 0.0000E+00
0000449 0.3788E-04 0.1425E-04 0.3789E-04 0.4390E-05 0.0000E+00
0000450 0.3207E-04 0.1210E-04 0.3209E-04 0.2172E-05 0.0000E+00
0000451 0.3187E-04 0.1236E-04 0.3189E-04 0.6430E-05 0.0000E+00
0000452 0.3182E-04 0.1281E-04 0.3184E-04 0.6340E-05 0.0000E+00
0000453 0.3230E-04 0.1404E-04 0.3232E-04 0.9806E-05 0.0000E+00
0000454 0.3347E-04 0.1172E-04 0.3349E-04 0.1119E-04 0.0000E+00
0000455 0.3582E-04 0.1346E-04 0.3584E-04 0.4158E-05 0.0000E+00
0000456 0.3031E-04 0.1142E-04 0.3034E-04 0.2057E-05 0.0000E+00
0000457 0.3012E-04 0.1167E-04 0.3014E-04 0.6091E-05 0.0000E+00
0000458 0.3008E-04 0.1209E-04 0.3010E-04 0.6005E-05 0.0000E+00
0000459 0.3053E-04 0.1326E-04 0.3056E-04 0.9291E-05 0.0000E+00
0000460 0.3165E-04 0.1106E-04 0.3167E-04 0.1060E-04 0.0000E+00
0000461 0.3388E-04 0.1272E-04 0.3390E-04 0.3939E-05 0.0000E+00
0000462 0.2866E-04 0.1078E-04 0.2868E-04 0.1948E-05 0.0000E+00
0000463 0.2847E-04 0.1102E-04 0.2850E-04 0.5769E-05 0.0000E+00
0000464 0.2844E-04 0.1142E-04 0.2846E-04 0.5687E-05 0.0000E+00
0000465 0.2887E-04 0.1253E-04 0.2889E-04 0.8801E-05 0.0000E+00
0000466 0.2993E-04 0.1044E-04 0.2995E-04 0.1004E-04 0.0000E+00
0000467 0.3205E-04 0.1202E-04 0.3207E-04 0.3730E-05 0.0000E+00
0000468 0.2709E-04 0.1017E-04 0.2712E-04 0.1845E-05 0.0000E+00
0000469 0.2692E-04 0.1040E-04 0.2695E-04 0.5464E-05 0.0000E+00
0000470 0.2689E-04 0.1078E-04 0.2691E-04 0.5385E-05 0.0000E+00
0000471 0.2730E-04 0.1183E-04 0.2732E-04 0.8336E-05 0.0000E+00
0000472 0.2831E-04 0.9849E-05 0.2833E-04 0.9504E-05 0.0000E+00
0000473 0.3031E-04 0.1135E-04 0.3033E-04 0.3532E-05 0.0000E+00
0000474 0.2562E-04 0.9601E-05 0.2564E-04 0.1746E-05 0.0000E+00
0000475 0.2545E-04 0.9813E-05 0.2548E-04 0.5174E-05 0.0000E+00
0000476 0.2542E-04 0.1018E-04 0.2545E-04 0.5099E-05 0.0000E+00
0000477 0.2582E-04 0.1118E-04 0.2584E-04 0.7895E-05 0.0000E+00
0000478 0.2677E-04 0.9295E-05 0.2680E-04 0.9000E-05 0.0000E+00
0000479 0.2867E-04 0.1072E-04 0.2870E-04 0.3344E-05 0.0000E+00
0000480 0.2422E-04 0.9060E-05 0.2425E-04 0.1653E-05 0.0000E+00
0000481 0.2407E-04 0.9262E-05 0.2410E-04 0.4899E-05 0.0000E+00
0000482 0.2404E-04 0.9610E-05 0.2407E-04 0.4828E-05 0.0000E+00
0000483 0.2442E-04 0.1056E-04 0.2444E-04 0.7476E-05 0.0000E+00
0000484 0.2533E-04 0.8772E-05 0.2535E-04 0.8522E-05 0.0000E+00
0000485 0.2713E-04 0.1013E-04 0.2715E-04 0.3166E-05 0.0000E+00
0000486 0.2291E-04 0.8549E-05 0.2294E-04 0.1565E-05 0.0000E+00
0000487 0.2277E-04 0.8742E-05 0.2279E-04 0.4638E-05 0.0000E+00
0000488 0.2274E-04 0.9073E-05 0.2277E-04 0.4570E-05 0.0000E+00
0000489 0.2310E-04 0.9973E-05 0.2312E-04 0.7079E-05 0.0000E+00
0000490 0.2396E-04 0.8278E-05 0.2398E-04 0.8070E-05 0.0000E+00
0000491 0.2567E-04 0.9566E-05 0.2569E-04 0.2997E-05 0.0000E+00
0000492 0.2167E-04 0.8068E-05 0.2170E-04 0.1482E-05 0.0000E+00
0000493 0.2154E-04 0.8251E-05 0.2156E-04 0.4391E-05 0.0000E+00
0000494 0.2151E-04 0.8566E-05 0.2154E-04 0.4327E-05 0.0000E+00
0000495 0.2185E-04 0.9419E-05 0.2188E-04 0.6703E-05 0.0000E+00
0000496 0.2267E-04 0.7812E-05 0.2269E-04 0.7641E-05 0.0000E+00
0000497 0.2429E-04 0.9036E-05 0.2431E-04 0.2837E-05 0.0000E+00
0000498 0.2050E-04 0.7613E-05 0.2053E-04 0.1403E-05 0.0000E+00
0000499 0.2037E-04 0.7787E-05 0.2040E-04 0.4157E-05 0.0000E+00
0000500 0.2035E-04 0.8087E-05 0.2038E-04 0.4096E-05 0.0000E+00
0000501 0.2067E-04 0.8897E-05 0.2070E-04 0.6347E-05 0.0000E+00
0000502 0.2145E-04 0.7372E-05 0.2147E-04 0.5131E-05 0.0000E+00
0000503 0.1955E-04 0.8178E-05 0.2257E-04 0.2567E-05 0.0000E+00
0000504 0.1972E-04 0.7106E-05 0.1942E-04 0.2393E-05 0.0000E+00
0000505 0.1983E-04 0.7233E-05 0.1927E-04 0.4170E-05 0.0000E+00
0000506 0.2021E-04 0.7619E-05 0.1933E-04 0.4282E-05 0.0000E+00
0000507 0.2102E-04 0.7013E-05 0.1986E-04 0.5020E-05 0.0000E+00
0000508 0.1868E-04 0.7610E-05 0.2058E-04 0.1450E-05 0.0000E+00
0000509 0.1873E-04 0.6772E-05 0.1854E-04 0.2447E-05 0.0000E+00
0000510 0.1875E-04 0.6832E-05 0.1839E-04 0.2730E-05 0.0000E+00
0000511 0.1900E-04 0.7131E-05 0.1841E-04 0.4694E-05 0.0000E+00
0000512 0.1968E-04 0.7953E-05 0.1881E-04 0.3935E-05 0.0000E+00
0000513 0.1784E-04 0.6592E-05 0.1949E-04 0.2154E-05 0.0000E+00
0000514 0.1786E-04 0.6816E-05 0.1770E-04 0.2863E-05 0.0000E+00
0000515 0.1793E-04 0.7138E-05 0.1759E-04 0.2937E-05 0.0000E+00
0000516 0.1822E-04 0.6350E-05 0.1768E-04 0.3848E-05 0.0000E+00
0000517 0.1881E-04 0.6694E-05 0.1810E-04 0.4680E-05 0.0000E+00
0000518 0.1704E-04 0.7557E-05 0.1881E-04 0.1663E-05 0.0000E+00
0000519 0.1716E-04 0.6159E-05 0.1691E-04 0.2344E-05 0.0000E+00
0000520 0.1723E-04 0.6224E-05 0.1680E-04 0.3035E-05 0.0000E+00
0000521 0.1756E-04 0.6572E-05 0.1688E-04 0.4017E-05 0.0000E+00
0000522 0.1822E-04 0.6059E-05 0.1734E-04 0.4249E-05 0.0000E+00
0000523 0.1628E-04 0.6591E-05 0.1798E-04 0.1496E-05 0.0000E+00
0000524 0.1633E-04 0.5850E-05 0.1616E-04 0.1919E-05 0.0000E+00
0000525 0.1636E-04 0.5913E-05 0.1603E-04 0.2682E-05 0.0000E+00
0000526 0.1658E-04 0.6175E-05 0.1605E-04 0.3907E-05 0.0000E+00
0000527 0.1720E-04 0.6929E-05 0.1642E-04 0.3700E-05 0.0000E+00
0000528 0.1555E-04 0.5695E-05 0.1700E-04 0.1737E-05 0.0000E+00
0000529 0.1557E-04 0.5899E-05 0.1543E-04 0.2645E-05 0.0000E+00
0000530 0.1564E-04 0.6178E-05 0.1534E-04 0.2483E-05 0.0000E+00
0000531 0.1589E-04 0.5494E-05 0.1543E-04 0.3540E-05 0.0000E+00
0000532 0.1642E-04 0.5809E-05 0.1581E-04 0.4142E-05 0.0000E+00
0000533 0.1486E-04 0.6586E-05 0.1643E-04 0.1563E-05 0.0000E+00
0000534 0.1497E-04 0.5324E-05 0.1475E-04 0.2018E-05 0.0000E+00
0000535 0.1505E-04 0.5387E-05 0.1466E-04 0.2800E-05 0.0000E+00
0000536 0.1534E-04 0.5702E-05 0.1473E-04 0.3534E-05 0.0000E+00
0000537 0.1594E-04 0.5245E-05 0.1516E-04 0.3896E-05 0.0000E+00
0000538 0.1420E-04 0.5726E-05 0.1572E-04 0.1300E-05 0.0000E+00
0000539 0.1425E-04 0.5059E-05 0.1410E-04 0.1760E-05 0.0000E+00
0000540 0.1428E-04 0.5119E-05 0.1399E-04 0.2364E-05 0.0000E+00
0000541 0.1449E-04 0.5364E-05 0.1402E-04 0.3549E-05 0.0000E+00
0000542 0.1506E-04 0.6048E-05 0.1436E-04 0.3335E-05 0.0000E+00
0000543 0.1357E-04 0.4928E-05 0.1488E-04 0.1587E-05 0.0000E+00
0000544 0.1360E-04 0.5116E-05 0.1347E-04 0.2345E-05 0.0000E+00
0000545 0.1366E-04 0.5372E-05 0.1340E-04 0.2262E-05 0.0000E+00
0000546 0.1390E-04 0.4752E-05 0.1348E-04 0.3161E-05 0.0000E+00
0000547 0.1438E-04 0.5046E-05 0.1383E-04 0.3758E-05 0.0000E+00
0000548 0.1297E-04 0.5749E-05 0.1440E-04 0.1391E-05 0.0000E+00
0000549 0.1308E-04 0.4604E-05 0.1288E-04 0.1824E-05 0.0000E+00
0000550 0.1316E-04 0.4665E-05 0.1281E-04 0.2500E-05 0.0000E+00
0000551 0.1343E-04 0.4956E-05 0.1288E-04 0.3179E-05 0.0000E+00
0000552 0.1397E-04 0.4540E-05 0.1327E-04 0.3507E-05 0.0000E+00
0000553 0.1240E-04 0.4980E-05 0.1378E-04 0.1176E-05 0.0000E+00
0000554 0.1246E-04 0.4374E-05 0.1232E-04 0.1571E-05 0.0000E+00
0000555 0.1249E-04 0.4432E-05 0.1223E-04 0.2131E-05 0.0000E+00
0000556 0.1268E-04 0.4658E-05 0.1225E-04 0.3170E-05 0.0000E+00
0000557 0.1320E-04 0.5279E-05 0.1257E-04 0.3009E-05 0.0000E+00
0000558 0.1186E-04 0.4264E-05 0.1305E-04 0.1415E-05 0.0000E+00
0000559 0.1189E-04 0.4437E-05 0.1177E-04 0.2098E-05 0.0000E+00
0000560 0.1195E-04 0.4669E-05 0.1171E-04 0.2021E-05 0.0000E+00
0000561 0.1217E-04 0.4110E-05 0.1180E-04 0.2829E-05 0.0000E+00
0000562 0.1260E-04 0.4382E-05 0.1211E-04 0.2860E-05 0.0000E+00
0000563 0.1134E-04 0.4067E-05 0.1254E-04 0.1439E-05 0.0000E+00
0000564 0.1136E-04 0.4270E-05 0.1126E-04 0.2012E-05 0.0000E+00
0000565 0.1141E-04 0.4511E-05 0.1120E-04 0.1920E-05 0.0000E+00
0000566 0.1162E-04 0.3914E-05 0.1129E-04 0.2665E-05 0.0000E+00
0000567 0.1203E-04 0.4169E-05 0.1159E-04 0.2727E-05 0.0000E+00
0000568 0.1084E-04 0.3876E-05 0.1200E-04 0.1371E-05 0.0000E+00
0000569 0.1086E-04 0.4076E-05 0.1077E-04 0.1969E-05 0.0000E+00
0000570 0.1092E-04 0.4306E-05 0.1072E-04 0.1850E-05 0.0000E+00
0000571 0.1112E-04 0.3730E-05 0.1080E-04 0.2566E-05 0.0000E+00
0000572 0.1151E-04 0.3976E-05 0.1110E-04 0.2597E-05 0.0000E+00
0000573 0.1037E-04 0.3696E-05 0.1149E-04 0.1344E-05 0.0000E+00
0000574 0.1039E-04 0.3891E-05 0.1030E-04 0.1897E-05 0.0000E+00
0000575 0.1045E-04 0.4116E-05 0.1025E-04 0.1780E-05 0.0000E+00
0000576 0.1064E-04 0.3553E-05 0.1034E-04 0.2468E-05 0.0000E+00
0000577 0.1101E-04 0.3792E-05 0.1063E-04 0.2494E-05 0.0000E+00
0000578 0.9922E-05 0.3523E-05 0.1101E-04 0.1295E-05 0.0000E+00
0000579 0.9947E-05 0.3714E-05 0.9860E-05 0.1841E-05 0.0000E+00
0000580 0.9999E-05 0.3930E-05 0.9811E-05 0.1716E-05 0.0000E+00
0000581 0.1019E-04 0.3385E-05 0.9894E-05 0.2379E-05 0.0000E+00
0000582 0.1055E-04 0.3617E-05 0.1018E-04 0.2392E-05 0.0000E+00
0000583 0.9494E-05 0.3359E-05 0.1055E-04 0.1258E-05 0.0000E+00
0000584 0.9519E-05 0.3545E-05 0.9436E-05 0.1778E-05 0.0000E+00
0000585 0.9571E-05 0.3755E-05 0.9390E-05 0.1653E-05 0.0000E+00
0000586 0.9755E-05 0.3225E-05 0.9472E-05 0.2291E-05 0.0000E+00
0000587 0.1010E-04 0.3451E-05 0.9746E-05 0.2300E-05 0.0000E+00
0000588 0.9086E-05 0.3201E-05 0.1011E-04 0.1215E-05 0.0000E+00
0000589 0.9112E-05 0.3383E-05 0.9032E-05 0.1719E-05 0.0000E+00
0000590 0.9163E-05 0.3586E-05 0.8988E-05 0.1592E-05 0.0000E+00
0000591 0.9341E-05 0.3073E-05 0.9069E-05 0.2207E-05 0.0000E+00
0000592 0.9679E-05 0.3293E-05 0.9336E-05 0.2209E-05 0.0000E+00
0000593 0.8696E-05 0.3051E-05 0.9688E-05 0.1176E-05 0.0000E+00
0000594 0.8723E-05 0.3228E-05 0.8646E-05 0.1111E-05 0.0000E+00
0000595 0.8756E-05 0.2926E-05 0.8594E-05 0.1255E-05 0.0000E+00
0000596 0.8855E-05 0.2972E-05 0.8607E-05 0.1978E-05 0.0000E+00
0000597 0.9121E-05 0.3217E-05 0.8789E-05 0.1879E-05 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 14
0000598 0.8325E-05 0.2894E-05 0.9055E-05 0.1063E-05 0.0000E+00
0000599 0.8330E-05 0.3009E-05 0.8276E-05 0.1374E-05 0.0000E+00
0000600 0.8354E-05 0.3164E-05 0.8230E-05 0.1317E-05 0.0000E+00
0000601 0.8474E-05 0.2779E-05 0.8276E-05 0.1818E-05 0.0000E+00
0000602 0.8723E-05 0.2941E-05 0.8464E-05 0.2144E-05 0.0000E+00
0000603 0.7971E-05 0.3343E-05 0.8785E-05 0.8287E-06 0.0000E+00
0000604 0.8028E-05 0.2695E-05 0.7926E-05 0.1113E-05 0.0000E+00
0000605 0.8062E-05 0.2727E-05 0.7878E-05 0.1456E-05 0.0000E+00
0000606 0.8203E-05 0.2894E-05 0.7912E-05 0.1880E-05 0.0000E+00
0000607 0.8494E-05 0.2655E-05 0.8121E-05 0.2007E-05 0.0000E+00
0000608 0.7632E-05 0.2911E-05 0.8405E-05 0.7173E-06 0.0000E+00
0000609 0.7660E-05 0.2558E-05 0.7592E-05 0.9335E-06 0.0000E+00
0000610 0.7674E-05 0.2591E-05 0.7536E-05 0.1264E-05 0.0000E+00
0000611 0.7773E-05 0.2717E-05 0.7546E-05 0.1853E-05 0.0000E+00
0000612 0.8050E-05 0.3073E-05 0.7716E-05 0.1755E-05 0.0000E+00
0000613 0.7311E-05 0.2497E-05 0.7980E-05 0.8404E-06 0.0000E+00
0000614 0.7326E-05 0.2597E-05 0.7270E-05 0.1261E-05 0.0000E+00
0000615 0.7356E-05 0.2730E-05 0.7230E-05 0.1197E-05 0.0000E+00
0000616 0.7472E-05 0.2407E-05 0.7273E-05 0.1679E-05 0.0000E+00
0000617 0.7710E-05 0.2565E-05 0.7447E-05 0.1685E-05 0.0000E+00
0000618 0.7001E-05 0.2383E-05 0.7688E-05 0.8746E-06 0.0000E+00
0000619 0.7013E-05 0.2502E-05 0.6966E-05 0.1204E-05 0.0000E+00
0000620 0.7041E-05 0.2644E-05 0.6929E-05 0.1146E-05 0.0000E+00
0000621 0.7156E-05 0.2291E-05 0.6974E-05 0.1591E-05 0.0000E+00
0000622 0.7382E-05 0.2445E-05 0.7146E-05 0.1623E-05 0.0000E+00
0000623 0.6708E-05 0.2272E-05 0.7382E-05 0.8292E-06 0.0000E+00
0000624 0.6721E-05 0.2391E-05 0.6675E-05 0.1191E-05 0.0000E+00
0000625 0.6750E-05 0.2527E-05 0.6640E-05 0.1111E-05 0.0000E+00
0000626 0.6862E-05 0.2184E-05 0.6687E-05 0.1543E-05 0.0000E+00
0000627 0.7083E-05 0.2334E-05 0.6856E-05 0.1556E-05 0.0000E+00
0000628 0.6428E-05 0.2167E-05 0.7088E-05 0.8209E-06 0.0000E+00
0000629 0.6442E-05 0.2285E-05 0.6398E-05 0.1150E-05 0.0000E+00
0000630 0.6472E-05 0.2420E-05 0.6365E-05 0.1075E-05 0.0000E+00
0000631 0.6583E-05 0.2081E-05 0.6412E-05 0.1491E-05 0.0000E+00
0000632 0.6798E-05 0.2229E-05 0.6580E-05 0.1504E-05 0.0000E+00
0000633 0.6161E-05 0.2066E-05 0.6808E-05 0.7918E-06 0.0000E+00
0000634 0.6177E-05 0.2183E-05 0.6133E-05 0.1122E-05 0.0000E+00
0000635 0.6206E-05 0.2314E-05 0.6103E-05 0.1040E-05 0.0000E+00
0000636 0.6316E-05 0.1983E-05 0.6150E-05 0.1445E-05 0.0000E+00
0000637 0.6527E-05 0.2128E-05 0.6315E-05 0.1450E-05 0.0000E+00
0000638 0.5907E-05 0.1970E-05 0.6539E-05 0.7730E-06 0.0000E+00
0000639 0.5923E-05 0.2085E-05 0.5881E-05 0.7311E-06 0.0000E+00
0000640 0.5943E-05 0.1887E-05 0.5845E-05 0.8256E-06 0.0000E+00
0000641 0.6003E-05 0.1919E-05 0.5852E-05 0.1301E-05 0.0000E+00
0000642 0.6171E-05 0.2082E-05 0.5964E-05 0.1239E-05 0.0000E+00
0000643 0.5664E-05 0.1868E-05 0.6135E-05 0.1374E-05 0.0000E+00
0000644 0.5706E-05 0.2036E-05 0.6349E-05 0.1009E-05 0.0000E+00
0000645 0.5833E-05 0.1816E-05 0.5594E-05 0.1131E-05 0.0000E+00
0000646 0.5954E-05 0.1906E-05 0.5587E-05 0.1605E-05 0.0000E+00
0000647 0.6217E-05 0.2167E-05 0.5721E-05 0.1195E-05 0.0000E+00
0000648 0.5435E-05 0.1787E-05 0.5957E-05 0.6666E-06 0.0000E+00
0000649 0.5444E-05 0.1875E-05 0.5409E-05 0.9845E-06 0.0000E+00
0000650 0.5463E-05 0.1981E-05 0.5380E-05 0.9117E-06 0.0000E+00
0000651 0.5550E-05 0.1712E-05 0.5408E-05 0.1229E-05 0.0000E+00
0000652 0.5715E-05 0.1829E-05 0.5537E-05 0.1281E-05 0.0000E+00
0000653 0.5211E-05 0.1698E-05 0.5711E-05 0.6658E-06 0.0000E+00
0000654 0.5220E-05 0.1788E-05 0.5190E-05 0.9082E-06 0.0000E+00
0000655 0.5243E-05 0.1893E-05 0.5163E-05 0.8431E-06 0.0000E+00
0000656 0.5326E-05 0.1631E-05 0.5200E-05 0.1197E-05 0.0000E+00
0000657 0.5495E-05 0.1747E-05 0.5328E-05 0.1174E-05 0.0000E+00
0000658 0.4998E-05 0.1620E-05 0.5511E-05 0.6311E-06 0.0000E+00
0000659 0.5011E-05 0.1713E-05 0.4980E-05 0.6153E-06 0.0000E+00
0000660 0.5024E-05 0.1553E-05 0.4949E-05 0.6902E-06 0.0000E+00
0000661 0.5071E-05 0.1578E-05 0.4951E-05 0.1076E-05 0.0000E+00
0000662 0.5202E-05 0.1709E-05 0.5039E-05 0.1397E-05 0.0000E+00
0000663 0.5483E-05 0.1565E-05 0.5266E-05 0.6865E-06 0.0000E+00
0000664 0.4762E-05 0.1734E-05 0.4778E-05 0.3466E-06 0.0000E+00
0000665 0.4734E-05 0.1478E-05 0.4760E-05 0.5710E-06 0.0000E+00
0000666 0.4716E-05 0.1479E-05 0.4746E-05 0.6979E-06 0.0000E+00
0000667 0.4734E-05 0.1533E-05 0.4766E-05 0.1145E-05 0.0000E+00
0000668 0.4822E-05 0.1713E-05 0.4868E-05 0.1458E-05 0.0000E+00
0000669 0.5045E-05 0.1482E-05 0.5095E-05 0.6344E-06 0.0000E+00
0000670 0.4531E-05 0.1646E-05 0.4550E-05 0.2832E-06 0.0000E+00
0000671 0.4512E-05 0.1393E-05 0.4529E-05 0.5875E-06 0.0000E+00
0000672 0.4496E-05 0.1394E-05 0.4514E-05 0.6486E-06 0.0000E+00
0000673 0.4517E-05 0.1440E-05 0.4533E-05 0.1108E-05 0.0000E+00
0000674 0.4608E-05 0.1611E-05 0.4626E-05 0.1363E-05 0.0000E+00
0000675 0.4833E-05 0.1396E-05 0.4847E-05 0.5949E-06 0.0000E+00
0000676 0.4315E-05 0.1556E-05 0.4333E-05 0.2575E-06 0.0000E+00
0000677 0.4296E-05 0.1314E-05 0.4314E-05 0.5763E-06 0.0000E+00
0000678 0.4281E-05 0.1314E-05 0.4299E-05 0.6076E-06 0.0000E+00
0000679 0.4300E-05 0.1355E-05 0.4318E-05 0.1053E-05 0.0000E+00
0000680 0.4384E-05 0.1517E-05 0.4403E-05 0.1270E-05 0.0000E+00
0000681 0.4593E-05 0.1316E-05 0.4611E-05 0.5578E-06 0.0000E+00
0000682 0.4110E-05 0.1466E-05 0.4127E-05 0.2365E-06 0.0000E+00
0000683 0.4092E-05 0.1239E-05 0.4109E-05 0.5451E-06 0.0000E+00
0000684 0.4077E-05 0.1239E-05 0.4094E-05 0.5623E-06 0.0000E+00
0000685 0.4094E-05 0.1275E-05 0.4111E-05 0.9831E-06 0.0000E+00
0000686 0.4170E-05 0.1423E-05 0.4187E-05 0.1172E-05 0.0000E+00
0000687 0.4364E-05 0.1239E-05 0.4380E-05 0.5216E-06 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 15
0000688 0.3916E-05 0.1379E-05 0.3933E-05 0.2187E-06 0.0000E+00
0000689 0.3899E-05 0.1168E-05 0.3916E-05 0.5091E-06 0.0000E+00
0000690 0.3884E-05 0.1168E-05 0.3900E-05 0.5213E-06 0.0000E+00
0000691 0.3898E-05 0.1200E-05 0.3914E-05 0.9139E-06 0.0000E+00
0000692 0.3967E-05 0.1336E-05 0.3983E-05 0.1084E-05 0.0000E+00
0000693 0.4145E-05 0.1168E-05 0.4161E-05 0.4870E-06 0.0000E+00
0000694 0.3732E-05 0.1296E-05 0.3749E-05 0.2024E-06 0.0000E+00
0000695 0.3715E-05 0.1101E-05 0.3732E-05 0.4723E-06 0.0000E+00
0000696 0.3701E-05 0.1101E-05 0.3717E-05 0.4830E-06 0.0000E+00
0000697 0.3712E-05 0.1130E-05 0.3728E-05 0.8475E-06 0.0000E+00
0000698 0.3775E-05 0.1254E-05 0.3790E-05 0.1003E-05 0.0000E+00
0000699 0.3938E-05 0.1100E-05 0.3953E-05 0.4548E-06 0.0000E+00
0000700 0.3558E-05 0.1218E-05 0.3574E-05 0.1879E-06 0.0000E+00
0000701 0.3542E-05 0.1038E-05 0.3558E-05 0.4379E-06 0.0000E+00
0000702 0.3527E-05 0.1037E-05 0.3543E-05 0.4487E-06 0.0000E+00
0000703 0.3537E-05 0.1064E-05 0.3553E-05 0.7870E-06 0.0000E+00
0000704 0.3593E-05 0.1178E-05 0.3608E-05 0.9306E-06 0.0000E+00
0000705 0.3743E-05 0.1037E-05 0.3757E-05 0.4251E-06 0.0000E+00
0000706 0.3393E-05 0.1146E-05 0.3409E-05 0.1748E-06 0.0000E+00
0000707 0.3377E-05 0.9790E-06 0.3393E-05 0.4063E-06 0.0000E+00
0000708 0.3363E-05 0.9780E-06 0.3379E-05 0.4176E-06 0.0000E+00
0000709 0.3371E-05 0.1002E-05 0.3386E-05 0.7318E-06 0.0000E+00
0000710 0.3422E-05 0.1108E-05 0.3437E-05 0.8655E-06 0.0000E+00
0000711 0.3559E-05 0.9772E-06 0.3574E-05 0.3979E-06 0.0000E+00
0000712 0.3237E-05 0.1078E-05 0.3252E-05 0.1630E-06 0.0000E+00
0000713 0.3222E-05 0.9231E-06 0.3237E-05 0.3778E-06 0.0000E+00
0000714 0.3208E-05 0.9220E-06 0.3223E-05 0.3897E-06 0.0000E+00
0000715 0.3215E-05 0.9440E-06 0.3229E-05 0.6820E-06 0.0000E+00
0000716 0.3261E-05 0.1042E-05 0.3275E-05 0.8072E-06 0.0000E+00
0000717 0.3387E-05 0.9212E-06 0.3401E-05 0.3729E-06 0.0000E+00
0000718 0.3089E-05 0.1015E-05 0.3104E-05 0.1524E-06 0.0000E+00
0000719 0.3074E-05 0.8704E-06 0.3089E-05 0.3521E-06 0.0000E+00
0000720 0.3061E-05 0.8693E-06 0.3075E-05 0.3644E-06 0.0000E+00
0000721 0.3066E-05 0.8895E-06 0.3081E-05 0.6369E-06 0.0000E+00
0000722 0.3108E-05 0.9805E-06 0.3122E-05 0.7545E-06 0.0000E+00
0000723 0.3225E-05 0.8685E-06 0.3238E-05 0.3501E-06 0.0000E+00
0000724 0.2949E-05 0.9553E-06 0.2963E-05 0.1428E-06 0.0000E+00
0000725 0.2934E-05 0.8207E-06 0.2949E-05 0.3288E-06 0.0000E+00
0000726 0.2921E-05 0.8196E-06 0.2936E-05 0.3414E-06 0.0000E+00
0000727 0.2926E-05 0.8383E-06 0.2940E-05 0.5960E-06 0.0000E+00
0000728 0.2964E-05 0.9232E-06 0.2978E-05 0.7067E-06 0.0000E+00
0000729 0.3072E-05 0.8188E-06 0.3085E-05 0.1106E-05 0.0000E+00
0000730 0.3284E-05 0.1022E-05 0.3296E-05 0.3272E-06 0.0000E+00
0000731 0.2799E-05 0.7956E-06 0.2813E-05 0.2863E-06 0.0000E+00
0000732 0.2786E-05 0.8254E-06 0.2800E-05 0.5168E-06 0.0000E+00
0000733 0.2789E-05 0.8752E-06 0.2803E-05 0.5050E-06 0.0000E+00
0000734 0.2825E-05 0.7685E-06 0.2838E-05 0.7573E-06 0.0000E+00
0000735 0.2911E-05 0.8529E-06 0.2923E-05 0.9903E-06 0.0000E+00
0000736 0.3094E-05 0.7992E-06 0.3106E-05 0.2797E-06 0.0000E+00
0000737 0.2672E-05 0.7519E-06 0.2686E-05 0.2361E-06 0.0000E+00
0000738 0.2657E-05 0.7763E-06 0.2671E-05 0.4487E-06 0.0000E+00
0000739 0.2653E-05 0.8191E-06 0.2666E-05 0.3828E-06 0.0000E+00
0000740 0.2674E-05 0.7185E-06 0.2687E-05 0.6412E-06 0.0000E+00
0000741 0.2728E-05 0.7757E-06 0.2740E-05 0.7961E-06 0.0000E+00
0000742 0.2859E-05 0.7356E-06 0.2871E-05 0.3786E-06 0.0000E+00
0000743 0.2552E-05 0.8375E-06 0.2565E-05 0.1463E-06 0.0000E+00
0000744 0.2543E-05 0.6833E-06 0.2556E-05 0.3232E-06 0.0000E+00
0000745 0.2537E-05 0.6859E-06 0.2550E-05 0.3563E-06 0.0000E+00
0000746 0.2552E-05 0.7188E-06 0.2564E-05 0.6264E-06 0.0000E+00
0000747 0.2609E-05 0.8270E-06 0.2621E-05 0.7529E-06 0.0000E+00
0000748 0.2746E-05 0.6984E-06 0.2757E-05 0.3513E-06 0.0000E+00
0000749 0.2440E-05 0.7994E-06 0.2452E-05 0.1385E-06 0.0000E+00
0000750 0.2431E-05 0.6440E-06 0.2444E-05 0.3151E-06 0.0000E+00
0000751 0.2425E-05 0.6468E-06 0.2437E-05 0.3374E-06 0.0000E+00
0000752 0.2439E-05 0.6764E-06 0.2451E-05 0.5898E-06 0.0000E+00
0000753 0.2493E-05 0.7805E-06 0.2504E-05 0.7041E-06 0.0000E+00
0000754 0.2622E-05 0.6583E-06 0.2633E-05 0.3263E-06 0.0000E+00
0000755 0.2333E-05 0.7550E-06 0.2345E-05 0.1307E-06 0.0000E+00
0000756 0.2325E-05 0.6072E-06 0.2337E-05 0.3001E-06 0.0000E+00
0000757 0.2318E-05 0.6097E-06 0.2330E-05 0.3165E-06 0.0000E+00
0000758 0.2331E-05 0.6361E-06 0.2342E-05 0.5517E-06 0.0000E+00
0000759 0.2379E-05 0.7331E-06 0.2391E-05 0.6552E-06 0.0000E+00
0000760 0.2499E-05 0.6199E-06 0.2509E-05 0.3036E-06 0.0000E+00
0000761 0.2231E-05 0.7101E-06 0.2243E-05 0.1226E-06 0.0000E+00
0000762 0.2223E-05 0.5725E-06 0.2235E-05 0.2818E-06 0.0000E+00
0000763 0.2216E-05 0.5746E-06 0.2228E-05 0.2953E-06 0.0000E+00
0000764 0.2227E-05 0.5982E-06 0.2238E-05 0.5141E-06 0.0000E+00
0000765 0.2271E-05 0.6875E-06 0.2282E-05 0.6089E-06 0.0000E+00
0000766 0.2380E-05 0.5836E-06 0.2390E-05 0.2826E-06 0.0000E+00
0000767 0.2135E-05 0.6669E-06 0.2146E-05 0.1145E-06 0.0000E+00
0000768 0.2127E-05 0.5398E-06 0.2138E-05 0.2630E-06 0.0000E+00
0000769 0.2120E-05 0.5415E-06 0.2131E-05 0.2749E-06 0.0000E+00
0000770 0.2129E-05 0.5628E-06 0.2140E-05 0.4782E-06 0.0000E+00
0000771 0.2168E-05 0.6448E-06 0.2178E-05 0.5658E-06 0.0000E+00
0000772 0.2267E-05 0.5495E-06 0.2277E-05 0.2634E-06 0.0000E+00
0000773 0.2043E-05 0.6262E-06 0.2054E-05 0.1068E-06 0.0000E+00
0000774 0.2035E-05 0.5089E-06 0.2046E-05 0.2448E-06 0.0000E+00
0000775 0.2028E-05 0.5104E-06 0.2039E-05 0.2560E-06 0.0000E+00
0000776 0.2035E-05 0.5297E-06 0.2046E-05 0.4451E-06 0.0000E+00
0000777 0.2070E-05 0.6051E-06 0.2081E-05 0.5266E-06 0.0000E+00
0000778 0.2160E-05 0.5175E-06 0.2170E-05 0.2459E-06 0.0000E+00
0000779 0.1956E-05 0.5883E-06 0.1966E-05 0.9960E-07 0.0000E+00
0000780 0.1948E-05 0.4799E-06 0.1958E-05 0.2280E-06 0.0000E+00
0000781 0.1941E-05 0.4811E-06 0.1951E-05 0.2386E-06 0.0000E+00
0000782 0.1947E-05 0.4987E-06 0.1957E-05 0.4147E-06 0.0000E+00
0000783 0.1978E-05 0.5683E-06 0.1988E-05 0.4909E-06 0.0000E+00
0000784 0.2060E-05 0.4875E-06 0.2070E-05 0.2298E-06 0.0000E+00
0000785 0.1873E-05 0.5529E-06 0.1883E-05 0.9302E-07 0.0000E+00
0000786 0.1865E-05 0.4524E-06 0.1875E-05 0.2125E-06 0.0000E+00
0000787 0.1858E-05 0.4535E-06 0.1868E-05 0.2228E-06 0.0000E+00
0000788 0.1863E-05 0.4697E-06 0.1873E-05 0.3870E-06 0.0000E+00
0000789 0.1891E-05 0.5341E-06 0.1901E-05 0.4585E-06 0.0000E+00
0000790 0.1966E-05 0.4594E-06 0.1975E-05 0.2152E-06 0.0000E+00
0000791 0.1794E-05 0.5200E-06 0.1804E-05 0.8701E-07 0.0000E+00
0000792 0.1786E-05 0.4266E-06 0.1796E-05 0.1984E-06 0.0000E+00
0000793 0.1779E-05 0.4275E-06 0.1789E-05 0.2084E-06 0.0000E+00
0000794 0.1784E-05 0.4424E-06 0.1793E-05 0.3618E-06 0.0000E+00
0000795 0.1809E-05 0.5023E-06 0.1818E-05 0.4291E-06 0.0000E+00
0000796 0.1877E-05 0.4329E-06 0.1886E-05 0.6729E-06 0.0000E+00
0000797 0.2011E-05 0.5743E-06 0.2019E-05 0.2009E-06 0.0000E+00
0000798 0.1710E-05 0.4187E-06 0.1719E-05 0.1753E-06 0.0000E+00
0000799 0.1703E-05 0.4402E-06 0.1712E-05 0.2185E-06 0.0000E+00
0000800 0.1704E-05 0.3965E-06 0.1713E-05 0.2669E-06 0.0000E+00
0000801 0.1718E-05 0.4178E-06 0.1727E-05 0.4518E-06 0.0000E+00
0000802 0.1765E-05 0.4859E-06 0.1773E-05 0.5603E-06 0.0000E+00
0000803 0.1869E-05 0.4247E-06 0.1877E-05 0.1685E-06 0.0000E+00
0000804 0.1637E-05 0.3927E-06 0.1646E-05 0.1253E-06 0.0000E+00
0000805 0.1629E-05 0.4084E-06 0.1638E-05 0.1838E-06 0.0000E+00
0000806 0.1625E-05 0.3733E-06 0.1633E-05 0.1794E-06 0.0000E+00
0000807 0.1629E-05 0.3834E-06 0.1637E-05 0.3506E-06 0.0000E+00
0000808 0.1651E-05 0.4255E-06 0.1660E-05 0.4096E-06 0.0000E+00
0000809 0.1714E-05 0.3846E-06 0.1722E-05 0.2152E-06 0.0000E+00
0000810 0.1569E-05 0.4342E-06 0.1577E-05 0.7127E-07 0.0000E+00
0000811 0.1562E-05 0.3548E-06 0.1571E-05 0.1716E-06 0.0000E+00
0000812 0.1557E-05 0.3565E-06 0.1566E-05 0.1795E-06 0.0000E+00
0000813 0.1562E-05 0.3749E-06 0.1570E-05 0.3341E-06 0.0000E+00
0000814 0.1586E-05 0.4317E-06 0.1594E-05 0.3919E-06 0.0000E+00
0000815 0.1650E-05 0.3656E-06 0.1658E-05 0.1952E-06 0.0000E+00
0000816 0.1504E-05 0.4181E-06 0.1513E-05 0.7037E-07 0.0000E+00
0000817 0.1499E-05 0.3344E-06 0.1507E-05 0.1670E-06 0.0000E+00
0000818 0.1494E-05 0.3362E-06 0.1502E-05 0.1761E-06 0.0000E+00
0000819 0.1498E-05 0.3529E-06 0.1506E-05 0.3154E-06 0.0000E+00
0000820 0.1522E-05 0.4092E-06 0.1530E-05 0.3739E-06 0.0000E+00
0000821 0.1584E-05 0.3448E-06 0.1591E-05 0.1798E-06 0.0000E+00
0000822 0.1443E-05 0.3967E-06 0.1451E-05 0.6871E-07 0.0000E+00
0000823 0.1438E-05 0.3153E-06 0.1445E-05 0.1603E-06 0.0000E+00
0000824 0.1433E-05 0.3170E-06 0.1441E-05 0.1688E-06 0.0000E+00
0000825 0.1437E-05 0.3321E-06 0.1445E-05 0.2973E-06 0.0000E+00
0000826 0.1459E-05 0.3859E-06 0.1466E-05 0.3532E-06 0.0000E+00
0000827 0.1517E-05 0.3250E-06 0.1524E-05 0.1675E-06 0.0000E+00
0000828 0.1385E-05 0.3746E-06 0.1392E-05 0.6593E-07 0.0000E+00
0000829 0.1379E-05 0.2973E-06 0.1387E-05 0.1520E-06 0.0000E+00
0000830 0.1375E-05 0.2988E-06 0.1382E-05 0.1600E-06 0.0000E+00
0000831 0.1378E-05 0.3126E-06 0.1385E-05 0.2794E-06 0.0000E+00
0000832 0.1398E-05 0.3630E-06 0.1405E-05 0.3322E-06 0.0000E+00
0000833 0.1452E-05 0.3061E-06 0.1458E-05 0.5201E-06 0.0000E+00
0000834 0.1556E-05 0.4235E-06 0.1562E-05 0.1545E-06 0.0000E+00
0000835 0.1322E-05 0.2948E-06 0.1329E-05 0.1356E-06 0.0000E+00
0000836 0.1317E-05 0.3128E-06 0.1325E-05 0.1688E-06 0.0000E+00
0000837 0.1318E-05 0.2767E-06 0.1326E-05 0.2061E-06 0.0000E+00
0000838 0.1330E-05 0.2955E-06 0.1337E-05 0.3485E-06 0.0000E+00
0000839 0.1366E-05 0.3523E-06 0.1373E-05 0.4329E-06 0.0000E+00
0000840 0.1448E-05 0.3030E-06 0.1454E-05 0.1301E-06 0.0000E+00
0000841 0.1268E-05 0.2761E-06 0.1275E-05 0.9704E-07 0.0000E+00
0000842 0.1262E-05 0.2894E-06 0.1269E-05 0.1420E-06 0.0000E+00
0000843 0.1259E-05 0.2604E-06 0.1266E-05 0.1386E-06 0.0000E+00
0000844 0.1263E-05 0.2696E-06 0.1269E-05 0.2708E-06 0.0000E+00
0000845 0.1281E-05 0.3053E-06 0.1287E-05 0.3165E-06 0.0000E+00
0000846 0.1329E-05 0.2721E-06 0.1335E-05 0.3443E-06 0.0000E+00
0000847 0.1212E-05 0.2714E-06 0.1400E-05 0.1015E-06 0.0000E+00
0000848 0.1225E-05 0.2521E-06 0.1218E-05 0.1711E-06 0.0000E+00
0000849 0.1231E-05 0.2651E-06 0.1208E-05 0.1986E-06 0.0000E+00
0000850 0.1251E-05 0.2965E-06 0.1211E-05 0.2580E-06 0.0000E+00
0000851 0.1292E-05 0.2523E-06 0.1234E-05 0.2584E-06 0.0000E+00
0000852 0.1176E-05 0.2961E-06 0.1274E-05 0.2699E-06 0.0000E+00
0000853 0.1184E-05 0.2468E-06 0.1323E-05 0.2085E-06 0.0000E+00
0000854 0.1213E-05 0.2848E-06 0.1169E-05 0.2154E-06 0.0000E+00
0000855 0.1243E-05 0.2365E-06 0.1168E-05 0.2706E-06 0.0000E+00
0000856 0.1295E-05 0.2812E-06 0.1191E-05 0.2233E-06 0.0000E+00
0000857 0.1138E-05 0.2386E-06 0.1237E-05 0.2829E-06 0.0000E+00
0000858 0.1143E-05 0.2888E-06 0.1284E-05 0.1974E-06 0.0000E+00
0000859 0.1171E-05 0.2300E-06 0.1131E-05 0.1946E-06 0.0000E+00
0000860 0.1200E-05 0.2597E-06 0.1129E-05 0.2708E-06 0.0000E+00
0000861 0.1247E-05 0.2300E-06 0.1151E-05 0.2390E-06 0.0000E+00
0000862 0.1101E-05 0.2785E-06 0.1193E-05 0.2672E-06 0.0000E+00
0000863 0.1108E-05 0.2230E-06 0.1238E-05 0.1981E-06 0.0000E+00
0000864 0.1135E-05 0.2595E-06 0.1094E-05 0.2020E-06 0.0000E+00
0000865 0.1163E-05 0.2140E-06 0.1093E-05 0.2575E-06 0.0000E+00
0000866 0.1211E-05 0.2569E-06 0.1116E-05 0.2251E-06 0.0000E+00
0000867 0.1065E-05 0.2163E-06 0.1159E-05 0.2674E-06 0.0000E+00
0000868 0.1071E-05 0.2634E-06 0.1202E-05 0.1905E-06 0.0000E+00
0000869 0.1098E-05 0.2087E-06 0.1059E-05 0.1901E-06 0.0000E+00
0000870 0.1125E-05 0.2381E-06 0.1057E-05 0.2608E-06 0.0000E+00
0000871 0.1169E-05 0.2091E-06 0.1080E-05 0.2297E-06 0.0000E+00
0000872 0.1031E-05 0.2563E-06 0.1120E-05 0.2636E-06 0.0000E+00
0000873 0.1039E-05 0.2024E-06 0.1161E-05 0.1937E-06 0.0000E+00
0000874 0.1065E-05 0.2381E-06 0.1025E-05 0.1959E-06 0.0000E+00
0000875 0.1092E-05 0.1943E-06 0.1024E-05 0.2515E-06 0.0000E+00
0000876 0.1136E-05 0.2358E-06 0.1048E-05 0.2241E-06 0.0000E+00
0000877 0.9978E-06 0.1967E-06 0.1089E-05 0.9582E-07 0.0000E+00
0000878 0.1000E-05 0.2204E-06 0.9984E-06 0.1168E-06 0.0000E+00
0000879 0.1003E-05 0.1831E-06 0.9924E-06 0.1235E-06 0.0000E+00
0000880 0.1011E-05 0.1919E-06 0.9919E-06 0.1972E-06 0.0000E+00
0000881 0.1032E-05 0.2226E-06 0.1005E-05 0.2527E-06 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 16
0000882 0.1080E-05 0.1961E-06 0.1041E-05 0.7799E-07 0.0000E+00
0000883 0.9612E-06 0.1811E-06 0.9654E-06 0.6375E-07 0.0000E+00
0000884 0.9550E-06 0.1883E-06 0.9610E-06 0.1182E-06 0.0000E+00
0000885 0.9516E-06 0.2002E-06 0.9581E-06 0.1128E-06 0.0000E+00
0000886 0.9526E-06 0.1732E-06 0.9593E-06 0.1765E-06 0.0000E+00
0000887 0.9595E-06 0.1892E-06 0.9677E-06 0.2261E-06 0.0000E+00
0000888 0.9823E-06 0.1793E-06 0.9912E-06 0.3389E-06 0.0000E+00
0000889 0.1033E-05 0.2436E-06 0.1044E-05 0.8961E-07 0.0000E+00
0000890 0.9188E-06 0.1730E-06 0.9236E-06 0.8349E-07 0.0000E+00
0000891 0.9153E-06 0.1831E-06 0.9197E-06 0.1143E-06 0.0000E+00
0000892 0.9145E-06 0.1620E-06 0.9186E-06 0.1318E-06 0.0000E+00
0000893 0.9192E-06 0.1730E-06 0.9231E-06 0.2073E-06 0.0000E+00
0000894 0.9350E-06 0.1653E-06 0.9381E-06 0.2763E-06 0.0000E+00
0000895 0.9746E-06 0.2141E-06 0.9771E-06 0.8663E-07 0.0000E+00
0000896 0.8837E-06 0.1609E-06 0.8881E-06 0.5772E-07 0.0000E+00
0000897 0.8796E-06 0.1689E-06 0.8841E-06 0.1024E-06 0.0000E+00
0000898 0.8775E-06 0.1522E-06 0.8818E-06 0.9833E-07 0.0000E+00
0000899 0.8796E-06 0.1600E-06 0.8839E-06 0.1920E-06 0.0000E+00
0000900 0.8911E-06 0.1865E-06 0.8952E-06 0.2240E-06 0.0000E+00
0000901 0.9223E-06 0.1626E-06 0.9263E-06 0.7194E-07 0.0000E+00
0000902 0.8499E-06 0.1509E-06 0.8542E-06 0.4501E-07 0.0000E+00
0000903 0.8454E-06 0.1570E-06 0.8496E-06 0.1080E-06 0.0000E+00
0000904 0.8424E-06 0.1674E-06 0.8465E-06 0.8239E-07 0.0000E+00
0000905 0.8434E-06 0.1438E-06 0.8475E-06 0.1558E-06 0.0000E+00
0000906 0.8498E-06 0.1579E-06 0.8537E-06 0.1819E-06 0.0000E+00
0000907 0.8704E-06 0.1496E-06 0.8741E-06 0.2941E-06 0.0000E+00
0000908 0.9158E-06 0.2069E-06 0.9190E-06 0.7491E-07 0.0000E+00
0000909 0.8135E-06 0.1447E-06 0.8175E-06 0.7709E-07 0.0000E+00
0000910 0.8102E-06 0.1541E-06 0.8143E-06 0.9455E-07 0.0000E+00
0000911 0.8096E-06 0.1347E-06 0.8136E-06 0.1188E-06 0.0000E+00
0000912 0.8136E-06 0.1451E-06 0.8175E-06 0.1773E-06 0.0000E+00
0000913 0.8276E-06 0.1382E-06 0.8313E-06 0.2453E-06 0.0000E+00
0000914 0.8625E-06 0.1830E-06 0.8660E-06 0.7462E-07 0.0000E+00
0000915 0.7828E-06 0.1345E-06 0.7866E-06 0.5273E-07 0.0000E+00
0000916 0.7793E-06 0.1422E-06 0.7832E-06 0.8729E-07 0.0000E+00
0000917 0.7776E-06 0.1265E-06 0.7814E-06 0.8797E-07 0.0000E+00
0000918 0.7796E-06 0.1341E-06 0.7834E-06 0.1677E-06 0.0000E+00
0000919 0.7903E-06 0.1587E-06 0.7939E-06 0.1985E-06 0.0000E+00
0000920 0.8189E-06 0.1372E-06 0.8222E-06 0.2128E-06 0.0000E+00
0000921 0.7498E-06 0.1370E-06 0.8614E-06 0.6295E-07 0.0000E+00
0000922 0.7578E-06 0.1241E-06 0.7535E-06 0.1059E-06 0.0000E+00
0000923 0.7621E-06 0.1340E-06 0.7479E-06 0.9907E-07 0.0000E+00
0000924 0.7725E-06 0.1210E-06 0.7492E-06 0.1583E-06 0.0000E+00
0000925 0.7943E-06 0.1437E-06 0.7615E-06 0.2014E-06 0.0000E+00
0000926 0.8405E-06 0.1325E-06 0.7953E-06 0.6047E-07 0.0000E+00
0000927 0.7262E-06 0.1215E-06 0.7288E-06 0.5657E-07 0.0000E+00
0000928 0.7216E-06 0.1283E-06 0.7263E-06 0.7237E-07 0.0000E+00
0000929 0.7193E-06 0.1128E-06 0.7245E-06 0.7697E-07 0.0000E+00
0000930 0.7198E-06 0.1179E-06 0.7254E-06 0.1388E-06 0.0000E+00
0000931 0.7260E-06 0.1374E-06 0.7333E-06 0.1672E-06 0.0000E+00
0000932 0.7459E-06 0.1193E-06 0.7549E-06 0.2487E-06 0.0000E+00
0000933 0.7860E-06 0.1297E-06 0.7976E-06 0.6162E-07 0.0000E+00
0000934 0.6948E-06 0.1154E-06 0.6982E-06 0.3926E-07 0.0000E+00
0000935 0.6918E-06 0.1054E-06 0.6948E-06 0.6731E-07 0.0000E+00
0000936 0.6897E-06 0.1071E-06 0.6926E-06 0.8666E-07 0.0000E+00
0000937 0.6910E-06 0.1153E-06 0.6936E-06 0.1255E-06 0.0000E+00
0000938 0.6986E-06 0.1066E-06 0.7006E-06 0.1748E-06 0.0000E+00
0000939 0.7195E-06 0.1320E-06 0.7209E-06 0.2467E-06 0.0000E+00
0000940 0.7642E-06 0.1197E-06 0.7644E-06 0.6077E-07 0.0000E+00
0000941 0.6654E-06 0.1088E-06 0.6684E-06 0.3772E-07 0.0000E+00
0000942 0.6624E-06 0.9833E-07 0.6656E-06 0.6891E-07 0.0000E+00
0000943 0.6604E-06 0.9999E-07 0.6636E-06 0.8637E-07 0.0000E+00
0000944 0.6619E-06 0.1075E-06 0.6650E-06 0.1264E-06 0.0000E+00
0000945 0.6694E-06 0.9985E-07 0.6727E-06 0.1735E-06 0.0000E+00
0000946 0.6904E-06 0.1240E-06 0.6937E-06 0.2459E-06 0.0000E+00
0000947 0.7344E-06 0.1125E-06 0.7379E-06 0.5970E-07 0.0000E+00
0000948 0.6372E-06 0.1021E-06 0.6401E-06 0.3768E-07 0.0000E+00
0000949 0.6345E-06 0.9187E-07 0.6374E-06 0.6741E-07 0.0000E+00
0000950 0.6328E-06 0.9356E-07 0.6357E-06 0.8536E-07 0.0000E+00
0000951 0.6346E-06 0.1012E-06 0.6374E-06 0.1242E-06 0.0000E+00
0000952 0.6428E-06 0.9341E-07 0.6454E-06 0.1715E-06 0.0000E+00
0000953 0.6645E-06 0.1173E-06 0.6668E-06 0.2421E-06 0.0000E+00
0000954 0.7094E-06 0.1060E-06 0.7114E-06 0.5860E-07 0.0000E+00
0000955 0.6104E-06 0.9606E-07 0.6131E-06 0.3708E-07 0.0000E+00
0000956 0.6079E-06 0.8580E-07 0.6106E-06 0.6685E-07 0.0000E+00
0000957 0.6064E-06 0.8752E-07 0.6092E-06 0.8426E-07 0.0000E+00
0000958 0.6084E-06 0.9503E-07 0.6111E-06 0.1227E-06 0.0000E+00
0000959 0.6168E-06 0.8751E-07 0.6195E-06 0.1688E-06 0.0000E+00
0000960 0.6387E-06 0.1109E-06 0.6412E-06 0.2382E-06 0.0000E+00
0000961 0.6833E-06 0.9994E-07 0.6858E-06 0.5723E-07 0.0000E+00
0000962 0.5847E-06 0.9036E-07 0.5874E-06 0.3639E-07 0.0000E+00
0000963 0.5824E-06 0.8015E-07 0.5851E-06 0.6538E-07 0.0000E+00
0000964 0.5812E-06 0.8191E-07 0.5838E-06 0.8244E-07 0.0000E+00
0000965 0.5834E-06 0.8941E-07 0.5859E-06 0.1200E-06 0.0000E+00
0000966 0.5920E-06 0.8198E-07 0.5944E-06 0.1651E-06 0.0000E+00
0000967 0.6141E-06 0.1050E-06 0.6163E-06 0.2326E-06 0.0000E+00
0000968 0.6586E-06 0.9431E-07 0.6606E-06 0.5572E-07 0.0000E+00
0000969 0.5603E-06 0.8504E-07 0.5628E-06 0.3559E-07 0.0000E+00
0000970 0.5582E-06 0.7487E-07 0.5607E-06 0.6397E-07 0.0000E+00
0000971 0.5571E-06 0.7666E-07 0.5596E-06 0.8056E-07 0.0000E+00
0000972 0.5594E-06 0.8409E-07 0.5618E-06 0.1172E-06 0.0000E+00
0000973 0.5682E-06 0.7682E-07 0.5705E-06 0.1611E-06 0.0000E+00
0000974 0.5901E-06 0.9944E-07 0.5923E-06 0.4690E-07 0.0000E+00
0000975 0.5398E-06 0.7550E-07 0.5421E-06 0.3424E-07 0.0000E+00
0000976 0.5373E-06 0.7993E-07 0.5397E-06 0.5520E-07 0.0000E+00
0000977 0.5359E-06 0.7042E-07 0.5382E-06 0.5345E-07 0.0000E+00
0000978 0.5366E-06 0.7436E-07 0.5389E-06 0.1048E-06 0.0000E+00
0000979 0.5420E-06 0.8776E-07 0.5442E-06 0.1207E-06 0.0000E+00
0000980 0.5581E-06 0.7620E-07 0.5602E-06 0.1860E-06 0.0000E+00
0000981 0.5902E-06 0.8355E-07 0.5922E-06 0.4400E-07 0.0000E+00
0000982 0.5175E-06 0.7420E-07 0.5197E-06 0.3114E-07 0.0000E+00
0000983 0.5153E-06 0.6594E-07 0.5175E-06 0.4982E-07 0.0000E+00
0000984 0.5138E-06 0.6736E-07 0.5160E-06 0.6724E-07 0.0000E+00
0000985 0.5148E-06 0.7352E-07 0.5170E-06 0.9387E-07 0.0000E+00
0000986 0.5205E-06 0.6736E-07 0.5226E-06 0.1334E-06 0.0000E+00
0000987 0.5360E-06 0.8617E-07 0.5380E-06 0.1856E-06 0.0000E+00
0000988 0.5692E-06 0.7759E-07 0.5710E-06 0.4562E-07 0.0000E+00
0000989 0.4961E-06 0.6990E-07 0.4982E-06 0.2734E-07 0.0000E+00
0000990 0.4940E-06 0.6156E-07 0.4961E-06 0.5183E-07 0.0000E+00
0000991 0.4927E-06 0.6299E-07 0.4948E-06 0.6321E-07 0.0000E+00
0000992 0.4940E-06 0.6900E-07 0.4960E-06 0.9396E-07 0.0000E+00
0000993 0.4999E-06 0.6316E-07 0.5019E-06 0.1278E-06 0.0000E+00
0000994 0.5160E-06 0.8159E-07 0.5178E-06 0.1829E-06 0.0000E+00
0000995 0.5496E-06 0.7336E-07 0.5513E-06 0.4355E-07 0.0000E+00
0000996 0.4757E-06 0.6585E-07 0.4776E-06 0.2848E-07 0.0000E+00
0000997 0.4738E-06 0.5752E-07 0.4757E-06 0.4987E-07 0.0000E+00
0000998 0.4726E-06 0.5898E-07 0.4746E-06 0.6375E-07 0.0000E+00
0000999 0.4740E-06 0.6499E-07 0.4759E-06 0.9191E-07 0.0000E+00
0001000 0.4802E-06 0.5918E-07 0.4820E-06 0.1275E-06 0.0000E+00
0001001 0.4963E-06 0.7731E-07 0.4981E-06 0.1797E-06 0.0000E+00
0001002 0.5299E-06 0.6923E-07 0.5315E-06 0.4306E-07 0.0000E+00
0001003 0.4561E-06 0.6205E-07 0.4580E-06 0.2718E-07 0.0000E+00
0001004 0.4544E-06 0.5373E-07 0.4562E-06 0.4941E-07 0.0000E+00
0001005 0.4534E-06 0.5522E-07 0.4552E-06 0.6165E-07 0.0000E+00
0001006 0.4549E-06 0.6119E-07 0.4567E-06 0.9023E-07 0.0000E+00
0001007 0.4612E-06 0.5550E-07 0.4629E-06 0.1238E-06 0.0000E+00
0001008 0.4775E-06 0.7338E-07 0.4791E-06 0.1756E-06 0.0000E+00
0001009 0.5109E-06 0.6550E-07 0.5124E-06 0.4166E-07 0.0000E+00
0001010 0.4375E-06 0.5851E-07 0.4392E-06 0.2691E-07 0.0000E+00
0001011 0.4358E-06 0.5021E-07 0.4376E-06 0.4804E-07 0.0000E+00
0001012 0.4349E-06 0.5172E-07 0.4367E-06 0.6057E-07 0.0000E+00
0001013 0.4366E-06 0.5764E-07 0.4382E-06 0.8801E-07 0.0000E+00
0001014 0.4429E-06 0.5204E-07 0.4446E-06 0.1213E-06 0.0000E+00
0001015 0.4591E-06 0.6959E-07 0.4607E-06 0.1712E-06 0.0000E+00
0001016 0.4921E-06 0.6191E-07 0.4935E-06 0.4055E-07 0.0000E+00
0001017 0.4196E-06 0.5515E-07 0.4213E-06 0.2602E-07 0.0000E+00
0001018 0.4181E-06 0.4691E-07 0.4197E-06 0.4685E-07 0.0000E+00
0001019 0.4173E-06 0.4843E-07 0.4189E-06 0.5869E-07 0.0000E+00
0001020 0.4190E-06 0.5430E-07 0.4206E-06 0.8563E-07 0.0000E+00
0001021 0.4254E-06 0.4881E-07 0.4269E-06 0.1176E-06 0.0000E+00
0001022 0.4414E-06 0.6603E-07 0.4429E-06 0.1663E-06 0.0000E+00
0001023 0.4738E-06 0.5856E-07 0.4752E-06 0.3920E-07 0.0000E+00
0001024 0.4025E-06 0.5200E-07 0.4041E-06 0.2536E-07 0.0000E+00
0001025 0.4011E-06 0.4383E-07 0.4026E-06 0.4545E-07 0.0000E+00
0001026 0.4004E-06 0.4536E-07 0.4019E-06 0.5705E-07 0.0000E+00
0001027 0.4021E-06 0.5115E-07 0.4036E-06 0.8312E-07 0.0000E+00
0001028 0.4085E-06 0.4577E-07 0.4099E-06 0.1142E-06 0.0000E+00
0001029 0.4243E-06 0.6259E-07 0.4256E-06 0.1613E-06 0.0000E+00
0001030 0.4559E-06 0.5535E-07 0.4572E-06 0.3788E-07 0.0000E+00
0001031 0.3862E-06 0.4902E-07 0.3877E-06 0.2450E-07 0.0000E+00
0001032 0.3848E-06 0.4096E-07 0.3863E-06 0.4403E-07 0.0000E+00
0001033 0.3842E-06 0.4249E-07 0.3857E-06 0.5513E-07 0.0000E+00
0001034 0.3860E-06 0.4818E-07 0.3874E-06 0.8045E-07 0.0000E+00
0001035 0.3922E-06 0.4293E-07 0.3936E-06 0.1104E-06 0.0000E+00
0001036 0.4077E-06 0.5934E-07 0.4090E-06 0.1560E-06 0.0000E+00
0001037 0.4386E-06 0.5233E-07 0.4398E-06 0.3651E-07 0.0000E+00
0001038 0.3706E-06 0.4621E-07 0.3719E-06 0.2372E-07 0.0000E+00
0001039 0.3693E-06 0.3828E-07 0.3707E-06 0.4256E-07 0.0000E+00
0001040 0.3687E-06 0.3979E-07 0.3701E-06 0.5330E-07 0.0000E+00
0001041 0.3705E-06 0.4537E-07 0.3718E-06 0.7778E-07 0.0000E+00
0001042 0.3766E-06 0.4026E-07 0.3779E-06 0.1067E-06 0.0000E+00
0001043 0.3917E-06 0.5620E-07 0.3929E-06 0.1507E-06 0.0000E+00
0001044 0.4217E-06 0.4944E-07 0.4228E-06 0.3514E-07 0.0000E+00
0001045 0.3556E-06 0.4356E-07 0.3569E-06 0.2287E-07 0.0000E+00
0001046 0.3544E-06 0.3577E-07 0.3557E-06 0.4107E-07 0.0000E+00
0001047 0.3539E-06 0.3727E-07 0.3552E-06 0.5136E-07 0.0000E+00
0001048 0.3556E-06 0.4273E-07 0.3569E-06 0.7502E-07 0.0000E+00
0001049 0.3616E-06 0.3776E-07 0.3628E-06 0.1029E-06 0.0000E+00
0001050 0.3763E-06 0.5323E-07 0.3775E-06 0.1453E-06 0.0000E+00
0001051 0.4054E-06 0.4672E-07 0.4065E-06 0.3378E-07 0.0000E+00
0001052 0.3413E-06 0.4107E-07 0.3425E-06 0.2205E-07 0.0000E+00
0001053 0.3401E-06 0.3343E-07 0.3413E-06 0.3959E-07 0.0000E+00
0001054 0.3397E-06 0.3491E-07 0.3409E-06 0.4949E-07 0.0000E+00
0001055 0.3414E-06 0.4023E-07 0.3426E-06 0.7232E-07 0.0000E+00
0001056 0.3472E-06 0.3541E-07 0.3483E-06 0.9912E-07 0.0000E+00
0001057 0.3615E-06 0.5038E-07 0.3625E-06 0.1400E-06 0.0000E+00
0001058 0.3896E-06 0.4413E-07 0.3906E-06 0.3243E-07 0.0000E+00
0001059 0.3276E-06 0.3871E-07 0.3287E-06 0.2121E-07 0.0000E+00
0001060 0.3265E-06 0.3124E-07 0.3276E-06 0.3811E-07 0.0000E+00
0001061 0.3261E-06 0.3270E-07 0.3272E-06 0.4758E-07 0.0000E+00
0001062 0.3277E-06 0.3788E-07 0.3288E-06 0.6960E-07 0.0000E+00
0001063 0.3334E-06 0.3322E-07 0.3345E-06 0.9534E-07 0.0000E+00
0001064 0.3472E-06 0.4769E-07 0.3482E-06 0.1347E-06 0.0000E+00
0001065 0.3744E-06 0.4169E-07 0.3753E-06 0.3112E-07 0.0000E+00
0001066 0.3144E-06 0.3650E-07 0.3155E-06 0.2041E-07 0.0000E+00
0001067 0.3134E-06 0.2920E-07 0.3145E-06 0.3666E-07 0.0000E+00
0001068 0.3130E-06 0.3063E-07 0.3140E-06 0.4576E-07 0.0000E+00
0001069 0.3147E-06 0.3566E-07 0.3157E-06 0.6696E-07 0.0000E+00
0001070 0.3201E-06 0.3115E-07 0.3211E-06 0.8774E-07 0.0000E+00
0001071 0.3332E-06 0.3411E-07 0.3341E-06 0.1279E-06 0.0000E+00
0001072 0.3585E-06 0.3910E-07 0.3593E-06 0.2989E-07 0.0000E+00
0001073 0.3018E-06 0.3403E-07 0.3028E-06 0.1912E-07 0.0000E+00
0001074 0.3008E-06 0.2733E-07 0.3018E-06 0.3510E-07 0.0000E+00
0001075 0.3004E-06 0.2867E-07 0.3014E-06 0.4318E-07 0.0000E+00
0001076 0.3020E-06 0.3356E-07 0.3030E-06 0.6387E-07 0.0000E+00
0001077 0.3072E-06 0.2908E-07 0.3081E-06 0.8343E-07 0.0000E+00
0001078 0.3196E-06 0.3204E-07 0.3205E-06 0.1221E-06 0.0000E+00
0001079 0.3437E-06 0.3662E-07 0.3445E-06 0.2817E-07 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 17
0001080 0.2898E-06 0.3198E-07 0.2907E-06 0.1832E-07 0.0000E+00
0001081 0.2888E-06 0.2552E-07 0.2897E-06 0.3337E-07 0.0000E+00
0001082 0.2884E-06 0.2679E-07 0.2893E-06 0.4129E-07 0.0000E+00
0001083 0.2899E-06 0.3135E-07 0.2908E-06 0.6088E-07 0.0000E+00
0001084 0.2948E-06 0.2721E-07 0.2957E-06 0.7973E-07 0.0000E+00
0001085 0.3066E-06 0.2996E-07 0.3074E-06 0.1166E-06 0.0000E+00
0001086 0.3297E-06 0.3437E-07 0.3304E-06 0.2687E-07 0.0000E+00
0001087 0.2782E-06 0.3002E-07 0.2791E-06 0.1742E-07 0.0000E+00
0001088 0.2773E-06 0.2385E-07 0.2782E-06 0.3190E-07 0.0000E+00
0001089 0.2769E-06 0.2507E-07 0.2778E-06 0.3932E-07 0.0000E+00
0001090 0.2783E-06 0.2944E-07 0.2792E-06 0.5817E-07 0.0000E+00
0001091 0.2830E-06 0.2547E-07 0.2838E-06 0.7616E-07 0.0000E+00
0001092 0.2943E-06 0.2813E-07 0.2951E-06 0.1116E-06 0.0000E+00
0001093 0.3163E-06 0.3230E-07 0.3171E-06 0.2555E-07 0.0000E+00
0001094 0.2671E-06 0.2823E-07 0.2679E-06 0.1668E-07 0.0000E+00
0001095 0.2662E-06 0.2229E-07 0.2671E-06 0.3049E-07 0.0000E+00
0001096 0.2659E-06 0.2345E-07 0.2667E-06 0.3762E-07 0.0000E+00
0001097 0.2672E-06 0.2761E-07 0.2680E-06 0.5566E-07 0.0000E+00
0001098 0.2717E-06 0.2385E-07 0.2725E-06 0.7294E-07 0.0000E+00
0001099 0.2825E-06 0.2638E-07 0.2832E-06 0.1069E-06 0.0000E+00
0001100 0.3037E-06 0.3037E-07 0.3044E-06 0.2439E-07 0.0000E+00
0001101 0.2565E-06 0.2655E-07 0.2573E-06 0.1595E-07 0.0000E+00
0001102 0.2556E-06 0.2083E-07 0.2564E-06 0.2921E-07 0.0000E+00
0001103 0.2553E-06 0.2195E-07 0.2561E-06 0.3598E-07 0.0000E+00
0001104 0.2566E-06 0.2595E-07 0.2573E-06 0.5333E-07 0.0000E+00
0001105 0.2609E-06 0.2234E-07 0.2616E-06 0.6990E-07 0.0000E+00
0001106 0.2713E-06 0.2479E-07 0.2720E-06 0.1025E-06 0.0000E+00
0001107 0.2916E-06 0.2861E-07 0.2923E-06 0.2328E-07 0.0000E+00
0001108 0.2463E-06 0.2500E-07 0.2470E-06 0.1530E-07 0.0000E+00
0001109 0.2455E-06 0.1947E-07 0.2462E-06 0.2802E-07 0.0000E+00
0001110 0.2452E-06 0.2056E-07 0.2459E-06 0.3451E-07 0.0000E+00
0001111 0.2464E-06 0.2439E-07 0.2471E-06 0.5119E-07 0.0000E+00
0001112 0.2506E-06 0.2094E-07 0.2513E-06 0.6713E-07 0.0000E+00
0001113 0.2606E-06 0.2330E-07 0.2613E-06 0.9846E-07 0.0000E+00
0001114 0.2802E-06 0.2696E-07 0.2809E-06 0.2228E-07 0.0000E+00
0001115 0.2365E-06 0.2356E-07 0.2372E-06 0.1469E-07 0.0000E+00
0001116 0.2358E-06 0.1821E-07 0.2365E-06 0.2693E-07 0.0000E+00
0001117 0.2355E-06 0.1926E-07 0.2362E-06 0.3315E-07 0.0000E+00
0001118 0.2367E-06 0.2296E-07 0.2374E-06 0.4923E-07 0.0000E+00
0001119 0.2407E-06 0.1964E-07 0.2414E-06 0.6458E-07 0.0000E+00
0001120 0.2504E-06 0.2193E-07 0.2511E-06 0.9473E-07 0.0000E+00
0001121 0.2694E-06 0.2545E-07 0.2701E-06 0.2136E-07 0.0000E+00
0001122 0.2272E-06 0.2222E-07 0.2278E-06 0.1415E-07 0.0000E+00
0001123 0.2265E-06 0.1702E-07 0.2271E-06 0.2595E-07 0.0000E+00
0001124 0.2262E-06 0.1805E-07 0.2268E-06 0.3194E-07 0.0000E+00
0001125 0.2274E-06 0.2164E-07 0.2280E-06 0.4748E-07 0.0000E+00
0001126 0.2314E-06 0.1843E-07 0.2320E-06 0.6230E-07 0.0000E+00
0001127 0.2408E-06 0.2066E-07 0.2414E-06 0.9137E-07 0.0000E+00
0001128 0.2592E-06 0.2406E-07 0.2598E-06 0.2053E-07 0.0000E+00
0001129 0.2182E-06 0.2098E-07 0.2188E-06 0.1366E-07 0.0000E+00
0001130 0.2175E-06 0.1592E-07 0.2181E-06 0.2508E-07 0.0000E+00
0001131 0.2173E-06 0.1693E-07 0.2179E-06 0.3087E-07 0.0000E+00
0001132 0.2185E-06 0.2043E-07 0.2191E-06 0.4593E-07 0.0000E+00
0001133 0.2224E-06 0.1732E-07 0.2231E-06 0.6029E-07 0.0000E+00
0001134 0.2317E-06 0.1950E-07 0.2323E-06 0.8838E-07 0.0000E+00
0001135 0.2496E-06 0.2280E-07 0.2503E-06 0.1980E-07 0.0000E+00
0001136 0.2096E-06 0.1985E-07 0.2102E-06 0.1325E-07 0.0000E+00
0001137 0.2090E-06 0.1489E-07 0.2095E-06 0.2434E-07 0.0000E+00
0001138 0.2088E-06 0.1590E-07 0.2094E-06 0.2997E-07 0.0000E+00
0001139 0.2100E-06 0.1933E-07 0.2106E-06 0.4462E-07 0.0000E+00
0001140 0.2139E-06 0.1629E-07 0.2145E-06 0.5860E-07 0.0000E+00
0001141 0.2231E-06 0.1844E-07 0.2237E-06 0.8581E-07 0.0000E+00
0001142 0.2408E-06 0.2165E-07 0.2414E-06 0.1918E-07 0.0000E+00
0001143 0.2014E-06 0.1882E-07 0.2019E-06 0.1291E-07 0.0000E+00
0001144 0.2008E-06 0.1393E-07 0.2013E-06 0.2373E-07 0.0000E+00
0001145 0.2006E-06 0.1495E-07 0.2012E-06 0.2924E-07 0.0000E+00
0001146 0.2019E-06 0.1834E-07 0.2025E-06 0.4357E-07 0.0000E+00
0001147 0.2059E-06 0.1535E-07 0.2065E-06 0.5723E-07 0.0000E+00
0001148 0.2150E-06 0.1748E-07 0.2157E-06 0.1553E-07 0.0000E+00
0001149 0.1943E-06 0.1563E-07 0.1948E-06 0.7117E-08 0.0000E+00
0001150 0.1935E-06 0.1308E-07 0.1940E-06 0.1823E-07 0.0000E+00
0001151 0.1929E-06 0.1353E-07 0.1934E-06 0.1813E-07 0.0000E+00
0001152 0.1930E-06 0.1545E-07 0.1935E-06 0.3103E-07 0.0000E+00
0001153 0.1944E-06 0.1358E-07 0.1950E-06 0.3881E-07 0.0000E+00
0001154 0.1988E-06 0.1881E-07 0.1994E-06 0.5979E-07 0.0000E+00
0001155 0.2086E-06 0.1666E-07 0.2093E-06 0.1241E-07 0.0000E+00
0001156 0.1867E-06 0.1522E-07 0.1872E-06 0.1034E-07 0.0000E+00
0001157 0.1859E-06 0.1220E-07 0.1864E-06 0.1593E-07 0.0000E+00
0001158 0.1855E-06 0.1275E-07 0.1860E-06 0.2188E-07 0.0000E+00
0001159 0.1857E-06 0.1473E-07 0.1863E-06 0.3045E-07 0.0000E+00
0001160 0.1876E-06 0.1297E-07 0.1882E-06 0.4372E-07 0.0000E+00
0001161 0.1927E-06 0.1860E-07 0.1934E-06 0.6130E-07 0.0000E+00
0001162 0.2039E-06 0.1638E-07 0.2047E-06 0.1434E-07 0.0000E+00
0001163 0.1794E-06 0.1466E-07 0.1798E-06 0.9184E-08 0.0000E+00
0001164 0.1787E-06 0.1145E-07 0.1792E-06 0.1793E-07 0.0000E+00
0001165 0.1784E-06 0.1211E-07 0.1789E-06 0.2139E-07 0.0000E+00
0001166 0.1789E-06 0.1444E-07 0.1795E-06 0.3271E-07 0.0000E+00
0001167 0.1813E-06 0.1236E-07 0.1819E-06 0.4260E-07 0.0000E+00
0001168 0.1873E-06 0.1382E-07 0.1880E-06 0.6364E-07 0.0000E+00
0001169 0.1995E-06 0.1612E-07 0.2003E-06 0.1424E-07 0.0000E+00
0001170 0.1724E-06 0.1422E-07 0.1728E-06 0.1016E-07 0.0000E+00
0001171 0.1718E-06 0.1074E-07 0.1723E-06 0.1821E-07 0.0000E+00
0001172 0.1716E-06 0.1151E-07 0.1721E-06 0.2299E-07 0.0000E+00
0001173 0.1725E-06 0.1410E-07 0.1731E-06 0.3399E-07 0.0000E+00
0001174 0.1754E-06 0.1182E-07 0.1761E-06 0.4531E-07 0.0000E+00
0001175 0.1823E-06 0.1347E-07 0.1831E-06 0.6623E-07 0.0000E+00
0001176 0.1959E-06 0.1593E-07 0.1969E-06 0.1500E-07 0.0000E+00
0001177 0.1657E-06 0.1389E-07 0.1661E-06 0.1030E-07 0.0000E+00
0001178 0.1652E-06 0.1007E-07 0.1657E-06 0.1928E-07 0.0000E+00
0001179 0.1652E-06 0.1096E-07 0.1657E-06 0.2219E-07 0.0000E+00
0001180 0.1663E-06 0.1053E-07 0.1669E-06 0.3653E-07 0.0000E+00
0001181 0.1697E-06 0.1450E-07 0.1704E-06 0.4702E-07 0.0000E+00
0001182 0.1777E-06 0.1288E-07 0.1786E-06 0.1252E-07 0.0000E+00
0001183 0.1599E-06 0.1171E-07 0.1603E-06 0.6346E-08 0.0000E+00
0001184 0.1593E-06 0.9444E-08 0.1597E-06 0.1549E-07 0.0000E+00
0001185 0.1589E-06 0.9911E-08 0.1593E-06 0.1620E-07 0.0000E+00
0001186 0.1592E-06 0.1167E-07 0.1597E-06 0.2712E-07 0.0000E+00
0001187 0.1609E-06 0.1007E-07 0.1615E-06 0.3466E-07 0.0000E+00
0001188 0.1654E-06 0.1484E-07 0.1662E-06 0.5267E-07 0.0000E+00
0001189 0.1752E-06 0.1298E-07 0.1761E-06 0.1115E-07 0.0000E+00
0001190 0.1537E-06 0.1171E-07 0.1541E-06 0.9267E-08 0.0000E+00
0001191 0.1532E-06 0.8852E-08 0.1536E-06 0.1489E-07 0.0000E+00
0001192 0.1530E-06 0.9497E-08 0.1535E-06 0.2019E-07 0.0000E+00
0001193 0.1537E-06 0.1162E-07 0.1542E-06 0.2867E-07 0.0000E+00
0001194 0.1562E-06 0.9795E-08 0.1568E-06 0.3946E-07 0.0000E+00
0001195 0.1620E-06 0.1114E-07 0.1628E-06 0.5677E-07 0.0000E+00
0001196 0.1738E-06 0.1328E-07 0.1747E-06 0.1323E-07 0.0000E+00
0001197 0.1478E-06 0.1159E-07 0.1482E-06 0.8725E-08 0.0000E+00
0001198 0.1474E-06 0.8337E-08 0.1478E-06 0.1720E-07 0.0000E+00
0001199 0.1474E-06 0.9137E-08 0.1478E-06 0.1934E-07 0.0000E+00
0001200 0.1484E-06 0.8774E-08 0.1490E-06 0.3249E-07 0.0000E+00
0001201 0.1515E-06 0.1229E-07 0.1522E-06 0.4147E-07 0.0000E+00
0001202 0.1587E-06 0.1089E-07 0.1596E-06 0.1123E-07 0.0000E+00
0001203 0.1427E-06 0.9857E-08 0.1430E-06 0.5589E-08 0.0000E+00
0001204 0.1421E-06 0.7817E-08 0.1425E-06 0.1408E-07 0.0000E+00
0001205 0.1418E-06 0.8269E-08 0.1422E-06 0.1457E-07 0.0000E+00
0001206 0.1422E-06 0.9925E-08 0.1426E-06 0.2470E-07 0.0000E+00
0001207 0.1438E-06 0.8437E-08 0.1443E-06 0.3044E-07 0.0000E+00
0001208 0.1481E-06 0.9512E-08 0.1488E-06 0.4762E-07 0.0000E+00
0001209 0.1571E-06 0.1112E-07 0.1580E-06 0.1006E-07 0.0000E+00
0001210 0.1371E-06 0.9932E-08 0.1375E-06 0.8418E-08 0.0000E+00
0001211 0.1367E-06 0.7341E-08 0.1371E-06 0.1367E-07 0.0000E+00
0001212 0.1366E-06 0.7963E-08 0.1370E-06 0.1849E-07 0.0000E+00
0001213 0.1373E-06 0.9981E-08 0.1378E-06 0.2644E-07 0.0000E+00
0001214 0.1398E-06 0.8246E-08 0.1404E-06 0.3642E-07 0.0000E+00
0001215 0.1456E-06 0.9562E-08 0.1463E-06 0.3800E-07 0.0000E+00
0001216 0.1546E-06 0.1027E-07 0.1320E-06 0.1136E-07 0.0000E+00
0001217 0.1319E-06 0.8199E-08 0.1338E-06 0.1536E-07 0.0000E+00
0001218 0.1310E-06 0.7215E-08 0.1350E-06 0.1945E-07 0.0000E+00
0001219 0.1313E-06 0.9354E-08 0.1375E-06 0.2732E-07 0.0000E+00
0001220 0.1335E-06 0.8435E-08 0.1426E-06 0.3802E-07 0.0000E+00
0001221 0.1394E-06 0.1010E-07 0.1524E-06 0.3323E-07 0.0000E+00
0001222 0.1492E-06 0.1057E-07 0.1280E-06 0.9847E-08 0.0000E+00
0001223 0.1274E-06 0.7854E-08 0.1293E-06 0.1615E-07 0.0000E+00
0001224 0.1266E-06 0.6914E-08 0.1304E-06 0.1720E-07 0.0000E+00
0001225 0.1267E-06 0.9103E-08 0.1327E-06 0.2567E-07 0.0000E+00
0001226 0.1287E-06 0.8173E-08 0.1371E-06 0.3391E-07 0.0000E+00
0001227 0.1341E-06 0.9810E-08 0.1460E-06 0.3082E-07 0.0000E+00
0001228 0.1428E-06 0.1002E-07 0.1236E-06 0.8683E-08 0.0000E+00
0001229 0.1231E-06 0.7398E-08 0.1247E-06 0.1528E-07 0.0000E+00
0001230 0.1223E-06 0.6533E-08 0.1254E-06 0.1500E-07 0.0000E+00
0001231 0.1223E-06 0.8466E-08 0.1271E-06 0.2289E-07 0.0000E+00
0001232 0.1238E-06 0.7643E-08 0.1305E-06 0.2964E-07 0.0000E+00
0001233 0.1280E-06 0.9079E-08 0.1378E-06 0.2749E-07 0.0000E+00
0001234 0.1351E-06 0.9180E-08 0.1194E-06 0.7762E-08 0.0000E+00
0001235 0.1190E-06 0.6878E-08 0.1202E-06 0.1412E-07 0.0000E+00
0001236 0.1182E-06 0.6141E-08 0.1206E-06 0.1319E-07 0.0000E+00
0001237 0.1180E-06 0.7796E-08 0.1218E-06 0.2036E-07 0.0000E+00
0001238 0.1191E-06 0.7081E-08 0.1243E-06 0.2604E-07 0.0000E+00
0001239 0.1223E-06 0.8306E-08 0.1300E-06 0.2441E-07 0.0000E+00
0001240 0.1278E-06 0.8330E-08 0.1154E-06 0.7017E-08 0.0000E+00
0001241 0.1149E-06 0.6379E-08 0.1159E-06 0.1289E-07 0.0000E+00
0001242 0.1142E-06 0.5762E-08 0.1161E-06 0.1175E-07 0.0000E+00
0001243 0.1139E-06 0.7173E-08 0.1170E-06 0.1813E-07 0.0000E+00
0001244 0.1147E-06 0.6553E-08 0.1188E-06 0.2314E-07 0.0000E+00
0001245 0.1171E-06 0.7598E-08 0.1233E-06 0.3356E-07 0.0000E+00
0001246 0.1235E-06 0.9489E-08 0.1312E-06 0.9021E-08 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 18
0001247 0.1109E-06 0.7581E-08 0.1114E-06 0.5746E-08 0.0000E+00
0001248 0.1106E-06 0.5194E-08 0.1107E-06 0.1067E-07 0.0000E+00
0001249 0.1103E-06 0.5669E-08 0.1104E-06 0.1130E-07 0.0000E+00
0001250 0.1104E-06 0.5434E-08 0.1105E-06 0.1882E-07 0.0000E+00
0001251 0.1113E-06 0.7450E-08 0.1113E-06 0.2362E-07 0.0000E+00
0001252 0.1140E-06 0.6587E-08 0.1138E-06 0.3509E-07 0.0000E+00
0001253 0.1197E-06 0.8046E-08 0.1193E-06 0.7720E-08 0.0000E+00
0001254 0.1067E-06 0.6880E-08 0.1069E-06 0.5523E-08 0.0000E+00
0001255 0.1062E-06 0.4860E-08 0.1065E-06 0.9736E-08 0.0000E+00
0001256 0.1059E-06 0.5314E-08 0.1062E-06 0.1111E-07 0.0000E+00
0001257 0.1060E-06 0.5104E-08 0.1064E-06 0.1802E-07 0.0000E+00
0001258 0.1069E-06 0.7061E-08 0.1073E-06 0.2330E-07 0.0000E+00
0001259 0.1096E-06 0.6263E-08 0.1102E-06 0.3430E-07 0.0000E+00
0001260 0.1153E-06 0.7694E-08 0.1161E-06 0.7730E-08 0.0000E+00
0001261 0.1025E-06 0.6576E-08 0.1028E-06 0.5306E-08 0.0000E+00
0001262 0.1021E-06 0.4557E-08 0.1024E-06 0.9919E-08 0.0000E+00
0001263 0.1019E-06 0.5023E-08 0.1021E-06 0.1113E-07 0.0000E+00
0001264 0.1021E-06 0.4810E-08 0.1023E-06 0.1834E-07 0.0000E+00
0001265 0.1030E-06 0.6763E-08 0.1034E-06 0.2353E-07 0.0000E+00
0001266 0.1059E-06 0.5972E-08 0.1064E-06 0.3475E-07 0.0000E+00
0001267 0.1119E-06 0.7387E-08 0.1125E-06 0.7664E-08 0.0000E+00
0001268 0.9856E-07 0.6341E-08 0.9877E-07 0.5368E-08 0.0000E+00
0001269 0.9820E-07 0.4280E-08 0.9842E-07 0.9968E-08 0.0000E+00
0001270 0.9799E-07 0.4775E-08 0.9825E-07 0.1133E-07 0.0000E+00
0001271 0.9827E-07 0.4561E-08 0.9859E-07 0.1799E-07 0.0000E+00
0001272 0.9943E-07 0.4941E-08 0.9986E-07 0.2375E-07 0.0000E+00
0001273 0.1025E-06 0.5782E-08 0.1031E-06 0.3507E-07 0.0000E+00
0001274 0.1090E-06 0.7086E-08 0.1098E-06 0.7668E-08 0.0000E+00
0001275 0.9473E-07 0.6148E-08 0.9496E-07 0.5490E-08 0.0000E+00
0001276 0.9443E-07 0.4017E-08 0.9465E-07 0.1016E-07 0.0000E+00
0001277 0.9429E-07 0.4539E-08 0.9456E-07 0.1168E-07 0.0000E+00
0001278 0.9469E-07 0.4319E-08 0.9503E-07 0.1849E-07 0.0000E+00
0001279 0.9608E-07 0.4735E-08 0.9654E-07 0.2448E-07 0.0000E+00
0001280 0.9959E-07 0.5591E-08 0.1002E-06 0.3594E-07 0.0000E+00
0001281 0.1066E-06 0.6929E-08 0.1074E-06 0.7829E-08 0.0000E+00
0001282 0.9108E-07 0.6006E-08 0.9130E-07 0.5619E-08 0.0000E+00
0001283 0.9083E-07 0.3781E-08 0.9105E-07 0.1047E-07 0.0000E+00
0001284 0.9077E-07 0.4346E-08 0.9104E-07 0.1207E-07 0.0000E+00
0001285 0.9133E-07 0.4123E-08 0.9169E-07 0.1915E-07 0.0000E+00
0001286 0.9300E-07 0.4569E-08 0.9350E-07 0.2532E-07 0.0000E+00
0001287 0.9702E-07 0.5490E-08 0.9771E-07 0.6661E-08 0.0000E+00
0001288 0.8796E-07 0.4853E-08 0.8815E-07 0.3358E-08 0.0000E+00
0001289 0.8762E-07 0.3543E-08 0.8781E-07 0.8476E-08 0.0000E+00
0001290 0.8738E-07 0.3855E-08 0.8760E-07 0.8065E-08 0.0000E+00
0001291 0.8751E-07 0.3722E-08 0.8779E-07 0.1509E-07 0.0000E+00
0001292 0.8830E-07 0.5119E-08 0.8867E-07 0.1815E-07 0.0000E+00
0001293 0.9064E-07 0.4574E-08 0.9115E-07 0.2827E-07 0.0000E+00
0001294 0.9557E-07 0.5600E-08 0.9626E-07 0.5889E-08 0.0000E+00
0001295 0.8457E-07 0.4958E-08 0.8476E-07 0.4950E-08 0.0000E+00
0001296 0.8429E-07 0.3332E-08 0.8448E-07 0.8190E-08 0.0000E+00
0001297 0.8417E-07 0.3746E-08 0.8440E-07 0.1025E-07 0.0000E+00
0001298 0.8451E-07 0.3574E-08 0.8480E-07 0.1549E-07 0.0000E+00
0001299 0.8572E-07 0.3918E-08 0.8612E-07 0.2129E-07 0.0000E+00
0001300 0.8877E-07 0.4626E-08 0.8932E-07 0.3073E-07 0.0000E+00
0001301 0.9493E-07 0.5742E-08 0.9564E-07 0.6912E-08 0.0000E+00
0001302 0.8133E-07 0.5029E-08 0.8151E-07 0.4771E-08 0.0000E+00
0001303 0.8112E-07 0.3148E-08 0.8130E-07 0.9415E-08 0.0000E+00
0001304 0.8111E-07 0.3648E-08 0.8133E-07 0.1064E-07 0.0000E+00
0001305 0.8169E-07 0.3461E-08 0.8198E-07 0.1727E-07 0.0000E+00
0001306 0.8334E-07 0.3863E-08 0.8373E-07 0.2267E-07 0.0000E+00
0001307 0.8721E-07 0.4690E-08 0.8773E-07 0.6058E-08 0.0000E+00
0001308 0.7855E-07 0.4152E-08 0.7871E-07 0.3025E-08 0.0000E+00
0001309 0.7827E-07 0.2956E-08 0.7842E-07 0.7850E-08 0.0000E+00
0001310 0.7809E-07 0.3258E-08 0.7827E-07 0.7479E-08 0.0000E+00
0001311 0.7831E-07 0.3140E-08 0.7853E-07 0.1409E-07 0.0000E+00
0001312 0.7919E-07 0.4461E-08 0.7949E-07 0.1699E-07 0.0000E+00
0001313 0.8166E-07 0.3966E-08 0.8206E-07 0.2648E-07 0.0000E+00
0001314 0.8668E-07 0.4929E-08 0.8719E-07 0.5446E-08 0.0000E+00
0001315 0.7555E-07 0.4365E-08 0.7570E-07 0.4680E-08 0.0000E+00
0001316 0.7533E-07 0.2786E-08 0.7548E-07 0.7751E-08 0.0000E+00
0001317 0.7529E-07 0.3204E-08 0.7547E-07 0.9813E-08 0.0000E+00
0001318 0.7574E-07 0.3045E-08 0.7596E-07 0.1484E-07 0.0000E+00
0001319 0.7714E-07 0.3394E-08 0.7743E-07 0.2044E-07 0.0000E+00
0001320 0.8043E-07 0.4095E-08 0.8082E-07 0.5090E-08 0.0000E+00
0001321 0.7297E-07 0.3671E-08 0.7310E-07 0.2956E-08 0.0000E+00
0001322 0.7270E-07 0.2622E-08 0.7283E-07 0.6805E-08 0.0000E+00
0001323 0.7253E-07 0.2890E-08 0.7268E-07 0.7033E-08 0.0000E+00
0001324 0.7271E-07 0.2785E-08 0.7289E-07 0.1257E-07 0.0000E+00
0001325 0.7352E-07 0.3963E-08 0.7374E-07 0.1571E-07 0.0000E+00
0001326 0.7574E-07 0.3524E-08 0.7603E-07 0.2404E-07 0.0000E+00
0001327 0.8032E-07 0.4394E-08 0.8070E-07 0.5053E-08 0.0000E+00
0001328 0.7018E-07 0.3898E-08 0.7031E-07 0.4109E-08 0.0000E+00
0001329 0.6997E-07 0.2476E-08 0.7010E-07 0.7193E-08 0.0000E+00
0001330 0.6993E-07 0.2851E-08 0.7008E-07 0.8843E-08 0.0000E+00
0001331 0.7035E-07 0.2712E-08 0.7052E-07 0.1369E-07 0.0000E+00
0001332 0.7162E-07 0.3027E-08 0.7184E-07 0.1866E-07 0.0000E+00
0001333 0.7466E-07 0.3667E-08 0.7495E-07 0.1890E-07 0.0000E+00
0001334 0.7947E-07 0.4066E-08 0.6751E-07 0.5383E-08 0.0000E+00
0001335 0.6753E-07 0.3096E-08 0.6841E-07 0.7770E-08 0.0000E+00
0001336 0.6712E-07 0.2533E-08 0.6907E-07 0.9559E-08 0.0000E+00
0001337 0.6731E-07 0.3679E-08 0.7037E-07 0.1384E-07 0.0000E+00
0001338 0.6856E-07 0.3233E-08 0.7302E-07 0.1902E-07 0.0000E+00
0001339 0.7182E-07 0.4083E-08 0.7812E-07 0.1720E-07 0.0000E+00
0001340 0.7700E-07 0.4334E-08 0.6538E-07 0.4778E-08 0.0000E+00
0001341 0.6527E-07 0.2982E-08 0.6613E-07 0.8021E-08 0.0000E+00
0001342 0.6486E-07 0.2454E-08 0.6669E-07 0.8373E-08 0.0000E+00
0001343 0.6496E-07 0.2636E-08 0.6786E-07 0.1285E-07 0.0000E+00
0001344 0.6605E-07 0.3171E-08 0.7014E-07 0.1706E-07 0.0000E+00
0001345 0.6892E-07 0.3911E-08 0.7474E-07 0.1565E-07 0.0000E+00
0001346 0.7353E-07 0.4089E-08 0.6320E-07 0.4343E-08 0.0000E+00
0001347 0.6307E-07 0.2798E-08 0.6381E-07 0.7715E-08 0.0000E+00
0001348 0.6267E-07 0.2332E-08 0.6422E-07 0.7492E-08 0.0000E+00
0001349 0.6268E-07 0.2465E-08 0.6515E-07 0.1171E-07 0.0000E+00
0001350 0.6354E-07 0.2974E-08 0.6697E-07 0.1531E-07 0.0000E+00
0001351 0.6584E-07 0.3618E-08 0.7085E-07 0.1401E-07 0.0000E+00
0001352 0.6969E-07 0.3759E-08 0.6110E-07 0.3969E-08 0.0000E+00
0001353 0.6094E-07 0.2593E-08 0.6156E-07 0.7229E-08 0.0000E+00
0001354 0.6055E-07 0.2197E-08 0.6182E-07 0.6711E-08 0.0000E+00
0001355 0.6050E-07 0.2301E-08 0.6252E-07 0.1059E-07 0.0000E+00
0001356 0.6115E-07 0.2760E-08 0.6392E-07 0.1371E-07 0.0000E+00
0001357 0.6295E-07 0.3319E-08 0.6709E-07 0.1262E-07 0.0000E+00
0001358 0.6608E-07 0.3425E-08 0.5907E-07 0.3660E-08 0.0000E+00
0001359 0.5889E-07 0.2400E-08 0.5940E-07 0.6690E-08 0.0000E+00
0001360 0.5851E-07 0.2064E-08 0.5956E-07 0.6076E-08 0.0000E+00
0001361 0.5842E-07 0.2148E-08 0.6006E-07 0.9575E-08 0.0000E+00
0001362 0.5890E-07 0.2553E-08 0.6114E-07 0.1238E-07 0.0000E+00
0001363 0.6032E-07 0.3043E-08 0.6369E-07 0.1151E-07 0.0000E+00
0001364 0.6286E-07 0.3122E-08 0.5710E-07 0.1538E-07 0.0000E+00
0001365 0.6555E-07 0.3015E-08 0.5742E-07 0.9388E-08 0.0000E+00
0001366 0.5662E-07 0.2924E-08 0.5885E-07 0.8586E-08 0.0000E+00
0001367 0.5647E-07 0.2371E-08 0.6031E-07 0.1301E-07 0.0000E+00
0001368 0.5743E-07 0.2952E-08 0.6257E-07 0.1051E-07 0.0000E+00
0001369 0.5925E-07 0.2926E-08 0.5560E-07 0.1215E-07 0.0000E+00
0001370 0.6118E-07 0.2566E-08 0.5567E-07 0.7306E-08 0.0000E+00
0001371 0.5499E-07 0.2520E-08 0.5664E-07 0.8470E-08 0.0000E+00
0001372 0.5480E-07 0.2168E-08 0.5752E-07 0.1064E-07 0.0000E+00
0001373 0.5537E-07 0.2594E-08 0.5914E-07 0.1426E-07 0.0000E+00
0001374 0.5735E-07 0.3346E-08 0.6219E-07 0.1463E-07 0.0000E+00
0001375 0.6018E-07 0.3317E-08 0.5363E-07 0.4389E-08 0.0000E+00
0001376 0.5353E-07 0.2215E-08 0.5404E-07 0.6521E-08 0.0000E+00
0001377 0.5316E-07 0.1798E-08 0.5428E-07 0.6744E-08 0.0000E+00
0001378 0.5317E-07 0.2003E-08 0.5479E-07 0.9918E-08 0.0000E+00
0001379 0.5380E-07 0.2402E-08 0.5594E-07 0.1329E-07 0.0000E+00
0001380 0.5553E-07 0.3032E-08 0.5847E-07 0.1387E-07 0.0000E+00
0001381 0.5807E-07 0.3042E-08 0.5179E-07 0.4122E-08 0.0000E+00
0001382 0.5174E-07 0.2076E-08 0.5224E-07 0.6871E-08 0.0000E+00
0001383 0.5137E-07 0.1721E-08 0.5243E-07 0.6593E-08 0.0000E+00
0001384 0.5136E-07 0.1884E-08 0.5290E-07 0.9816E-08 0.0000E+00
0001385 0.5195E-07 0.2275E-08 0.5392E-07 0.1306E-07 0.0000E+00
0001386 0.5351E-07 0.2832E-08 0.5625E-07 0.1318E-07 0.0000E+00
0001387 0.5587E-07 0.2826E-08 0.5005E-07 0.3970E-08 0.0000E+00
0001388 0.5002E-07 0.1937E-08 0.5047E-07 0.6898E-08 0.0000E+00
0001389 0.4965E-07 0.1633E-08 0.5063E-07 0.6382E-08 0.0000E+00
0001390 0.4962E-07 0.1766E-08 0.5105E-07 0.9532E-08 0.0000E+00
0001391 0.5016E-07 0.2131E-08 0.5194E-07 0.1262E-07 0.0000E+00
0001392 0.5156E-07 0.2626E-08 0.5406E-07 0.1261E-07 0.0000E+00
0001393 0.5372E-07 0.2610E-08 0.4838E-07 0.3838E-08 0.0000E+00
0001394 0.4835E-07 0.1807E-08 0.4877E-07 0.6771E-08 0.0000E+00
0001395 0.4800E-07 0.1545E-08 0.4890E-07 0.6174E-08 0.0000E+00
0001396 0.4795E-07 0.1657E-08 0.4926E-07 0.9209E-08 0.0000E+00
0001397 0.4844E-07 0.1993E-08 0.5006E-07 0.1219E-07 0.0000E+00
0001398 0.4973E-07 0.2435E-08 0.5200E-07 0.1214E-07 0.0000E+00
0001399 0.5171E-07 0.2415E-08 0.4676E-07 0.3720E-08 0.0000E+00
0001400 0.4674E-07 0.1690E-08 0.4713E-07 0.6599E-08 0.0000E+00
0001401 0.4639E-07 0.1462E-08 0.4724E-07 0.5986E-08 0.0000E+00
0001402 0.4634E-07 0.1558E-08 0.4757E-07 0.8907E-08 0.0000E+00
0001403 0.4680E-07 0.1866E-08 0.4829E-07 0.1180E-07 0.0000E+00
0001404 0.4800E-07 0.2267E-08 0.5009E-07 0.1178E-07 0.0000E+00
0001405 0.4984E-07 0.2244E-08 0.4520E-07 0.3619E-08 0.0000E+00
0001406 0.4518E-07 0.1585E-08 0.4555E-07 0.6428E-08 0.0000E+00
0001407 0.4485E-07 0.1384E-08 0.4565E-07 0.5829E-08 0.0000E+00
0001408 0.4480E-07 0.1469E-08 0.4595E-07 0.8649E-08 0.0000E+00
0001409 0.4523E-07 0.1753E-08 0.4662E-07 0.1148E-07 0.0000E+00
0001410 0.4637E-07 0.2120E-08 0.4832E-07 0.1148E-07 0.0000E+00
0001411 0.4811E-07 0.2095E-08 0.4369E-07 0.3533E-08 0.0000E+00
0001412 0.4368E-07 0.1492E-08 0.4403E-07 0.6273E-08 0.0000E+00
0001413 0.4335E-07 0.1311E-08 0.4413E-07 0.5698E-08 0.0000E+00
0001414 0.4330E-07 0.1388E-08 0.4441E-07 0.8431E-08 0.0000E+00
0001415 0.4373E-07 0.1652E-08 0.4505E-07 0.1121E-07 0.0000E+00
0001416 0.4482E-07 0.1992E-08 0.4667E-07 0.1124E-07 0.0000E+00
0001417 0.4649E-07 0.1965E-08 0.4223E-07 0.3458E-08 0.0000E+00
0001418 0.4223E-07 0.1408E-08 0.4257E-07 0.6136E-08 0.0000E+00
0001419 0.4191E-07 0.1244E-08 0.4266E-07 0.5587E-08 0.0000E+00
0001420 0.4187E-07 0.1314E-08 0.4294E-07 0.8243E-08 0.0000E+00
0001421 0.4228E-07 0.1561E-08 0.4355E-07 0.1098E-07 0.0000E+00
0001422 0.4335E-07 0.1877E-08 0.4512E-07 0.3058E-08 0.0000E+00
0001423 0.4098E-07 0.1498E-08 0.4106E-07 0.2460E-08 0.0000E+00
0001424 0.4081E-07 0.1074E-08 0.4081E-07 0.3730E-08 0.0000E+00
0001425 0.4063E-07 0.1192E-08 0.4062E-07 0.3926E-08 0.0000E+00
0001426 0.4052E-07 0.1123E-08 0.4051E-07 0.6160E-08 0.0000E+00
0001427 0.4055E-07 0.1203E-08 0.4049E-07 0.7741E-08 0.0000E+00
0001428 0.4085E-07 0.1349E-08 0.4077E-07 0.1156E-07 0.0000E+00
0001429 0.4173E-07 0.1622E-08 0.4154E-07 0.9780E-08 0.0000E+00
0001430 0.3922E-07 0.1756E-08 0.4297E-07 0.3860E-08 0.0000E+00
0001431 0.3952E-07 0.1260E-08 0.3927E-07 0.5239E-08 0.0000E+00
0001432 0.3959E-07 0.1084E-08 0.3899E-07 0.5518E-08 0.0000E+00
0001433 0.3981E-07 0.1171E-08 0.3897E-07 0.7511E-08 0.0000E+00
0001434 0.4037E-07 0.1354E-08 0.3934E-07 0.1033E-07 0.0000E+00
0001435 0.4173E-07 0.1671E-08 0.4038E-07 0.2703E-08 0.0000E+00
0001436 0.3811E-07 0.1346E-08 0.3812E-07 0.2044E-08 0.0000E+00
0001437 0.3788E-07 0.9648E-09 0.3796E-07 0.3376E-08 0.0000E+00
0001438 0.3771E-07 0.1080E-08 0.3781E-07 0.3704E-08 0.0000E+00
0001439 0.3760E-07 0.1017E-08 0.3772E-07 0.5734E-08 0.0000E+00
0001440 0.3759E-07 0.1089E-08 0.3778E-07 0.7401E-08 0.0000E+00
0001441 0.3785E-07 0.1243E-08 0.3814E-07 0.1089E-07 0.0000E+00
0001442 0.3858E-07 0.1496E-08 0.3908E-07 0.9615E-08 0.0000E+00
0001443 0.3989E-07 0.1576E-08 0.3648E-07 0.3316E-08 0.0000E+00
0001444 0.3645E-07 0.1158E-08 0.3675E-07 0.4450E-08 0.0000E+00
0001445 0.3620E-07 0.9957E-09 0.3685E-07 0.5025E-08 0.0000E+00
0001446 0.3618E-07 0.1075E-08 0.3710E-07 0.6824E-08 0.0000E+00
0001447 0.3655E-07 0.1279E-08 0.3771E-07 0.9622E-08 0.0000E+00
0001448 0.3756E-07 0.1576E-08 0.3912E-07 0.2474E-08 0.0000E+00
0001449 0.3538E-07 0.1260E-08 0.3545E-07 0.1925E-08 0.0000E+00
0001450 0.3524E-07 0.8664E-09 0.3524E-07 0.3159E-08 0.0000E+00
0001451 0.3510E-07 0.9780E-09 0.3508E-07 0.3468E-08 0.0000E+00
0001452 0.3502E-07 0.9190E-09 0.3499E-07 0.5396E-08 0.0000E+00
0001453 0.3508E-07 0.9955E-09 0.3500E-07 0.6947E-08 0.0000E+00
0001454 0.3543E-07 0.1142E-08 0.3528E-07 0.1025E-07 0.0000E+00
0001455 0.3633E-07 0.1397E-08 0.3605E-07 0.8772E-08 0.0000E+00
0001456 0.3387E-07 0.1539E-08 0.3742E-07 0.3337E-08 0.0000E+00
0001457 0.3415E-07 0.1069E-08 0.3391E-07 0.4439E-08 0.0000E+00
0001458 0.3425E-07 0.8949E-09 0.3366E-07 0.4826E-08 0.0000E+00
0001459 0.3450E-07 0.9822E-09 0.3366E-07 0.6592E-08 0.0000E+00
0001460 0.3509E-07 0.1167E-08 0.3403E-07 0.9092E-08 0.0000E+00
0001461 0.3645E-07 0.1468E-08 0.3504E-07 0.2348E-08 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 19
0001462 0.3291E-07 0.1171E-08 0.3291E-07 0.1752E-08 0.0000E+00
0001463 0.3271E-07 0.7830E-09 0.3278E-07 0.2974E-08 0.0000E+00
0001464 0.3257E-07 0.8950E-09 0.3265E-07 0.3239E-08 0.0000E+00
0001465 0.3249E-07 0.8399E-09 0.3259E-07 0.5073E-08 0.0000E+00
0001466 0.3251E-07 0.9129E-09 0.3267E-07 0.6528E-08 0.0000E+00
0001467 0.3280E-07 0.1067E-08 0.3304E-07 0.9649E-08 0.0000E+00
0001468 0.3356E-07 0.1314E-08 0.3397E-07 0.8492E-08 0.0000E+00
0001469 0.3487E-07 0.1410E-08 0.3149E-07 0.2955E-08 0.0000E+00
0001470 0.3148E-07 0.9974E-09 0.3176E-07 0.3942E-08 0.0000E+00
0001471 0.3126E-07 0.8281E-09 0.3188E-07 0.4472E-08 0.0000E+00
0001472 0.3126E-07 0.9091E-09 0.3214E-07 0.6077E-08 0.0000E+00
0001473 0.3163E-07 0.1109E-08 0.3275E-07 0.8542E-08 0.0000E+00
0001474 0.3260E-07 0.1394E-08 0.3412E-07 0.2160E-08 0.0000E+00
0001475 0.3055E-07 0.1104E-08 0.3061E-07 0.1682E-08 0.0000E+00
0001476 0.3044E-07 0.7061E-09 0.3043E-07 0.2781E-08 0.0000E+00
0001477 0.3032E-07 0.8175E-09 0.3030E-07 0.3072E-08 0.0000E+00
0001478 0.3028E-07 0.7645E-09 0.3023E-07 0.4782E-08 0.0000E+00
0001479 0.3037E-07 0.8428E-09 0.3026E-07 0.6181E-08 0.0000E+00
0001480 0.3074E-07 0.9931E-09 0.3057E-07 0.9117E-08 0.0000E+00
0001481 0.3166E-07 0.1242E-08 0.3135E-07 0.7840E-08 0.0000E+00
0001482 0.2924E-07 0.1384E-08 0.3270E-07 0.2906E-08 0.0000E+00
0001483 0.2952E-07 0.9276E-09 0.2928E-07 0.3886E-08 0.0000E+00
0001484 0.2965E-07 0.7499E-09 0.2907E-07 0.4274E-08 0.0000E+00
0001485 0.2991E-07 0.8380E-09 0.2908E-07 0.5851E-08 0.0000E+00
0001486 0.3052E-07 0.1025E-08 0.2945E-07 0.8082E-08 0.0000E+00
0001487 0.3185E-07 0.1312E-08 0.3041E-07 0.2055E-08 0.0000E+00
0001488 0.2842E-07 0.1035E-08 0.2841E-07 0.1549E-08 0.0000E+00
0001489 0.2825E-07 0.6408E-09 0.2832E-07 0.2627E-08 0.0000E+00
0001490 0.2814E-07 0.7526E-09 0.2821E-07 0.2877E-08 0.0000E+00
0001491 0.2808E-07 0.7028E-09 0.2817E-07 0.4508E-08 0.0000E+00
0001492 0.2813E-07 0.7778E-09 0.2828E-07 0.5816E-08 0.0000E+00
0001493 0.2844E-07 0.9340E-09 0.2866E-07 0.8596E-08 0.0000E+00
0001494 0.2922E-07 0.1174E-08 0.2960E-07 0.1830E-08 0.0000E+00
0001495 0.2730E-07 0.9764E-09 0.2733E-07 0.1363E-08 0.0000E+00
0001496 0.2718E-07 0.6040E-09 0.2719E-07 0.2467E-08 0.0000E+00
0001497 0.2708E-07 0.7156E-09 0.2709E-07 0.2735E-08 0.0000E+00
0001498 0.2705E-07 0.6693E-09 0.2706E-07 0.4373E-08 0.0000E+00
0001499 0.2717E-07 0.7538E-09 0.2714E-07 0.5695E-08 0.0000E+00
0001500 0.2758E-07 0.9145E-09 0.2753E-07 0.8480E-08 0.0000E+00
0001501 0.2857E-07 0.1172E-08 0.2847E-07 0.1836E-08 0.0000E+00
0001502 0.2625E-07 0.9683E-09 0.2626E-07 0.1380E-08 0.0000E+00
0001503 0.2613E-07 0.5759E-09 0.2615E-07 0.2515E-08 0.0000E+00
0001504 0.2604E-07 0.6997E-09 0.2606E-07 0.2818E-08 0.0000E+00
0001505 0.2603E-07 0.6502E-09 0.2605E-07 0.4474E-08 0.0000E+00
0001506 0.2616E-07 0.7414E-09 0.2618E-07 0.5843E-08 0.0000E+00
0001507 0.2662E-07 0.9147E-09 0.2664E-07 0.8642E-08 0.0000E+00
0001508 0.2766E-07 0.1182E-08 0.2770E-07 0.1846E-08 0.0000E+00
0001509 0.2524E-07 0.9781E-09 0.2525E-07 0.1375E-08 0.0000E+00
0001510 0.2513E-07 0.5491E-09 0.2514E-07 0.2534E-08 0.0000E+00
0001511 0.2506E-07 0.6828E-09 0.2507E-07 0.2840E-08 0.0000E+00
0001512 0.2507E-07 0.6327E-09 0.2507E-07 0.4537E-08 0.0000E+00
0001513 0.2525E-07 0.7322E-09 0.2524E-07 0.5926E-08 0.0000E+00
0001514 0.2580E-07 0.9194E-09 0.2577E-07 0.8770E-08 0.0000E+00
0001515 0.2700E-07 0.1201E-08 0.2694E-07 0.1871E-08 0.0000E+00
0001516 0.2427E-07 0.9908E-09 0.2428E-07 0.1415E-08 0.0000E+00
0001517 0.2417E-07 0.5252E-09 0.2418E-07 0.2598E-08 0.0000E+00
0001518 0.2411E-07 0.6736E-09 0.2412E-07 0.2938E-08 0.0000E+00
0001519 0.2416E-07 0.6207E-09 0.2416E-07 0.4671E-08 0.0000E+00
0001520 0.2439E-07 0.7310E-09 0.2438E-07 0.6111E-08 0.0000E+00
0001521 0.2503E-07 0.9333E-09 0.2501E-07 0.8988E-08 0.0000E+00
0001522 0.2637E-07 0.1230E-08 0.2634E-07 0.1908E-08 0.0000E+00
0001523 0.2333E-07 0.1014E-08 0.2334E-07 0.1438E-08 0.0000E+00
0001524 0.2325E-07 0.5032E-09 0.2326E-07 0.2656E-08 0.0000E+00
0001525 0.2321E-07 0.6660E-09 0.2321E-07 0.3012E-08 0.0000E+00
0001526 0.2329E-07 0.6117E-09 0.2328E-07 0.4798E-08 0.0000E+00
0001527 0.2359E-07 0.7322E-09 0.2356E-07 0.6279E-08 0.0000E+00
0001528 0.2435E-07 0.9509E-09 0.2430E-07 0.6233E-08 0.0000E+00
0001529 0.2242E-07 0.1086E-08 0.2551E-07 0.1917E-08 0.0000E+00
0001530 0.2266E-07 0.7279E-09 0.2246E-07 0.2822E-08 0.0000E+00
0001531 0.2280E-07 0.5441E-09 0.2231E-07 0.3092E-08 0.0000E+00
0001532 0.2308E-07 0.6336E-09 0.2234E-07 0.4583E-08 0.0000E+00
0001533 0.2369E-07 0.7980E-09 0.2265E-07 0.6145E-08 0.0000E+00
0001534 0.2495E-07 0.1056E-08 0.2349E-07 0.1587E-08 0.0000E+00
0001535 0.2181E-07 0.8377E-09 0.2179E-07 0.1023E-08 0.0000E+00
0001536 0.2168E-07 0.4530E-09 0.2173E-07 0.2058E-08 0.0000E+00
0001537 0.2161E-07 0.5580E-09 0.2166E-07 0.2116E-08 0.0000E+00
0001538 0.2160E-07 0.5220E-09 0.2167E-07 0.3556E-08 0.0000E+00
0001539 0.2171E-07 0.5958E-09 0.2182E-07 0.4493E-08 0.0000E+00
0001540 0.2210E-07 0.7557E-09 0.2228E-07 0.6826E-08 0.0000E+00
0001541 0.2298E-07 0.9802E-09 0.2328E-07 0.1400E-08 0.0000E+00
0001542 0.2095E-07 0.8274E-09 0.2097E-07 0.1141E-08 0.0000E+00
0001543 0.2088E-07 0.4297E-09 0.2087E-07 0.1970E-08 0.0000E+00
0001544 0.2083E-07 0.5478E-09 0.2082E-07 0.2331E-08 0.0000E+00
0001545 0.2087E-07 0.5089E-09 0.2084E-07 0.3627E-08 0.0000E+00
0001546 0.2107E-07 0.6025E-09 0.2101E-07 0.4859E-08 0.0000E+00
0001547 0.2164E-07 0.7724E-09 0.2153E-07 0.7129E-08 0.0000E+00
0001548 0.2283E-07 0.1026E-08 0.2265E-07 0.1550E-08 0.0000E+00
0001549 0.2015E-07 0.8544E-09 0.2015E-07 0.1141E-08 0.0000E+00
0001550 0.2008E-07 0.4149E-09 0.2009E-07 0.2168E-08 0.0000E+00
0001551 0.2005E-07 0.5519E-09 0.2005E-07 0.2450E-08 0.0000E+00
0001552 0.2012E-07 0.5099E-09 0.2012E-07 0.3943E-08 0.0000E+00
0001553 0.2039E-07 0.6129E-09 0.2038E-07 0.5170E-08 0.0000E+00
0001554 0.2106E-07 0.8044E-09 0.2104E-07 0.7633E-08 0.0000E+00
0001555 0.2241E-07 0.1072E-08 0.2239E-07 0.1603E-08 0.0000E+00
0001556 0.1938E-07 0.8966E-09 0.1939E-07 0.1238E-08 0.0000E+00
0001557 0.1933E-07 0.4003E-09 0.1933E-07 0.2278E-08 0.0000E+00
0001558 0.1932E-07 0.5574E-09 0.1931E-07 0.2643E-08 0.0000E+00
0001559 0.1944E-07 0.5123E-09 0.1943E-07 0.4194E-08 0.0000E+00
0001560 0.1980E-07 0.6307E-09 0.1977E-07 0.5540E-08 0.0000E+00
0001561 0.2065E-07 0.8412E-09 0.2059E-07 0.1416E-08 0.0000E+00
0001562 0.1872E-07 0.7046E-09 0.1872E-07 0.7479E-09 0.0000E+00
0001563 0.1865E-07 0.3745E-09 0.1865E-07 0.1884E-08 0.0000E+00
0001564 0.1860E-07 0.4746E-09 0.1860E-07 0.1806E-08 0.0000E+00
0001565 0.1864E-07 0.4465E-09 0.1864E-07 0.3275E-08 0.0000E+00
0001566 0.1883E-07 0.5188E-09 0.1881E-07 0.4035E-08 0.0000E+00
0001567 0.1934E-07 0.6803E-09 0.1931E-07 0.6288E-08 0.0000E+00
0001568 0.2041E-07 0.8938E-09 0.2037E-07 0.1250E-08 0.0000E+00
0001569 0.1801E-07 0.7693E-09 0.1801E-07 0.1120E-08 0.0000E+00
0001570 0.1795E-07 0.3591E-09 0.1795E-07 0.1848E-08 0.0000E+00
0001571 0.1793E-07 0.4871E-09 0.1793E-07 0.2318E-08 0.0000E+00
0001572 0.1802E-07 0.4491E-09 0.1801E-07 0.3515E-08 0.0000E+00
0001573 0.1831E-07 0.5510E-09 0.1829E-07 0.4812E-08 0.0000E+00
0001574 0.1902E-07 0.7265E-09 0.1898E-07 0.4688E-08 0.0000E+00
0001575 0.1730E-07 0.8505E-09 0.2010E-07 0.1436E-08 0.0000E+00
0001576 0.1751E-07 0.5640E-09 0.1733E-07 0.2065E-08 0.0000E+00
0001577 0.1765E-07 0.4055E-09 0.1723E-07 0.2427E-08 0.0000E+00
0001578 0.1794E-07 0.4803E-09 0.1727E-07 0.3544E-08 0.0000E+00
0001579 0.1853E-07 0.6212E-09 0.1755E-07 0.4860E-08 0.0000E+00
0001580 0.1970E-07 0.8314E-09 0.1832E-07 0.4381E-08 0.0000E+00
0001581 0.1675E-07 0.9228E-09 0.1953E-07 0.1326E-08 0.0000E+00
0001582 0.1693E-07 0.5492E-09 0.1676E-07 0.2196E-08 0.0000E+00
0001583 0.1706E-07 0.4020E-09 0.1665E-07 0.2246E-08 0.0000E+00
0001584 0.1733E-07 0.4704E-09 0.1667E-07 0.3392E-08 0.0000E+00
0001585 0.1785E-07 0.6162E-09 0.1694E-07 0.4494E-08 0.0000E+00
0001586 0.1893E-07 0.8181E-09 0.1765E-07 0.4167E-08 0.0000E+00
0001587 0.1618E-07 0.8805E-09 0.1875E-07 0.1260E-08 0.0000E+00
0001588 0.1636E-07 0.5224E-09 0.1620E-07 0.2206E-08 0.0000E+00
0001589 0.1646E-07 0.3867E-09 0.1609E-07 0.2115E-08 0.0000E+00
0001590 0.1668E-07 0.4460E-09 0.1610E-07 0.3236E-08 0.0000E+00
0001591 0.1712E-07 0.5838E-09 0.1633E-07 0.4231E-08 0.0000E+00
0001592 0.1806E-07 0.7683E-09 0.1694E-07 0.3924E-08 0.0000E+00
0001593 0.1564E-07 0.8153E-09 0.1790E-07 0.1208E-08 0.0000E+00
0001594 0.1580E-07 0.4880E-09 0.1566E-07 0.2160E-08 0.0000E+00
0001595 0.1587E-07 0.3679E-09 0.1555E-07 0.1998E-08 0.0000E+00
0001596 0.1606E-07 0.4204E-09 0.1555E-07 0.3067E-08 0.0000E+00
0001597 0.1642E-07 0.5472E-09 0.1575E-07 0.3987E-08 0.0000E+00
0001598 0.1724E-07 0.7152E-09 0.1627E-07 0.3743E-08 0.0000E+00
0001599 0.1512E-07 0.7494E-09 0.1711E-07 0.1169E-08 0.0000E+00
0001600 0.1526E-07 0.4542E-09 0.1513E-07 0.2099E-08 0.0000E+00
0001601 0.1532E-07 0.3481E-09 0.1503E-07 0.1912E-08 0.0000E+00
0001602 0.1547E-07 0.3952E-09 0.1502E-07 0.2922E-08 0.0000E+00
0001603 0.1577E-07 0.5103E-09 0.1520E-07 0.3801E-08 0.0000E+00
0001604 0.1649E-07 0.6632E-09 0.1566E-07 0.3608E-08 0.0000E+00
0001605 0.1462E-07 0.6880E-09 0.1640E-07 0.1139E-08 0.0000E+00
0001606 0.1474E-07 0.4228E-09 0.1463E-07 0.2042E-08 0.0000E+00
0001607 0.1479E-07 0.3292E-09 0.1453E-07 0.1850E-08 0.0000E+00
0001608 0.1492E-07 0.3720E-09 0.1452E-07 0.2808E-08 0.0000E+00
0001609 0.1518E-07 0.4765E-09 0.1467E-07 0.3665E-08 0.0000E+00
0001610 0.1582E-07 0.6161E-09 0.1509E-07 0.3518E-08 0.0000E+00
0001611 0.1413E-07 0.6337E-09 0.1576E-07 0.1117E-08 0.0000E+00
0001612 0.1425E-07 0.3949E-09 0.1414E-07 0.1996E-08 0.0000E+00
0001613 0.1428E-07 0.3120E-09 0.1404E-07 0.1807E-08 0.0000E+00
0001614 0.1440E-07 0.3511E-09 0.1403E-07 0.2724E-08 0.0000E+00
0001615 0.1464E-07 0.4464E-09 0.1418E-07 0.3568E-08 0.0000E+00
0001616 0.1522E-07 0.5746E-09 0.1457E-07 0.3460E-08 0.0000E+00
0001617 0.1366E-07 0.5866E-09 0.1518E-07 0.1102E-08 0.0000E+00
0001618 0.1377E-07 0.3703E-09 0.1367E-07 0.1962E-08 0.0000E+00
0001619 0.1381E-07 0.2964E-09 0.1357E-07 0.1779E-08 0.0000E+00
0001620 0.1391E-07 0.3322E-09 0.1356E-07 0.2663E-08 0.0000E+00
0001621 0.1413E-07 0.4199E-09 0.1371E-07 0.3502E-08 0.0000E+00
0001622 0.1468E-07 0.5381E-09 0.1408E-07 0.9602E-09 0.0000E+00
0001623 0.1328E-07 0.4122E-09 0.1327E-07 0.7725E-09 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 20
0001624 0.1320E-07 0.2423E-09 0.1322E-07 0.1193E-08 0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 20
0001625 0.1314E-07 0.2914E-09 0.1316E-07 0.1268E-08 0.0000E+00
0001626 0.1311E-07 0.2702E-09 0.1314E-07 0.1994E-08 0.0000E+00
0001627 0.1311E-07 0.3037E-09 0.1317E-07 0.2526E-08 0.0000E+00
0001628 0.1323E-07 0.3698E-09 0.1330E-07 0.3777E-08 0.0000E+00
0001629 0.1354E-07 0.4716E-09 0.1366E-07 0.3257E-08 0.0000E+00
0001630 0.1409E-07 0.5177E-09 0.1270E-07 0.1213E-08 0.0000E+00
0001631 0.1270E-07 0.3420E-09 0.1281E-07 0.1670E-08 0.0000E+00
0001632 0.1261E-07 0.2684E-09 0.1285E-07 0.1823E-08 0.0000E+00
0001633 0.1261E-07 0.3048E-09 0.1296E-07 0.2492E-08 0.0000E+00
0001634 0.1276E-07 0.3848E-09 0.1319E-07 0.3461E-08 0.0000E+00
0001635 0.1316E-07 0.4991E-09 0.1374E-07 0.8705E-09 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 22
0001636 0.1233E-07 0.3893E-09 0.1234E-07 0.6876E-09 0.0000E+00
0001637 0.1228E-07 0.2219E-09 0.1227E-07 0.1130E-08 0.0000E+00
0001638 0.1224E-07 0.2726E-09 0.1222E-07 0.1259E-08 0.0000E+00
0001639 0.1222E-07 0.2517E-09 0.1220E-07 0.1952E-08 0.0000E+00
0001640 0.1227E-07 0.2868E-09 0.1222E-07 0.2536E-08 0.0000E+00
0001641 0.1244E-07 0.3537E-09 0.1235E-07 0.3734E-08 0.0000E+00
0001642 0.1285E-07 0.4557E-09 0.1269E-07 0.8039E-09 0.0000E+00
0001643 0.1186E-07 0.3726E-09 0.1186E-07 0.6067E-09 0.0000E+00
0001644 0.1180E-07 0.2114E-09 0.1181E-07 0.1103E-08 0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 19
0001645 0.1176E-07 0.2639E-09 0.1177E-07 0.1223E-08 0.0000E+00
0001646 0.1175E-07 0.2440E-09 0.1176E-07 0.1961E-08 0.0000E+00
0001647 0.1179E-07 0.2829E-09 0.1181E-07 0.2550E-08 0.0000E+00
0001648 0.1198E-07 0.3546E-09 0.1201E-07 0.3793E-08 0.0000E+00
0001649 0.1241E-07 0.4638E-09 0.1246E-07 0.8208E-09 0.0000E+00
0001650 0.1140E-07 0.3799E-09 0.1140E-07 0.6329E-09 0.0000E+00
0001651 0.1135E-07 0.2040E-09 0.1135E-07 0.1148E-08 0.0000E+00
0001652 0.1131E-07 0.2638E-09 0.1132E-07 0.1297E-08 0.0000E+00
0001653 0.1132E-07 0.2421E-09 0.1132E-07 0.2056E-08 0.0000E+00
0001654 0.1140E-07 0.2859E-09 0.1140E-07 0.2690E-08 0.0000E+00
0001655 0.1163E-07 0.3648E-09 0.1163E-07 0.3961E-08 0.0000E+00
0001656 0.1215E-07 0.4815E-09 0.1213E-07 0.8501E-09 0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 1354
0001657 0.1096E-07 0.3949E-09 0.1096E-07 0.6489E-09 0.0000E+00
0001658 0.1092E-07 0.1972E-09 0.1092E-07 0.1194E-08 0.0000E+00
0001659 0.1089E-07 0.2641E-09 0.1090E-07 0.1348E-08 0.0000E+00
0001660 0.1091E-07 0.2416E-09 0.1092E-07 0.2150E-08 0.0000E+00
0001661 0.1101E-07 0.2905E-09 0.1102E-07 0.2806E-08 0.0000E+00
0001662 0.1130E-07 0.3780E-09 0.1132E-07 0.4124E-08 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 21
0001663 0.1190E-07 0.5026E-09 0.1192E-07 0.8804E-09 0.0000E+00
0001664 0.1054E-07 0.4124E-09 0.1055E-07 0.6829E-09 0.0000E+00
0001665 0.1050E-07 0.1914E-09 0.1051E-07 0.1250E-08 0.0000E+00
0001666 0.1049E-07 0.2671E-09 0.1049E-07 0.1424E-08 0.0000E+00
0001667 0.1053E-07 0.2432E-09 0.1053E-07 0.2260E-08 0.0000E+00
0001668 0.1067E-07 0.2982E-09 0.1067E-07 0.2953E-08 0.0000E+00
0001669 0.1102E-07 0.3944E-09 0.1103E-07 0.7625E-09 0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 34
0001670 0.1018E-07 0.3263E-09 0.1019E-07 0.3999E-09 0.0000E+00
0001671 0.1014E-07 0.1790E-09 0.1014E-07 0.1009E-08 0.0000E+00
0001672 0.1011E-07 0.2263E-09 0.1011E-07 0.9446E-09 0.0000E+00
0001673 0.1011E-07 0.2117E-09 0.1011E-07 0.1723E-08 0.0000E+00
0001674 0.1017E-07 0.2452E-09 0.1018E-07 0.2096E-08 0.0000E+00
0001675 0.1038E-07 0.3179E-09 0.1039E-07 0.3274E-08 0.0000E+00
0001676 0.1082E-07 0.4166E-09 0.1084E-07 0.6585E-09 0.0000E+00
0001677 0.9792E-08 0.3539E-09 0.9797E-08 0.6003E-09 0.0000E+00
TIME FOR CALCULATION: 0.2333E+05
L2-NORM ERROR U VELOCITY 2.794552122239916E-005
L2-NORM ERROR V VELOCITY 2.790982482205062E-005
L2-NORM ERROR W VELOCITY 2.911527032104786E-005
L2-NORM ERROR ABS. VELOCITY 3.166182228011700E-005
L2-NORM ERROR PRESSURE 1.392953546653255E-003
*** CALCULATION FINISHED - SEE RESULTS ***
*** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./caffa3d.MB.lnx on a arch-openmpi-opt-intel-hlr-ext named hpb0075 with 1 processor, by gu08vomo Fri Feb 20 03:10:17 2015
Using Petsc Release Version 3.5.3, Jan, 31, 2015
Max Max/Min Avg Total
Time (sec): 2.334e+04 1.00000 2.334e+04
Objects: 9.246e+04 1.00000 9.246e+04
Flops: 1.177e+13 1.00000 1.177e+13 1.177e+13
Flops/sec: 5.046e+08 1.00000 5.046e+08 5.046e+08
MPI Messages: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Message Lengths: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Reductions: 0.000e+00 0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flops
and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts %Total Avg %Total counts %Total
0: Main Stage: 6.3490e+03 27.2% 6.5910e+06 0.0% 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
1: MOMENTUM: 2.5123e+03 10.8% 1.4158e+12 12.0% 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
2: PRESCORR: 1.4475e+04 62.0% 1.0359e+13 88.0% 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flops: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length (bytes)
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %F - percent flops in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event Count Time (sec) Flops --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
ThreadCommRunKer 8386 1.0 1.1347e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNorm 1 1.0 2.3177e-01 1.0 4.39e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 67 0 0 0 19
VecScale 1 1.0 2.4431e-03 1.0 2.20e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 33 0 0 0 899
VecSet 67086 1.0 1.3405e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 2 0 0 0 0 0
VecScatterBegin 75476 1.0 3.7952e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 1 1.0 2.4450e-03 1.0 2.20e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 33 0 0 0 899
MatAssemblyBegin 3354 1.0 2.0044e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyEnd 3354 1.0 7.7460e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
--- Event Stage 1: MOMENTUM
VecMDot 6511 1.0 1.6014e+01 1.0 3.51e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 2193
VecNorm 21604 1.0 3.0017e+01 1.0 9.49e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 1 7 0 0 0 3163
VecScale 11542 1.0 1.5715e+01 1.0 2.54e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 1614
VecCopy 10062 1.0 3.4057e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecSet 5031 1.0 4.6499e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 15093 1.0 4.9896e+01 1.0 6.63e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 2 5 0 0 0 1329
VecMAXPY 11542 1.0 3.5569e+01 1.0 6.37e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 1 5 0 0 0 1792
VecNormalize 11542 1.0 2.9960e+01 1.0 7.61e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 1 5 0 0 0 2539
MatMult 16573 1.0 4.5783e+02 1.0 4.50e+11 1.0 0.0e+00 0.0e+00 0.0e+00 2 4 0 0 0 18 32 0 0 0 983
MatSolve 16573 1.0 4.7564e+02 1.0 4.50e+11 1.0 0.0e+00 0.0e+00 0.0e+00 2 4 0 0 0 19 32 0 0 0 947
MatLUFactorNum 5031 1.0 5.4508e+02 1.0 2.30e+11 1.0 0.0e+00 0.0e+00 0.0e+00 2 2 0 0 0 22 16 0 0 0 422
MatILUFactorSym 5031 1.0 4.7919e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 19 0 0 0 0 0
MatGetRowIJ 5031 1.0 8.9526e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 5031 1.0 4.4503e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 0 0 0 0 0
KSPGMRESOrthog 6511 1.0 3.5106e+01 1.0 7.02e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 1 5 0 0 0 2000
KSPSetUp 5031 1.0 1.3708e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 5 0 0 0 0 0
KSPSolve 5031 1.0 2.1856e+03 1.0 1.23e+12 1.0 0.0e+00 0.0e+00 0.0e+00 9 10 0 0 0 87 87 0 0 0 565
PCSetUp 5031 1.0 1.0748e+03 1.0 2.30e+11 1.0 0.0e+00 0.0e+00 0.0e+00 5 2 0 0 0 43 16 0 0 0 214
PCApply 16573 1.0 4.7568e+02 1.0 4.50e+11 1.0 0.0e+00 0.0e+00 0.0e+00 2 4 0 0 0 19 32 0 0 0 946
--- Event Stage 2: PRESCORR
VecMDot 26952 1.0 9.9884e+01 1.0 1.19e+11 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 1 1 0 0 0 1187
VecTDot 50500 1.0 1.8378e+02 1.0 2.22e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 1207
VecNorm 28632 1.0 6.0194e+01 1.0 1.26e+11 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 2089
VecScale 33 1.0 1.6309e-02 1.0 2.63e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1611
VecCopy 5034 1.0 1.7482e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 252460 1.0 5.7891e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 52170 1.0 2.2045e+02 1.0 2.29e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 2 2 0 0 0 1040
VecAYPX 104334 1.0 2.1384e+02 1.0 1.68e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 2 0 0 0 785
VecMAXPY 26955 1.0 1.2491e+02 1.0 1.19e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 950
VecAssemblyBegin 3 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAssemblyEnd 3 1.0 1.9073e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 26955 1.0 7.0147e-02 1.0 2.70e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 385
VecSetRandom 3 1.0 2.3869e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 33 1.0 3.1275e-02 1.0 7.88e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 2520
MatMult 107718 1.0 1.6463e+03 1.0 1.80e+12 1.0 0.0e+00 0.0e+00 0.0e+00 7 15 0 0 0 11 17 0 0 0 1091
MatMultAdd 80766 1.0 5.6387e+02 1.0 4.34e+11 1.0 0.0e+00 0.0e+00 0.0e+00 2 4 0 0 0 4 4 0 0 0 770
MatMultTranspose 134610 1.0 6.3971e+02 1.0 4.34e+11 1.0 0.0e+00 0.0e+00 0.0e+00 3 4 0 0 0 4 4 0 0 0 679
MatSOR 161532 1.0 8.1896e+03 1.0 6.21e+12 1.0 0.0e+00 0.0e+00 0.0e+00 35 53 0 0 0 57 60 0 0 0 759
MatConvert 1682 1.0 1.4112e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatScale 9 1.0 6.8224e-02 1.0 5.81e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 851
MatResidual 80766 1.0 1.0138e+03 1.0 1.13e+12 1.0 0.0e+00 0.0e+00 0.0e+00 4 10 0 0 0 7 11 0 0 0 1114
MatAssemblyBegin 6738 1.0 2.8052e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyEnd 6738 1.0 8.4092e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetRow 9597518 1.0 5.0723e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatCoarsen 3 1.0 1.8700e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatView 6 1.0 6.3229e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAXPY 3 1.0 4.1201e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMatMult 3 1.0 4.6048e-01 1.0 4.98e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 108
MatMatMultSym 3 1.0 3.0840e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatMatMultNum 3 1.0 1.5204e-01 1.0 4.98e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 328
MatPtAP 5031 1.0 2.4475e+03 1.0 4.98e+11 1.0 0.0e+00 0.0e+00 0.0e+00 10 4 0 0 0 17 5 0 0 0 204
MatPtAPSymbolic 6 1.0 1.8564e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatPtAPNumeric 5031 1.0 2.4456e+03 1.0 4.98e+11 1.0 0.0e+00 0.0e+00 0.0e+00 10 4 0 0 0 17 5 0 0 0 204
MatTrnMatMult 3 1.0 6.2841e+00 1.0 6.33e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 101
MatTrnMatMultSym 3 1.0 2.9903e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatTrnMatMultNum 3 1.0 3.2938e+00 1.0 6.33e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 192
MatGetSymTrans 9 1.0 2.8709e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPGMRESOrthog 30 1.0 1.8173e-01 1.0 5.25e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 2891
KSPSetUp 11742 1.0 1.6553e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 1677 1.0 1.4421e+04 1.0 1.03e+13 1.0 0.0e+00 0.0e+00 0.0e+00 62 87 0 0 0 100 99 0 0 0 714
PCGAMGgraph_AGG 3 1.0 1.4958e+00 1.0 4.19e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 28
PCGAMGcoarse_AGG 3 1.0 6.7805e+00 1.0 6.33e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 93
PCGAMGProl_AGG 3 1.0 4.9031e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
PCGAMGPOpt_AGG 3 1.0 2.0095e+00 1.0 1.14e+09 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 570
PCSetUp 3354 1.0 2.4591e+03 1.0 5.00e+11 1.0 0.0e+00 0.0e+00 0.0e+00 11 4 0 0 0 17 5 0 0 0 203
PCSetUpOnBlocks 26922 1.0 5.5923e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
PCApply 26922 1.0 1.0459e+04 1.0 8.21e+12 1.0 0.0e+00 0.0e+00 0.0e+00 45 70 0 0 0 72 79 0 0 0 785
--- Event Stage 3: Unknown
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Vector 67 95 833878448 0
Vector Scatter 2 2 1304 0
Index Set 4 7 17581544 0
IS L to G Mapping 2 2 17577192 0
Matrix 1 11 490350860 0
Matrix Null Space 0 1 620 0
Krylov Solver 0 7 115533784 0
Preconditioner 0 7 7436 0
Vector 60376 60362 530554454928 0
Index Set 15093 15090 88419231280 0
Matrix 5031 5030 1063010020000 0
Matrix Null Space 1 0 0 0
Krylov Solver 2 0 0 0
Preconditioner 2 0 0 0
Vector 8478 8453 434897736 0
Index Set 3 3 2376 0
Matrix 3380 3371 687941176 0
Matrix Coarsen 3 3 1932 0
Krylov Solver 8 3 90648 0
Preconditioner 8 3 3144 0
PetscRandom 3 3 1920 0
Viewer 1 0 0 0
Average time to get PetscTime(): 0
#PETSc Option Table entries:
-log_summary
-momentum_ksp_type gmres
-options_left
-pressure_ksp_converged_reason
-pressure_mg_coarse_sub_pc_type svd
-pressure_mg_levels_ksp_rtol 1e-4
-pressure_mg_levels_ksp_type richardson
-pressure_mg_levels_pc_type sor
-pressure_pc_gamg_agg_nsmooths 1
-pressure_pc_gamg_reuse_interpolation true
-pressure_pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: PETSC_ARCH=arch-openmpi-opt-intel-hlr-ext PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3 -prefix=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr-ext --with-blas-lapack-dir=/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64/ --with-mpi-dir=/shared/apps/openmpi/1.8.2_intel COPTFLAGS="-O3 -xHost" FOPTFLAGS="-O3 -xHost" CXXOPTFLAGS="-O3 -xHost" --with-debugging=0 --download-hypre --download-ml
Libraries compiled on Sun Feb 1 16:09:22 2015 on hla0003
Machine characteristics: Linux-3.0.101-0.40-default-x86_64-with-SuSE-11-x86_64
Using PETSc directory: /home/gu08vomo/soft/petsc/3.5.3
Using PETSc arch: arch-openmpi-opt-intel-hlr-ext
Using C compiler: /shared/apps/openmpi/1.8.2_intel/bin/mpicc -fPIC -wd1572 -O3 -xHost ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /shared/apps/openmpi/1.8.2_intel/bin/mpif90 -fPIC -O3 -xHost ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/include -I/home/gu08vomo/soft/petsc/3.5.3/include -I/home/gu08vomo/soft/petsc/3.5.3/include -I/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/include -I/shared/apps/openmpi/1.8.2_intel/include
Using C linker: /shared/apps/openmpi/1.8.2_intel/bin/mpicc
Using Fortran linker: /shared/apps/openmpi/1.8.2_intel/bin/mpif90
Using libraries: -Wl,-rpath,/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -L/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -lpetsc -Wl,-rpath,/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -L/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -lHYPRE -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -lmpi_cxx -lml -lmpi_cxx -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -lX11 -lpthread -lssl -lcrypto -lmpi_usempi_ignore_tkr -lmpi_mpifh -lifport -lifcore -lm -lmpi_cxx -ldl -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -lmpi -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -limf -lsvml -lirng -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc_s -lirc -lpthread -lirc_s -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -ldl
-log_summary
-options_left
There are no unused options.
Sender: LSF System <lsfadmin at hpb0241>
Subject: Job 541300: <mg_test> in cluster <lichtenberg> Done
Job <mg_test> was submitted from host <hla0003> by user <gu08vomo> in cluster <lichtenberg>.
Job was executed on host(s) <hpb0241>, in queue <test_mpi2>, as user <gu08vomo> in cluster <lichtenberg>.
</home/gu08vomo> was used as the home directory.
</work/scratch/gu08vomo/thesis/singleblock/128_1_1_seg> was used as the working directory.
Started at Thu Feb 19 10:46:15 2015
Results reported at Thu Feb 19 22:43:07 2015
Your job looked like:
# LSBATCH: User input
#! /bin/sh
#BSUB -J mg_test
#BSUB -o /home/gu08vomo/thesis/mgtest/gamg.128.out.%J
#BSUB -n 1
#BSUB -W 14:00
#BSUB -x
#BSUB -q test_mpi2
#BSUB -a openmpi
module load openmpi/intel/1.8.2
#export PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr
export PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr-ext
export MYWORKDIR=/work/scratch/gu08vomo/thesis/singleblock/128_1_1_seg/
export OUTPUTDIR=/home/gu08vomo/thesis/coupling
export PETSC_OPS="-options_file ops.gamg.old"
cat ops.gamg
echo "PETSC_DIR="$PETSC_DIR
echo "MYWORKDIR="$MYWORKDIR
cd $MYWORKDIR
mpirun -n 1 ./caffa3d.MB.lnx ${PETSC_OPS}
Successfully completed.
Resource usage summary:
CPU time : 43014.29 sec.
Max Memory : 2905 MB
Average Memory : 2235.03 MB
Total Requested Memory : -
Delta Memory : -
(Delta: the difference between total requested memory and actual max usage.)
Max Swap : 3659 MB
Max Processes : 6
Max Threads : 11
The output (if any) follows:
Modules: loading openmpi/intel/1.8.2
-log_summary
-options_left
ENTER PROBLEM NAME (SIX CHARACTERS):
NAME OF PROBLEM SOLVED control
CONTROL SETTINGS
LREAD,LWRITE,LPOST,LTEST,LOUTS,LOUTE,LTIME,LGRAD
F F F F F F F F
IMON, JMON, KMON, MMON, RMON, IPR, JPR, KPR, MPR,NPCOR,NIGRAD
8 9 8 1 0 2 2 3 1 1 1
SORMAX, SLARGE, ALFA
0.1000E-07 0.1000E+31 0.9200E+00
(URF(I),I=1,5)
0.9000E+00 0.9000E+00 0.9000E+00 0.1000E+00 0.1000E+01
(SOR(I),I=1,5)
0.1000E+00 0.1000E+00 0.1000E+00 0.1000E+00 0.1000E+00
(GDS(I),I=1,5) - BLENDING (CDS-UDS)
0.1000E+01 0.1000E+01 0.1000E+01 0.1000E+01 0.1000E+01
LSG
100000
START SIMPLE RELAXATIONS
KSP Object:(pressure_) 1 MPI processes
type: cg
maximum iterations=10000, initial guess is zero
tolerances: relative=0.1, absolute=1e-50, divergence=10000
left preconditioning
has attached null space
using PRECONDITIONED norm type for convergence test
PC Object:(pressure_) 1 MPI processes
type: gamg
MG: type is MULTIPLICATIVE, levels=4 cycles=v
Cycles per PCApply=1
Using Galerkin computed coarse grid matrices
Coarse grid solver -- level -------------------------------
KSP Object: (pressure_mg_coarse_) 1 MPI processes
type: preonly
maximum iterations=1, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
using NONE norm type for convergence test
PC Object: (pressure_mg_coarse_) 1 MPI processes
type: bjacobi
block Jacobi: number of blocks = 1
Local solve is same for all blocks, in the following KSP and PC objects:
KSP Object: (pressure_mg_coarse_sub_) 1 MPI processes
type: preonly
PC Object: (pressure_mg_coarse_sub_) 1 MPI processes
type: svd
linear system matrix = precond matrix:
Mat Object: 1 MPI processes
type: seqaij
rows=26, cols=26
total: nonzeros=536, allocated nonzeros=536
total number of mallocs used during MatSetValues calls =0
not using I-node routines
type: seqaij
rows=26, cols=26
Down solver (pre-smoother) on level 1 -------------------------------
KSP Object: (pressure_mg_levels_1_) 1 MPI processes
type: richardson
Richardson: damping factor=1
maximum iterations=2
tolerances: relative=0.0001, absolute=1e-50, divergence=10000
using nonzero initial guess
PC Object: (pressure_mg_levels_1_) 1 MPI processes
type: sor
SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
type: seqaij
rows=2781, cols=2781
total: nonzeros=156609, allocated nonzeros=156609
Up solver (post-smoother) same as down solver (pre-smoother)
Down solver (pre-smoother) on level 2 -------------------------------
KSP Object: (pressure_mg_levels_2_) 1 MPI processes
type: richardson
PC Object: (pressure_mg_levels_2_) 1 MPI processes
type: sor
type: seqaij
rows=188698, cols=188698
total: nonzeros=6.12809e+06, allocated nonzeros=6.12809e+06
Down solver (pre-smoother) on level 3 -------------------------------
KSP Object: (pressure_mg_levels_3_) 1 MPI processes
type: richardson
PC Object: (pressure_mg_levels_3_) 1 MPI processes
type: sor
type: seqaij
rows=2197000, cols=2197000
total: nonzeros=1.46816e+07, allocated nonzeros=1.46816e+07
type: seqaij
0000001 0.1000E+01 0.1000E+01 0.1000E+01 0.1000E+01 0.0000E+00
0000002 0.7654E+00 0.7194E+00 0.7661E+00 0.7330E+00 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 3
0000003 0.4442E+00 0.3597E+00 0.4375E+00 0.2886E+00 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 5
0000004 0.1641E+00 0.1296E+00 0.1648E+00 0.4463E-01 0.0000E+00
0000005 0.5112E-01 0.3598E-01 0.5166E-01 0.3104E-01 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 6
0000006 0.1957E-01 0.7820E-02 0.1983E-01 0.1447E-01 0.0000E+00
0000007 0.1497E-01 0.7200E-02 0.1495E-01 0.8590E-02 0.0000E+00
0000008 0.1272E-01 0.5662E-02 0.1269E-01 0.8207E-02 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 7
0000009 0.1135E-01 0.4639E-02 0.1135E-01 0.5068E-02 0.0000E+00
0000010 0.1033E-01 0.4072E-02 0.1035E-01 0.5708E-02 0.0000E+00
0000011 0.9421E-02 0.3706E-02 0.9432E-02 0.3233E-02 0.0000E+00
0000012 0.8734E-02 0.3483E-02 0.8746E-02 0.3921E-02 0.0000E+00
0000013 0.8122E-02 0.3221E-02 0.8130E-02 0.2095E-02 0.0000E+00
0000014 0.7652E-02 0.3058E-02 0.7662E-02 0.3045E-02 0.0000E+00
0000015 0.7237E-02 0.2890E-02 0.7245E-02 0.1618E-02 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 8
0000016 0.6956E-02 0.2818E-02 0.6965E-02 0.1471E-02 0.0000E+00
0000017 0.6339E-02 0.2521E-02 0.6346E-02 0.1578E-02 0.0000E+00
0000018 0.6017E-02 0.2392E-02 0.6023E-02 0.1044E-02 0.0000E+00
0000019 0.5734E-02 0.2283E-02 0.5740E-02 0.1212E-02 0.0000E+00
0000020 0.5476E-02 0.2180E-02 0.5481E-02 0.7940E-03 0.0000E+00
0000021 0.5248E-02 0.2095E-02 0.5254E-02 0.1054E-02 0.0000E+00
0000022 0.5044E-02 0.2020E-02 0.5050E-02 0.8218E-03 0.0000E+00
0000023 0.4875E-02 0.1970E-02 0.4881E-02 0.1209E-02 0.0000E+00
0000024 0.4745E-02 0.1949E-02 0.4751E-02 0.1315E-02 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 9
0000025 0.4687E-02 0.1991E-02 0.4694E-02 0.4871E-03 0.0000E+00
0000026 0.4312E-02 0.1718E-02 0.4317E-02 0.4958E-03 0.0000E+00
0000027 0.4170E-02 0.1661E-02 0.4174E-02 0.4818E-03 0.0000E+00
0000028 0.4040E-02 0.1617E-02 0.4045E-02 0.5838E-03 0.0000E+00
0000029 0.3930E-02 0.1591E-02 0.3935E-02 0.7478E-03 0.0000E+00
0000030 0.3852E-02 0.1602E-02 0.3858E-02 0.1019E-02 0.0000E+00
0000031 0.3836E-02 0.1682E-02 0.3842E-02 0.1235E-02 0.0000E+00
0000032 0.3904E-02 0.1425E-02 0.3914E-02 0.4310E-03 0.0000E+00
0000033 0.3462E-02 0.1459E-02 0.3465E-02 0.4804E-03 0.0000E+00
0000034 0.3375E-02 0.1481E-02 0.3378E-02 0.4952E-03 0.0000E+00
0000035 0.3307E-02 0.1300E-02 0.3311E-02 0.5204E-03 0.0000E+00
0000036 0.3259E-02 0.1284E-02 0.3263E-02 0.7728E-03 0.0000E+00
0000037 0.3254E-02 0.1329E-02 0.3259E-02 0.1037E-02 0.0000E+00
0000038 0.3346E-02 0.1486E-02 0.3353E-02 0.3282E-03 0.0000E+00
0000039 0.2956E-02 0.1177E-02 0.2960E-02 0.2359E-03 0.0000E+00
0000040 0.2892E-02 0.1160E-02 0.2896E-02 0.4576E-03 0.0000E+00
0000041 0.2838E-02 0.1160E-02 0.2841E-02 0.5030E-03 0.0000E+00
0000042 0.2811E-02 0.1200E-02 0.2815E-02 0.7012E-03 0.0000E+00
0000043 0.2820E-02 0.1068E-02 0.2824E-02 0.8205E-03 0.0000E+00
0000044 0.2892E-02 0.1123E-02 0.2897E-02 0.4962E-03 0.0000E+00
0000045 0.2573E-02 0.1220E-02 0.2576E-02 0.2104E-03 0.0000E+00
0000046 0.2534E-02 0.9942E-03 0.2537E-02 0.4036E-03 0.0000E+00
0000047 0.2498E-02 0.9794E-03 0.2501E-02 0.4000E-03 0.0000E+00
0000048 0.2489E-02 0.9990E-03 0.2492E-02 0.7027E-03 0.0000E+00
0000049 0.2529E-02 0.1090E-02 0.2532E-02 0.8338E-03 0.0000E+00
0000050 0.2644E-02 0.9371E-03 0.2648E-02 0.3577E-03 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 10
0000051 0.2274E-02 0.1012E-02 0.2276E-02 0.1423E-03 0.0000E+00
0000052 0.2239E-02 0.8736E-03 0.2242E-02 0.3321E-03 0.0000E+00
0000053 0.2206E-02 0.8618E-03 0.2209E-02 0.3065E-03 0.0000E+00
0000054 0.2193E-02 0.8675E-03 0.2196E-02 0.5479E-03 0.0000E+00
0000055 0.2211E-02 0.9236E-03 0.2213E-02 0.6273E-03 0.0000E+00
0000056 0.2286E-02 0.8231E-03 0.2289E-02 0.2699E-03 0.0000E+00
0000057 0.2029E-02 0.8714E-03 0.2032E-02 0.1083E-03 0.0000E+00
0000058 0.1999E-02 0.7774E-03 0.2002E-02 0.2617E-03 0.0000E+00
0000059 0.1970E-02 0.7665E-03 0.1973E-02 0.2341E-03 0.0000E+00
0000060 0.1954E-02 0.7659E-03 0.1957E-02 0.4193E-03 0.0000E+00
0000061 0.1959E-02 0.7992E-03 0.1961E-02 0.5482E-03 0.0000E+00
0000062 0.2019E-02 0.8872E-03 0.2021E-02 0.1874E-03 0.0000E+00
0000063 0.1828E-02 0.7171E-03 0.1830E-02 0.1414E-03 0.0000E+00
0000064 0.1802E-02 0.7103E-03 0.1804E-02 0.2711E-03 0.0000E+00
0000065 0.1780E-02 0.7150E-03 0.1782E-02 0.2977E-03 0.0000E+00
0000066 0.1775E-02 0.7407E-03 0.1777E-02 0.4188E-03 0.0000E+00
0000067 0.1793E-02 0.6706E-03 0.1794E-02 0.4859E-03 0.0000E+00
0000068 0.1853E-02 0.7134E-03 0.1854E-02 0.1724E-03 0.0000E+00
0000069 0.1658E-02 0.6460E-03 0.1660E-02 0.1030E-03 0.0000E+00
0000070 0.1634E-02 0.6452E-03 0.1636E-02 0.2447E-03 0.0000E+00
0000071 0.1615E-02 0.6498E-03 0.1617E-02 0.2467E-03 0.0000E+00
0000072 0.1610E-02 0.6750E-03 0.1612E-02 0.3604E-03 0.0000E+00
0000073 0.1623E-02 0.6071E-03 0.1624E-02 0.4072E-03 0.0000E+00
0000074 0.1670E-02 0.6422E-03 0.1672E-02 0.2926E-03 0.0000E+00
0000075 0.1511E-02 0.6956E-03 0.1513E-02 0.1032E-03 0.0000E+00
0000076 0.1498E-02 0.5768E-03 0.1500E-02 0.2234E-03 0.0000E+00
0000077 0.1486E-02 0.5720E-03 0.1488E-02 0.2207E-03 0.0000E+00
0000078 0.1490E-02 0.5875E-03 0.1492E-02 0.4043E-03 0.0000E+00
0000079 0.1524E-02 0.6456E-03 0.1525E-02 0.4684E-03 0.0000E+00
0000080 0.1606E-02 0.5600E-03 0.1607E-02 0.2275E-03 0.0000E+00
0000081 0.1386E-02 0.6101E-03 0.1387E-02 0.8311E-04 0.0000E+00
0000082 0.1372E-02 0.5256E-03 0.1374E-02 0.1982E-03 0.0000E+00
0000083 0.1360E-02 0.5216E-03 0.1362E-02 0.1917E-03 0.0000E+00
0000084 0.1360E-02 0.5293E-03 0.1362E-02 0.3408E-03 0.0000E+00
0000085 0.1382E-02 0.5710E-03 0.1383E-02 0.3904E-03 0.0000E+00
0000086 0.1443E-02 0.5078E-03 0.1443E-02 0.1817E-03 0.0000E+00
0000087 0.1275E-02 0.5449E-03 0.1276E-02 0.6984E-04 0.0000E+00
0000088 0.1262E-02 0.4818E-03 0.1264E-02 0.1668E-03 0.0000E+00
0000089 0.1250E-02 0.4775E-03 0.1252E-02 0.1587E-03 0.0000E+00
0000090 0.1247E-02 0.4809E-03 0.1248E-02 0.2788E-03 0.0000E+00
0000091 0.1259E-02 0.5097E-03 0.1261E-02 0.3156E-03 0.0000E+00
0000092 0.1303E-02 0.4637E-03 0.1303E-02 0.1476E-03 0.0000E+00
0000093 0.1176E-02 0.4901E-03 0.1178E-02 0.1786E-03 0.0000E+00
0000094 0.1165E-02 0.5038E-03 0.1166E-02 0.1799E-03 0.0000E+00
0000095 0.1161E-02 0.4410E-03 0.1162E-02 0.1606E-03 0.0000E+00
0000096 0.1165E-02 0.4456E-03 0.1166E-02 0.2954E-03 0.0000E+00
0000097 0.1190E-02 0.4843E-03 0.1191E-02 0.3493E-03 0.0000E+00
0000098 0.1251E-02 0.4346E-03 0.1251E-02 0.1745E-03 0.0000E+00
0000099 0.1089E-02 0.4733E-03 0.1091E-02 0.6286E-04 0.0000E+00
0000100 0.1081E-02 0.4100E-03 0.1082E-02 0.1508E-03 0.0000E+00
0000101 0.1072E-02 0.4073E-03 0.1074E-02 0.1477E-03 0.0000E+00
0000102 0.1073E-02 0.4132E-03 0.1075E-02 0.2604E-03 0.0000E+00
0000103 0.1091E-02 0.4455E-03 0.1092E-02 0.2983E-03 0.0000E+00
0000104 0.1139E-02 0.3984E-03 0.1139E-02 0.1423E-03 0.0000E+00
0000105 0.1011E-02 0.4275E-03 0.1012E-02 0.5486E-04 0.0000E+00
0000106 0.1002E-02 0.3791E-03 0.1003E-02 0.1289E-03 0.0000E+00
0000107 0.9939E-03 0.3763E-03 0.9951E-03 0.1251E-03 0.0000E+00
0000108 0.9925E-03 0.3793E-03 0.9936E-03 0.2172E-03 0.0000E+00
0000109 0.1003E-02 0.4023E-03 0.1004E-02 0.2469E-03 0.0000E+00
0000110 0.1039E-02 0.3670E-03 0.1039E-02 0.1175E-03 0.0000E+00
0000111 0.9400E-03 0.3884E-03 0.9411E-03 0.4702E-04 0.0000E+00
0000112 0.9314E-03 0.3515E-03 0.9326E-03 0.1080E-03 0.0000E+00
0000113 0.9232E-03 0.3486E-03 0.9243E-03 0.1045E-03 0.0000E+00
0000114 0.9200E-03 0.3496E-03 0.9211E-03 0.1799E-03 0.0000E+00
0000115 0.9259E-03 0.3656E-03 0.9268E-03 0.2472E-03 0.0000E+00
0000116 0.9561E-03 0.4049E-03 0.9566E-03 0.3358E-03 0.0000E+00
0000117 0.1017E-02 0.3465E-03 0.1017E-02 0.1589E-03 0.0000E+00
0000118 0.8667E-03 0.3811E-03 0.8678E-03 0.7975E-04 0.0000E+00
0000119 0.8612E-03 0.3240E-03 0.8623E-03 0.1111E-03 0.0000E+00
0000120 0.8578E-03 0.3235E-03 0.8588E-03 0.1533E-03 0.0000E+00
0000121 0.8630E-03 0.3341E-03 0.8638E-03 0.2287E-03 0.0000E+00
0000122 0.8873E-03 0.3705E-03 0.8878E-03 0.2975E-03 0.0000E+00
0000123 0.9398E-03 0.3204E-03 0.9399E-03 0.1344E-03 0.0000E+00
0000124 0.8088E-03 0.3522E-03 0.8098E-03 0.5957E-04 0.0000E+00
0000125 0.8036E-03 0.3015E-03 0.8046E-03 0.1102E-03 0.0000E+00
0000126 0.7996E-03 0.3006E-03 0.8005E-03 0.1291E-03 0.0000E+00
0000127 0.8031E-03 0.3073E-03 0.8039E-03 0.2047E-03 0.0000E+00
0000128 0.8216E-03 0.3367E-03 0.8222E-03 0.2506E-03 0.0000E+00
0000129 0.8655E-03 0.2962E-03 0.8657E-03 0.1150E-03 0.0000E+00
0000130 0.7558E-03 0.3227E-03 0.7567E-03 0.4880E-04 0.0000E+00
0000131 0.7506E-03 0.2811E-03 0.7514E-03 0.1009E-03 0.0000E+00
0000132 0.7460E-03 0.2798E-03 0.7468E-03 0.1086E-03 0.0000E+00
0000133 0.7475E-03 0.2838E-03 0.7482E-03 0.1776E-03 0.0000E+00
0000134 0.7604E-03 0.3062E-03 0.7610E-03 0.2101E-03 0.0000E+00
0000135 0.7945E-03 0.2747E-03 0.7948E-03 0.9760E-04 0.0000E+00
0000136 0.7071E-03 0.2953E-03 0.7078E-03 0.4072E-04 0.0000E+00
0000137 0.7017E-03 0.2624E-03 0.7025E-03 0.8785E-04 0.0000E+00
0000138 0.6968E-03 0.2608E-03 0.6976E-03 0.9057E-04 0.0000E+00
0000139 0.6966E-03 0.2631E-03 0.6973E-03 0.1507E-03 0.0000E+00
0000140 0.7050E-03 0.2795E-03 0.7056E-03 0.1748E-03 0.0000E+00
0000141 0.7305E-03 0.2554E-03 0.7309E-03 0.8246E-04 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 11
0000142 0.6621E-03 0.2708E-03 0.6628E-03 0.3419E-04 0.0000E+00
0000143 0.6568E-03 0.2453E-03 0.6575E-03 0.7491E-04 0.0000E+00
0000144 0.6517E-03 0.2436E-03 0.6524E-03 0.7552E-04 0.0000E+00
0000145 0.6502E-03 0.2447E-03 0.6508E-03 0.1269E-03 0.0000E+00
0000146 0.6552E-03 0.2565E-03 0.6558E-03 0.1776E-03 0.0000E+00
0000147 0.6775E-03 0.2847E-03 0.6779E-03 0.2377E-03 0.0000E+00
0000148 0.7225E-03 0.2438E-03 0.7225E-03 0.1154E-03 0.0000E+00
0000149 0.6148E-03 0.2689E-03 0.6154E-03 0.5615E-04 0.0000E+00
0000150 0.6115E-03 0.2280E-03 0.6122E-03 0.7955E-04 0.0000E+00
0000151 0.6098E-03 0.2280E-03 0.6104E-03 0.1097E-03 0.0000E+00
0000152 0.6143E-03 0.2361E-03 0.6148E-03 0.1648E-03 0.0000E+00
0000153 0.6327E-03 0.2630E-03 0.6330E-03 0.2129E-03 0.0000E+00
0000154 0.6718E-03 0.2269E-03 0.6718E-03 0.9835E-04 0.0000E+00
0000155 0.5767E-03 0.2504E-03 0.5773E-03 0.4277E-04 0.0000E+00
0000156 0.5736E-03 0.2135E-03 0.5741E-03 0.7934E-04 0.0000E+00
0000157 0.5713E-03 0.2131E-03 0.5718E-03 0.9365E-04 0.0000E+00
0000158 0.5745E-03 0.2184E-03 0.5750E-03 0.1485E-03 0.0000E+00
0000159 0.5889E-03 0.2405E-03 0.5892E-03 0.1814E-03 0.0000E+00
0000160 0.6221E-03 0.2109E-03 0.6221E-03 0.8473E-04 0.0000E+00
0000161 0.5414E-03 0.2309E-03 0.5418E-03 0.3557E-04 0.0000E+00
0000162 0.5381E-03 0.2001E-03 0.5386E-03 0.7318E-04 0.0000E+00
0000163 0.5353E-03 0.1994E-03 0.5358E-03 0.7973E-04 0.0000E+00
0000164 0.5370E-03 0.2028E-03 0.5375E-03 0.1300E-03 0.0000E+00
0000165 0.5474E-03 0.2199E-03 0.5477E-03 0.1538E-03 0.0000E+00
0000166 0.5737E-03 0.1966E-03 0.5738E-03 0.7252E-04 0.0000E+00
0000167 0.5084E-03 0.2123E-03 0.5089E-03 0.3004E-04 0.0000E+00
0000168 0.5050E-03 0.1878E-03 0.5054E-03 0.6436E-04 0.0000E+00
0000169 0.5019E-03 0.1868E-03 0.5023E-03 0.6726E-04 0.0000E+00
0000170 0.5024E-03 0.1889E-03 0.5027E-03 0.1115E-03 0.0000E+00
0000171 0.5095E-03 0.2018E-03 0.5098E-03 0.1295E-03 0.0000E+00
0000172 0.5296E-03 0.1836E-03 0.5298E-03 0.6188E-04 0.0000E+00
0000173 0.4777E-03 0.1957E-03 0.4781E-03 0.2550E-04 0.0000E+00
0000174 0.4742E-03 0.1763E-03 0.4746E-03 0.5548E-04 0.0000E+00
0000175 0.4710E-03 0.1752E-03 0.4713E-03 0.5675E-04 0.0000E+00
0000176 0.4704E-03 0.1764E-03 0.4708E-03 0.9496E-04 0.0000E+00
0000177 0.4750E-03 0.1859E-03 0.4753E-03 0.1337E-03 0.0000E+00
0000178 0.4930E-03 0.2079E-03 0.4932E-03 0.4391E-04 0.0000E+00
0000179 0.4493E-03 0.1693E-03 0.4496E-03 0.3742E-04 0.0000E+00
0000180 0.4458E-03 0.1689E-03 0.4462E-03 0.6682E-04 0.0000E+00
0000181 0.4435E-03 0.1715E-03 0.4438E-03 0.7805E-04 0.0000E+00
0000182 0.4455E-03 0.1794E-03 0.4458E-03 0.1020E-03 0.0000E+00
0000183 0.4540E-03 0.1630E-03 0.4543E-03 0.1249E-03 0.0000E+00
0000184 0.4746E-03 0.1776E-03 0.4748E-03 0.4554E-04 0.0000E+00
0000185 0.4227E-03 0.1588E-03 0.4230E-03 0.2914E-04 0.0000E+00
0000186 0.4191E-03 0.1599E-03 0.4194E-03 0.6642E-04 0.0000E+00
0000187 0.4168E-03 0.1626E-03 0.4171E-03 0.7010E-04 0.0000E+00
0000188 0.4185E-03 0.1712E-03 0.4188E-03 0.9635E-04 0.0000E+00
0000189 0.4261E-03 0.1531E-03 0.4263E-03 0.1137E-03 0.0000E+00
0000190 0.4445E-03 0.1665E-03 0.4446E-03 0.4378E-04 0.0000E+00
0000191 0.3977E-03 0.1492E-03 0.3979E-03 0.2408E-04 0.0000E+00
0000192 0.3943E-03 0.1503E-03 0.3945E-03 0.6230E-04 0.0000E+00
0000193 0.3920E-03 0.1525E-03 0.3923E-03 0.6226E-04 0.0000E+00
0000194 0.3933E-03 0.1603E-03 0.3935E-03 0.8894E-04 0.0000E+00
0000195 0.3998E-03 0.1438E-03 0.3999E-03 0.1031E-03 0.0000E+00
0000196 0.4158E-03 0.1557E-03 0.4159E-03 0.4061E-04 0.0000E+00
0000197 0.3742E-03 0.1403E-03 0.3744E-03 0.2071E-04 0.0000E+00
0000198 0.3710E-03 0.1412E-03 0.3712E-03 0.5712E-04 0.0000E+00
0000199 0.3688E-03 0.1431E-03 0.3690E-03 0.5552E-04 0.0000E+00
0000200 0.3696E-03 0.1502E-03 0.3698E-03 0.8150E-04 0.0000E+00
0000201 0.3751E-03 0.1352E-03 0.3752E-03 0.9356E-04 0.0000E+00
0000202 0.3890E-03 0.1456E-03 0.3891E-03 0.3714E-04 0.0000E+00
0000203 0.3522E-03 0.1320E-03 0.3524E-03 0.1826E-04 0.0000E+00
0000204 0.3492E-03 0.1327E-03 0.3493E-03 0.5202E-04 0.0000E+00
0000205 0.3470E-03 0.1344E-03 0.3471E-03 0.4991E-04 0.0000E+00
0000206 0.3475E-03 0.1406E-03 0.3477E-03 0.7452E-04 0.0000E+00
0000207 0.3521E-03 0.1272E-03 0.3522E-03 0.8515E-04 0.0000E+00
0000208 0.3642E-03 0.1363E-03 0.3642E-03 0.3380E-04 0.0000E+00
0000209 0.3316E-03 0.1242E-03 0.3317E-03 0.1633E-04 0.0000E+00
0000210 0.3287E-03 0.1248E-03 0.3288E-03 0.4733E-04 0.0000E+00
0000211 0.3265E-03 0.1262E-03 0.3267E-03 0.4520E-04 0.0000E+00
0000212 0.3269E-03 0.1318E-03 0.3270E-03 0.6826E-04 0.0000E+00
0000213 0.3307E-03 0.1197E-03 0.3308E-03 0.7786E-04 0.0000E+00
0000214 0.3413E-03 0.1278E-03 0.3413E-03 0.1209E-03 0.0000E+00
0000215 0.3624E-03 0.1207E-03 0.3624E-03 0.4753E-04 0.0000E+00
0000216 0.3094E-03 0.1352E-03 0.3095E-03 0.2928E-04 0.0000E+00
0000217 0.3079E-03 0.1144E-03 0.3081E-03 0.4019E-04 0.0000E+00
0000218 0.3072E-03 0.1143E-03 0.3073E-03 0.5720E-04 0.0000E+00
0000219 0.3095E-03 0.1178E-03 0.3096E-03 0.8150E-04 0.0000E+00
0000220 0.3186E-03 0.1312E-03 0.3187E-03 0.1088E-03 0.0000E+00
0000221 0.3382E-03 0.1136E-03 0.3381E-03 0.4429E-04 0.0000E+00
0000222 0.2914E-03 0.1261E-03 0.2915E-03 0.2233E-04 0.0000E+00
0000223 0.2899E-03 0.1077E-03 0.2900E-03 0.4024E-04 0.0000E+00
0000224 0.2889E-03 0.1076E-03 0.2890E-03 0.4806E-04 0.0000E+00
0000225 0.2907E-03 0.1102E-03 0.2907E-03 0.7508E-04 0.0000E+00
0000226 0.2981E-03 0.1214E-03 0.2981E-03 0.9334E-04 0.0000E+00
0000227 0.3151E-03 0.1066E-03 0.3151E-03 0.4049E-04 0.0000E+00
0000228 0.2744E-03 0.1172E-03 0.2745E-03 0.1845E-04 0.0000E+00
0000229 0.2729E-03 0.1015E-03 0.2730E-03 0.3757E-04 0.0000E+00
0000230 0.2717E-03 0.1012E-03 0.2718E-03 0.4122E-04 0.0000E+00
0000231 0.2729E-03 0.1031E-03 0.2729E-03 0.6738E-04 0.0000E+00
0000232 0.2786E-03 0.1123E-03 0.2786E-03 0.8076E-04 0.0000E+00
0000233 0.2928E-03 0.1000E-03 0.2927E-03 0.3621E-04 0.0000E+00
0000234 0.2585E-03 0.1088E-03 0.2586E-03 0.1567E-04 0.0000E+00
0000235 0.2570E-03 0.9566E-04 0.2570E-03 0.3375E-04 0.0000E+00
0000236 0.2556E-03 0.9529E-04 0.2557E-03 0.3549E-04 0.0000E+00
0000237 0.2562E-03 0.9664E-04 0.2563E-03 0.5946E-04 0.0000E+00
0000238 0.2606E-03 0.1040E-03 0.2606E-03 0.6992E-04 0.0000E+00
0000239 0.2722E-03 0.9395E-04 0.2722E-03 0.3214E-04 0.0000E+00
0000240 0.2436E-03 0.1011E-03 0.2436E-03 0.1355E-04 0.0000E+00
0000241 0.2420E-03 0.9017E-04 0.2420E-03 0.2990E-04 0.0000E+00
0000242 0.2405E-03 0.8973E-04 0.2406E-03 0.3083E-04 0.0000E+00
0000243 0.2407E-03 0.9069E-04 0.2408E-03 0.5231E-04 0.0000E+00
0000244 0.2440E-03 0.9658E-04 0.2440E-03 0.6096E-04 0.0000E+00
0000245 0.2534E-03 0.8830E-04 0.2534E-03 0.2845E-04 0.0000E+00
0000246 0.2295E-03 0.9407E-04 0.2295E-03 0.1181E-04 0.0000E+00
0000247 0.2279E-03 0.8500E-04 0.2279E-03 0.2636E-04 0.0000E+00
0000248 0.2264E-03 0.8453E-04 0.2265E-03 0.2693E-04 0.0000E+00
0000249 0.2263E-03 0.8520E-04 0.2263E-03 0.4602E-04 0.0000E+00
0000250 0.2287E-03 0.8995E-04 0.2287E-03 0.6504E-04 0.0000E+00
0000251 0.2379E-03 0.1012E-03 0.2379E-03 0.2121E-04 0.0000E+00
0000252 0.2164E-03 0.8187E-04 0.2164E-03 0.1794E-04 0.0000E+00
0000253 0.2148E-03 0.8184E-04 0.2149E-03 0.3297E-04 0.0000E+00
0000254 0.2139E-03 0.8340E-04 0.2139E-03 0.3899E-04 0.0000E+00
0000255 0.2152E-03 0.8784E-04 0.2153E-03 0.5174E-04 0.0000E+00
0000256 0.2202E-03 0.7910E-04 0.2202E-03 0.6376E-04 0.0000E+00
0000257 0.2314E-03 0.8696E-04 0.2314E-03 0.2270E-04 0.0000E+00
0000258 0.2040E-03 0.7713E-04 0.2040E-03 0.1473E-04 0.0000E+00
0000259 0.2024E-03 0.7794E-04 0.2025E-03 0.3393E-04 0.0000E+00
0000260 0.2016E-03 0.7966E-04 0.2016E-03 0.3651E-04 0.0000E+00
0000261 0.2030E-03 0.8472E-04 0.2030E-03 0.5052E-04 0.0000E+00
0000262 0.2078E-03 0.7458E-04 0.2078E-03 0.6018E-04 0.0000E+00
0000263 0.2186E-03 0.8236E-04 0.2186E-03 0.2258E-04 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 12
0000264 0.1924E-03 0.7272E-04 0.1924E-03 0.1272E-04 0.0000E+00
0000265 0.1909E-03 0.7356E-04 0.1909E-03 0.3295E-04 0.0000E+00
0000266 0.1900E-03 0.7515E-04 0.1901E-03 0.3372E-04 0.0000E+00
0000267 0.1914E-03 0.8008E-04 0.1914E-03 0.4828E-04 0.0000E+00
0000268 0.1960E-03 0.7030E-04 0.1959E-03 0.5657E-04 0.0000E+00
0000269 0.2061E-03 0.7768E-04 0.2061E-03 0.2168E-04 0.0000E+00
0000270 0.1813E-03 0.6858E-04 0.1813E-03 0.1138E-04 0.0000E+00
0000271 0.1799E-03 0.6940E-04 0.1799E-03 0.3127E-04 0.0000E+00
0000272 0.1792E-03 0.7089E-04 0.1792E-03 0.3119E-04 0.0000E+00
0000273 0.1804E-03 0.7561E-04 0.1804E-03 0.4571E-04 0.0000E+00
0000274 0.1847E-03 0.6630E-04 0.1847E-03 0.5304E-04 0.0000E+00
0000275 0.1942E-03 0.7325E-04 0.1942E-03 0.2051E-04 0.0000E+00
0000276 0.1710E-03 0.6469E-04 0.1710E-03 0.1040E-04 0.0000E+00
0000277 0.1697E-03 0.6547E-04 0.1697E-03 0.2944E-04 0.0000E+00
0000278 0.1689E-03 0.6687E-04 0.1689E-03 0.2900E-04 0.0000E+00
0000279 0.1701E-03 0.7134E-04 0.1701E-03 0.4312E-04 0.0000E+00
0000280 0.1741E-03 0.6254E-04 0.1741E-03 0.4978E-04 0.0000E+00
0000281 0.1830E-03 0.6904E-04 0.1829E-03 0.1928E-04 0.0000E+00
0000282 0.1612E-03 0.6103E-04 0.1612E-03 0.9614E-05 0.0000E+00
0000283 0.1600E-03 0.6176E-04 0.1600E-03 0.2765E-04 0.0000E+00
0000284 0.1593E-03 0.6308E-04 0.1593E-03 0.2709E-04 0.0000E+00
0000285 0.1604E-03 0.6731E-04 0.1604E-03 0.4065E-04 0.0000E+00
0000286 0.1641E-03 0.5899E-04 0.1641E-03 0.4681E-04 0.0000E+00
0000287 0.1724E-03 0.6510E-04 0.1724E-03 0.1810E-04 0.0000E+00
0000288 0.1520E-03 0.5759E-04 0.1520E-03 0.8957E-05 0.0000E+00
0000289 0.1509E-03 0.5827E-04 0.1508E-03 0.2598E-04 0.0000E+00
0000290 0.1502E-03 0.5952E-04 0.1502E-03 0.2541E-04 0.0000E+00
0000291 0.1512E-03 0.6352E-04 0.1512E-03 0.3837E-04 0.0000E+00
0000292 0.1547E-03 0.5566E-04 0.1547E-03 0.4414E-04 0.0000E+00
0000293 0.1626E-03 0.6141E-04 0.1625E-03 0.1701E-04 0.0000E+00
0000294 0.1434E-03 0.5434E-04 0.1434E-03 0.8394E-05 0.0000E+00
0000295 0.1423E-03 0.5498E-04 0.1423E-03 0.2445E-04 0.0000E+00
0000296 0.1416E-03 0.5618E-04 0.1416E-03 0.2393E-04 0.0000E+00
0000297 0.1426E-03 0.5998E-04 0.1426E-03 0.3628E-04 0.0000E+00
0000298 0.1459E-03 0.5252E-04 0.1459E-03 0.4171E-04 0.0000E+00
0000299 0.1534E-03 0.5795E-04 0.1533E-03 0.1601E-04 0.0000E+00
0000300 0.1352E-03 0.5128E-04 0.1352E-03 0.7902E-05 0.0000E+00
0000301 0.1342E-03 0.5189E-04 0.1342E-03 0.2307E-04 0.0000E+00
0000302 0.1336E-03 0.5304E-04 0.1336E-03 0.2260E-04 0.0000E+00
0000303 0.1346E-03 0.5666E-04 0.1345E-03 0.3436E-04 0.0000E+00
0000304 0.1377E-03 0.4956E-04 0.1377E-03 0.3952E-04 0.0000E+00
0000305 0.1447E-03 0.5472E-04 0.1447E-03 0.1511E-04 0.0000E+00
0000306 0.1275E-03 0.4840E-04 0.1275E-03 0.7464E-05 0.0000E+00
0000307 0.1266E-03 0.4898E-04 0.1265E-03 0.2181E-04 0.0000E+00
0000308 0.1260E-03 0.5008E-04 0.1260E-03 0.2141E-04 0.0000E+00
0000309 0.1270E-03 0.5355E-04 0.1269E-03 0.3261E-04 0.0000E+00
0000310 0.1300E-03 0.4678E-04 0.1299E-03 0.3751E-04 0.0000E+00
0000311 0.1367E-03 0.5169E-04 0.1367E-03 0.1429E-04 0.0000E+00
0000312 0.1203E-03 0.4568E-04 0.1203E-03 0.7069E-05 0.0000E+00
0000313 0.1194E-03 0.4624E-04 0.1194E-03 0.2067E-04 0.0000E+00
0000314 0.1189E-03 0.4731E-04 0.1189E-03 0.2032E-04 0.0000E+00
0000315 0.1198E-03 0.5063E-04 0.1198E-03 0.3100E-04 0.0000E+00
0000316 0.1227E-03 0.4415E-04 0.1227E-03 0.3566E-04 0.0000E+00
0000317 0.1291E-03 0.4885E-04 0.1291E-03 0.1354E-04 0.0000E+00
0000318 0.1135E-03 0.4311E-04 0.1135E-03 0.6708E-05 0.0000E+00
0000319 0.1126E-03 0.4366E-04 0.1126E-03 0.1962E-04 0.0000E+00
0000320 0.1122E-03 0.4469E-04 0.1122E-03 0.1932E-04 0.0000E+00
0000321 0.1131E-03 0.4788E-04 0.1130E-03 0.2950E-04 0.0000E+00
0000322 0.1159E-03 0.4167E-04 0.1158E-03 0.3395E-04 0.0000E+00
0000323 0.1220E-03 0.4618E-04 0.1220E-03 0.1285E-04 0.0000E+00
0000324 0.1071E-03 0.4069E-04 0.1070E-03 0.6374E-05 0.0000E+00
0000325 0.1063E-03 0.4123E-04 0.1062E-03 0.1865E-04 0.0000E+00
0000326 0.1058E-03 0.4223E-04 0.1058E-03 0.1838E-04 0.0000E+00
0000327 0.1067E-03 0.4530E-04 0.1067E-03 0.2811E-04 0.0000E+00
0000328 0.1094E-03 0.3934E-04 0.1094E-03 0.3234E-04 0.0000E+00
0000329 0.1154E-03 0.4367E-04 0.1154E-03 0.1221E-04 0.0000E+00
0000330 0.1010E-03 0.3841E-04 0.1010E-03 0.6064E-05 0.0000E+00
0000331 0.1003E-03 0.3893E-04 0.1002E-03 0.1775E-04 0.0000E+00
0000332 0.9987E-04 0.3990E-04 0.9986E-04 0.1751E-04 0.0000E+00
0000333 0.1007E-03 0.4286E-04 0.1007E-03 0.2680E-04 0.0000E+00
0000334 0.1034E-03 0.3714E-04 0.1034E-03 0.3083E-04 0.0000E+00
0000335 0.1091E-03 0.4131E-04 0.1091E-03 0.1161E-04 0.0000E+00
0000336 0.9530E-04 0.3626E-04 0.9529E-04 0.5772E-05 0.0000E+00
0000337 0.9460E-04 0.3677E-04 0.9459E-04 0.1690E-04 0.0000E+00
0000338 0.9425E-04 0.3771E-04 0.9424E-04 0.1669E-04 0.0000E+00
0000339 0.9511E-04 0.4056E-04 0.9511E-04 0.2556E-04 0.0000E+00
0000340 0.9766E-04 0.3506E-04 0.9765E-04 0.2939E-04 0.0000E+00
0000341 0.1032E-03 0.3907E-04 0.1032E-03 0.1105E-04 0.0000E+00
0000342 0.8993E-04 0.3423E-04 0.8992E-04 0.5496E-05 0.0000E+00
0000343 0.8927E-04 0.3473E-04 0.8926E-04 0.1610E-04 0.0000E+00
0000344 0.8896E-04 0.3564E-04 0.8895E-04 0.1591E-04 0.0000E+00
0000345 0.8981E-04 0.3838E-04 0.8980E-04 0.2438E-04 0.0000E+00
0000346 0.9228E-04 0.3309E-04 0.9227E-04 0.2803E-04 0.0000E+00
0000347 0.9759E-04 0.3696E-04 0.9758E-04 0.1052E-04 0.0000E+00
0000348 0.8486E-04 0.3231E-04 0.8485E-04 0.5234E-05 0.0000E+00
0000349 0.8425E-04 0.3280E-04 0.8424E-04 0.1534E-04 0.0000E+00
0000350 0.8397E-04 0.3368E-04 0.8396E-04 0.1516E-04 0.0000E+00
0000351 0.8480E-04 0.3633E-04 0.8480E-04 0.2326E-04 0.0000E+00
0000352 0.8720E-04 0.3124E-04 0.8719E-04 0.2673E-04 0.0000E+00
0000353 0.9232E-04 0.3497E-04 0.9231E-04 0.1002E-04 0.0000E+00
0000354 0.8009E-04 0.3050E-04 0.8008E-04 0.4984E-05 0.0000E+00
0000355 0.7951E-04 0.3097E-04 0.7951E-04 0.1462E-04 0.0000E+00
0000356 0.7926E-04 0.3184E-04 0.7925E-04 0.1445E-04 0.0000E+00
0000357 0.8008E-04 0.3438E-04 0.8008E-04 0.2218E-04 0.0000E+00
0000358 0.8240E-04 0.2950E-04 0.8240E-04 0.2548E-04 0.0000E+00
0000359 0.8733E-04 0.3308E-04 0.8732E-04 0.9537E-05 0.0000E+00
0000360 0.7559E-04 0.2879E-04 0.7558E-04 0.4745E-05 0.0000E+00
0000361 0.7505E-04 0.2925E-04 0.7505E-04 0.1393E-04 0.0000E+00
0000362 0.7482E-04 0.3009E-04 0.7482E-04 0.1377E-04 0.0000E+00
0000363 0.7563E-04 0.3254E-04 0.7563E-04 0.2115E-04 0.0000E+00
0000364 0.7788E-04 0.2785E-04 0.7787E-04 0.2428E-04 0.0000E+00
0000365 0.8261E-04 0.3130E-04 0.8261E-04 0.9080E-05 0.0000E+00
0000366 0.7135E-04 0.2718E-04 0.7134E-04 0.4517E-05 0.0000E+00
0000367 0.7084E-04 0.2763E-04 0.7084E-04 0.1327E-04 0.0000E+00
0000368 0.7064E-04 0.2844E-04 0.7064E-04 0.1311E-04 0.0000E+00
0000369 0.7143E-04 0.3079E-04 0.7143E-04 0.2016E-04 0.0000E+00
0000370 0.7360E-04 0.2629E-04 0.7360E-04 0.2313E-04 0.0000E+00
0000371 0.7815E-04 0.2961E-04 0.7815E-04 0.8641E-05 0.0000E+00
0000372 0.6735E-04 0.2566E-04 0.6735E-04 0.4297E-05 0.0000E+00
0000373 0.6688E-04 0.2609E-04 0.6688E-04 0.1263E-04 0.0000E+00
0000374 0.6669E-04 0.2687E-04 0.6669E-04 0.1249E-04 0.0000E+00
0000375 0.6747E-04 0.2913E-04 0.6747E-04 0.1920E-04 0.0000E+00
0000376 0.6957E-04 0.2482E-04 0.6957E-04 0.2202E-04 0.0000E+00
0000377 0.7393E-04 0.2801E-04 0.7393E-04 0.8222E-05 0.0000E+00
0000378 0.6358E-04 0.2422E-04 0.6358E-04 0.4087E-05 0.0000E+00
0000379 0.6314E-04 0.2464E-04 0.6314E-04 0.1202E-04 0.0000E+00
0000380 0.6297E-04 0.2539E-04 0.6298E-04 0.1188E-04 0.0000E+00
0000381 0.6373E-04 0.2756E-04 0.6373E-04 0.1829E-04 0.0000E+00
0000382 0.6575E-04 0.2343E-04 0.6575E-04 0.2096E-04 0.0000E+00
0000383 0.6994E-04 0.2649E-04 0.6994E-04 0.7819E-05 0.0000E+00
0000384 0.6003E-04 0.2286E-04 0.6003E-04 0.3885E-05 0.0000E+00
0000385 0.5961E-04 0.2327E-04 0.5962E-04 0.1144E-04 0.0000E+00
0000386 0.5946E-04 0.2400E-04 0.5947E-04 0.1130E-04 0.0000E+00
0000387 0.6020E-04 0.2607E-04 0.6021E-04 0.1740E-04 0.0000E+00
0000388 0.6215E-04 0.2212E-04 0.6215E-04 0.1993E-04 0.0000E+00
0000389 0.6615E-04 0.2505E-04 0.6616E-04 0.7433E-05 0.0000E+00
0000390 0.5668E-04 0.2158E-04 0.5668E-04 0.3692E-05 0.0000E+00
0000391 0.5629E-04 0.2197E-04 0.5629E-04 0.1088E-04 0.0000E+00
0000392 0.5616E-04 0.2267E-04 0.5616E-04 0.1075E-04 0.0000E+00
0000393 0.5687E-04 0.2466E-04 0.5688E-04 0.1655E-04 0.0000E+00
0000394 0.5874E-04 0.2088E-04 0.5875E-04 0.1895E-04 0.0000E+00
0000395 0.6257E-04 0.2369E-04 0.6258E-04 0.7064E-05 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 13
0000396 0.5352E-04 0.2037E-04 0.5352E-04 0.3507E-05 0.0000E+00
0000397 0.5315E-04 0.2075E-04 0.5316E-04 0.1034E-04 0.0000E+00
0000398 0.5304E-04 0.2142E-04 0.5304E-04 0.1021E-04 0.0000E+00
0000399 0.5373E-04 0.2332E-04 0.5374E-04 0.1574E-04 0.0000E+00
0000400 0.5552E-04 0.1971E-04 0.5553E-04 0.1801E-04 0.0000E+00
0000401 0.5918E-04 0.2240E-04 0.5919E-04 0.6710E-05 0.0000E+00
0000402 0.5054E-04 0.1923E-04 0.5055E-04 0.3330E-05 0.0000E+00
0000403 0.5020E-04 0.1959E-04 0.5021E-04 0.9820E-05 0.0000E+00
0000404 0.5009E-04 0.2024E-04 0.5010E-04 0.9699E-05 0.0000E+00
0000405 0.5076E-04 0.2205E-04 0.5077E-04 0.1496E-04 0.0000E+00
0000406 0.5248E-04 0.1860E-04 0.5249E-04 0.1710E-04 0.0000E+00
0000407 0.5598E-04 0.2117E-04 0.5598E-04 0.6371E-05 0.0000E+00
0000408 0.4773E-04 0.1815E-04 0.4774E-04 0.3160E-05 0.0000E+00
0000409 0.4741E-04 0.1850E-04 0.4742E-04 0.9325E-05 0.0000E+00
0000410 0.4732E-04 0.1912E-04 0.4733E-04 0.9208E-05 0.0000E+00
0000411 0.4796E-04 0.2085E-04 0.4797E-04 0.1421E-04 0.0000E+00
0000412 0.4960E-04 0.1756E-04 0.4962E-04 0.1624E-04 0.0000E+00
0000413 0.5294E-04 0.2001E-04 0.5295E-04 0.6046E-05 0.0000E+00
0000414 0.4508E-04 0.1713E-04 0.4509E-04 0.2998E-05 0.0000E+00
0000415 0.4478E-04 0.1747E-04 0.4480E-04 0.8852E-05 0.0000E+00
0000416 0.4470E-04 0.1806E-04 0.4471E-04 0.8738E-05 0.0000E+00
0000417 0.4532E-04 0.1971E-04 0.4533E-04 0.1349E-04 0.0000E+00
0000418 0.4689E-04 0.1657E-04 0.4690E-04 0.1541E-04 0.0000E+00
0000419 0.5007E-04 0.1892E-04 0.5008E-04 0.5737E-05 0.0000E+00
0000420 0.4258E-04 0.1617E-04 0.4260E-04 0.2843E-05 0.0000E+00
0000421 0.4230E-04 0.1649E-04 0.4232E-04 0.8399E-05 0.0000E+00
0000422 0.4223E-04 0.1705E-04 0.4224E-04 0.8289E-05 0.0000E+00
0000423 0.4282E-04 0.1863E-04 0.4284E-04 0.1280E-04 0.0000E+00
0000424 0.4432E-04 0.1564E-04 0.4434E-04 0.1462E-04 0.0000E+00
0000425 0.4735E-04 0.1788E-04 0.4736E-04 0.5441E-05 0.0000E+00
0000426 0.4023E-04 0.1526E-04 0.4024E-04 0.2695E-05 0.0000E+00
0000427 0.3996E-04 0.1557E-04 0.3998E-04 0.7967E-05 0.0000E+00
0000428 0.3989E-04 0.1611E-04 0.3991E-04 0.7861E-05 0.0000E+00
0000429 0.4047E-04 0.1761E-04 0.4048E-04 0.1214E-04 0.0000E+00
0000430 0.4190E-04 0.1477E-04 0.4191E-04 0.1386E-04 0.0000E+00
0000431 0.4478E-04 0.1690E-04 0.4479E-04 0.5159E-05 0.0000E+00
0000432 0.3801E-04 0.1440E-04 0.3802E-04 0.2555E-05 0.0000E+00
0000433 0.3776E-04 0.1470E-04 0.3778E-04 0.7554E-05 0.0000E+00
0000434 0.3770E-04 0.1521E-04 0.3771E-04 0.7453E-05 0.0000E+00
0000435 0.3824E-04 0.1664E-04 0.3826E-04 0.1152E-04 0.0000E+00
0000436 0.3961E-04 0.1394E-04 0.3963E-04 0.1314E-04 0.0000E+00
0000437 0.4235E-04 0.1597E-04 0.4236E-04 0.4890E-05 0.0000E+00
0000438 0.3591E-04 0.1359E-04 0.3593E-04 0.2421E-05 0.0000E+00
0000439 0.3568E-04 0.1387E-04 0.3570E-04 0.7161E-05 0.0000E+00
0000440 0.3562E-04 0.1436E-04 0.3564E-04 0.7063E-05 0.0000E+00
0000441 0.3615E-04 0.1572E-04 0.3617E-04 0.1092E-04 0.0000E+00
0000442 0.3745E-04 0.1315E-04 0.3746E-04 0.1246E-04 0.0000E+00
0000443 0.4005E-04 0.1509E-04 0.4007E-04 0.4634E-05 0.0000E+00
0000444 0.3394E-04 0.1283E-04 0.3396E-04 0.2293E-05 0.0000E+00
0000445 0.3372E-04 0.1310E-04 0.3374E-04 0.6787E-05 0.0000E+00
0000446 0.3367E-04 0.1356E-04 0.3369E-04 0.6693E-05 0.0000E+00
0000447 0.3417E-04 0.1486E-04 0.3419E-04 0.1035E-04 0.0000E+00
0000448 0.3540E-04 0.1241E-04 0.3542E-04 0.1181E-04 0.0000E+00
0000449 0.3788E-04 0.1425E-04 0.3789E-04 0.4390E-05 0.0000E+00
0000450 0.3207E-04 0.1210E-04 0.3209E-04 0.2172E-05 0.0000E+00
0000451 0.3187E-04 0.1236E-04 0.3189E-04 0.6430E-05 0.0000E+00
0000452 0.3182E-04 0.1281E-04 0.3184E-04 0.6340E-05 0.0000E+00
0000453 0.3230E-04 0.1404E-04 0.3232E-04 0.9806E-05 0.0000E+00
0000454 0.3347E-04 0.1172E-04 0.3349E-04 0.1119E-04 0.0000E+00
0000455 0.3582E-04 0.1346E-04 0.3584E-04 0.4158E-05 0.0000E+00
0000456 0.3031E-04 0.1142E-04 0.3034E-04 0.2057E-05 0.0000E+00
0000457 0.3012E-04 0.1167E-04 0.3014E-04 0.6091E-05 0.0000E+00
0000458 0.3008E-04 0.1209E-04 0.3010E-04 0.6005E-05 0.0000E+00
0000459 0.3053E-04 0.1326E-04 0.3056E-04 0.9291E-05 0.0000E+00
0000460 0.3165E-04 0.1106E-04 0.3167E-04 0.1060E-04 0.0000E+00
0000461 0.3388E-04 0.1272E-04 0.3390E-04 0.3939E-05 0.0000E+00
0000462 0.2866E-04 0.1078E-04 0.2868E-04 0.1948E-05 0.0000E+00
0000463 0.2847E-04 0.1102E-04 0.2850E-04 0.5769E-05 0.0000E+00
0000464 0.2844E-04 0.1142E-04 0.2846E-04 0.5687E-05 0.0000E+00
0000465 0.2887E-04 0.1253E-04 0.2889E-04 0.8801E-05 0.0000E+00
0000466 0.2993E-04 0.1044E-04 0.2995E-04 0.1004E-04 0.0000E+00
0000467 0.3205E-04 0.1202E-04 0.3207E-04 0.3730E-05 0.0000E+00
0000468 0.2709E-04 0.1017E-04 0.2712E-04 0.1845E-05 0.0000E+00
0000469 0.2692E-04 0.1040E-04 0.2695E-04 0.5464E-05 0.0000E+00
0000470 0.2689E-04 0.1078E-04 0.2691E-04 0.5385E-05 0.0000E+00
0000471 0.2730E-04 0.1183E-04 0.2732E-04 0.8336E-05 0.0000E+00
0000472 0.2831E-04 0.9849E-05 0.2833E-04 0.9504E-05 0.0000E+00
0000473 0.3031E-04 0.1135E-04 0.3033E-04 0.3532E-05 0.0000E+00
0000474 0.2562E-04 0.9601E-05 0.2564E-04 0.1746E-05 0.0000E+00
0000475 0.2545E-04 0.9814E-05 0.2548E-04 0.5174E-05 0.0000E+00
0000476 0.2542E-04 0.1018E-04 0.2545E-04 0.5099E-05 0.0000E+00
0000477 0.2582E-04 0.1118E-04 0.2584E-04 0.7895E-05 0.0000E+00
0000478 0.2677E-04 0.9295E-05 0.2680E-04 0.9000E-05 0.0000E+00
0000479 0.2867E-04 0.1072E-04 0.2870E-04 0.3344E-05 0.0000E+00
0000480 0.2422E-04 0.9060E-05 0.2425E-04 0.1653E-05 0.0000E+00
0000481 0.2407E-04 0.9262E-05 0.2410E-04 0.4899E-05 0.0000E+00
0000482 0.2404E-04 0.9610E-05 0.2407E-04 0.4828E-05 0.0000E+00
0000483 0.2442E-04 0.1056E-04 0.2444E-04 0.7476E-05 0.0000E+00
0000484 0.2533E-04 0.8772E-05 0.2535E-04 0.8523E-05 0.0000E+00
0000485 0.2713E-04 0.1013E-04 0.2715E-04 0.3166E-05 0.0000E+00
0000486 0.2291E-04 0.8549E-05 0.2294E-04 0.1565E-05 0.0000E+00
0000487 0.2277E-04 0.8742E-05 0.2279E-04 0.4638E-05 0.0000E+00
0000488 0.2274E-04 0.9073E-05 0.2277E-04 0.4570E-05 0.0000E+00
0000489 0.2310E-04 0.9973E-05 0.2312E-04 0.7079E-05 0.0000E+00
0000490 0.2396E-04 0.8278E-05 0.2398E-04 0.8070E-05 0.0000E+00
0000491 0.2567E-04 0.9566E-05 0.2569E-04 0.2997E-05 0.0000E+00
0000492 0.2167E-04 0.8068E-05 0.2170E-04 0.1482E-05 0.0000E+00
0000493 0.2154E-04 0.8251E-05 0.2156E-04 0.4391E-05 0.0000E+00
0000494 0.2151E-04 0.8566E-05 0.2154E-04 0.4327E-05 0.0000E+00
0000495 0.2185E-04 0.9420E-05 0.2188E-04 0.6703E-05 0.0000E+00
0000496 0.2267E-04 0.7812E-05 0.2269E-04 0.7641E-05 0.0000E+00
0000497 0.2429E-04 0.9036E-05 0.2431E-04 0.2837E-05 0.0000E+00
0000498 0.2050E-04 0.7613E-05 0.2053E-04 0.1403E-05 0.0000E+00
0000499 0.2037E-04 0.7787E-05 0.2040E-04 0.4157E-05 0.0000E+00
0000500 0.2035E-04 0.8087E-05 0.2038E-04 0.4096E-05 0.0000E+00
0000501 0.2067E-04 0.8897E-05 0.2070E-04 0.6347E-05 0.0000E+00
0000502 0.2145E-04 0.7372E-05 0.2147E-04 0.5131E-05 0.0000E+00
0000503 0.1955E-04 0.8178E-05 0.2257E-04 0.2567E-05 0.0000E+00
0000504 0.1972E-04 0.7106E-05 0.1942E-04 0.2393E-05 0.0000E+00
0000505 0.1983E-04 0.7233E-05 0.1927E-04 0.4170E-05 0.0000E+00
0000506 0.2021E-04 0.7619E-05 0.1933E-04 0.4282E-05 0.0000E+00
0000507 0.2102E-04 0.7013E-05 0.1986E-04 0.5020E-05 0.0000E+00
0000508 0.1868E-04 0.7610E-05 0.2058E-04 0.1450E-05 0.0000E+00
0000509 0.1873E-04 0.6772E-05 0.1854E-04 0.2447E-05 0.0000E+00
0000510 0.1875E-04 0.6832E-05 0.1839E-04 0.2730E-05 0.0000E+00
0000511 0.1900E-04 0.7131E-05 0.1841E-04 0.4694E-05 0.0000E+00
0000512 0.1968E-04 0.7953E-05 0.1881E-04 0.3936E-05 0.0000E+00
0000513 0.1784E-04 0.6592E-05 0.1949E-04 0.2154E-05 0.0000E+00
0000514 0.1786E-04 0.6816E-05 0.1770E-04 0.2863E-05 0.0000E+00
0000515 0.1793E-04 0.7138E-05 0.1759E-04 0.2937E-05 0.0000E+00
0000516 0.1822E-04 0.6350E-05 0.1768E-04 0.3848E-05 0.0000E+00
0000517 0.1881E-04 0.6694E-05 0.1810E-04 0.4680E-05 0.0000E+00
0000518 0.1704E-04 0.7557E-05 0.1881E-04 0.1663E-05 0.0000E+00
0000519 0.1716E-04 0.6159E-05 0.1691E-04 0.2344E-05 0.0000E+00
0000520 0.1723E-04 0.6224E-05 0.1680E-04 0.3035E-05 0.0000E+00
0000521 0.1756E-04 0.6572E-05 0.1688E-04 0.4017E-05 0.0000E+00
0000522 0.1822E-04 0.6059E-05 0.1734E-04 0.4249E-05 0.0000E+00
0000523 0.1628E-04 0.6591E-05 0.1798E-04 0.1496E-05 0.0000E+00
0000524 0.1633E-04 0.5850E-05 0.1616E-04 0.1919E-05 0.0000E+00
0000525 0.1636E-04 0.5913E-05 0.1603E-04 0.2683E-05 0.0000E+00
0000526 0.1658E-04 0.6175E-05 0.1605E-04 0.3907E-05 0.0000E+00
0000527 0.1720E-04 0.6930E-05 0.1642E-04 0.3700E-05 0.0000E+00
0000528 0.1555E-04 0.5695E-05 0.1700E-04 0.1737E-05 0.0000E+00
0000529 0.1557E-04 0.5899E-05 0.1543E-04 0.2645E-05 0.0000E+00
0000530 0.1564E-04 0.6178E-05 0.1534E-04 0.2484E-05 0.0000E+00
0000531 0.1589E-04 0.5494E-05 0.1543E-04 0.3540E-05 0.0000E+00
0000532 0.1642E-04 0.5809E-05 0.1581E-04 0.4142E-05 0.0000E+00
0000533 0.1486E-04 0.6586E-05 0.1643E-04 0.1563E-05 0.0000E+00
0000534 0.1497E-04 0.5324E-05 0.1475E-04 0.2018E-05 0.0000E+00
0000535 0.1505E-04 0.5387E-05 0.1466E-04 0.2800E-05 0.0000E+00
0000536 0.1534E-04 0.5702E-05 0.1473E-04 0.3534E-05 0.0000E+00
0000537 0.1594E-04 0.5245E-05 0.1516E-04 0.3896E-05 0.0000E+00
0000538 0.1420E-04 0.5726E-05 0.1572E-04 0.1300E-05 0.0000E+00
0000539 0.1425E-04 0.5059E-05 0.1410E-04 0.1760E-05 0.0000E+00
0000540 0.1428E-04 0.5119E-05 0.1399E-04 0.2364E-05 0.0000E+00
0000541 0.1449E-04 0.5364E-05 0.1402E-04 0.3549E-05 0.0000E+00
0000542 0.1506E-04 0.6048E-05 0.1436E-04 0.3335E-05 0.0000E+00
0000543 0.1357E-04 0.4928E-05 0.1488E-04 0.1587E-05 0.0000E+00
0000544 0.1360E-04 0.5116E-05 0.1347E-04 0.2345E-05 0.0000E+00
0000545 0.1366E-04 0.5372E-05 0.1340E-04 0.2262E-05 0.0000E+00
0000546 0.1390E-04 0.4752E-05 0.1348E-04 0.3161E-05 0.0000E+00
0000547 0.1438E-04 0.5046E-05 0.1383E-04 0.3758E-05 0.0000E+00
0000548 0.1297E-04 0.5749E-05 0.1440E-04 0.1391E-05 0.0000E+00
0000549 0.1308E-04 0.4604E-05 0.1288E-04 0.1824E-05 0.0000E+00
0000550 0.1316E-04 0.4665E-05 0.1281E-04 0.2500E-05 0.0000E+00
0000551 0.1343E-04 0.4956E-05 0.1288E-04 0.3179E-05 0.0000E+00
0000552 0.1397E-04 0.4540E-05 0.1327E-04 0.3507E-05 0.0000E+00
0000553 0.1240E-04 0.4980E-05 0.1378E-04 0.1176E-05 0.0000E+00
0000554 0.1246E-04 0.4374E-05 0.1232E-04 0.1571E-05 0.0000E+00
0000555 0.1249E-04 0.4432E-05 0.1223E-04 0.2131E-05 0.0000E+00
0000556 0.1268E-04 0.4658E-05 0.1225E-04 0.3170E-05 0.0000E+00
0000557 0.1320E-04 0.5279E-05 0.1257E-04 0.3009E-05 0.0000E+00
0000558 0.1186E-04 0.4264E-05 0.1305E-04 0.1415E-05 0.0000E+00
0000559 0.1189E-04 0.4437E-05 0.1177E-04 0.2098E-05 0.0000E+00
0000560 0.1195E-04 0.4669E-05 0.1171E-04 0.2021E-05 0.0000E+00
0000561 0.1217E-04 0.4110E-05 0.1180E-04 0.2829E-05 0.0000E+00
0000562 0.1260E-04 0.4382E-05 0.1211E-04 0.2860E-05 0.0000E+00
0000563 0.1134E-04 0.4067E-05 0.1254E-04 0.1439E-05 0.0000E+00
0000564 0.1136E-04 0.4270E-05 0.1126E-04 0.2012E-05 0.0000E+00
0000565 0.1141E-04 0.4511E-05 0.1120E-04 0.1920E-05 0.0000E+00
0000566 0.1162E-04 0.3914E-05 0.1129E-04 0.2665E-05 0.0000E+00
0000567 0.1203E-04 0.4169E-05 0.1159E-04 0.2727E-05 0.0000E+00
0000568 0.1084E-04 0.3876E-05 0.1200E-04 0.1371E-05 0.0000E+00
0000569 0.1086E-04 0.4076E-05 0.1077E-04 0.1969E-05 0.0000E+00
0000570 0.1092E-04 0.4306E-05 0.1072E-04 0.1850E-05 0.0000E+00
0000571 0.1112E-04 0.3730E-05 0.1080E-04 0.2566E-05 0.0000E+00
0000572 0.1151E-04 0.3976E-05 0.1110E-04 0.2597E-05 0.0000E+00
0000573 0.1037E-04 0.3696E-05 0.1149E-04 0.1344E-05 0.0000E+00
0000574 0.1039E-04 0.3891E-05 0.1030E-04 0.1897E-05 0.0000E+00
0000575 0.1045E-04 0.4116E-05 0.1025E-04 0.1780E-05 0.0000E+00
0000576 0.1064E-04 0.3553E-05 0.1034E-04 0.2468E-05 0.0000E+00
0000577 0.1101E-04 0.3792E-05 0.1063E-04 0.2494E-05 0.0000E+00
0000578 0.9922E-05 0.3523E-05 0.1101E-04 0.1295E-05 0.0000E+00
0000579 0.9947E-05 0.3714E-05 0.9860E-05 0.1841E-05 0.0000E+00
0000580 0.9999E-05 0.3930E-05 0.9811E-05 0.1716E-05 0.0000E+00
0000581 0.1019E-04 0.3385E-05 0.9894E-05 0.2379E-05 0.0000E+00
0000582 0.1055E-04 0.3617E-05 0.1018E-04 0.2392E-05 0.0000E+00
0000583 0.9494E-05 0.3359E-05 0.1055E-04 0.1258E-05 0.0000E+00
0000584 0.9519E-05 0.3545E-05 0.9436E-05 0.1778E-05 0.0000E+00
0000585 0.9571E-05 0.3755E-05 0.9390E-05 0.1653E-05 0.0000E+00
0000586 0.9755E-05 0.3225E-05 0.9472E-05 0.2291E-05 0.0000E+00
0000587 0.1010E-04 0.3451E-05 0.9746E-05 0.2300E-05 0.0000E+00
0000588 0.9086E-05 0.3201E-05 0.1011E-04 0.1215E-05 0.0000E+00
0000589 0.9112E-05 0.3383E-05 0.9032E-05 0.1719E-05 0.0000E+00
0000590 0.9163E-05 0.3586E-05 0.8988E-05 0.1592E-05 0.0000E+00
0000591 0.9341E-05 0.3073E-05 0.9069E-05 0.2207E-05 0.0000E+00
0000592 0.9679E-05 0.3293E-05 0.9336E-05 0.2209E-05 0.0000E+00
0000593 0.8696E-05 0.3051E-05 0.9688E-05 0.1176E-05 0.0000E+00
0000594 0.8723E-05 0.3228E-05 0.8646E-05 0.1111E-05 0.0000E+00
0000595 0.8756E-05 0.2926E-05 0.8594E-05 0.1255E-05 0.0000E+00
0000596 0.8855E-05 0.2972E-05 0.8607E-05 0.1978E-05 0.0000E+00
0000597 0.9121E-05 0.3217E-05 0.8789E-05 0.1879E-05 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 14
0000598 0.8325E-05 0.2894E-05 0.9055E-05 0.1063E-05 0.0000E+00
0000599 0.8330E-05 0.3009E-05 0.8276E-05 0.1374E-05 0.0000E+00
0000600 0.8354E-05 0.3164E-05 0.8230E-05 0.1317E-05 0.0000E+00
0000601 0.8474E-05 0.2779E-05 0.8276E-05 0.1818E-05 0.0000E+00
0000602 0.8723E-05 0.2941E-05 0.8464E-05 0.2144E-05 0.0000E+00
0000603 0.7971E-05 0.3343E-05 0.8785E-05 0.8287E-06 0.0000E+00
0000604 0.8028E-05 0.2695E-05 0.7926E-05 0.1113E-05 0.0000E+00
0000605 0.8062E-05 0.2727E-05 0.7878E-05 0.1456E-05 0.0000E+00
0000606 0.8203E-05 0.2894E-05 0.7912E-05 0.1880E-05 0.0000E+00
0000607 0.8494E-05 0.2655E-05 0.8121E-05 0.2007E-05 0.0000E+00
0000608 0.7632E-05 0.2911E-05 0.8405E-05 0.7173E-06 0.0000E+00
0000609 0.7660E-05 0.2558E-05 0.7592E-05 0.9335E-06 0.0000E+00
0000610 0.7674E-05 0.2591E-05 0.7536E-05 0.1264E-05 0.0000E+00
0000611 0.7773E-05 0.2717E-05 0.7546E-05 0.1853E-05 0.0000E+00
0000612 0.8050E-05 0.3073E-05 0.7716E-05 0.1755E-05 0.0000E+00
0000613 0.7311E-05 0.2497E-05 0.7980E-05 0.8404E-06 0.0000E+00
0000614 0.7326E-05 0.2597E-05 0.7270E-05 0.1261E-05 0.0000E+00
0000615 0.7356E-05 0.2730E-05 0.7230E-05 0.1197E-05 0.0000E+00
0000616 0.7472E-05 0.2407E-05 0.7273E-05 0.1679E-05 0.0000E+00
0000617 0.7710E-05 0.2565E-05 0.7447E-05 0.1685E-05 0.0000E+00
0000618 0.7001E-05 0.2383E-05 0.7688E-05 0.8746E-06 0.0000E+00
0000619 0.7013E-05 0.2502E-05 0.6966E-05 0.1204E-05 0.0000E+00
0000620 0.7041E-05 0.2644E-05 0.6929E-05 0.1146E-05 0.0000E+00
0000621 0.7156E-05 0.2291E-05 0.6974E-05 0.1591E-05 0.0000E+00
0000622 0.7382E-05 0.2445E-05 0.7146E-05 0.1623E-05 0.0000E+00
0000623 0.6708E-05 0.2272E-05 0.7382E-05 0.8292E-06 0.0000E+00
0000624 0.6721E-05 0.2391E-05 0.6675E-05 0.1191E-05 0.0000E+00
0000625 0.6750E-05 0.2527E-05 0.6640E-05 0.1111E-05 0.0000E+00
0000626 0.6862E-05 0.2184E-05 0.6687E-05 0.1543E-05 0.0000E+00
0000627 0.7083E-05 0.2334E-05 0.6856E-05 0.1556E-05 0.0000E+00
0000628 0.6428E-05 0.2167E-05 0.7088E-05 0.8209E-06 0.0000E+00
0000629 0.6442E-05 0.2285E-05 0.6398E-05 0.1150E-05 0.0000E+00
0000630 0.6472E-05 0.2420E-05 0.6365E-05 0.1075E-05 0.0000E+00
0000631 0.6583E-05 0.2081E-05 0.6412E-05 0.1491E-05 0.0000E+00
0000632 0.6798E-05 0.2229E-05 0.6580E-05 0.1504E-05 0.0000E+00
0000633 0.6161E-05 0.2066E-05 0.6808E-05 0.7918E-06 0.0000E+00
0000634 0.6177E-05 0.2183E-05 0.6133E-05 0.1122E-05 0.0000E+00
0000635 0.6206E-05 0.2314E-05 0.6103E-05 0.1040E-05 0.0000E+00
0000636 0.6316E-05 0.1983E-05 0.6150E-05 0.1445E-05 0.0000E+00
0000637 0.6527E-05 0.2128E-05 0.6315E-05 0.1450E-05 0.0000E+00
0000638 0.5907E-05 0.1970E-05 0.6539E-05 0.7730E-06 0.0000E+00
0000639 0.5923E-05 0.2085E-05 0.5881E-05 0.7311E-06 0.0000E+00
0000640 0.5943E-05 0.1887E-05 0.5845E-05 0.8256E-06 0.0000E+00
0000641 0.6003E-05 0.1919E-05 0.5852E-05 0.1301E-05 0.0000E+00
0000642 0.6171E-05 0.2082E-05 0.5964E-05 0.1239E-05 0.0000E+00
0000643 0.5664E-05 0.1868E-05 0.6135E-05 0.1374E-05 0.0000E+00
0000644 0.5706E-05 0.2036E-05 0.6349E-05 0.1009E-05 0.0000E+00
0000645 0.5833E-05 0.1816E-05 0.5594E-05 0.1131E-05 0.0000E+00
0000646 0.5954E-05 0.1906E-05 0.5587E-05 0.1605E-05 0.0000E+00
0000647 0.6217E-05 0.2167E-05 0.5721E-05 0.1195E-05 0.0000E+00
0000648 0.5435E-05 0.1787E-05 0.5957E-05 0.6667E-06 0.0000E+00
0000649 0.5444E-05 0.1875E-05 0.5409E-05 0.9845E-06 0.0000E+00
0000650 0.5463E-05 0.1981E-05 0.5380E-05 0.9117E-06 0.0000E+00
0000651 0.5550E-05 0.1712E-05 0.5408E-05 0.1229E-05 0.0000E+00
0000652 0.5715E-05 0.1829E-05 0.5537E-05 0.1281E-05 0.0000E+00
0000653 0.5211E-05 0.1698E-05 0.5711E-05 0.6658E-06 0.0000E+00
0000654 0.5220E-05 0.1788E-05 0.5190E-05 0.9082E-06 0.0000E+00
0000655 0.5243E-05 0.1893E-05 0.5163E-05 0.8431E-06 0.0000E+00
0000656 0.5326E-05 0.1631E-05 0.5200E-05 0.1197E-05 0.0000E+00
0000657 0.5495E-05 0.1747E-05 0.5328E-05 0.1174E-05 0.0000E+00
0000658 0.4998E-05 0.1620E-05 0.5511E-05 0.6311E-06 0.0000E+00
0000659 0.5011E-05 0.1713E-05 0.4980E-05 0.6153E-06 0.0000E+00
0000660 0.5024E-05 0.1553E-05 0.4949E-05 0.6902E-06 0.0000E+00
0000661 0.5071E-05 0.1578E-05 0.4951E-05 0.1076E-05 0.0000E+00
0000662 0.5202E-05 0.1709E-05 0.5039E-05 0.1397E-05 0.0000E+00
0000663 0.5483E-05 0.1565E-05 0.5266E-05 0.6865E-06 0.0000E+00
0000664 0.4762E-05 0.1734E-05 0.4778E-05 0.3466E-06 0.0000E+00
0000665 0.4734E-05 0.1478E-05 0.4760E-05 0.5710E-06 0.0000E+00
0000666 0.4716E-05 0.1479E-05 0.4746E-05 0.6979E-06 0.0000E+00
0000667 0.4734E-05 0.1533E-05 0.4766E-05 0.1145E-05 0.0000E+00
0000668 0.4822E-05 0.1713E-05 0.4868E-05 0.1458E-05 0.0000E+00
0000669 0.5045E-05 0.1482E-05 0.5095E-05 0.6344E-06 0.0000E+00
0000670 0.4531E-05 0.1646E-05 0.4550E-05 0.2832E-06 0.0000E+00
0000671 0.4512E-05 0.1393E-05 0.4529E-05 0.5875E-06 0.0000E+00
0000672 0.4496E-05 0.1394E-05 0.4514E-05 0.6486E-06 0.0000E+00
0000673 0.4517E-05 0.1440E-05 0.4533E-05 0.1108E-05 0.0000E+00
0000674 0.4608E-05 0.1611E-05 0.4626E-05 0.1363E-05 0.0000E+00
0000675 0.4833E-05 0.1396E-05 0.4847E-05 0.5949E-06 0.0000E+00
0000676 0.4315E-05 0.1556E-05 0.4333E-05 0.2575E-06 0.0000E+00
0000677 0.4296E-05 0.1314E-05 0.4314E-05 0.5763E-06 0.0000E+00
0000678 0.4281E-05 0.1314E-05 0.4299E-05 0.6076E-06 0.0000E+00
0000679 0.4300E-05 0.1355E-05 0.4318E-05 0.1053E-05 0.0000E+00
0000680 0.4384E-05 0.1517E-05 0.4403E-05 0.1270E-05 0.0000E+00
0000681 0.4593E-05 0.1316E-05 0.4611E-05 0.5578E-06 0.0000E+00
0000682 0.4110E-05 0.1466E-05 0.4127E-05 0.2365E-06 0.0000E+00
0000683 0.4092E-05 0.1239E-05 0.4109E-05 0.5451E-06 0.0000E+00
0000684 0.4077E-05 0.1239E-05 0.4094E-05 0.5623E-06 0.0000E+00
0000685 0.4094E-05 0.1275E-05 0.4111E-05 0.9831E-06 0.0000E+00
0000686 0.4170E-05 0.1423E-05 0.4187E-05 0.1172E-05 0.0000E+00
0000687 0.4364E-05 0.1239E-05 0.4380E-05 0.5216E-06 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 15
0000688 0.3916E-05 0.1379E-05 0.3933E-05 0.2187E-06 0.0000E+00
0000689 0.3899E-05 0.1168E-05 0.3916E-05 0.5091E-06 0.0000E+00
0000690 0.3884E-05 0.1168E-05 0.3900E-05 0.5213E-06 0.0000E+00
0000691 0.3898E-05 0.1200E-05 0.3914E-05 0.9139E-06 0.0000E+00
0000692 0.3967E-05 0.1336E-05 0.3983E-05 0.1084E-05 0.0000E+00
0000693 0.4145E-05 0.1168E-05 0.4161E-05 0.4870E-06 0.0000E+00
0000694 0.3732E-05 0.1296E-05 0.3749E-05 0.2024E-06 0.0000E+00
0000695 0.3715E-05 0.1101E-05 0.3732E-05 0.4723E-06 0.0000E+00
0000696 0.3701E-05 0.1101E-05 0.3717E-05 0.4830E-06 0.0000E+00
0000697 0.3712E-05 0.1130E-05 0.3728E-05 0.8475E-06 0.0000E+00
0000698 0.3775E-05 0.1254E-05 0.3790E-05 0.1003E-05 0.0000E+00
0000699 0.3938E-05 0.1100E-05 0.3953E-05 0.4548E-06 0.0000E+00
0000700 0.3558E-05 0.1218E-05 0.3574E-05 0.1879E-06 0.0000E+00
0000701 0.3542E-05 0.1038E-05 0.3558E-05 0.4379E-06 0.0000E+00
0000702 0.3527E-05 0.1037E-05 0.3543E-05 0.4487E-06 0.0000E+00
0000703 0.3537E-05 0.1064E-05 0.3553E-05 0.7870E-06 0.0000E+00
0000704 0.3593E-05 0.1178E-05 0.3608E-05 0.9306E-06 0.0000E+00
0000705 0.3743E-05 0.1037E-05 0.3757E-05 0.4251E-06 0.0000E+00
0000706 0.3393E-05 0.1146E-05 0.3409E-05 0.1748E-06 0.0000E+00
0000707 0.3377E-05 0.9790E-06 0.3393E-05 0.4064E-06 0.0000E+00
0000708 0.3363E-05 0.9780E-06 0.3379E-05 0.4176E-06 0.0000E+00
0000709 0.3371E-05 0.1002E-05 0.3386E-05 0.7318E-06 0.0000E+00
0000710 0.3422E-05 0.1108E-05 0.3437E-05 0.8655E-06 0.0000E+00
0000711 0.3559E-05 0.9772E-06 0.3574E-05 0.3979E-06 0.0000E+00
0000712 0.3237E-05 0.1078E-05 0.3252E-05 0.1630E-06 0.0000E+00
0000713 0.3222E-05 0.9231E-06 0.3237E-05 0.3778E-06 0.0000E+00
0000714 0.3208E-05 0.9220E-06 0.3223E-05 0.3897E-06 0.0000E+00
0000715 0.3215E-05 0.9440E-06 0.3229E-05 0.6820E-06 0.0000E+00
0000716 0.3261E-05 0.1042E-05 0.3275E-05 0.8072E-06 0.0000E+00
0000717 0.3387E-05 0.9212E-06 0.3401E-05 0.3729E-06 0.0000E+00
0000718 0.3089E-05 0.1015E-05 0.3104E-05 0.1524E-06 0.0000E+00
0000719 0.3074E-05 0.8704E-06 0.3089E-05 0.3521E-06 0.0000E+00
0000720 0.3061E-05 0.8693E-06 0.3075E-05 0.3644E-06 0.0000E+00
0000721 0.3066E-05 0.8895E-06 0.3081E-05 0.6369E-06 0.0000E+00
0000722 0.3108E-05 0.9805E-06 0.3122E-05 0.7545E-06 0.0000E+00
0000723 0.3225E-05 0.8685E-06 0.3238E-05 0.3501E-06 0.0000E+00
0000724 0.2949E-05 0.9553E-06 0.2963E-05 0.1428E-06 0.0000E+00
0000725 0.2934E-05 0.8207E-06 0.2949E-05 0.3288E-06 0.0000E+00
0000726 0.2921E-05 0.8196E-06 0.2936E-05 0.3414E-06 0.0000E+00
0000727 0.2926E-05 0.8383E-06 0.2940E-05 0.5960E-06 0.0000E+00
0000728 0.2964E-05 0.9232E-06 0.2978E-05 0.7067E-06 0.0000E+00
0000729 0.3072E-05 0.8188E-06 0.3085E-05 0.1106E-05 0.0000E+00
0000730 0.3284E-05 0.1022E-05 0.3296E-05 0.3272E-06 0.0000E+00
0000731 0.2799E-05 0.7956E-06 0.2813E-05 0.2863E-06 0.0000E+00
0000732 0.2786E-05 0.8254E-06 0.2800E-05 0.5168E-06 0.0000E+00
0000733 0.2789E-05 0.8752E-06 0.2803E-05 0.5050E-06 0.0000E+00
0000734 0.2825E-05 0.7685E-06 0.2838E-05 0.7574E-06 0.0000E+00
0000735 0.2911E-05 0.8529E-06 0.2923E-05 0.9903E-06 0.0000E+00
0000736 0.3094E-05 0.7992E-06 0.3106E-05 0.2797E-06 0.0000E+00
0000737 0.2672E-05 0.7519E-06 0.2686E-05 0.2361E-06 0.0000E+00
0000738 0.2657E-05 0.7763E-06 0.2671E-05 0.4487E-06 0.0000E+00
0000739 0.2653E-05 0.8191E-06 0.2666E-05 0.3828E-06 0.0000E+00
0000740 0.2674E-05 0.7185E-06 0.2687E-05 0.6412E-06 0.0000E+00
0000741 0.2728E-05 0.7757E-06 0.2740E-05 0.7961E-06 0.0000E+00
0000742 0.2859E-05 0.7356E-06 0.2871E-05 0.3786E-06 0.0000E+00
0000743 0.2552E-05 0.8375E-06 0.2565E-05 0.1463E-06 0.0000E+00
0000744 0.2543E-05 0.6833E-06 0.2556E-05 0.3232E-06 0.0000E+00
0000745 0.2537E-05 0.6859E-06 0.2550E-05 0.3563E-06 0.0000E+00
0000746 0.2552E-05 0.7188E-06 0.2564E-05 0.6264E-06 0.0000E+00
0000747 0.2609E-05 0.8270E-06 0.2621E-05 0.7529E-06 0.0000E+00
0000748 0.2746E-05 0.6984E-06 0.2757E-05 0.3513E-06 0.0000E+00
0000749 0.2440E-05 0.7994E-06 0.2452E-05 0.1385E-06 0.0000E+00
0000750 0.2431E-05 0.6440E-06 0.2444E-05 0.3151E-06 0.0000E+00
0000751 0.2425E-05 0.6468E-06 0.2437E-05 0.3374E-06 0.0000E+00
0000752 0.2439E-05 0.6764E-06 0.2451E-05 0.5898E-06 0.0000E+00
0000753 0.2493E-05 0.7805E-06 0.2504E-05 0.7041E-06 0.0000E+00
0000754 0.2622E-05 0.6583E-06 0.2633E-05 0.3263E-06 0.0000E+00
0000755 0.2333E-05 0.7550E-06 0.2345E-05 0.1307E-06 0.0000E+00
0000756 0.2325E-05 0.6072E-06 0.2337E-05 0.3001E-06 0.0000E+00
0000757 0.2318E-05 0.6097E-06 0.2330E-05 0.3165E-06 0.0000E+00
0000758 0.2331E-05 0.6361E-06 0.2342E-05 0.5517E-06 0.0000E+00
0000759 0.2379E-05 0.7331E-06 0.2391E-05 0.6552E-06 0.0000E+00
0000760 0.2499E-05 0.6199E-06 0.2509E-05 0.3036E-06 0.0000E+00
0000761 0.2231E-05 0.7101E-06 0.2243E-05 0.1226E-06 0.0000E+00
0000762 0.2223E-05 0.5725E-06 0.2235E-05 0.2818E-06 0.0000E+00
0000763 0.2216E-05 0.5746E-06 0.2228E-05 0.2953E-06 0.0000E+00
0000764 0.2227E-05 0.5982E-06 0.2238E-05 0.5141E-06 0.0000E+00
0000765 0.2271E-05 0.6875E-06 0.2282E-05 0.6089E-06 0.0000E+00
0000766 0.2380E-05 0.5836E-06 0.2390E-05 0.2826E-06 0.0000E+00
0000767 0.2135E-05 0.6669E-06 0.2146E-05 0.1145E-06 0.0000E+00
0000768 0.2127E-05 0.5398E-06 0.2138E-05 0.2630E-06 0.0000E+00
0000769 0.2120E-05 0.5415E-06 0.2131E-05 0.2749E-06 0.0000E+00
0000770 0.2129E-05 0.5628E-06 0.2140E-05 0.4782E-06 0.0000E+00
0000771 0.2168E-05 0.6448E-06 0.2178E-05 0.5658E-06 0.0000E+00
0000772 0.2267E-05 0.5495E-06 0.2277E-05 0.2634E-06 0.0000E+00
0000773 0.2043E-05 0.6263E-06 0.2054E-05 0.1068E-06 0.0000E+00
0000774 0.2035E-05 0.5089E-06 0.2046E-05 0.2448E-06 0.0000E+00
0000775 0.2028E-05 0.5104E-06 0.2039E-05 0.2560E-06 0.0000E+00
0000776 0.2035E-05 0.5297E-06 0.2046E-05 0.4451E-06 0.0000E+00
0000777 0.2070E-05 0.6051E-06 0.2081E-05 0.5266E-06 0.0000E+00
0000778 0.2161E-05 0.5175E-06 0.2170E-05 0.2459E-06 0.0000E+00
0000779 0.1956E-05 0.5883E-06 0.1966E-05 0.9960E-07 0.0000E+00
0000780 0.1948E-05 0.4799E-06 0.1958E-05 0.2280E-06 0.0000E+00
0000781 0.1941E-05 0.4811E-06 0.1951E-05 0.2386E-06 0.0000E+00
0000782 0.1947E-05 0.4987E-06 0.1957E-05 0.4147E-06 0.0000E+00
0000783 0.1978E-05 0.5683E-06 0.1988E-05 0.4909E-06 0.0000E+00
0000784 0.2060E-05 0.4875E-06 0.2070E-05 0.2298E-06 0.0000E+00
0000785 0.1873E-05 0.5529E-06 0.1883E-05 0.9302E-07 0.0000E+00
0000786 0.1865E-05 0.4524E-06 0.1875E-05 0.2125E-06 0.0000E+00
0000787 0.1858E-05 0.4535E-06 0.1868E-05 0.2228E-06 0.0000E+00
0000788 0.1863E-05 0.4697E-06 0.1873E-05 0.3870E-06 0.0000E+00
0000789 0.1891E-05 0.5341E-06 0.1901E-05 0.4585E-06 0.0000E+00
0000790 0.1966E-05 0.4594E-06 0.1975E-05 0.2152E-06 0.0000E+00
0000791 0.1794E-05 0.5200E-06 0.1804E-05 0.8701E-07 0.0000E+00
0000792 0.1786E-05 0.4266E-06 0.1796E-05 0.1984E-06 0.0000E+00
0000793 0.1779E-05 0.4275E-06 0.1789E-05 0.2084E-06 0.0000E+00
0000794 0.1784E-05 0.4424E-06 0.1793E-05 0.3618E-06 0.0000E+00
0000795 0.1809E-05 0.5023E-06 0.1818E-05 0.4291E-06 0.0000E+00
0000796 0.1877E-05 0.4329E-06 0.1886E-05 0.6729E-06 0.0000E+00
0000797 0.2011E-05 0.5743E-06 0.2019E-05 0.2009E-06 0.0000E+00
0000798 0.1710E-05 0.4187E-06 0.1719E-05 0.1753E-06 0.0000E+00
0000799 0.1703E-05 0.4402E-06 0.1712E-05 0.2185E-06 0.0000E+00
0000800 0.1704E-05 0.3965E-06 0.1713E-05 0.2669E-06 0.0000E+00
0000801 0.1718E-05 0.4178E-06 0.1727E-05 0.4518E-06 0.0000E+00
0000802 0.1765E-05 0.4859E-06 0.1773E-05 0.5603E-06 0.0000E+00
0000803 0.1869E-05 0.4247E-06 0.1877E-05 0.1685E-06 0.0000E+00
0000804 0.1637E-05 0.3927E-06 0.1646E-05 0.1253E-06 0.0000E+00
0000805 0.1629E-05 0.4084E-06 0.1638E-05 0.1838E-06 0.0000E+00
0000806 0.1625E-05 0.3733E-06 0.1633E-05 0.1794E-06 0.0000E+00
0000807 0.1629E-05 0.3834E-06 0.1637E-05 0.3506E-06 0.0000E+00
0000808 0.1651E-05 0.4255E-06 0.1660E-05 0.4096E-06 0.0000E+00
0000809 0.1714E-05 0.3846E-06 0.1722E-05 0.2152E-06 0.0000E+00
0000810 0.1569E-05 0.4342E-06 0.1577E-05 0.7127E-07 0.0000E+00
0000811 0.1562E-05 0.3548E-06 0.1571E-05 0.1716E-06 0.0000E+00
0000812 0.1557E-05 0.3565E-06 0.1566E-05 0.1795E-06 0.0000E+00
0000813 0.1562E-05 0.3749E-06 0.1570E-05 0.3341E-06 0.0000E+00
0000814 0.1586E-05 0.4317E-06 0.1594E-05 0.3919E-06 0.0000E+00
0000815 0.1650E-05 0.3656E-06 0.1658E-05 0.1952E-06 0.0000E+00
0000816 0.1504E-05 0.4181E-06 0.1513E-05 0.7037E-07 0.0000E+00
0000817 0.1499E-05 0.3344E-06 0.1507E-05 0.1670E-06 0.0000E+00
0000818 0.1494E-05 0.3362E-06 0.1502E-05 0.1761E-06 0.0000E+00
0000819 0.1498E-05 0.3529E-06 0.1506E-05 0.3154E-06 0.0000E+00
0000820 0.1522E-05 0.4092E-06 0.1530E-05 0.3739E-06 0.0000E+00
0000821 0.1584E-05 0.3448E-06 0.1591E-05 0.1798E-06 0.0000E+00
0000822 0.1443E-05 0.3967E-06 0.1451E-05 0.6871E-07 0.0000E+00
0000823 0.1438E-05 0.3153E-06 0.1445E-05 0.1603E-06 0.0000E+00
0000824 0.1433E-05 0.3170E-06 0.1441E-05 0.1688E-06 0.0000E+00
0000825 0.1437E-05 0.3321E-06 0.1445E-05 0.2973E-06 0.0000E+00
0000826 0.1459E-05 0.3859E-06 0.1466E-05 0.3532E-06 0.0000E+00
0000827 0.1517E-05 0.3250E-06 0.1524E-05 0.1675E-06 0.0000E+00
0000828 0.1385E-05 0.3746E-06 0.1392E-05 0.6593E-07 0.0000E+00
0000829 0.1379E-05 0.2973E-06 0.1387E-05 0.1520E-06 0.0000E+00
0000830 0.1375E-05 0.2988E-06 0.1382E-05 0.1600E-06 0.0000E+00
0000831 0.1378E-05 0.3126E-06 0.1385E-05 0.2794E-06 0.0000E+00
0000832 0.1398E-05 0.3630E-06 0.1405E-05 0.3322E-06 0.0000E+00
0000833 0.1452E-05 0.3061E-06 0.1458E-05 0.5201E-06 0.0000E+00
0000834 0.1556E-05 0.4235E-06 0.1562E-05 0.1545E-06 0.0000E+00
0000835 0.1322E-05 0.2948E-06 0.1329E-05 0.1356E-06 0.0000E+00
0000836 0.1317E-05 0.3128E-06 0.1325E-05 0.1688E-06 0.0000E+00
0000837 0.1318E-05 0.2767E-06 0.1326E-05 0.2061E-06 0.0000E+00
0000838 0.1330E-05 0.2955E-06 0.1337E-05 0.3485E-06 0.0000E+00
0000839 0.1366E-05 0.3523E-06 0.1373E-05 0.4329E-06 0.0000E+00
0000840 0.1448E-05 0.3030E-06 0.1454E-05 0.1301E-06 0.0000E+00
0000841 0.1268E-05 0.2761E-06 0.1275E-05 0.9704E-07 0.0000E+00
0000842 0.1262E-05 0.2894E-06 0.1269E-05 0.1420E-06 0.0000E+00
0000843 0.1259E-05 0.2604E-06 0.1266E-05 0.1386E-06 0.0000E+00
0000844 0.1263E-05 0.2696E-06 0.1269E-05 0.2708E-06 0.0000E+00
0000845 0.1281E-05 0.3053E-06 0.1287E-05 0.3165E-06 0.0000E+00
0000846 0.1329E-05 0.2721E-06 0.1335E-05 0.3443E-06 0.0000E+00
0000847 0.1212E-05 0.2714E-06 0.1400E-05 0.1015E-06 0.0000E+00
0000848 0.1225E-05 0.2521E-06 0.1218E-05 0.1711E-06 0.0000E+00
0000849 0.1231E-05 0.2651E-06 0.1208E-05 0.1986E-06 0.0000E+00
0000850 0.1251E-05 0.2965E-06 0.1211E-05 0.2580E-06 0.0000E+00
0000851 0.1292E-05 0.2523E-06 0.1234E-05 0.2584E-06 0.0000E+00
0000852 0.1176E-05 0.2961E-06 0.1274E-05 0.2699E-06 0.0000E+00
0000853 0.1184E-05 0.2468E-06 0.1323E-05 0.2085E-06 0.0000E+00
0000854 0.1213E-05 0.2848E-06 0.1169E-05 0.2154E-06 0.0000E+00
0000855 0.1243E-05 0.2365E-06 0.1168E-05 0.2706E-06 0.0000E+00
0000856 0.1295E-05 0.2813E-06 0.1191E-05 0.2233E-06 0.0000E+00
0000857 0.1138E-05 0.2386E-06 0.1237E-05 0.2829E-06 0.0000E+00
0000858 0.1143E-05 0.2888E-06 0.1284E-05 0.1974E-06 0.0000E+00
0000859 0.1171E-05 0.2300E-06 0.1131E-05 0.1947E-06 0.0000E+00
0000860 0.1200E-05 0.2597E-06 0.1129E-05 0.2708E-06 0.0000E+00
0000861 0.1247E-05 0.2300E-06 0.1151E-05 0.2390E-06 0.0000E+00
0000862 0.1101E-05 0.2785E-06 0.1193E-05 0.2672E-06 0.0000E+00
0000863 0.1108E-05 0.2230E-06 0.1238E-05 0.1981E-06 0.0000E+00
0000864 0.1135E-05 0.2595E-06 0.1094E-05 0.2020E-06 0.0000E+00
0000865 0.1163E-05 0.2140E-06 0.1093E-05 0.2575E-06 0.0000E+00
0000866 0.1211E-05 0.2569E-06 0.1116E-05 0.2251E-06 0.0000E+00
0000867 0.1065E-05 0.2163E-06 0.1159E-05 0.2674E-06 0.0000E+00
0000868 0.1071E-05 0.2634E-06 0.1202E-05 0.1905E-06 0.0000E+00
0000869 0.1098E-05 0.2087E-06 0.1059E-05 0.1901E-06 0.0000E+00
0000870 0.1125E-05 0.2381E-06 0.1057E-05 0.2608E-06 0.0000E+00
0000871 0.1169E-05 0.2091E-06 0.1080E-05 0.2297E-06 0.0000E+00
0000872 0.1031E-05 0.2563E-06 0.1120E-05 0.2636E-06 0.0000E+00
0000873 0.1039E-05 0.2024E-06 0.1161E-05 0.1937E-06 0.0000E+00
0000874 0.1065E-05 0.2381E-06 0.1025E-05 0.1959E-06 0.0000E+00
0000875 0.1092E-05 0.1943E-06 0.1024E-05 0.2515E-06 0.0000E+00
0000876 0.1136E-05 0.2358E-06 0.1048E-05 0.2241E-06 0.0000E+00
0000877 0.9978E-06 0.1967E-06 0.1089E-05 0.9582E-07 0.0000E+00
0000878 0.1000E-05 0.2204E-06 0.9984E-06 0.1168E-06 0.0000E+00
0000879 0.1003E-05 0.1831E-06 0.9924E-06 0.1235E-06 0.0000E+00
0000880 0.1011E-05 0.1919E-06 0.9919E-06 0.1972E-06 0.0000E+00
0000881 0.1032E-05 0.2226E-06 0.1005E-05 0.2527E-06 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 16
0000882 0.1080E-05 0.1961E-06 0.1041E-05 0.7799E-07 0.0000E+00
0000883 0.9612E-06 0.1811E-06 0.9654E-06 0.6375E-07 0.0000E+00
0000884 0.9550E-06 0.1883E-06 0.9610E-06 0.1182E-06 0.0000E+00
0000885 0.9516E-06 0.2002E-06 0.9581E-06 0.1128E-06 0.0000E+00
0000886 0.9526E-06 0.1732E-06 0.9593E-06 0.1765E-06 0.0000E+00
0000887 0.9595E-06 0.1892E-06 0.9677E-06 0.2261E-06 0.0000E+00
0000888 0.9823E-06 0.1793E-06 0.9912E-06 0.3389E-06 0.0000E+00
0000889 0.1033E-05 0.2436E-06 0.1044E-05 0.8961E-07 0.0000E+00
0000890 0.9188E-06 0.1730E-06 0.9236E-06 0.8349E-07 0.0000E+00
0000891 0.9153E-06 0.1831E-06 0.9197E-06 0.1143E-06 0.0000E+00
0000892 0.9145E-06 0.1620E-06 0.9186E-06 0.1318E-06 0.0000E+00
0000893 0.9192E-06 0.1730E-06 0.9231E-06 0.2073E-06 0.0000E+00
0000894 0.9350E-06 0.1653E-06 0.9381E-06 0.2763E-06 0.0000E+00
0000895 0.9746E-06 0.2141E-06 0.9771E-06 0.8663E-07 0.0000E+00
0000896 0.8837E-06 0.1609E-06 0.8881E-06 0.5772E-07 0.0000E+00
0000897 0.8796E-06 0.1689E-06 0.8841E-06 0.1024E-06 0.0000E+00
0000898 0.8775E-06 0.1522E-06 0.8818E-06 0.9834E-07 0.0000E+00
0000899 0.8796E-06 0.1600E-06 0.8839E-06 0.1920E-06 0.0000E+00
0000900 0.8911E-06 0.1865E-06 0.8952E-06 0.2240E-06 0.0000E+00
0000901 0.9223E-06 0.1626E-06 0.9263E-06 0.7194E-07 0.0000E+00
0000902 0.8499E-06 0.1509E-06 0.8542E-06 0.4501E-07 0.0000E+00
0000903 0.8454E-06 0.1570E-06 0.8496E-06 0.1080E-06 0.0000E+00
0000904 0.8424E-06 0.1674E-06 0.8465E-06 0.8239E-07 0.0000E+00
0000905 0.8434E-06 0.1438E-06 0.8476E-06 0.1558E-06 0.0000E+00
0000906 0.8498E-06 0.1579E-06 0.8537E-06 0.1819E-06 0.0000E+00
0000907 0.8704E-06 0.1496E-06 0.8741E-06 0.2941E-06 0.0000E+00
0000908 0.9158E-06 0.2069E-06 0.9190E-06 0.7491E-07 0.0000E+00
0000909 0.8135E-06 0.1447E-06 0.8175E-06 0.7709E-07 0.0000E+00
0000910 0.8102E-06 0.1541E-06 0.8143E-06 0.9455E-07 0.0000E+00
0000911 0.8096E-06 0.1347E-06 0.8136E-06 0.1188E-06 0.0000E+00
0000912 0.8137E-06 0.1451E-06 0.8175E-06 0.1773E-06 0.0000E+00
0000913 0.8276E-06 0.1382E-06 0.8313E-06 0.2453E-06 0.0000E+00
0000914 0.8625E-06 0.1830E-06 0.8660E-06 0.7462E-07 0.0000E+00
0000915 0.7828E-06 0.1345E-06 0.7866E-06 0.5273E-07 0.0000E+00
0000916 0.7793E-06 0.1422E-06 0.7832E-06 0.8729E-07 0.0000E+00
0000917 0.7776E-06 0.1265E-06 0.7814E-06 0.8797E-07 0.0000E+00
0000918 0.7796E-06 0.1341E-06 0.7834E-06 0.1677E-06 0.0000E+00
0000919 0.7903E-06 0.1587E-06 0.7939E-06 0.1985E-06 0.0000E+00
0000920 0.8189E-06 0.1372E-06 0.8222E-06 0.2128E-06 0.0000E+00
0000921 0.7498E-06 0.1370E-06 0.8614E-06 0.6295E-07 0.0000E+00
0000922 0.7578E-06 0.1241E-06 0.7535E-06 0.1059E-06 0.0000E+00
0000923 0.7621E-06 0.1340E-06 0.7479E-06 0.9907E-07 0.0000E+00
0000924 0.7725E-06 0.1210E-06 0.7492E-06 0.1583E-06 0.0000E+00
0000925 0.7943E-06 0.1437E-06 0.7615E-06 0.2014E-06 0.0000E+00
0000926 0.8405E-06 0.1325E-06 0.7953E-06 0.6047E-07 0.0000E+00
0000927 0.7262E-06 0.1215E-06 0.7288E-06 0.5658E-07 0.0000E+00
0000928 0.7216E-06 0.1283E-06 0.7263E-06 0.7237E-07 0.0000E+00
0000929 0.7193E-06 0.1128E-06 0.7245E-06 0.7697E-07 0.0000E+00
0000930 0.7198E-06 0.1179E-06 0.7254E-06 0.1388E-06 0.0000E+00
0000931 0.7260E-06 0.1374E-06 0.7333E-06 0.1672E-06 0.0000E+00
0000932 0.7459E-06 0.1193E-06 0.7549E-06 0.2487E-06 0.0000E+00
0000933 0.7860E-06 0.1297E-06 0.7976E-06 0.6162E-07 0.0000E+00
0000934 0.6948E-06 0.1154E-06 0.6982E-06 0.3926E-07 0.0000E+00
0000935 0.6918E-06 0.1054E-06 0.6948E-06 0.6731E-07 0.0000E+00
0000936 0.6897E-06 0.1071E-06 0.6926E-06 0.8666E-07 0.0000E+00
0000937 0.6910E-06 0.1153E-06 0.6936E-06 0.1255E-06 0.0000E+00
0000938 0.6986E-06 0.1066E-06 0.7006E-06 0.1748E-06 0.0000E+00
0000939 0.7195E-06 0.1320E-06 0.7209E-06 0.2467E-06 0.0000E+00
0000940 0.7642E-06 0.1197E-06 0.7644E-06 0.6077E-07 0.0000E+00
0000941 0.6654E-06 0.1088E-06 0.6684E-06 0.3772E-07 0.0000E+00
0000942 0.6624E-06 0.9833E-07 0.6656E-06 0.6891E-07 0.0000E+00
0000943 0.6604E-06 0.9999E-07 0.6636E-06 0.8637E-07 0.0000E+00
0000944 0.6619E-06 0.1075E-06 0.6650E-06 0.1264E-06 0.0000E+00
0000945 0.6694E-06 0.9985E-07 0.6727E-06 0.1735E-06 0.0000E+00
0000946 0.6904E-06 0.1240E-06 0.6937E-06 0.2459E-06 0.0000E+00
0000947 0.7344E-06 0.1125E-06 0.7379E-06 0.5970E-07 0.0000E+00
0000948 0.6372E-06 0.1021E-06 0.6401E-06 0.3768E-07 0.0000E+00
0000949 0.6345E-06 0.9187E-07 0.6374E-06 0.6741E-07 0.0000E+00
0000950 0.6328E-06 0.9356E-07 0.6357E-06 0.8536E-07 0.0000E+00
0000951 0.6346E-06 0.1012E-06 0.6374E-06 0.1242E-06 0.0000E+00
0000952 0.6428E-06 0.9341E-07 0.6454E-06 0.1715E-06 0.0000E+00
0000953 0.6645E-06 0.1173E-06 0.6668E-06 0.2421E-06 0.0000E+00
0000954 0.7094E-06 0.1060E-06 0.7114E-06 0.5860E-07 0.0000E+00
0000955 0.6104E-06 0.9606E-07 0.6131E-06 0.3708E-07 0.0000E+00
0000956 0.6079E-06 0.8580E-07 0.6106E-06 0.6685E-07 0.0000E+00
0000957 0.6064E-06 0.8752E-07 0.6092E-06 0.8426E-07 0.0000E+00
0000958 0.6084E-06 0.9503E-07 0.6111E-06 0.1227E-06 0.0000E+00
0000959 0.6168E-06 0.8751E-07 0.6195E-06 0.1688E-06 0.0000E+00
0000960 0.6387E-06 0.1109E-06 0.6412E-06 0.2382E-06 0.0000E+00
0000961 0.6833E-06 0.9994E-07 0.6858E-06 0.5723E-07 0.0000E+00
0000962 0.5847E-06 0.9036E-07 0.5874E-06 0.3639E-07 0.0000E+00
0000963 0.5824E-06 0.8015E-07 0.5851E-06 0.6538E-07 0.0000E+00
0000964 0.5812E-06 0.8191E-07 0.5838E-06 0.8244E-07 0.0000E+00
0000965 0.5834E-06 0.8941E-07 0.5859E-06 0.1200E-06 0.0000E+00
0000966 0.5920E-06 0.8198E-07 0.5944E-06 0.1651E-06 0.0000E+00
0000967 0.6141E-06 0.1050E-06 0.6163E-06 0.2326E-06 0.0000E+00
0000968 0.6586E-06 0.9431E-07 0.6606E-06 0.5572E-07 0.0000E+00
0000969 0.5603E-06 0.8504E-07 0.5628E-06 0.3559E-07 0.0000E+00
0000970 0.5582E-06 0.7487E-07 0.5607E-06 0.6397E-07 0.0000E+00
0000971 0.5571E-06 0.7666E-07 0.5596E-06 0.8056E-07 0.0000E+00
0000972 0.5594E-06 0.8409E-07 0.5618E-06 0.1172E-06 0.0000E+00
0000973 0.5682E-06 0.7682E-07 0.5705E-06 0.1611E-06 0.0000E+00
0000974 0.5901E-06 0.9944E-07 0.5923E-06 0.4690E-07 0.0000E+00
0000975 0.5398E-06 0.7550E-07 0.5421E-06 0.3424E-07 0.0000E+00
0000976 0.5373E-06 0.7993E-07 0.5397E-06 0.5520E-07 0.0000E+00
0000977 0.5359E-06 0.7042E-07 0.5382E-06 0.5345E-07 0.0000E+00
0000978 0.5366E-06 0.7436E-07 0.5389E-06 0.1048E-06 0.0000E+00
0000979 0.5420E-06 0.8776E-07 0.5442E-06 0.1207E-06 0.0000E+00
0000980 0.5581E-06 0.7620E-07 0.5602E-06 0.1860E-06 0.0000E+00
0000981 0.5902E-06 0.8355E-07 0.5922E-06 0.4400E-07 0.0000E+00
0000982 0.5175E-06 0.7420E-07 0.5197E-06 0.3114E-07 0.0000E+00
0000983 0.5153E-06 0.6594E-07 0.5175E-06 0.4982E-07 0.0000E+00
0000984 0.5138E-06 0.6736E-07 0.5160E-06 0.6724E-07 0.0000E+00
0000985 0.5148E-06 0.7352E-07 0.5170E-06 0.9387E-07 0.0000E+00
0000986 0.5205E-06 0.6736E-07 0.5226E-06 0.1334E-06 0.0000E+00
0000987 0.5360E-06 0.8617E-07 0.5380E-06 0.1856E-06 0.0000E+00
0000988 0.5692E-06 0.7759E-07 0.5710E-06 0.4562E-07 0.0000E+00
0000989 0.4961E-06 0.6990E-07 0.4982E-06 0.2734E-07 0.0000E+00
0000990 0.4940E-06 0.6156E-07 0.4961E-06 0.5183E-07 0.0000E+00
0000991 0.4927E-06 0.6299E-07 0.4948E-06 0.6321E-07 0.0000E+00
0000992 0.4940E-06 0.6900E-07 0.4960E-06 0.9396E-07 0.0000E+00
0000993 0.4999E-06 0.6316E-07 0.5019E-06 0.1278E-06 0.0000E+00
0000994 0.5160E-06 0.8159E-07 0.5178E-06 0.1829E-06 0.0000E+00
0000995 0.5496E-06 0.7336E-07 0.5513E-06 0.4355E-07 0.0000E+00
0000996 0.4757E-06 0.6585E-07 0.4776E-06 0.2848E-07 0.0000E+00
0000997 0.4738E-06 0.5752E-07 0.4757E-06 0.4987E-07 0.0000E+00
0000998 0.4726E-06 0.5898E-07 0.4746E-06 0.6375E-07 0.0000E+00
0000999 0.4740E-06 0.6499E-07 0.4759E-06 0.9192E-07 0.0000E+00
0001000 0.4802E-06 0.5918E-07 0.4820E-06 0.1275E-06 0.0000E+00
0001001 0.4963E-06 0.7731E-07 0.4981E-06 0.1797E-06 0.0000E+00
0001002 0.5299E-06 0.6923E-07 0.5315E-06 0.4306E-07 0.0000E+00
0001003 0.4561E-06 0.6205E-07 0.4580E-06 0.2718E-07 0.0000E+00
0001004 0.4544E-06 0.5373E-07 0.4562E-06 0.4941E-07 0.0000E+00
0001005 0.4534E-06 0.5522E-07 0.4552E-06 0.6165E-07 0.0000E+00
0001006 0.4549E-06 0.6119E-07 0.4567E-06 0.9023E-07 0.0000E+00
0001007 0.4612E-06 0.5550E-07 0.4629E-06 0.1238E-06 0.0000E+00
0001008 0.4775E-06 0.7338E-07 0.4791E-06 0.1756E-06 0.0000E+00
0001009 0.5109E-06 0.6550E-07 0.5124E-06 0.4166E-07 0.0000E+00
0001010 0.4375E-06 0.5851E-07 0.4392E-06 0.2691E-07 0.0000E+00
0001011 0.4358E-06 0.5021E-07 0.4376E-06 0.4804E-07 0.0000E+00
0001012 0.4349E-06 0.5172E-07 0.4367E-06 0.6057E-07 0.0000E+00
0001013 0.4366E-06 0.5764E-07 0.4382E-06 0.8801E-07 0.0000E+00
0001014 0.4429E-06 0.5204E-07 0.4446E-06 0.1213E-06 0.0000E+00
0001015 0.4591E-06 0.6959E-07 0.4607E-06 0.1712E-06 0.0000E+00
0001016 0.4921E-06 0.6191E-07 0.4935E-06 0.4055E-07 0.0000E+00
0001017 0.4196E-06 0.5515E-07 0.4213E-06 0.2602E-07 0.0000E+00
0001018 0.4181E-06 0.4691E-07 0.4197E-06 0.4685E-07 0.0000E+00
0001019 0.4173E-06 0.4843E-07 0.4189E-06 0.5869E-07 0.0000E+00
0001020 0.4190E-06 0.5430E-07 0.4206E-06 0.8563E-07 0.0000E+00
0001021 0.4254E-06 0.4881E-07 0.4269E-06 0.1176E-06 0.0000E+00
0001022 0.4414E-06 0.6603E-07 0.4429E-06 0.1663E-06 0.0000E+00
0001023 0.4738E-06 0.5856E-07 0.4752E-06 0.3920E-07 0.0000E+00
0001024 0.4025E-06 0.5200E-07 0.4041E-06 0.2536E-07 0.0000E+00
0001025 0.4011E-06 0.4383E-07 0.4026E-06 0.4545E-07 0.0000E+00
0001026 0.4004E-06 0.4536E-07 0.4019E-06 0.5705E-07 0.0000E+00
0001027 0.4021E-06 0.5115E-07 0.4036E-06 0.8312E-07 0.0000E+00
0001028 0.4085E-06 0.4577E-07 0.4099E-06 0.1142E-06 0.0000E+00
0001029 0.4243E-06 0.6259E-07 0.4256E-06 0.1613E-06 0.0000E+00
0001030 0.4559E-06 0.5535E-07 0.4572E-06 0.3788E-07 0.0000E+00
0001031 0.3862E-06 0.4902E-07 0.3877E-06 0.2450E-07 0.0000E+00
0001032 0.3848E-06 0.4096E-07 0.3863E-06 0.4403E-07 0.0000E+00
0001033 0.3842E-06 0.4249E-07 0.3857E-06 0.5513E-07 0.0000E+00
0001034 0.3860E-06 0.4818E-07 0.3874E-06 0.8045E-07 0.0000E+00
0001035 0.3922E-06 0.4293E-07 0.3936E-06 0.1104E-06 0.0000E+00
0001036 0.4077E-06 0.5934E-07 0.4090E-06 0.1560E-06 0.0000E+00
0001037 0.4386E-06 0.5233E-07 0.4398E-06 0.3651E-07 0.0000E+00
0001038 0.3706E-06 0.4621E-07 0.3719E-06 0.2372E-07 0.0000E+00
0001039 0.3693E-06 0.3828E-07 0.3707E-06 0.4256E-07 0.0000E+00
0001040 0.3687E-06 0.3979E-07 0.3701E-06 0.5330E-07 0.0000E+00
0001041 0.3705E-06 0.4537E-07 0.3718E-06 0.7778E-07 0.0000E+00
0001042 0.3766E-06 0.4026E-07 0.3779E-06 0.1067E-06 0.0000E+00
0001043 0.3917E-06 0.5620E-07 0.3929E-06 0.1507E-06 0.0000E+00
0001044 0.4217E-06 0.4944E-07 0.4228E-06 0.3514E-07 0.0000E+00
0001045 0.3556E-06 0.4356E-07 0.3569E-06 0.2287E-07 0.0000E+00
0001046 0.3544E-06 0.3577E-07 0.3557E-06 0.4107E-07 0.0000E+00
0001047 0.3539E-06 0.3727E-07 0.3552E-06 0.5136E-07 0.0000E+00
0001048 0.3556E-06 0.4273E-07 0.3569E-06 0.7502E-07 0.0000E+00
0001049 0.3616E-06 0.3776E-07 0.3628E-06 0.1029E-06 0.0000E+00
0001050 0.3763E-06 0.5323E-07 0.3775E-06 0.1453E-06 0.0000E+00
0001051 0.4054E-06 0.4672E-07 0.4065E-06 0.3378E-07 0.0000E+00
0001052 0.3413E-06 0.4107E-07 0.3425E-06 0.2205E-07 0.0000E+00
0001053 0.3401E-06 0.3343E-07 0.3413E-06 0.3959E-07 0.0000E+00
0001054 0.3397E-06 0.3491E-07 0.3409E-06 0.4949E-07 0.0000E+00
0001055 0.3414E-06 0.4023E-07 0.3426E-06 0.7232E-07 0.0000E+00
0001056 0.3472E-06 0.3541E-07 0.3483E-06 0.9912E-07 0.0000E+00
0001057 0.3615E-06 0.5038E-07 0.3625E-06 0.1400E-06 0.0000E+00
0001058 0.3896E-06 0.4413E-07 0.3906E-06 0.3243E-07 0.0000E+00
0001059 0.3276E-06 0.3871E-07 0.3287E-06 0.2121E-07 0.0000E+00
0001060 0.3265E-06 0.3124E-07 0.3276E-06 0.3811E-07 0.0000E+00
0001061 0.3261E-06 0.3270E-07 0.3272E-06 0.4758E-07 0.0000E+00
0001062 0.3277E-06 0.3788E-07 0.3288E-06 0.6960E-07 0.0000E+00
0001063 0.3334E-06 0.3322E-07 0.3345E-06 0.9534E-07 0.0000E+00
0001064 0.3472E-06 0.4769E-07 0.3482E-06 0.1347E-06 0.0000E+00
0001065 0.3744E-06 0.4169E-07 0.3753E-06 0.3112E-07 0.0000E+00
0001066 0.3144E-06 0.3650E-07 0.3155E-06 0.2041E-07 0.0000E+00
0001067 0.3134E-06 0.2920E-07 0.3145E-06 0.3666E-07 0.0000E+00
0001068 0.3130E-06 0.3063E-07 0.3141E-06 0.4576E-07 0.0000E+00
0001069 0.3147E-06 0.3566E-07 0.3157E-06 0.6696E-07 0.0000E+00
0001070 0.3201E-06 0.3115E-07 0.3211E-06 0.8774E-07 0.0000E+00
0001071 0.3332E-06 0.3411E-07 0.3341E-06 0.1279E-06 0.0000E+00
0001072 0.3585E-06 0.3910E-07 0.3593E-06 0.2989E-07 0.0000E+00
0001073 0.3018E-06 0.3403E-07 0.3028E-06 0.1912E-07 0.0000E+00
0001074 0.3008E-06 0.2733E-07 0.3018E-06 0.3510E-07 0.0000E+00
0001075 0.3004E-06 0.2867E-07 0.3014E-06 0.4318E-07 0.0000E+00
0001076 0.3020E-06 0.3356E-07 0.3030E-06 0.6387E-07 0.0000E+00
0001077 0.3072E-06 0.2908E-07 0.3081E-06 0.8343E-07 0.0000E+00
0001078 0.3196E-06 0.3204E-07 0.3205E-06 0.1221E-06 0.0000E+00
0001079 0.3437E-06 0.3662E-07 0.3445E-06 0.2817E-07 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 17
0001080 0.2898E-06 0.3198E-07 0.2907E-06 0.1832E-07 0.0000E+00
0001081 0.2888E-06 0.2552E-07 0.2897E-06 0.3337E-07 0.0000E+00
0001082 0.2884E-06 0.2679E-07 0.2893E-06 0.4129E-07 0.0000E+00
0001083 0.2899E-06 0.3135E-07 0.2908E-06 0.6088E-07 0.0000E+00
0001084 0.2948E-06 0.2721E-07 0.2957E-06 0.7973E-07 0.0000E+00
0001085 0.3066E-06 0.2996E-07 0.3074E-06 0.1166E-06 0.0000E+00
0001086 0.3297E-06 0.3437E-07 0.3304E-06 0.2688E-07 0.0000E+00
0001087 0.2782E-06 0.3002E-07 0.2791E-06 0.1742E-07 0.0000E+00
0001088 0.2773E-06 0.2385E-07 0.2782E-06 0.3190E-07 0.0000E+00
0001089 0.2769E-06 0.2507E-07 0.2778E-06 0.3932E-07 0.0000E+00
0001090 0.2783E-06 0.2944E-07 0.2792E-06 0.5817E-07 0.0000E+00
0001091 0.2830E-06 0.2547E-07 0.2838E-06 0.7616E-07 0.0000E+00
0001092 0.2943E-06 0.2813E-07 0.2951E-06 0.1116E-06 0.0000E+00
0001093 0.3163E-06 0.3230E-07 0.3171E-06 0.2555E-07 0.0000E+00
0001094 0.2671E-06 0.2823E-07 0.2679E-06 0.1668E-07 0.0000E+00
0001095 0.2662E-06 0.2229E-07 0.2671E-06 0.3049E-07 0.0000E+00
0001096 0.2659E-06 0.2345E-07 0.2667E-06 0.3762E-07 0.0000E+00
0001097 0.2672E-06 0.2761E-07 0.2680E-06 0.5566E-07 0.0000E+00
0001098 0.2717E-06 0.2385E-07 0.2725E-06 0.7294E-07 0.0000E+00
0001099 0.2825E-06 0.2638E-07 0.2832E-06 0.1069E-06 0.0000E+00
0001100 0.3037E-06 0.3037E-07 0.3044E-06 0.2439E-07 0.0000E+00
0001101 0.2565E-06 0.2655E-07 0.2573E-06 0.1595E-07 0.0000E+00
0001102 0.2556E-06 0.2083E-07 0.2564E-06 0.2921E-07 0.0000E+00
0001103 0.2553E-06 0.2195E-07 0.2561E-06 0.3598E-07 0.0000E+00
0001104 0.2566E-06 0.2595E-07 0.2573E-06 0.5333E-07 0.0000E+00
0001105 0.2609E-06 0.2234E-07 0.2616E-06 0.6990E-07 0.0000E+00
0001106 0.2713E-06 0.2479E-07 0.2720E-06 0.1025E-06 0.0000E+00
0001107 0.2916E-06 0.2861E-07 0.2923E-06 0.2328E-07 0.0000E+00
0001108 0.2463E-06 0.2500E-07 0.2470E-06 0.1530E-07 0.0000E+00
0001109 0.2455E-06 0.1947E-07 0.2462E-06 0.2802E-07 0.0000E+00
0001110 0.2452E-06 0.2056E-07 0.2459E-06 0.3451E-07 0.0000E+00
0001111 0.2464E-06 0.2439E-07 0.2471E-06 0.5119E-07 0.0000E+00
0001112 0.2506E-06 0.2094E-07 0.2513E-06 0.6713E-07 0.0000E+00
0001113 0.2606E-06 0.2330E-07 0.2613E-06 0.9846E-07 0.0000E+00
0001114 0.2802E-06 0.2696E-07 0.2809E-06 0.2228E-07 0.0000E+00
0001115 0.2365E-06 0.2356E-07 0.2372E-06 0.1469E-07 0.0000E+00
0001116 0.2358E-06 0.1821E-07 0.2365E-06 0.2693E-07 0.0000E+00
0001117 0.2355E-06 0.1926E-07 0.2362E-06 0.3315E-07 0.0000E+00
0001118 0.2367E-06 0.2296E-07 0.2374E-06 0.4923E-07 0.0000E+00
0001119 0.2407E-06 0.1964E-07 0.2414E-06 0.6458E-07 0.0000E+00
0001120 0.2504E-06 0.2193E-07 0.2511E-06 0.9473E-07 0.0000E+00
0001121 0.2694E-06 0.2545E-07 0.2701E-06 0.2136E-07 0.0000E+00
0001122 0.2272E-06 0.2222E-07 0.2278E-06 0.1415E-07 0.0000E+00
0001123 0.2265E-06 0.1702E-07 0.2271E-06 0.2595E-07 0.0000E+00
0001124 0.2262E-06 0.1805E-07 0.2268E-06 0.3194E-07 0.0000E+00
0001125 0.2274E-06 0.2164E-07 0.2280E-06 0.4748E-07 0.0000E+00
0001126 0.2314E-06 0.1843E-07 0.2320E-06 0.6230E-07 0.0000E+00
0001127 0.2408E-06 0.2066E-07 0.2414E-06 0.9137E-07 0.0000E+00
0001128 0.2592E-06 0.2406E-07 0.2598E-06 0.2053E-07 0.0000E+00
0001129 0.2182E-06 0.2098E-07 0.2188E-06 0.1366E-07 0.0000E+00
0001130 0.2175E-06 0.1592E-07 0.2181E-06 0.2508E-07 0.0000E+00
0001131 0.2173E-06 0.1693E-07 0.2179E-06 0.3087E-07 0.0000E+00
0001132 0.2185E-06 0.2043E-07 0.2191E-06 0.4593E-07 0.0000E+00
0001133 0.2224E-06 0.1732E-07 0.2231E-06 0.6029E-07 0.0000E+00
0001134 0.2317E-06 0.1950E-07 0.2323E-06 0.8838E-07 0.0000E+00
0001135 0.2496E-06 0.2280E-07 0.2503E-06 0.1980E-07 0.0000E+00
0001136 0.2096E-06 0.1985E-07 0.2102E-06 0.1325E-07 0.0000E+00
0001137 0.2090E-06 0.1489E-07 0.2095E-06 0.2434E-07 0.0000E+00
0001138 0.2088E-06 0.1590E-07 0.2094E-06 0.2997E-07 0.0000E+00
0001139 0.2100E-06 0.1933E-07 0.2106E-06 0.4462E-07 0.0000E+00
0001140 0.2139E-06 0.1629E-07 0.2145E-06 0.5860E-07 0.0000E+00
0001141 0.2231E-06 0.1843E-07 0.2237E-06 0.8581E-07 0.0000E+00
0001142 0.2408E-06 0.2165E-07 0.2414E-06 0.1918E-07 0.0000E+00
0001143 0.2014E-06 0.1882E-07 0.2019E-06 0.1291E-07 0.0000E+00
0001144 0.2008E-06 0.1393E-07 0.2013E-06 0.2373E-07 0.0000E+00
0001145 0.2006E-06 0.1495E-07 0.2012E-06 0.2924E-07 0.0000E+00
0001146 0.2019E-06 0.1834E-07 0.2025E-06 0.4357E-07 0.0000E+00
0001147 0.2059E-06 0.1535E-07 0.2065E-06 0.5723E-07 0.0000E+00
0001148 0.2150E-06 0.1748E-07 0.2157E-06 0.1553E-07 0.0000E+00
0001149 0.1943E-06 0.1563E-07 0.1948E-06 0.7116E-08 0.0000E+00
0001150 0.1935E-06 0.1308E-07 0.1940E-06 0.1823E-07 0.0000E+00
0001151 0.1929E-06 0.1353E-07 0.1934E-06 0.1813E-07 0.0000E+00
0001152 0.1930E-06 0.1545E-07 0.1935E-06 0.3103E-07 0.0000E+00
0001153 0.1944E-06 0.1358E-07 0.1950E-06 0.3881E-07 0.0000E+00
0001154 0.1988E-06 0.1881E-07 0.1994E-06 0.5979E-07 0.0000E+00
0001155 0.2086E-06 0.1666E-07 0.2093E-06 0.1240E-07 0.0000E+00
0001156 0.1867E-06 0.1522E-07 0.1872E-06 0.1034E-07 0.0000E+00
0001157 0.1859E-06 0.1220E-07 0.1864E-06 0.1593E-07 0.0000E+00
0001158 0.1855E-06 0.1275E-07 0.1860E-06 0.2188E-07 0.0000E+00
0001159 0.1857E-06 0.1473E-07 0.1863E-06 0.3045E-07 0.0000E+00
0001160 0.1876E-06 0.1297E-07 0.1882E-06 0.4372E-07 0.0000E+00
0001161 0.1927E-06 0.1860E-07 0.1934E-06 0.6130E-07 0.0000E+00
0001162 0.2039E-06 0.1638E-07 0.2047E-06 0.1434E-07 0.0000E+00
0001163 0.1794E-06 0.1466E-07 0.1798E-06 0.9183E-08 0.0000E+00
0001164 0.1787E-06 0.1145E-07 0.1792E-06 0.1793E-07 0.0000E+00
0001165 0.1784E-06 0.1211E-07 0.1789E-06 0.2139E-07 0.0000E+00
0001166 0.1789E-06 0.1444E-07 0.1795E-06 0.3271E-07 0.0000E+00
0001167 0.1813E-06 0.1236E-07 0.1819E-06 0.4260E-07 0.0000E+00
0001168 0.1873E-06 0.1382E-07 0.1880E-06 0.6364E-07 0.0000E+00
0001169 0.1995E-06 0.1612E-07 0.2003E-06 0.1424E-07 0.0000E+00
0001170 0.1724E-06 0.1422E-07 0.1728E-06 0.1016E-07 0.0000E+00
0001171 0.1718E-06 0.1074E-07 0.1723E-06 0.1821E-07 0.0000E+00
0001172 0.1716E-06 0.1151E-07 0.1721E-06 0.2299E-07 0.0000E+00
0001173 0.1725E-06 0.1410E-07 0.1731E-06 0.3399E-07 0.0000E+00
0001174 0.1754E-06 0.1182E-07 0.1761E-06 0.4530E-07 0.0000E+00
0001175 0.1823E-06 0.1347E-07 0.1831E-06 0.6623E-07 0.0000E+00
0001176 0.1959E-06 0.1593E-07 0.1969E-06 0.1500E-07 0.0000E+00
0001177 0.1657E-06 0.1389E-07 0.1661E-06 0.1030E-07 0.0000E+00
0001178 0.1652E-06 0.1007E-07 0.1657E-06 0.1928E-07 0.0000E+00
0001179 0.1652E-06 0.1096E-07 0.1657E-06 0.2219E-07 0.0000E+00
0001180 0.1663E-06 0.1053E-07 0.1669E-06 0.3653E-07 0.0000E+00
0001181 0.1697E-06 0.1450E-07 0.1704E-06 0.4702E-07 0.0000E+00
0001182 0.1777E-06 0.1288E-07 0.1786E-06 0.1252E-07 0.0000E+00
0001183 0.1599E-06 0.1171E-07 0.1603E-06 0.6346E-08 0.0000E+00
0001184 0.1593E-06 0.9444E-08 0.1597E-06 0.1549E-07 0.0000E+00
0001185 0.1589E-06 0.9911E-08 0.1593E-06 0.1620E-07 0.0000E+00
0001186 0.1592E-06 0.1167E-07 0.1597E-06 0.2712E-07 0.0000E+00
0001187 0.1609E-06 0.1007E-07 0.1615E-06 0.3466E-07 0.0000E+00
0001188 0.1654E-06 0.1484E-07 0.1662E-06 0.5266E-07 0.0000E+00
0001189 0.1752E-06 0.1298E-07 0.1761E-06 0.1115E-07 0.0000E+00
0001190 0.1537E-06 0.1171E-07 0.1541E-06 0.9266E-08 0.0000E+00
0001191 0.1532E-06 0.8852E-08 0.1536E-06 0.1489E-07 0.0000E+00
0001192 0.1530E-06 0.9497E-08 0.1535E-06 0.2019E-07 0.0000E+00
0001193 0.1537E-06 0.1162E-07 0.1542E-06 0.2867E-07 0.0000E+00
0001194 0.1562E-06 0.9795E-08 0.1568E-06 0.3945E-07 0.0000E+00
0001195 0.1620E-06 0.1114E-07 0.1628E-06 0.5677E-07 0.0000E+00
0001196 0.1738E-06 0.1328E-07 0.1747E-06 0.1323E-07 0.0000E+00
0001197 0.1478E-06 0.1159E-07 0.1482E-06 0.8724E-08 0.0000E+00
0001198 0.1474E-06 0.8337E-08 0.1478E-06 0.1720E-07 0.0000E+00
0001199 0.1474E-06 0.9137E-08 0.1478E-06 0.1933E-07 0.0000E+00
0001200 0.1484E-06 0.8774E-08 0.1490E-06 0.3249E-07 0.0000E+00
0001201 0.1515E-06 0.1229E-07 0.1522E-06 0.4147E-07 0.0000E+00
0001202 0.1587E-06 0.1089E-07 0.1596E-06 0.1123E-07 0.0000E+00
0001203 0.1427E-06 0.9856E-08 0.1430E-06 0.5589E-08 0.0000E+00
0001204 0.1421E-06 0.7818E-08 0.1425E-06 0.1408E-07 0.0000E+00
0001205 0.1418E-06 0.8269E-08 0.1422E-06 0.1457E-07 0.0000E+00
0001206 0.1422E-06 0.9924E-08 0.1426E-06 0.2470E-07 0.0000E+00
0001207 0.1438E-06 0.8437E-08 0.1443E-06 0.3044E-07 0.0000E+00
0001208 0.1481E-06 0.9512E-08 0.1488E-06 0.4762E-07 0.0000E+00
0001209 0.1571E-06 0.1112E-07 0.1580E-06 0.1006E-07 0.0000E+00
0001210 0.1371E-06 0.9932E-08 0.1375E-06 0.8417E-08 0.0000E+00
0001211 0.1367E-06 0.7341E-08 0.1371E-06 0.1367E-07 0.0000E+00
0001212 0.1366E-06 0.7963E-08 0.1370E-06 0.1849E-07 0.0000E+00
0001213 0.1373E-06 0.9981E-08 0.1378E-06 0.2644E-07 0.0000E+00
0001214 0.1398E-06 0.8246E-08 0.1404E-06 0.3642E-07 0.0000E+00
0001215 0.1456E-06 0.9562E-08 0.1463E-06 0.3800E-07 0.0000E+00
0001216 0.1546E-06 0.1027E-07 0.1320E-06 0.1136E-07 0.0000E+00
0001217 0.1319E-06 0.8199E-08 0.1338E-06 0.1536E-07 0.0000E+00
0001218 0.1310E-06 0.7215E-08 0.1350E-06 0.1945E-07 0.0000E+00
0001219 0.1313E-06 0.9354E-08 0.1375E-06 0.2732E-07 0.0000E+00
0001220 0.1335E-06 0.8434E-08 0.1426E-06 0.3802E-07 0.0000E+00
0001221 0.1394E-06 0.1010E-07 0.1524E-06 0.3323E-07 0.0000E+00
0001222 0.1492E-06 0.1056E-07 0.1280E-06 0.9847E-08 0.0000E+00
0001223 0.1274E-06 0.7854E-08 0.1293E-06 0.1615E-07 0.0000E+00
0001224 0.1266E-06 0.6914E-08 0.1304E-06 0.1720E-07 0.0000E+00
0001225 0.1267E-06 0.9103E-08 0.1327E-06 0.2567E-07 0.0000E+00
0001226 0.1287E-06 0.8173E-08 0.1371E-06 0.3391E-07 0.0000E+00
0001227 0.1341E-06 0.9810E-08 0.1460E-06 0.3082E-07 0.0000E+00
0001228 0.1428E-06 0.1002E-07 0.1236E-06 0.8683E-08 0.0000E+00
0001229 0.1231E-06 0.7398E-08 0.1247E-06 0.1528E-07 0.0000E+00
0001230 0.1223E-06 0.6533E-08 0.1254E-06 0.1500E-07 0.0000E+00
0001231 0.1223E-06 0.8466E-08 0.1271E-06 0.2289E-07 0.0000E+00
0001232 0.1238E-06 0.7643E-08 0.1305E-06 0.2963E-07 0.0000E+00
0001233 0.1280E-06 0.9079E-08 0.1378E-06 0.2749E-07 0.0000E+00
0001234 0.1351E-06 0.9180E-08 0.1194E-06 0.7762E-08 0.0000E+00
0001235 0.1190E-06 0.6878E-08 0.1202E-06 0.1412E-07 0.0000E+00
0001236 0.1182E-06 0.6141E-08 0.1206E-06 0.1319E-07 0.0000E+00
0001237 0.1180E-06 0.7796E-08 0.1218E-06 0.2036E-07 0.0000E+00
0001238 0.1191E-06 0.7081E-08 0.1243E-06 0.2604E-07 0.0000E+00
0001239 0.1223E-06 0.8306E-08 0.1300E-06 0.2441E-07 0.0000E+00
0001240 0.1278E-06 0.8330E-08 0.1154E-06 0.7017E-08 0.0000E+00
0001241 0.1149E-06 0.6379E-08 0.1159E-06 0.1289E-07 0.0000E+00
0001242 0.1142E-06 0.5762E-08 0.1161E-06 0.1175E-07 0.0000E+00
0001243 0.1139E-06 0.7173E-08 0.1170E-06 0.1813E-07 0.0000E+00
0001244 0.1147E-06 0.6553E-08 0.1188E-06 0.2314E-07 0.0000E+00
0001245 0.1171E-06 0.7598E-08 0.1233E-06 0.3356E-07 0.0000E+00
0001246 0.1235E-06 0.9488E-08 0.1312E-06 0.9021E-08 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 18
0001247 0.1109E-06 0.7581E-08 0.1114E-06 0.5746E-08 0.0000E+00
0001248 0.1106E-06 0.5194E-08 0.1107E-06 0.1067E-07 0.0000E+00
0001249 0.1103E-06 0.5669E-08 0.1104E-06 0.1130E-07 0.0000E+00
0001250 0.1104E-06 0.5434E-08 0.1105E-06 0.1882E-07 0.0000E+00
0001251 0.1113E-06 0.7450E-08 0.1113E-06 0.2362E-07 0.0000E+00
0001252 0.1140E-06 0.6587E-08 0.1138E-06 0.3509E-07 0.0000E+00
0001253 0.1197E-06 0.8046E-08 0.1193E-06 0.7720E-08 0.0000E+00
0001254 0.1067E-06 0.6880E-08 0.1069E-06 0.5523E-08 0.0000E+00
0001255 0.1062E-06 0.4860E-08 0.1065E-06 0.9736E-08 0.0000E+00
0001256 0.1059E-06 0.5314E-08 0.1062E-06 0.1111E-07 0.0000E+00
0001257 0.1060E-06 0.5103E-08 0.1064E-06 0.1802E-07 0.0000E+00
0001258 0.1069E-06 0.7061E-08 0.1073E-06 0.2330E-07 0.0000E+00
0001259 0.1096E-06 0.6263E-08 0.1102E-06 0.3429E-07 0.0000E+00
0001260 0.1153E-06 0.7694E-08 0.1161E-06 0.7730E-08 0.0000E+00
0001261 0.1025E-06 0.6576E-08 0.1028E-06 0.5306E-08 0.0000E+00
0001262 0.1021E-06 0.4557E-08 0.1024E-06 0.9919E-08 0.0000E+00
0001263 0.1019E-06 0.5023E-08 0.1021E-06 0.1113E-07 0.0000E+00
0001264 0.1021E-06 0.4810E-08 0.1023E-06 0.1834E-07 0.0000E+00
0001265 0.1030E-06 0.6763E-08 0.1034E-06 0.2353E-07 0.0000E+00
0001266 0.1059E-06 0.5972E-08 0.1064E-06 0.3475E-07 0.0000E+00
0001267 0.1119E-06 0.7387E-08 0.1125E-06 0.7664E-08 0.0000E+00
0001268 0.9856E-07 0.6341E-08 0.9877E-07 0.5368E-08 0.0000E+00
0001269 0.9820E-07 0.4280E-08 0.9842E-07 0.9968E-08 0.0000E+00
0001270 0.9799E-07 0.4775E-08 0.9825E-07 0.1133E-07 0.0000E+00
0001271 0.9827E-07 0.4561E-08 0.9859E-07 0.1799E-07 0.0000E+00
0001272 0.9943E-07 0.4941E-08 0.9986E-07 0.2375E-07 0.0000E+00
0001273 0.1025E-06 0.5782E-08 0.1031E-06 0.3507E-07 0.0000E+00
0001274 0.1090E-06 0.7086E-08 0.1098E-06 0.7668E-08 0.0000E+00
0001275 0.9473E-07 0.6147E-08 0.9496E-07 0.5490E-08 0.0000E+00
0001276 0.9443E-07 0.4017E-08 0.9465E-07 0.1016E-07 0.0000E+00
0001277 0.9429E-07 0.4539E-08 0.9456E-07 0.1168E-07 0.0000E+00
0001278 0.9469E-07 0.4319E-08 0.9503E-07 0.1849E-07 0.0000E+00
0001279 0.9608E-07 0.4735E-08 0.9654E-07 0.2448E-07 0.0000E+00
0001280 0.9959E-07 0.5591E-08 0.1002E-06 0.3594E-07 0.0000E+00
0001281 0.1066E-06 0.6929E-08 0.1074E-06 0.7829E-08 0.0000E+00
0001282 0.9108E-07 0.6006E-08 0.9130E-07 0.5619E-08 0.0000E+00
0001283 0.9083E-07 0.3781E-08 0.9105E-07 0.1047E-07 0.0000E+00
0001284 0.9077E-07 0.4346E-08 0.9104E-07 0.1207E-07 0.0000E+00
0001285 0.9133E-07 0.4123E-08 0.9169E-07 0.1915E-07 0.0000E+00
0001286 0.9300E-07 0.4569E-08 0.9350E-07 0.2532E-07 0.0000E+00
0001287 0.9702E-07 0.5490E-08 0.9771E-07 0.6661E-08 0.0000E+00
0001288 0.8796E-07 0.4853E-08 0.8815E-07 0.3358E-08 0.0000E+00
0001289 0.8762E-07 0.3543E-08 0.8781E-07 0.8476E-08 0.0000E+00
0001290 0.8738E-07 0.3855E-08 0.8760E-07 0.8065E-08 0.0000E+00
0001291 0.8751E-07 0.3722E-08 0.8779E-07 0.1509E-07 0.0000E+00
0001292 0.8830E-07 0.5119E-08 0.8867E-07 0.1815E-07 0.0000E+00
0001293 0.9064E-07 0.4574E-08 0.9115E-07 0.2827E-07 0.0000E+00
0001294 0.9557E-07 0.5600E-08 0.9625E-07 0.5889E-08 0.0000E+00
0001295 0.8457E-07 0.4958E-08 0.8476E-07 0.4949E-08 0.0000E+00
0001296 0.8429E-07 0.3332E-08 0.8448E-07 0.8190E-08 0.0000E+00
0001297 0.8417E-07 0.3746E-08 0.8440E-07 0.1025E-07 0.0000E+00
0001298 0.8451E-07 0.3574E-08 0.8480E-07 0.1549E-07 0.0000E+00
0001299 0.8572E-07 0.3918E-08 0.8612E-07 0.2129E-07 0.0000E+00
0001300 0.8877E-07 0.4626E-08 0.8931E-07 0.3073E-07 0.0000E+00
0001301 0.9493E-07 0.5742E-08 0.9564E-07 0.6912E-08 0.0000E+00
0001302 0.8133E-07 0.5029E-08 0.8151E-07 0.4771E-08 0.0000E+00
0001303 0.8112E-07 0.3148E-08 0.8130E-07 0.9415E-08 0.0000E+00
0001304 0.8111E-07 0.3648E-08 0.8133E-07 0.1064E-07 0.0000E+00
0001305 0.8169E-07 0.3461E-08 0.8198E-07 0.1727E-07 0.0000E+00
0001306 0.8334E-07 0.3863E-08 0.8373E-07 0.2267E-07 0.0000E+00
0001307 0.8721E-07 0.4690E-08 0.8773E-07 0.6058E-08 0.0000E+00
0001308 0.7855E-07 0.4152E-08 0.7871E-07 0.3025E-08 0.0000E+00
0001309 0.7827E-07 0.2956E-08 0.7842E-07 0.7850E-08 0.0000E+00
0001310 0.7809E-07 0.3258E-08 0.7827E-07 0.7479E-08 0.0000E+00
0001311 0.7831E-07 0.3140E-08 0.7853E-07 0.1409E-07 0.0000E+00
0001312 0.7919E-07 0.4461E-08 0.7949E-07 0.1699E-07 0.0000E+00
0001313 0.8166E-07 0.3966E-08 0.8206E-07 0.2648E-07 0.0000E+00
0001314 0.8668E-07 0.4929E-08 0.8719E-07 0.5446E-08 0.0000E+00
0001315 0.7555E-07 0.4365E-08 0.7570E-07 0.4680E-08 0.0000E+00
0001316 0.7533E-07 0.2786E-08 0.7548E-07 0.7751E-08 0.0000E+00
0001317 0.7529E-07 0.3204E-08 0.7547E-07 0.9813E-08 0.0000E+00
0001318 0.7574E-07 0.3045E-08 0.7596E-07 0.1484E-07 0.0000E+00
0001319 0.7714E-07 0.3394E-08 0.7742E-07 0.2044E-07 0.0000E+00
0001320 0.8043E-07 0.4095E-08 0.8082E-07 0.5090E-08 0.0000E+00
0001321 0.7297E-07 0.3671E-08 0.7310E-07 0.2956E-08 0.0000E+00
0001322 0.7270E-07 0.2622E-08 0.7283E-07 0.6805E-08 0.0000E+00
0001323 0.7253E-07 0.2890E-08 0.7268E-07 0.7033E-08 0.0000E+00
0001324 0.7271E-07 0.2785E-08 0.7289E-07 0.1257E-07 0.0000E+00
0001325 0.7352E-07 0.3963E-08 0.7374E-07 0.1571E-07 0.0000E+00
0001326 0.7574E-07 0.3524E-08 0.7603E-07 0.2404E-07 0.0000E+00
0001327 0.8032E-07 0.4394E-08 0.8070E-07 0.5053E-08 0.0000E+00
0001328 0.7018E-07 0.3898E-08 0.7031E-07 0.4108E-08 0.0000E+00
0001329 0.6997E-07 0.2476E-08 0.7010E-07 0.7192E-08 0.0000E+00
0001330 0.6993E-07 0.2851E-08 0.7008E-07 0.8842E-08 0.0000E+00
0001331 0.7035E-07 0.2712E-08 0.7052E-07 0.1369E-07 0.0000E+00
0001332 0.7162E-07 0.3027E-08 0.7184E-07 0.1866E-07 0.0000E+00
0001333 0.7466E-07 0.3666E-08 0.7495E-07 0.1890E-07 0.0000E+00
0001334 0.7947E-07 0.4066E-08 0.6751E-07 0.5383E-08 0.0000E+00
0001335 0.6753E-07 0.3096E-08 0.6841E-07 0.7770E-08 0.0000E+00
0001336 0.6712E-07 0.2533E-08 0.6907E-07 0.9559E-08 0.0000E+00
0001337 0.6731E-07 0.3679E-08 0.7037E-07 0.1384E-07 0.0000E+00
0001338 0.6856E-07 0.3233E-08 0.7302E-07 0.1902E-07 0.0000E+00
0001339 0.7182E-07 0.4083E-08 0.7812E-07 0.1720E-07 0.0000E+00
0001340 0.7700E-07 0.4334E-08 0.6538E-07 0.4778E-08 0.0000E+00
0001341 0.6527E-07 0.2982E-08 0.6613E-07 0.8021E-08 0.0000E+00
0001342 0.6486E-07 0.2454E-08 0.6669E-07 0.8373E-08 0.0000E+00
0001343 0.6496E-07 0.2636E-08 0.6786E-07 0.1285E-07 0.0000E+00
0001344 0.6605E-07 0.3171E-08 0.7014E-07 0.1706E-07 0.0000E+00
0001345 0.6892E-07 0.3911E-08 0.7474E-07 0.1565E-07 0.0000E+00
0001346 0.7353E-07 0.4089E-08 0.6320E-07 0.4343E-08 0.0000E+00
0001347 0.6307E-07 0.2798E-08 0.6381E-07 0.7715E-08 0.0000E+00
0001348 0.6267E-07 0.2332E-08 0.6422E-07 0.7492E-08 0.0000E+00
0001349 0.6268E-07 0.2465E-08 0.6515E-07 0.1171E-07 0.0000E+00
0001350 0.6354E-07 0.2974E-08 0.6697E-07 0.1531E-07 0.0000E+00
0001351 0.6584E-07 0.3618E-08 0.7085E-07 0.1401E-07 0.0000E+00
0001352 0.6969E-07 0.3759E-08 0.6110E-07 0.3969E-08 0.0000E+00
0001353 0.6094E-07 0.2593E-08 0.6156E-07 0.7229E-08 0.0000E+00
0001354 0.6055E-07 0.2197E-08 0.6182E-07 0.6711E-08 0.0000E+00
0001355 0.6050E-07 0.2301E-08 0.6252E-07 0.1059E-07 0.0000E+00
0001356 0.6115E-07 0.2760E-08 0.6392E-07 0.1371E-07 0.0000E+00
0001357 0.6295E-07 0.3319E-08 0.6709E-07 0.1262E-07 0.0000E+00
0001358 0.6608E-07 0.3425E-08 0.5907E-07 0.3660E-08 0.0000E+00
0001359 0.5889E-07 0.2400E-08 0.5940E-07 0.6690E-08 0.0000E+00
0001360 0.5851E-07 0.2064E-08 0.5956E-07 0.6075E-08 0.0000E+00
0001361 0.5842E-07 0.2148E-08 0.6006E-07 0.9575E-08 0.0000E+00
0001362 0.5890E-07 0.2553E-08 0.6114E-07 0.1238E-07 0.0000E+00
0001363 0.6032E-07 0.3043E-08 0.6369E-07 0.1151E-07 0.0000E+00
0001364 0.6286E-07 0.3122E-08 0.5710E-07 0.1538E-07 0.0000E+00
0001365 0.6555E-07 0.3014E-08 0.5742E-07 0.9388E-08 0.0000E+00
0001366 0.5662E-07 0.2924E-08 0.5885E-07 0.8586E-08 0.0000E+00
0001367 0.5647E-07 0.2371E-08 0.6031E-07 0.1301E-07 0.0000E+00
0001368 0.5743E-07 0.2952E-08 0.6257E-07 0.1051E-07 0.0000E+00
0001369 0.5925E-07 0.2926E-08 0.5560E-07 0.1215E-07 0.0000E+00
0001370 0.6118E-07 0.2566E-08 0.5567E-07 0.7305E-08 0.0000E+00
0001371 0.5499E-07 0.2520E-08 0.5664E-07 0.8470E-08 0.0000E+00
0001372 0.5480E-07 0.2168E-08 0.5752E-07 0.1064E-07 0.0000E+00
0001373 0.5537E-07 0.2594E-08 0.5914E-07 0.1426E-07 0.0000E+00
0001374 0.5735E-07 0.3346E-08 0.6219E-07 0.1463E-07 0.0000E+00
0001375 0.6018E-07 0.3317E-08 0.5363E-07 0.4389E-08 0.0000E+00
0001376 0.5353E-07 0.2215E-08 0.5404E-07 0.6521E-08 0.0000E+00
0001377 0.5316E-07 0.1798E-08 0.5428E-07 0.6744E-08 0.0000E+00
0001378 0.5317E-07 0.2003E-08 0.5479E-07 0.9917E-08 0.0000E+00
0001379 0.5380E-07 0.2402E-08 0.5594E-07 0.1329E-07 0.0000E+00
0001380 0.5553E-07 0.3032E-08 0.5847E-07 0.1387E-07 0.0000E+00
0001381 0.5807E-07 0.3042E-08 0.5179E-07 0.4122E-08 0.0000E+00
0001382 0.5174E-07 0.2076E-08 0.5224E-07 0.6871E-08 0.0000E+00
0001383 0.5137E-07 0.1721E-08 0.5243E-07 0.6593E-08 0.0000E+00
0001384 0.5136E-07 0.1884E-08 0.5290E-07 0.9816E-08 0.0000E+00
0001385 0.5195E-07 0.2275E-08 0.5392E-07 0.1306E-07 0.0000E+00
0001386 0.5351E-07 0.2832E-08 0.5625E-07 0.1318E-07 0.0000E+00
0001387 0.5587E-07 0.2826E-08 0.5005E-07 0.3970E-08 0.0000E+00
0001388 0.5002E-07 0.1937E-08 0.5047E-07 0.6898E-08 0.0000E+00
0001389 0.4965E-07 0.1633E-08 0.5063E-07 0.6382E-08 0.0000E+00
0001390 0.4962E-07 0.1766E-08 0.5105E-07 0.9531E-08 0.0000E+00
0001391 0.5016E-07 0.2131E-08 0.5194E-07 0.1262E-07 0.0000E+00
0001392 0.5156E-07 0.2626E-08 0.5406E-07 0.1261E-07 0.0000E+00
0001393 0.5372E-07 0.2610E-08 0.4838E-07 0.3838E-08 0.0000E+00
0001394 0.4835E-07 0.1807E-08 0.4877E-07 0.6771E-08 0.0000E+00
0001395 0.4800E-07 0.1545E-08 0.4890E-07 0.6174E-08 0.0000E+00
0001396 0.4795E-07 0.1657E-08 0.4926E-07 0.9209E-08 0.0000E+00
0001397 0.4844E-07 0.1993E-08 0.5006E-07 0.1219E-07 0.0000E+00
0001398 0.4973E-07 0.2435E-08 0.5200E-07 0.1214E-07 0.0000E+00
0001399 0.5171E-07 0.2415E-08 0.4676E-07 0.3720E-08 0.0000E+00
0001400 0.4674E-07 0.1690E-08 0.4713E-07 0.6599E-08 0.0000E+00
0001401 0.4639E-07 0.1462E-08 0.4724E-07 0.5986E-08 0.0000E+00
0001402 0.4634E-07 0.1558E-08 0.4757E-07 0.8907E-08 0.0000E+00
0001403 0.4680E-07 0.1866E-08 0.4829E-07 0.1180E-07 0.0000E+00
0001404 0.4800E-07 0.2267E-08 0.5009E-07 0.1178E-07 0.0000E+00
0001405 0.4984E-07 0.2244E-08 0.4520E-07 0.3619E-08 0.0000E+00
0001406 0.4518E-07 0.1585E-08 0.4555E-07 0.6428E-08 0.0000E+00
0001407 0.4485E-07 0.1384E-08 0.4565E-07 0.5829E-08 0.0000E+00
0001408 0.4480E-07 0.1469E-08 0.4595E-07 0.8649E-08 0.0000E+00
0001409 0.4523E-07 0.1753E-08 0.4662E-07 0.1148E-07 0.0000E+00
0001410 0.4637E-07 0.2120E-08 0.4832E-07 0.1148E-07 0.0000E+00
0001411 0.4811E-07 0.2095E-08 0.4369E-07 0.3533E-08 0.0000E+00
0001412 0.4368E-07 0.1492E-08 0.4403E-07 0.6273E-08 0.0000E+00
0001413 0.4335E-07 0.1311E-08 0.4413E-07 0.5698E-08 0.0000E+00
0001414 0.4330E-07 0.1388E-08 0.4441E-07 0.8431E-08 0.0000E+00
0001415 0.4373E-07 0.1652E-08 0.4505E-07 0.1121E-07 0.0000E+00
0001416 0.4482E-07 0.1992E-08 0.4667E-07 0.1124E-07 0.0000E+00
0001417 0.4649E-07 0.1965E-08 0.4223E-07 0.3458E-08 0.0000E+00
0001418 0.4223E-07 0.1408E-08 0.4257E-07 0.6136E-08 0.0000E+00
0001419 0.4191E-07 0.1244E-08 0.4266E-07 0.5587E-08 0.0000E+00
0001420 0.4187E-07 0.1314E-08 0.4294E-07 0.8243E-08 0.0000E+00
0001421 0.4228E-07 0.1561E-08 0.4355E-07 0.1098E-07 0.0000E+00
0001422 0.4335E-07 0.1877E-08 0.4512E-07 0.3058E-08 0.0000E+00
0001423 0.4098E-07 0.1498E-08 0.4106E-07 0.2460E-08 0.0000E+00
0001424 0.4081E-07 0.1074E-08 0.4081E-07 0.3730E-08 0.0000E+00
0001425 0.4063E-07 0.1192E-08 0.4062E-07 0.3926E-08 0.0000E+00
0001426 0.4052E-07 0.1123E-08 0.4051E-07 0.6160E-08 0.0000E+00
0001427 0.4055E-07 0.1203E-08 0.4049E-07 0.7741E-08 0.0000E+00
0001428 0.4085E-07 0.1349E-08 0.4077E-07 0.1156E-07 0.0000E+00
0001429 0.4173E-07 0.1622E-08 0.4154E-07 0.9780E-08 0.0000E+00
0001430 0.3922E-07 0.1756E-08 0.4297E-07 0.3860E-08 0.0000E+00
0001431 0.3952E-07 0.1260E-08 0.3927E-07 0.5239E-08 0.0000E+00
0001432 0.3959E-07 0.1084E-08 0.3899E-07 0.5518E-08 0.0000E+00
0001433 0.3981E-07 0.1171E-08 0.3897E-07 0.7511E-08 0.0000E+00
0001434 0.4037E-07 0.1354E-08 0.3934E-07 0.1033E-07 0.0000E+00
0001435 0.4173E-07 0.1671E-08 0.4038E-07 0.2703E-08 0.0000E+00
0001436 0.3811E-07 0.1346E-08 0.3812E-07 0.2044E-08 0.0000E+00
0001437 0.3788E-07 0.9648E-09 0.3796E-07 0.3376E-08 0.0000E+00
0001438 0.3771E-07 0.1080E-08 0.3781E-07 0.3704E-08 0.0000E+00
0001439 0.3760E-07 0.1017E-08 0.3772E-07 0.5734E-08 0.0000E+00
0001440 0.3759E-07 0.1089E-08 0.3778E-07 0.7401E-08 0.0000E+00
0001441 0.3785E-07 0.1243E-08 0.3814E-07 0.1089E-07 0.0000E+00
0001442 0.3858E-07 0.1496E-08 0.3908E-07 0.9615E-08 0.0000E+00
0001443 0.3989E-07 0.1576E-08 0.3648E-07 0.3316E-08 0.0000E+00
0001444 0.3645E-07 0.1158E-08 0.3675E-07 0.4450E-08 0.0000E+00
0001445 0.3620E-07 0.9957E-09 0.3685E-07 0.5025E-08 0.0000E+00
0001446 0.3618E-07 0.1075E-08 0.3710E-07 0.6824E-08 0.0000E+00
0001447 0.3655E-07 0.1279E-08 0.3771E-07 0.9622E-08 0.0000E+00
0001448 0.3756E-07 0.1576E-08 0.3912E-07 0.2474E-08 0.0000E+00
0001449 0.3538E-07 0.1260E-08 0.3545E-07 0.1925E-08 0.0000E+00
0001450 0.3524E-07 0.8664E-09 0.3524E-07 0.3159E-08 0.0000E+00
0001451 0.3510E-07 0.9780E-09 0.3508E-07 0.3468E-08 0.0000E+00
0001452 0.3502E-07 0.9190E-09 0.3499E-07 0.5396E-08 0.0000E+00
0001453 0.3508E-07 0.9955E-09 0.3500E-07 0.6947E-08 0.0000E+00
0001454 0.3543E-07 0.1142E-08 0.3528E-07 0.1025E-07 0.0000E+00
0001455 0.3633E-07 0.1397E-08 0.3605E-07 0.8772E-08 0.0000E+00
0001456 0.3387E-07 0.1539E-08 0.3742E-07 0.3337E-08 0.0000E+00
0001457 0.3415E-07 0.1069E-08 0.3391E-07 0.4439E-08 0.0000E+00
0001458 0.3425E-07 0.8949E-09 0.3366E-07 0.4826E-08 0.0000E+00
0001459 0.3450E-07 0.9822E-09 0.3366E-07 0.6592E-08 0.0000E+00
0001460 0.3509E-07 0.1167E-08 0.3403E-07 0.9092E-08 0.0000E+00
0001461 0.3645E-07 0.1468E-08 0.3504E-07 0.2348E-08 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 19
0001462 0.3291E-07 0.1171E-08 0.3291E-07 0.1752E-08 0.0000E+00
0001463 0.3271E-07 0.7830E-09 0.3278E-07 0.2974E-08 0.0000E+00
0001464 0.3257E-07 0.8950E-09 0.3265E-07 0.3239E-08 0.0000E+00
0001465 0.3249E-07 0.8399E-09 0.3259E-07 0.5073E-08 0.0000E+00
0001466 0.3251E-07 0.9129E-09 0.3267E-07 0.6528E-08 0.0000E+00
0001467 0.3280E-07 0.1067E-08 0.3304E-07 0.9649E-08 0.0000E+00
0001468 0.3356E-07 0.1314E-08 0.3397E-07 0.8492E-08 0.0000E+00
0001469 0.3487E-07 0.1410E-08 0.3149E-07 0.2955E-08 0.0000E+00
0001470 0.3148E-07 0.9974E-09 0.3176E-07 0.3942E-08 0.0000E+00
0001471 0.3126E-07 0.8281E-09 0.3188E-07 0.4472E-08 0.0000E+00
0001472 0.3126E-07 0.9091E-09 0.3214E-07 0.6077E-08 0.0000E+00
0001473 0.3163E-07 0.1109E-08 0.3275E-07 0.8542E-08 0.0000E+00
0001474 0.3260E-07 0.1394E-08 0.3412E-07 0.2160E-08 0.0000E+00
0001475 0.3055E-07 0.1104E-08 0.3061E-07 0.1682E-08 0.0000E+00
0001476 0.3044E-07 0.7061E-09 0.3043E-07 0.2781E-08 0.0000E+00
0001477 0.3032E-07 0.8175E-09 0.3030E-07 0.3072E-08 0.0000E+00
0001478 0.3028E-07 0.7645E-09 0.3023E-07 0.4782E-08 0.0000E+00
0001479 0.3037E-07 0.8428E-09 0.3026E-07 0.6181E-08 0.0000E+00
0001480 0.3074E-07 0.9931E-09 0.3057E-07 0.9117E-08 0.0000E+00
0001481 0.3166E-07 0.1242E-08 0.3135E-07 0.7840E-08 0.0000E+00
0001482 0.2924E-07 0.1384E-08 0.3270E-07 0.2906E-08 0.0000E+00
0001483 0.2952E-07 0.9276E-09 0.2928E-07 0.3886E-08 0.0000E+00
0001484 0.2965E-07 0.7499E-09 0.2907E-07 0.4274E-08 0.0000E+00
0001485 0.2991E-07 0.8380E-09 0.2908E-07 0.5851E-08 0.0000E+00
0001486 0.3052E-07 0.1025E-08 0.2945E-07 0.8082E-08 0.0000E+00
0001487 0.3185E-07 0.1312E-08 0.3041E-07 0.2055E-08 0.0000E+00
0001488 0.2842E-07 0.1035E-08 0.2841E-07 0.1549E-08 0.0000E+00
0001489 0.2825E-07 0.6408E-09 0.2832E-07 0.2627E-08 0.0000E+00
0001490 0.2814E-07 0.7526E-09 0.2821E-07 0.2877E-08 0.0000E+00
0001491 0.2808E-07 0.7028E-09 0.2817E-07 0.4508E-08 0.0000E+00
0001492 0.2813E-07 0.7778E-09 0.2828E-07 0.5816E-08 0.0000E+00
0001493 0.2844E-07 0.9340E-09 0.2866E-07 0.8596E-08 0.0000E+00
0001494 0.2922E-07 0.1174E-08 0.2960E-07 0.1830E-08 0.0000E+00
0001495 0.2730E-07 0.9764E-09 0.2733E-07 0.1363E-08 0.0000E+00
0001496 0.2718E-07 0.6040E-09 0.2719E-07 0.2467E-08 0.0000E+00
0001497 0.2708E-07 0.7156E-09 0.2709E-07 0.2735E-08 0.0000E+00
0001498 0.2705E-07 0.6693E-09 0.2706E-07 0.4373E-08 0.0000E+00
0001499 0.2717E-07 0.7538E-09 0.2714E-07 0.5695E-08 0.0000E+00
0001500 0.2758E-07 0.9145E-09 0.2753E-07 0.8480E-08 0.0000E+00
0001501 0.2857E-07 0.1172E-08 0.2847E-07 0.1836E-08 0.0000E+00
0001502 0.2625E-07 0.9683E-09 0.2626E-07 0.1380E-08 0.0000E+00
0001503 0.2613E-07 0.5759E-09 0.2615E-07 0.2515E-08 0.0000E+00
0001504 0.2604E-07 0.6997E-09 0.2606E-07 0.2818E-08 0.0000E+00
0001505 0.2603E-07 0.6502E-09 0.2605E-07 0.4474E-08 0.0000E+00
0001506 0.2616E-07 0.7414E-09 0.2618E-07 0.5843E-08 0.0000E+00
0001507 0.2662E-07 0.9147E-09 0.2664E-07 0.8642E-08 0.0000E+00
0001508 0.2766E-07 0.1182E-08 0.2770E-07 0.1846E-08 0.0000E+00
0001509 0.2524E-07 0.9781E-09 0.2525E-07 0.1375E-08 0.0000E+00
0001510 0.2513E-07 0.5491E-09 0.2514E-07 0.2534E-08 0.0000E+00
0001511 0.2506E-07 0.6828E-09 0.2507E-07 0.2840E-08 0.0000E+00
0001512 0.2507E-07 0.6327E-09 0.2507E-07 0.4537E-08 0.0000E+00
0001513 0.2525E-07 0.7322E-09 0.2524E-07 0.5926E-08 0.0000E+00
0001514 0.2580E-07 0.9194E-09 0.2577E-07 0.8770E-08 0.0000E+00
0001515 0.2700E-07 0.1201E-08 0.2694E-07 0.1871E-08 0.0000E+00
0001516 0.2427E-07 0.9908E-09 0.2428E-07 0.1415E-08 0.0000E+00
0001517 0.2417E-07 0.5252E-09 0.2418E-07 0.2598E-08 0.0000E+00
0001518 0.2411E-07 0.6736E-09 0.2412E-07 0.2938E-08 0.0000E+00
0001519 0.2416E-07 0.6207E-09 0.2416E-07 0.4671E-08 0.0000E+00
0001520 0.2439E-07 0.7310E-09 0.2438E-07 0.6111E-08 0.0000E+00
0001521 0.2503E-07 0.9333E-09 0.2501E-07 0.8988E-08 0.0000E+00
0001522 0.2637E-07 0.1230E-08 0.2634E-07 0.1908E-08 0.0000E+00
0001523 0.2333E-07 0.1014E-08 0.2334E-07 0.1438E-08 0.0000E+00
0001524 0.2325E-07 0.5032E-09 0.2326E-07 0.2656E-08 0.0000E+00
0001525 0.2321E-07 0.6660E-09 0.2321E-07 0.3012E-08 0.0000E+00
0001526 0.2329E-07 0.6117E-09 0.2328E-07 0.4798E-08 0.0000E+00
0001527 0.2359E-07 0.7322E-09 0.2356E-07 0.6279E-08 0.0000E+00
0001528 0.2435E-07 0.9509E-09 0.2430E-07 0.6233E-08 0.0000E+00
0001529 0.2242E-07 0.1086E-08 0.2551E-07 0.1917E-08 0.0000E+00
0001530 0.2266E-07 0.7279E-09 0.2246E-07 0.2822E-08 0.0000E+00
0001531 0.2280E-07 0.5441E-09 0.2231E-07 0.3092E-08 0.0000E+00
0001532 0.2308E-07 0.6336E-09 0.2234E-07 0.4583E-08 0.0000E+00
0001533 0.2369E-07 0.7980E-09 0.2265E-07 0.6145E-08 0.0000E+00
0001534 0.2495E-07 0.1056E-08 0.2349E-07 0.1587E-08 0.0000E+00
0001535 0.2181E-07 0.8377E-09 0.2179E-07 0.1023E-08 0.0000E+00
0001536 0.2168E-07 0.4530E-09 0.2173E-07 0.2058E-08 0.0000E+00
0001537 0.2161E-07 0.5580E-09 0.2166E-07 0.2116E-08 0.0000E+00
0001538 0.2160E-07 0.5220E-09 0.2167E-07 0.3556E-08 0.0000E+00
0001539 0.2171E-07 0.5958E-09 0.2182E-07 0.4493E-08 0.0000E+00
0001540 0.2210E-07 0.7557E-09 0.2228E-07 0.6826E-08 0.0000E+00
0001541 0.2298E-07 0.9802E-09 0.2328E-07 0.1400E-08 0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 21
0001542 0.2095E-07 0.8274E-09 0.2097E-07 0.1141E-08 0.0000E+00
0001543 0.2088E-07 0.4297E-09 0.2087E-07 0.1970E-08 0.0000E+00
0001544 0.2083E-07 0.5478E-09 0.2082E-07 0.2331E-08 0.0000E+00
0001545 0.2087E-07 0.5089E-09 0.2084E-07 0.3627E-08 0.0000E+00
0001546 0.2107E-07 0.6025E-09 0.2101E-07 0.4859E-08 0.0000E+00
0001547 0.2164E-07 0.7724E-09 0.2153E-07 0.7129E-08 0.0000E+00
0001548 0.2283E-07 0.1026E-08 0.2265E-07 0.1550E-08 0.0000E+00
0001549 0.2015E-07 0.8544E-09 0.2015E-07 0.1141E-08 0.0000E+00
0001550 0.2008E-07 0.4149E-09 0.2009E-07 0.2168E-08 0.0000E+00
0001551 0.2005E-07 0.5519E-09 0.2005E-07 0.2450E-08 0.0000E+00
0001552 0.2012E-07 0.5099E-09 0.2012E-07 0.3943E-08 0.0000E+00
0001553 0.2039E-07 0.6129E-09 0.2038E-07 0.5170E-08 0.0000E+00
0001554 0.2106E-07 0.8044E-09 0.2104E-07 0.7633E-08 0.0000E+00
0001555 0.2241E-07 0.1072E-08 0.2239E-07 0.1603E-08 0.0000E+00
0001556 0.1938E-07 0.8966E-09 0.1939E-07 0.1238E-08 0.0000E+00
0001557 0.1933E-07 0.4003E-09 0.1933E-07 0.2278E-08 0.0000E+00
0001558 0.1932E-07 0.5574E-09 0.1931E-07 0.2644E-08 0.0000E+00
0001559 0.1944E-07 0.5123E-09 0.1943E-07 0.4194E-08 0.0000E+00
0001560 0.1980E-07 0.6307E-09 0.1977E-07 0.5540E-08 0.0000E+00
0001561 0.2065E-07 0.8412E-09 0.2059E-07 0.1416E-08 0.0000E+00
0001562 0.1872E-07 0.7046E-09 0.1872E-07 0.7479E-09 0.0000E+00
0001563 0.1865E-07 0.3745E-09 0.1865E-07 0.1884E-08 0.0000E+00
0001564 0.1860E-07 0.4746E-09 0.1860E-07 0.1806E-08 0.0000E+00
0001565 0.1864E-07 0.4465E-09 0.1864E-07 0.3275E-08 0.0000E+00
0001566 0.1883E-07 0.5188E-09 0.1881E-07 0.4035E-08 0.0000E+00
0001567 0.1934E-07 0.6803E-09 0.1931E-07 0.6288E-08 0.0000E+00
0001568 0.2041E-07 0.8938E-09 0.2037E-07 0.1250E-08 0.0000E+00
0001569 0.1801E-07 0.7693E-09 0.1801E-07 0.1120E-08 0.0000E+00
0001570 0.1795E-07 0.3591E-09 0.1795E-07 0.1848E-08 0.0000E+00
0001571 0.1793E-07 0.4871E-09 0.1793E-07 0.2318E-08 0.0000E+00
0001572 0.1802E-07 0.4491E-09 0.1801E-07 0.3515E-08 0.0000E+00
0001573 0.1831E-07 0.5510E-09 0.1829E-07 0.4812E-08 0.0000E+00
0001574 0.1902E-07 0.7265E-09 0.1898E-07 0.4688E-08 0.0000E+00
0001575 0.1730E-07 0.8505E-09 0.2010E-07 0.1436E-08 0.0000E+00
0001576 0.1751E-07 0.5640E-09 0.1733E-07 0.2065E-08 0.0000E+00
0001577 0.1765E-07 0.4055E-09 0.1723E-07 0.2427E-08 0.0000E+00
0001578 0.1794E-07 0.4803E-09 0.1727E-07 0.3544E-08 0.0000E+00
0001579 0.1853E-07 0.6212E-09 0.1755E-07 0.4860E-08 0.0000E+00
0001580 0.1970E-07 0.8314E-09 0.1832E-07 0.4381E-08 0.0000E+00
0001581 0.1675E-07 0.9228E-09 0.1953E-07 0.1326E-08 0.0000E+00
0001582 0.1693E-07 0.5492E-09 0.1676E-07 0.2196E-08 0.0000E+00
0001583 0.1706E-07 0.4020E-09 0.1665E-07 0.2246E-08 0.0000E+00
0001584 0.1733E-07 0.4704E-09 0.1667E-07 0.3392E-08 0.0000E+00
0001585 0.1785E-07 0.6162E-09 0.1694E-07 0.4494E-08 0.0000E+00
0001586 0.1893E-07 0.8181E-09 0.1765E-07 0.4167E-08 0.0000E+00
0001587 0.1618E-07 0.8805E-09 0.1875E-07 0.1260E-08 0.0000E+00
0001588 0.1636E-07 0.5224E-09 0.1620E-07 0.2206E-08 0.0000E+00
0001589 0.1646E-07 0.3867E-09 0.1609E-07 0.2115E-08 0.0000E+00
0001590 0.1668E-07 0.4460E-09 0.1610E-07 0.3236E-08 0.0000E+00
0001591 0.1712E-07 0.5838E-09 0.1633E-07 0.4231E-08 0.0000E+00
0001592 0.1806E-07 0.7683E-09 0.1694E-07 0.3924E-08 0.0000E+00
0001593 0.1564E-07 0.8153E-09 0.1790E-07 0.1208E-08 0.0000E+00
0001594 0.1580E-07 0.4880E-09 0.1566E-07 0.2160E-08 0.0000E+00
0001595 0.1587E-07 0.3679E-09 0.1555E-07 0.1998E-08 0.0000E+00
0001596 0.1606E-07 0.4204E-09 0.1555E-07 0.3067E-08 0.0000E+00
0001597 0.1642E-07 0.5472E-09 0.1575E-07 0.3987E-08 0.0000E+00
0001598 0.1724E-07 0.7152E-09 0.1627E-07 0.3743E-08 0.0000E+00
0001599 0.1512E-07 0.7494E-09 0.1711E-07 0.1169E-08 0.0000E+00
0001600 0.1526E-07 0.4542E-09 0.1513E-07 0.2099E-08 0.0000E+00
0001601 0.1532E-07 0.3481E-09 0.1503E-07 0.1912E-08 0.0000E+00
0001602 0.1547E-07 0.3952E-09 0.1502E-07 0.2922E-08 0.0000E+00
0001603 0.1577E-07 0.5103E-09 0.1520E-07 0.3801E-08 0.0000E+00
0001604 0.1649E-07 0.6632E-09 0.1566E-07 0.3608E-08 0.0000E+00
0001605 0.1462E-07 0.6880E-09 0.1640E-07 0.1139E-08 0.0000E+00
0001606 0.1474E-07 0.4228E-09 0.1463E-07 0.2042E-08 0.0000E+00
0001607 0.1479E-07 0.3292E-09 0.1453E-07 0.1850E-08 0.0000E+00
0001608 0.1492E-07 0.3720E-09 0.1452E-07 0.2808E-08 0.0000E+00
0001609 0.1518E-07 0.4765E-09 0.1467E-07 0.3665E-08 0.0000E+00
0001610 0.1582E-07 0.6161E-09 0.1509E-07 0.3518E-08 0.0000E+00
0001611 0.1413E-07 0.6337E-09 0.1576E-07 0.1117E-08 0.0000E+00
0001612 0.1425E-07 0.3949E-09 0.1414E-07 0.1996E-08 0.0000E+00
0001613 0.1428E-07 0.3120E-09 0.1404E-07 0.1807E-08 0.0000E+00
0001614 0.1440E-07 0.3511E-09 0.1403E-07 0.2724E-08 0.0000E+00
0001615 0.1464E-07 0.4464E-09 0.1418E-07 0.3568E-08 0.0000E+00
0001616 0.1522E-07 0.5746E-09 0.1457E-07 0.3460E-08 0.0000E+00
0001617 0.1366E-07 0.5866E-09 0.1518E-07 0.1102E-08 0.0000E+00
0001618 0.1377E-07 0.3703E-09 0.1367E-07 0.1962E-08 0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 58
0001619 0.1381E-07 0.2964E-09 0.1357E-07 0.1779E-08 0.0000E+00
0001620 0.1391E-07 0.3322E-09 0.1356E-07 0.2663E-08 0.0000E+00
0001621 0.1413E-07 0.4199E-09 0.1371E-07 0.3502E-08 0.0000E+00
0001622 0.1468E-07 0.5381E-09 0.1408E-07 0.9602E-09 0.0000E+00
0001623 0.1328E-07 0.4122E-09 0.1327E-07 0.7725E-09 0.0000E+00
0001624 0.1320E-07 0.2423E-09 0.1322E-07 0.1193E-08 0.0000E+00
0001625 0.1314E-07 0.2914E-09 0.1316E-07 0.1268E-08 0.0000E+00
0001626 0.1311E-07 0.2702E-09 0.1314E-07 0.1994E-08 0.0000E+00
0001627 0.1311E-07 0.3037E-09 0.1317E-07 0.2526E-08 0.0000E+00
0001628 0.1323E-07 0.3698E-09 0.1330E-07 0.3777E-08 0.0000E+00
0001629 0.1354E-07 0.4716E-09 0.1366E-07 0.3257E-08 0.0000E+00
0001630 0.1409E-07 0.5177E-09 0.1270E-07 0.1213E-08 0.0000E+00
0001631 0.1270E-07 0.3420E-09 0.1281E-07 0.1670E-08 0.0000E+00
0001632 0.1261E-07 0.2684E-09 0.1285E-07 0.1823E-08 0.0000E+00
0001633 0.1261E-07 0.3048E-09 0.1296E-07 0.2492E-08 0.0000E+00
0001634 0.1276E-07 0.3848E-09 0.1319E-07 0.3461E-08 0.0000E+00
0001635 0.1316E-07 0.4991E-09 0.1374E-07 0.8705E-09 0.0000E+00
0001636 0.1233E-07 0.3893E-09 0.1234E-07 0.6876E-09 0.0000E+00
0001637 0.1228E-07 0.2219E-09 0.1227E-07 0.1130E-08 0.0000E+00
0001638 0.1224E-07 0.2726E-09 0.1222E-07 0.1259E-08 0.0000E+00
0001639 0.1222E-07 0.2517E-09 0.1220E-07 0.1952E-08 0.0000E+00
0001640 0.1227E-07 0.2868E-09 0.1222E-07 0.2536E-08 0.0000E+00
0001641 0.1244E-07 0.3537E-09 0.1235E-07 0.3734E-08 0.0000E+00
0001642 0.1285E-07 0.4557E-09 0.1269E-07 0.8039E-09 0.0000E+00
0001643 0.1186E-07 0.3726E-09 0.1186E-07 0.6068E-09 0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 20
0001644 0.1180E-07 0.2114E-09 0.1181E-07 0.1103E-08 0.0000E+00
0001645 0.1176E-07 0.2639E-09 0.1177E-07 0.1223E-08 0.0000E+00
0001646 0.1175E-07 0.2440E-09 0.1176E-07 0.1961E-08 0.0000E+00
0001647 0.1179E-07 0.2829E-09 0.1181E-07 0.2550E-08 0.0000E+00
0001648 0.1198E-07 0.3546E-09 0.1201E-07 0.3793E-08 0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 1758
0001649 0.1241E-07 0.4638E-09 0.1246E-07 0.8208E-09 0.0000E+00
0001650 0.1140E-07 0.3799E-09 0.1140E-07 0.6329E-09 0.0000E+00
0001651 0.1135E-07 0.2040E-09 0.1135E-07 0.1148E-08 0.0000E+00
0001652 0.1131E-07 0.2638E-09 0.1132E-07 0.1297E-08 0.0000E+00
0001653 0.1132E-07 0.2421E-09 0.1132E-07 0.2056E-08 0.0000E+00
0001654 0.1140E-07 0.2859E-09 0.1140E-07 0.2690E-08 0.0000E+00
0001655 0.1163E-07 0.3648E-09 0.1163E-07 0.3961E-08 0.0000E+00
0001656 0.1215E-07 0.4815E-09 0.1213E-07 0.8501E-09 0.0000E+00
0001657 0.1096E-07 0.3949E-09 0.1096E-07 0.6489E-09 0.0000E+00
0001658 0.1092E-07 0.1972E-09 0.1092E-07 0.1194E-08 0.0000E+00
0001659 0.1089E-07 0.2641E-09 0.1090E-07 0.1348E-08 0.0000E+00
0001660 0.1091E-07 0.2416E-09 0.1092E-07 0.2150E-08 0.0000E+00
0001661 0.1101E-07 0.2905E-09 0.1102E-07 0.2806E-08 0.0000E+00
0001662 0.1130E-07 0.3780E-09 0.1132E-07 0.4124E-08 0.0000E+00
0001663 0.1190E-07 0.5026E-09 0.1192E-07 0.8804E-09 0.0000E+00
0001664 0.1054E-07 0.4124E-09 0.1055E-07 0.6829E-09 0.0000E+00
0001665 0.1050E-07 0.1914E-09 0.1051E-07 0.1250E-08 0.0000E+00
0001666 0.1049E-07 0.2671E-09 0.1049E-07 0.1424E-08 0.0000E+00
0001667 0.1053E-07 0.2432E-09 0.1053E-07 0.2260E-08 0.0000E+00
0001668 0.1067E-07 0.2982E-09 0.1067E-07 0.2953E-08 0.0000E+00
0001669 0.1102E-07 0.3944E-09 0.1103E-07 0.7625E-09 0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 19
0001670 0.1018E-07 0.3263E-09 0.1019E-07 0.3999E-09 0.0000E+00
0001671 0.1014E-07 0.1790E-09 0.1014E-07 0.1009E-08 0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 20
0001672 0.1011E-07 0.2263E-09 0.1011E-07 0.9446E-09 0.0000E+00
0001673 0.1011E-07 0.2117E-09 0.1011E-07 0.1723E-08 0.0000E+00
0001674 0.1017E-07 0.2452E-09 0.1018E-07 0.2096E-08 0.0000E+00
0001675 0.1038E-07 0.3179E-09 0.1039E-07 0.3274E-08 0.0000E+00
0001676 0.1082E-07 0.4166E-09 0.1084E-07 0.6585E-09 0.0000E+00
0001677 0.9792E-08 0.3539E-09 0.9797E-08 0.6003E-09 0.0000E+00
TIME FOR CALCULATION: 0.4300E+05
L2-NORM ERROR U VELOCITY 2.794552119135372E-005
L2-NORM ERROR V VELOCITY 2.790982482146795E-005
L2-NORM ERROR W VELOCITY 2.911527030306516E-005
L2-NORM ERROR ABS. VELOCITY 3.166182227160789E-005
L2-NORM ERROR PRESSURE 1.392953546657367E-003
*** CALCULATION FINISHED - SEE RESULTS ***
*** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./caffa3d.MB.lnx on a arch-openmpi-opt-intel-hlr-ext named hpb0241 with 1 processor, by gu08vomo Thu Feb 19 22:43:07 2015
Using Petsc Release Version 3.5.3, Jan, 31, 2015
Max Max/Min Avg Total
Time (sec): 4.301e+04 1.00000 4.301e+04
Objects: 3.020e+05 1.00000 3.020e+05
Flops: 1.498e+13 1.00000 1.498e+13 1.498e+13
Flops/sec: 3.484e+08 1.00000 3.484e+08 3.484e+08
MPI Messages: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Message Lengths: 0.000e+00 0.00000 0.000e+00 0.000e+00
MPI Reductions: 0.000e+00 0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flops
and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts %Total Avg %Total counts %Total
0: Main Stage: 6.3111e+03 14.7% 6.5910e+06 0.0% 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
1: MOMENTUM: 2.5050e+03 5.8% 1.4158e+12 9.4% 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
2: PRESCORR: 3.4194e+04 79.5% 1.3567e+13 90.6% 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flops: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length (bytes)
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %F - percent flops in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event Count Time (sec) Flops --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
ThreadCommRunKer 8386 1.0 1.4162e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNorm 1 1.0 2.3067e-01 1.0 4.39e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 67 0 0 0 19
VecScale 1 1.0 1.8690e-03 1.0 2.20e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 33 0 0 0 1176
VecSet 67086 1.0 1.2403e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 0 0 0 0 0
VecScatterBegin 75476 1.0 3.8897e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 1 1.0 1.8699e-03 1.0 2.20e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 33 0 0 0 1175
MatAssemblyBegin 3354 1.0 2.0068e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyEnd 3354 1.0 7.7234e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
--- Event Stage 1: MOMENTUM
VecMDot 6511 1.0 1.5976e+01 1.0 3.51e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 2198
VecNorm 21604 1.0 2.9968e+01 1.0 9.49e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 1 7 0 0 0 3168
VecScale 11542 1.0 1.5647e+01 1.0 2.54e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 2 0 0 0 1621
VecCopy 10062 1.0 3.4819e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
VecSet 5031 1.0 4.6474e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 15093 1.0 4.9690e+01 1.0 6.63e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 5 0 0 0 1335
VecMAXPY 11542 1.0 3.5395e+01 1.0 6.37e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 5 0 0 0 1800
VecNormalize 11542 1.0 2.9870e+01 1.0 7.61e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 1 5 0 0 0 2547
MatMult 16573 1.0 4.5654e+02 1.0 4.50e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 3 0 0 0 18 32 0 0 0 986
MatSolve 16573 1.0 4.7541e+02 1.0 4.50e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 3 0 0 0 19 32 0 0 0 947
MatLUFactorNum 5031 1.0 5.4277e+02 1.0 2.30e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 22 16 0 0 0 424
MatILUFactorSym 5031 1.0 4.7841e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 19 0 0 0 0 0
MatGetRowIJ 5031 1.0 1.6491e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 5031 1.0 4.3468e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 2 0 0 0 0 0
KSPGMRESOrthog 6511 1.0 3.4936e+01 1.0 7.02e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 5 0 0 0 2010
KSPSetUp 5031 1.0 1.3675e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 5 0 0 0 0 0
KSPSolve 5031 1.0 2.1769e+03 1.0 1.23e+12 1.0 0.0e+00 0.0e+00 0.0e+00 5 8 0 0 0 87 87 0 0 0 567
PCSetUp 5031 1.0 1.0705e+03 1.0 2.30e+11 1.0 0.0e+00 0.0e+00 0.0e+00 2 2 0 0 0 43 16 0 0 0 215
PCApply 16573 1.0 4.7545e+02 1.0 4.50e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 3 0 0 0 19 32 0 0 0 947
--- Event Stage 2: PRESCORR
VecMDot 77665 1.0 2.4251e+02 1.0 5.61e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 4 0 0 0 1 4 0 0 0 2312
VecTDot 51363 1.0 1.8632e+02 1.0 2.26e+11 1.0 0.0e+00 0.0e+00 0.0e+00 0 2 0 0 0 1 2 0 0 0 1211
VecNorm 84373 1.0 8.5669e+01 1.0 2.16e+11 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 2 0 0 0 2518
VecScale 55341 1.0 2.7240e+01 1.0 4.41e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1617
VecCopy 10062 1.0 2.3209e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 423957 1.0 3.1843e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
VecAXPY 58064 1.0 2.2768e+02 1.0 2.41e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 2 0 0 0 1 2 0 0 0 1059
VecAYPX 106066 1.0 2.1610e+02 1.0 1.71e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 790
VecMAXPY 82696 1.0 3.0662e+02 1.0 6.41e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 4 0 0 0 1 5 0 0 0 2090
VecAssemblyBegin 5031 1.0 3.9411e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAssemblyEnd 5031 1.0 3.3855e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecPointwiseMult 82696 1.0 7.4910e+01 1.0 4.41e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 588
VecSetRandom 5031 1.0 4.0458e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecNormalize 55341 1.0 5.2289e+01 1.0 1.32e+11 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 2528
MatMult 159730 1.0 2.2406e+03 1.0 2.49e+12 1.0 0.0e+00 0.0e+00 0.0e+00 5 17 0 0 0 7 18 0 0 0 1110
MatMultAdd 82065 1.0 5.7318e+02 1.0 4.41e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 3 0 0 0 2 3 0 0 0 770
MatMultTranspose 136775 1.0 6.4944e+02 1.0 4.41e+11 1.0 0.0e+00 0.0e+00 0.0e+00 2 3 0 0 0 2 3 0 0 0 679
MatSOR 164130 1.0 8.3032e+03 1.0 6.31e+12 1.0 0.0e+00 0.0e+00 0.0e+00 19 42 0 0 0 24 47 0 0 0 760
MatConvert 10062 1.0 1.9290e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 0
MatScale 15093 1.0 1.1497e+02 1.0 9.74e+10 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 847
MatResidual 82065 1.0 1.0263e+03 1.0 1.15e+12 1.0 0.0e+00 0.0e+00 0.0e+00 2 8 0 0 0 3 8 0 0 0 1118
MatAssemblyBegin 51987 1.0 1.9356e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAssemblyEnd 51987 1.0 6.2574e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 2 0 0 0 0 0
MatGetRow -1157908450 1.0 8.1135e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0
MatCoarsen 5031 1.0 3.1474e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
MatView 6 1.0 6.5398e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatAXPY 5031 1.0 6.2875e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 2 0 0 0 0 0
MatMatMult 5031 1.0 7.4859e+02 1.0 8.35e+10 1.0 0.0e+00 0.0e+00 0.0e+00 2 1 0 0 0 2 1 0 0 0 112
MatMatMultSym 5031 1.0 5.0572e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
MatMatMultNum 5031 1.0 2.4280e+02 1.0 8.35e+10 1.0 0.0e+00 0.0e+00 0.0e+00 1 1 0 0 0 1 1 0 0 0 344
MatPtAP 5031 1.0 4.0040e+03 1.0 4.98e+11 1.0 0.0e+00 0.0e+00 0.0e+00 9 3 0 0 0 12 4 0 0 0 124
MatPtAPSymbolic 5031 1.0 1.5557e+03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 4 0 0 0 0 5 0 0 0 0 0
MatPtAPNumeric 5031 1.0 2.4483e+03 1.0 4.98e+11 1.0 0.0e+00 0.0e+00 0.0e+00 6 3 0 0 0 7 4 0 0 0 204
MatTrnMatMult 5031 1.0 1.0475e+04 1.0 1.06e+12 1.0 0.0e+00 0.0e+00 0.0e+00 24 7 0 0 0 31 8 0 0 0 101
MatTrnMatMultSym 5031 1.0 4.9370e+03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 11 0 0 0 0 14 0 0 0 0 0
MatTrnMatMultNum 5031 1.0 5.5378e+03 1.0 1.06e+12 1.0 0.0e+00 0.0e+00 0.0e+00 13 7 0 0 0 16 8 0 0 0 192
MatGetSymTrans 10062 1.0 2.6491e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
KSPGMRESOrthog 50310 1.0 2.9522e+02 1.0 8.81e+11 1.0 0.0e+00 0.0e+00 0.0e+00 1 6 0 0 0 1 6 0 0 0 2985
KSPSetUp 16770 1.0 8.3196e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 1677 1.0 3.4140e+04 1.0 1.35e+13 1.0 0.0e+00 0.0e+00 0.0e+00 79 90 0 0 0 100100 0 0 0 396
PCGAMGgraph_AGG 5031 1.0 2.5135e+03 1.0 7.03e+10 1.0 0.0e+00 0.0e+00 0.0e+00 6 0 0 0 0 7 1 0 0 0 28
PCGAMGcoarse_AGG 5031 1.0 1.1403e+04 1.0 1.06e+12 1.0 0.0e+00 0.0e+00 0.0e+00 27 7 0 0 0 33 8 0 0 0 93
PCGAMGProl_AGG 5031 1.0 7.1328e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 2 0 0 0 0 0
PCGAMGPOpt_AGG 5031 1.0 3.2823e+03 1.0 1.92e+12 1.0 0.0e+00 0.0e+00 0.0e+00 8 13 0 0 0 10 14 0 0 0 585
PCSetUp 3354 1.0 2.2016e+04 1.0 3.55e+12 1.0 0.0e+00 0.0e+00 0.0e+00 51 24 0 0 0 64 26 0 0 0 161
PCSetUpOnBlocks 27355 1.0 6.1723e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
PCApply 27355 1.0 1.0605e+04 1.0 8.34e+12 1.0 0.0e+00 0.0e+00 0.0e+00 25 56 0 0 0 31 61 0 0 0 787
--- Event Stage 3: Unknown
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Vector 67 95 833878448 0
Vector Scatter 2 2 1304 0
Index Set 4 7 17581544 0
IS L to G Mapping 2 2 17577192 0
Matrix 1 11 490350860 0
Matrix Null Space 0 1 620 0
Krylov Solver 0 7 116016472 0
Preconditioner 0 7 476716 0
Vector 60376 60362 530554454928 0
Index Set 15093 15090 88419231280 0
Matrix 5031 5030 1063010020000 0
Matrix Null Space 1 0 0 0
Krylov Solver 2 0 0 0
Preconditioner 2 0 0 0
Vector 154290 154265 806410318792 0
Index Set 5031 5031 3984552 0
Matrix 41925 41916 1141360535716 0
Matrix Coarsen 5031 5031 3239964 0
Krylov Solver 5036 5031 152016696 0
Preconditioner 5036 5031 5272488 0
PetscRandom 5031 5031 3219840 0
Viewer 1 0 0 0
Average time to get PetscTime(): 0
#PETSc Option Table entries:
-log_summary
-momentum_ksp_type gmres
-options_left
-pressure_ksp_converged_reason
-pressure_mg_coarse_sub_pc_type svd
-pressure_mg_levels_ksp_rtol 1e-4
-pressure_mg_levels_ksp_type richardson
-pressure_mg_levels_pc_type sor
-pressure_pc_gamg_agg_nsmooths 1
-pressure_pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: PETSC_ARCH=arch-openmpi-opt-intel-hlr-ext PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3 -prefix=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr-ext --with-blas-lapack-dir=/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64/ --with-mpi-dir=/shared/apps/openmpi/1.8.2_intel COPTFLAGS="-O3 -xHost" FOPTFLAGS="-O3 -xHost" CXXOPTFLAGS="-O3 -xHost" --with-debugging=0 --download-hypre --download-ml
Libraries compiled on Sun Feb 1 16:09:22 2015 on hla0003
Machine characteristics: Linux-3.0.101-0.40-default-x86_64-with-SuSE-11-x86_64
Using PETSc directory: /home/gu08vomo/soft/petsc/3.5.3
Using PETSc arch: arch-openmpi-opt-intel-hlr-ext
Using C compiler: /shared/apps/openmpi/1.8.2_intel/bin/mpicc -fPIC -wd1572 -O3 -xHost ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /shared/apps/openmpi/1.8.2_intel/bin/mpif90 -fPIC -O3 -xHost ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/include -I/home/gu08vomo/soft/petsc/3.5.3/include -I/home/gu08vomo/soft/petsc/3.5.3/include -I/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/include -I/shared/apps/openmpi/1.8.2_intel/include
Using C linker: /shared/apps/openmpi/1.8.2_intel/bin/mpicc
Using Fortran linker: /shared/apps/openmpi/1.8.2_intel/bin/mpif90
Using libraries: -Wl,-rpath,/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -L/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -lpetsc -Wl,-rpath,/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -L/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -lHYPRE -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -lmpi_cxx -lml -lmpi_cxx -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -lX11 -lpthread -lssl -lcrypto -lmpi_usempi_ignore_tkr -lmpi_mpifh -lifport -lifcore -lm -lmpi_cxx -ldl -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -lmpi -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -limf -lsvml -lirng -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc_s -lirc -lpthread -lirc_s -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -ldl
-log_summary
-options_left
There are no unused options.
